> 2010 MS3 - How-To's
Like Tree23Likes
 Old 09-12-2011, 07:25 PM   #41
bewsted's Avatar
Posts: 2,456   (View Stats)
bewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the worldbewsted is the leader of the world
Yea sure does.
tapa dat ass
EWG K04...GETSUM!
A journey to make people cry like babies when loosing to a wagon.
bewsted is offline   Reply With Quote
 Old 09-12-2011, 07:33 PM   #42
loopymps's Avatar
Posts: 13   (View Stats)
loopymps is a splendid one to beholdloopymps is a splendid one to beholdloopymps is a splendid one to beholdloopymps is a splendid one to beholdloopymps is a splendid one to beholdloopymps is a splendid one to beholdloopymps is a splendid one to beholdloopymps is a splendid one to behold
I have a gen 2 with a ECUTEK tune who has removed the angle sensor via the ecutek software. No lights on dash.
loopymps is offline   Reply With Quote
 Old 09-13-2011, 05:19 AM   #43
bewsted's Avatar
Reconnected swas and ran tables that khop is on.....Seems like a fix to me....
Also ran VTA with these tables to find that afr's were nice and stable.....
EWG K04...GETSUM!
The Following 6 Users Say Thank You to bewsted For This Useful Post:
Bucker (09-13-2011), Ckmazdaspeed3 (09-17-2011), khopwood77 (09-13-2011), myt_tuf1 (09-13-2011), wolly6973 (09-13-2011), xxdjfate76xx (03-22-2012)
 Old 09-13-2011, 06:16 AM   #44
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
More info on tables?
403whp/451ft/lb Dry Shot
 Old 09-13-2011, 10:32 AM   #45
bewsted's Avatar
read @khopwood77 post above.
EWG K04...GETSUM!
 Old 09-13-2011, 05:34 PM   #46
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Originally Posted by khopwood77 View Post
Hey guys try this out and see if it helps with your rich condition. The guys at Cobb let me know what they changed in ATR. I thought the tables were not exposed in ATR but they are available. Below is what they sent me when I was asking about what they did to correct my issue.
In the latest release of ATR (Shifting Control Tables):
Set Ignition Timing Limit (Min) (Throttle Closed) and (Throttle Open) to -3.0 (Stutter Fix)
Set all Load Based and Load/RPM Based Fuel Compensations to 1.0 (Post Shift Fueling Fix)
I have been running my car all weekend without a single rich condition. Attached is what prompted me to contact them. The "WOT 9s" file would occur randomly once every 10-15 WOT runs.
I will update you guys in a few days on the Boost > 22. Waiting on the Alpha fix...
Im assuming this would work with a gen1?
 Old 09-13-2011, 05:56 PM   #47
khopwood77's Avatar
Posts: 245   (View Stats)
khopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the world
I'm not 100% positive on that as there are some differences between the ECUs. It should work in theory but I read some of the Gen1 PERM guys have had no luck with it.
2010 Black Mica MS3 (Daily Driver) - self-tuned with the help of Lex www.mazdaspeedforum.org/forum/forum/f426/k06-log-86437/
K04 Hybrid, Nitto NT01s, JMF Manifold, 4 Port Meth, 100% E85, 3 Bar MAP, HTP 3.5, Cobb DP, ETS TMIC, KMD Internals, PTP RV, OCC, Forge BPV, CP-E Mounts, JBR Thermal Intake & Throttle Body Gaskets, JBR Shifter Plate & Bushings
2006 Mustang GT - www.vortechsuperchargers.com/global_item.php?gik=348
Built Motor, 675 RWHP 560 lb/ft T-Trim 21PSI Non-Intercooled
1993 Mustang LX - www.youtube.com/watch?v=WiCCvodp6CU
Budget 349 Stroker
khopwood77 is offline   Reply With Quote
 Old 09-14-2011, 05:50 AM   #48
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
So you're saying that with those tables you can leave the SWAS connected, but it won't limit you in 1st/2nd as well as when turning? Or is this just the when turning limit.
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is offline   Reply With Quote
 Old 09-14-2011, 07:02 AM   #49
bewsted's Avatar
I dont think that it takes the limit out of 1st but 2nd seems fine...
I dont get stutter if i launch....but from a roll i always do....
I think there will still need to be a way to disable the swas....
Hopefully @Cobb Tuning will figure out something on how to disable it.
