![]() Join Date: Sep 2011 Location: Rochester, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38
(Thread Starter) | Not Ranked : 0 score While driving the car the steering/handling feels incredibly unstable. I feel like i have to fight the steering wheel to get it to turn. The slightest of steering wheel movements produces a drastic jerk in the car with the steering wheel snapping back to center. All tires are properly inflated. The two rear tires have more wear & slight cupping on the insides from last seasons autocrossing. The best I can figure is that maybe I have a wheel or two that didnt seat properly when I put the summer stockers back on the car.... Can anyone offer any other suggestions...(Ill be taking the wheels off and re-seating them in the morning) Thanks
__________________ 2011 Liquid Silver *Cobb SRI* *Cobb TIH* *Cobb AP* *JBR 88 durometer dogbone RMM* *JBR Rear Sway Bar* *JBR Short Shift* *JBR 5mm Wheel Spacers* |
![]() Join Date: Mar 2013 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
| Not Ranked : 0 score Whens the last time you had your alignment checked? When you accelerate does it pull to one side?
__________________ 2006 MS6 GT - Black Betty "The damn thing gone wild" SURE Aeros + TIP | Cobb AP | Autotech HPFP Internals | SU TMIC |Juggernaught | Torq R6 | ITV 22 | 18x8 Avarus AV8 + Pirelli 210 Sottozero | CS Front & Rear Sway Bars | CS Front Strut |
(Thread Starter) | Not Ranked : 0 score No pulling to one side during acceleration. Also never had the alignment checked or an alignment issue....Wouldnt think alignment when things were fine with winter setup on the car & then an hour later things arent fine w/ the summer setup on the car.
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
| Not Ranked : 0 score did you rotate the tires correctly? or just randomly move them to a different side lol
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
is it possible that the wheels are out of balance?
__________________ 2011 Liquid Silver *Cobb SRI* *Cobb TIH* *Cobb AP* *JBR 88 durometer dogbone RMM* *JBR Rear Sway Bar* *JBR Short Shift* *JBR 5mm Wheel Spacers* | |
The backs swap.. so back right would go front left, back left would go front right.
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | |
i went out this morning & re-swapped the two front tires and then re-torqued all 4 wheels. Then took the car out for a drive & to double check air pressures in tires....Whether it was the swap or the re-torquing I dont know but the car is handling like it should now!! Once I got home I re-torques again just for good measure. Thanks for the ideas......
| The Following User Says Thank You to razor3232 For This Useful Post: | PapaSmurf (04-25-2013) |
| Weird Clutch Engagement Issue | Mfinlay04 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 04-02-2013 11:29 PM |
| Weird coolant issue | pinkcheese | MazdaSpeed 3 - Engine, Transmission & Driveline | 21 | 01-20-2013 11:06 PM |
| ms6 weird heat issue | maddocx240 | Mazdaspeed3/6 General Discussion | 22 | 01-18-2012 02:38 PM |
| Weird Issue | 2gr84u | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-08-2011 02:09 PM |