EWG K04...GETSUM!
 Old 09-14-2011, 07:27 AM   #50
khopwood77's Avatar
You can still pull the plug if you are are an aggressive driver in the corners and you don't want any input from the ECU. My problems are completely gone but they were related to WOT runs in a straight line or easy corners like highway off/on-ramps. Pulling the SWAS fixed that but I wanted a better solution.
Bucker and rfinkle2 like this.
Budget 349 Stroker
The Following 3 Users Say Thank You to khopwood77 For This Useful Post:
bewsted (09-14-2011), kornybun (04-14-2014), rfinkle2 (09-14-2011)
 Old 09-15-2011, 07:41 PM   #51
harryclay's Avatar
Posts: 685   (View Stats)
harryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the worldharryclay is the leader of the world
I have been rocking no swas for quite ahwile now and it deffinatly works but I agree there has to be a a better solution tuning whise. It takes all I have to get the car through slolums on autocross since the powersteering gets so stiff. So fucking anoying that car companies add some many nannys for all the newb drivers and no way to turn it off. With it plugged in it just takes the slightest turn of the wheel and it just falls on its face
2010 super smiley Red MS3
- Corksport SRI/TIP
- ETS TMIC
- CNT hiflow catted long DP
- Sure boost tubes
- SURE motorsports anchors
- SU RMM
- Greddy Type S BPV
- KMD HPFP Internals
- harryclay tune
- Semi-flat black wheels (painted stockers)
- Eibach pro springs ftw
- Michelin Pilot Super Sports 235/40/18
- Yellow 55v fogs
13.69 @ 106 (4g eth mix, intake/tune)
13.67 @106 (intake,dp,tmic, 50/50 eth)
harryclay is offline   Reply With Quote
 Old 09-17-2011, 12:29 AM   #52
myt_tuf1's Avatar
Posts: 256   (View Stats)
myt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the world
Just a heads up, when pulling the SWAS you won't get a CEL, but if you check for codes with the AP, a code, "U0410" (lost comms with BCM) will pop up. Nothing to worry about as far as I know, but it's just telling you that the SWAS is unplugged.
Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC
myt_tuf1 is offline   Reply With Quote
The Following User Says Thank You to myt_tuf1 For This Useful Post:
MS3G35 (04-04-2013)
 Old 09-17-2011, 07:50 AM   #53
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
If someone was smart they would figure out what kind of voltage is going through the wire, then make a board with a plug-in that would trick the car into thinking it was always going straight.
Hopefully we have someone smart here...
 Old 09-17-2011, 08:00 AM   #54
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
@khopwood77 , any news on the 3 bar?
Ckmazdaspeed3 is offline   Reply With Quote
 Old 09-17-2011, 02:31 PM   #55
Big Titty Sucker
BLK_MS3's Avatar
Posts: 1,612   (View Stats)
BLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the worldBLK_MS3 is the leader of the world
Groans: 139
Agreed. On my Camaro a company makes a traction control tricker that just plugs in and makes the default off, instead of on. Only cost $20 too.
BLK_MS3 is offline   Reply With Quote
The Following User Says Thank You to BLK_MS3 For This Useful Post:
wolly6973 (09-18-2011)
 Old 09-19-2011, 09:37 PM   #56
Groans: 134
There might be a better way to fix this coming soon...
I have been testing a fix from Cobb this weekend trying to eliminate the SWAS rich condition through tuning instead of unplugging the sensor. Prior to the fix I was randomly seeing WOT AFRs in the 9s for the entire run and now its gone. I do not know what they changed I'll try to find out more. From what I gathered it's a table exposed in the latest version of ATR but not visible to the end user. I'm hoping this makes it into the next beta release as it seems to have cured my problems.
Next up is testing the display and logging of boost > 22PSI on a 3 bar MAP for Gen2s.
So, all those numbers in the load/rpm based fuel compensation table to 1? Just making sure I got this.
Anyway, more importantly, any updates on the boost logging?
The Following 2 Users Say Thank You to Ckmazdaspeed3 For This Useful Post:
myt_tuf1 (09-20-2011), RodneyAE (10-19-2011)
 Old 09-21-2011, 05:10 AM   #57
khopwood77's Avatar
Yes you got it ck. Just the compensation tables under the shifting control node.
As for the boost logging, I'm still waiting on the alpha release. I'll see if I can get an update on the status.
Bucker likes this.
Budget 349 Stroker
The Following 4 Users Say Thank You to khopwood77 For This Useful Post:
Broxer (03-29-2012), Bucker (09-21-2011), myt_tuf1 (09-21-2011), wolly6973 (09-21-2011)
 Old 09-21-2011, 04:06 PM   #58
khopwood77's Avatar
@Bucker
@bewsted
@Ckmazdaspeed3
@rfinkle2
Loading up the alpha tune for the boost logging fix now. Will report back later.
Budget 349 Stroker
The Following 7 Users Say Thank You to khopwood77 For This Useful Post:
bewsted (09-21-2011), Bucker (09-21-2011), Ckmazdaspeed3 (09-21-2011), Keemo577 (09-21-2011), myt_tuf1 (09-21-2011), rfinkle2 (09-21-2011), wolly6973 (09-21-2011)
 Old 09-21-2011, 04:31 PM   #59
Bucker's Avatar
Groans: 451
Thanks man! I'm excited
The Following 2 Users Say Thank You to Bucker For This Useful Post:
khopwood77 (09-21-2011), rfinkle2 (09-21-2011)
 Old 09-21-2011, 08:37 PM   #60
bewsted's Avatar
Good stuff khop...
EWG K04...GETSUM!
The Following User Says Thank You to bewsted For This Useful Post:
 Old 09-21-2011, 08:48 PM   #61
khopwood77's Avatar
Results are in...
Boost display and logging seem to be fixed. Attached are a few tests from the ride home. You will see that I'm able to read past my previous limit of 22.34 and I saw spikes of 25.1. Your upper limit might be a little different depending on altitude/baro.pressure (I think).
I recorded over 20 runs today and still have yet to see that dreaded 9:1 AFR "SWAS" condition reappear unless traction control is on. Looks like I rid myself of two demons now. Time to find some more...
Budget 349 Stroker
The Following 5 Users Say Thank You to khopwood77 For This Useful Post:
Bucker (09-22-2011), Ckmazdaspeed3 (09-21-2011), rfinkle2 (11-11-2011), uncorked11 (01-03-2012), wolly6973 (09-22-2011)
 Old 09-21-2011, 09:13 PM   #62
Groans: 134
Results are in...
That shit is awesome!
Ok, so what do I need to do to get the hook up on this?
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
 Old 09-21-2011, 09:23 PM   #63
khopwood77's Avatar
I'm waiting to hear back from Cobb after I sent my logs. I'll let you know if they need more people to test. Hopefully it gets pushed to beta quickly cause I can't even open my file in ATR. They had to update my ptm and walk me through getting a new firmware through AP Manager.
Budget 349 Stroker
The Following 2 Users Say Thank You to khopwood77 For This Useful Post:
Ckmazdaspeed3 (09-21-2011), wolly6973 (09-22-2011)
 Old 09-22-2011, 06:16 AM   #64
Bucker's Avatar
Groans: 451
Ugh, I hope they make it a beta and push it like usual. I need this shit, I dont like just stabbing in the dark with my boost targets. Ill shoot for 24 if this works.
The Following User Says Thank You to Bucker For This Useful Post:
 Old 10-07-2011, 05:53 PM   #65
Jake5713's Avatar
Posts: 1,775   (View Stats)
It's probably a digital signal that reports back to the ECU not a voyage signal
I am here: http://maps.google.com/maps?ll=44.730235,-93.144551
-Jake
Jake5713 is offline   Reply With Quote
 Old 10-09-2011, 11:22 PM   #66
myt_tuf1's Avatar
After doing this, is it normal to get a high idle for ~10 secs on cold start ups? I noticed, after changing my tables to what you specified and flashing the map, that I get a high idle for a couple of seconds on a cold start up.
 Old 10-21-2011, 02:45 PM   #67
RodneyAE's Avatar
Posts: 75   (View Stats)
RodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond reputeRodneyAE has a reputation beyond repute
Me too. Not sure why but RPMS jump to 3500 during cold start up only.
2011 MS3, HKS SRI, Cobb AP (Custom Tune), KMD CDFP v2.2, ATP long catless DP, RMM.
AMSOIL Dealer - Hit me up for some good prices.
RodneyAE is offline   Reply With Quote
The Following User Says Thank You to RodneyAE For This Useful Post:
Koke382 (11-08-2013)
 Old 10-21-2011, 02:49 PM   #68
2011speed's Avatar
Posts: 1,497   (View Stats)
fuck you swass
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 12-02-2011, 04:12 PM   #69
Is the load based rpm comp fix for both the clutch in and out?
Thanks khopwood btw for the research on this.
mazdaspeed916 likes this.
 Old 12-23-2011, 01:45 PM   #70
So, FYI. If you have a toggle switch for your SWAS, and you're thinking about flipping it back on while driving, you're fine. If you decide that since it's starting to rain you'll just shut the car off and back on while rolling in order to get the traction control and power steering back, I'd think twice.
I tried it, didn't work so well. You'll end up with not only no power steering, but an almost locked steering column. The car starts fine, but then the wheel is incredibly hard to turn. I think the electric power steering freaks out and fights you for some reason. Once I pulled over (after almost crashing into a creek) and restarted the car while stopped it was fine. If you don't believe me, I'd recommend trying it in a parking lot.
The Following User Says Thank You to Pedal-Force For This Useful Post:
Brennan (06-05-2012)
 Old 03-22-2012, 09:16 AM   #71
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
@superskaterxes think we could make this a sticky like the Gen one thread?
RichTuned
BlueDmnSpeed is offline   Reply With Quote
 Old 03-22-2012, 03:12 PM   #72
harryclay's Avatar
I've had the swas disconnected for about a year now. Autox slolums are a bitch with no power steering, but other then that no bad side effects. Can't wait till cobb figures this out, if not I better start lifting so weights so I can muscle that steering wheel
- Corksport SRI/TIP
- ETS TMIC
- Sure boost tubes
- SU RMM
- Greddy Type S BPV
- harryclay tune
- Yellow 55v fogs
 Old 03-24-2012, 07:16 PM   #73
@Monotonous ONE i found an easier way than using a flathead and your fingers to disconnect the SWAS.. just unplug the yellow pigtail after you disconnect the white one and the clip that holds the wires in place. then once those three are disconnected you have ease of access to the swas and you can pinch and pull with your hand no problem.. i just disconnect my SWAS this afternoon. my afr's have returned to normal lmao
RichTuned
The Following 2 Users Say Thank You to BlueDmnSpeed For This Useful Post:
atvfreek (03-24-2012), Monotonous ONE (03-24-2012)
 Old 03-27-2013, 05:04 PM   #74
qweedqwag's Avatar
Posts: 233   (View Stats)
qweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the world
Groaned at 22 Times in 10 Posts
Has anyone taken a resistance reading on the wires to see if a resistor can be added to make the sensor think the car is always being steered straight?
qweedqwag is offline   Reply With Quote
 Old 10-09-2013, 12:41 PM   #75
manila's Avatar
Posts: 1,767   (View Stats)
Do you guys know when disabling SWAS for the tech package will disable the AFS and BSM?
I know power over features, but just curious.
'12 MS3 Black Mica w/ Tech
 Old 10-09-2013, 12:53 PM   #76
NCspecV81's Avatar
Posts: 2,867   (View Stats)
all you have to do is hold the DSC OFF button for somewhere between 5-10 seconds and it completely disables it for genpu's. No worries about making other stuff screw up in the process.
 Old 10-09-2013, 12:54 PM   #77
manila's Avatar
I read differently that holding the button and completely diconnecting have diffrent results.
 Old 10-09-2013, 12:55 PM   #78
NCspecV81's Avatar
Works on my '13 pu like a charm. I turn it off by just pressing it and it still goes ape crazy when going into boost with the GTX. Holding it solves everything for me. Even with the wheel turned.
 Old 10-09-2013, 12:58 PM   #79
manila's Avatar
Sounds good. I usually just hold the button after start-up.
Do you do it a different way?
 Old 10-09-2013, 12:59 PM   #80
NCspecV81's Avatar
1. turn car on like normal
2. Hold dsc off button for around 10s
3. release button
4. I push it a second time to verify it stays off because if you do it properly it won't cut off until you turn the car off
manila (10-09-2013)
I need SWAS pictures! mexicant MazdaSpeed 3/6 - ECU Computer Tuning 33 10-26-2016 07:23 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
The disconnect of connected cars Haltech Automotive News 0 05-03-2010 07:20 AM
Toyota's U.S.-Japan disconnect Haltech Automotive News 0 03-01-2010 10:10 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.58948 seconds with 39 queries
