Like Tree8Likes
  • 1 Post By g00s3y
  • 1 Post By Voltwings
  • 1 Post By jtday
  • 1 Post By SuckSqueezBangBlow
  • 1 Post By Omega
  • 1 Post By Justin@Freektune
  • 1 Post By Omega
  • 1 Post By MazdaspeedKills
 Old 05-02-2016, 11:55 AM   #1
TORQUERULES's Avatar
Posts: 283   (View Stats)
TORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond reputeTORQUERULES has a reputation beyond repute
Angry Has anyone ran into this issue and what did you do?
I have only one E85 station near me and there is only one chain that offers E85 in the state that I know of right now. I am getting ready to do log reviews on both of my Stratified tunes to send to them. I have a 93 tune and an E85 tune (they say to fill in such a way as to be about E30).
My issue is this: My local station that has E85 has now changed its signs to Flex Fuel and the button on the pump now says "Contains a Minimum of 51% Ethanol." So I guess I no longer have true E85 available and cannot be sure what concentration I am getting.
Has anyone else ran into this? What did you do? Buy a tool to analyze your fuel to see what you are getting each time (which would prevent me from fueling the car at the pumps and force me to keep my E85 in cans), or what?
Thanks.
(SOLD) 2013 Crystal White MS3--JBR 3.5" intake, very minor PNP intake manifold, CS TMIC, CS HPFP internals, CS BPV, JBR EGR delete and block-off, CFM RMM, CS TM insert, Cobb AP V3 with Stratified Stage 3 tunes (93 and E85 mix), VTCS delete, coolant bypass, 1 step colder plugs, CS shifter bushings, CS short shifter, Damond OCC, Ultra Gauge, Progress RSB, Koni dampers, Eibach Pro-Kit springs, JBR rear spacers, 235/40/18 Nitto Motivo tires, Drag DR-49 18x8" wheels, CNT cat-less DP, CNT cat-back, DDM HIDs, etc.
2017 Mazda CX-3 Meteor Gray
TORQUERULES is offline   Reply With Quote
 Old 05-02-2016, 12:22 PM   #2
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
I am curious of this as well, I was told nothing to worry about (I live in southern California our gas literally the worst).
Hey I am brown again!
 Old 05-02-2016, 12:54 PM   #3
I would think there would be a lot to worry about. You would never know if you were getting the right mixture and you stand a good chance of having too little corn to go with the tune.
 Old 05-02-2016, 01:42 PM   #4
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
You should be able to get an estimate of how off it could be, by monitoring your ltft/stft.
It wouldn't give you any ethanol % level, but you would know if it isn't an actual "full e85" pump if your trims are way off.
TORQUERULES likes this.
speedfreak44 (05-02-2016), TORQUERULES (05-03-2016)
 Old 05-02-2016, 01:54 PM   #5
Voltwings's Avatar
Posts: 3,713   (View Stats)
If i'm not mistaken, most of the times they dont just fill it up with whatever they feel like, they typically do seasonal mixes dont they? Ethanol test kits are cheap, so you could just test it once a quarter or so until you have a good idea of what blends they're running. Seems like a pain, i know, but it also really seems like the only option.
^^ monitoring trims could work too. Assuming you're only getting 50% ethanol instead of 85% you could expect to see your tune running rich.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
cyclist20 (01-18-2017), TORQUERULES (05-03-2016)
 Old 05-02-2016, 03:57 PM   #6
jtday's Avatar
Posts: 650   (View Stats)
Might just have to evaluate yourself. When I started getting gas at race trac I noticed the pump said the same 51% ethanol content. I think they just to that so they don't have to apply a different sticker in the summer because I noticed zero changes in trims when I used the e85 from that station.
2009 MS3 GT
The Following User Says Thank You to jtday For This Useful Post:
 Old 05-02-2016, 04:16 PM   #7
To be honest, my STFT and LTFT have not changed either from going Winter to Summer and vice-a-versa. I think you might be right, maybe just lazy insurance for not having to change the sticker.
I am scared, I have a track event 05/20/16 and plan to run my E85 map (25% mix) and afraid I am going to lean out and blow up.
The Following User Says Thank You to SuckSqueezBangBlow For This Useful Post:
 Old 05-02-2016, 05:04 PM   #8
Omega's Avatar
Posts: 441   (View Stats)
The reason the pump says minimum 51% ethanol is because E85 mandate by DoE regulations is a minimum of 51%. That's all they're legally required to have but this is due to seasonal blends, you'll only see minimum of 51% in places where it's super cold.
The typical seasonal blends are 70/75/80/85 -- you even get a cool sheet with months/states on it to show when blends change. If you've spent any time in the E85 section there's an E85 handbook and regulations that states all of this including the 51% requirement. Unfortunately you can't find ASTM D5798 (the standard explaining the blend info) unless you buy it, I'm sure there's a copy floating around but I haven't found it.
2006 Super Clean BCM MS6
The Following 2 Users Say Thank You to Omega For This Useful Post:
 Old 05-03-2016, 05:33 AM   #9
Justin@Freektune's Avatar
Posts: 954   (View Stats)
They are required to have a minimum of 51%. I would get a cheap tester and check it periodically to make sure its close to e85. But chances are, it is e85
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
cyclist20 (01-18-2017), EdgeAutosport.com (01-18-2017), TORQUERULES (05-03-2016)
 Old 05-03-2016, 05:55 AM   #10
Thumbs up
Thanks. It just freaked me out when they changed their labeling completely. I hate to have to test it all the time, but I guess it is the price to pay for the extra power.
 Old 05-04-2016, 04:22 PM   #11
Omega's Avatar
it made me double take too a bit ago because they used to say 70% but the stickers were updated when the new regulation passed a few years ago (4?) allowing 51% to be the new minimum.
Testers such as the quick fuel e85 tester could be had for like $20 better safe than sorry and it doesn't take long.
TORQUERULES (05-05-2016)
 Old 05-05-2016, 07:47 AM   #12
Yea, I am going to hold off on running the E85 tune until I can get a tester.
 Old 05-06-2016, 04:25 PM   #13
Talked to a reputable tuner on here and he says that the reduction only really affects people running full E85 (cant remember if you are). For pansies like me running only a 25% mix the reduction will only affect my levles about 2% over all.
Think I am going to just put 30% in to be safe and cover my ass...
 Old 05-09-2016, 09:11 AM   #14
Funktionull's Avatar
Posts: 215   (View Stats)
Funktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the worldFunktionull is the leader of the world
Of all the places I've purchased E85 only one of them has ever been a sub 85 blend and that was an E78ish reading during a trip to Washington in the winter.
Everywhere else has always tested E90 ish. Buying a quick fuel tester should be part of anyone's ethanol tuning process. Knowing what you have for $20 is cheap peace of mind.
GT3071R ll HTP 3.5'' ll CP-E DP ll UR Exhaust ll Synapse DV ll Autotech HPFP ll TR8 w/ JBR PIPING ll Cobb 3port EBCS ll Matt Damond OCC ll NGK Iridium IX ll Bosch 3BAR ll JBR Solid Shifter Bushings ll JBR 88/88/80 Trilogy ll AP V3
Funktionull is offline   Reply With Quote
 Old 05-09-2016, 09:45 AM   #15
As an example. Using the 4.5 gallon mix that I run E70 would be E27 and using E85 would be E31. Which is a ~13% variance.
If I were running a 50/50 mix (8 gallons) E70 would net a total content of E40 and E85 would net E47.5 which would be an 18.75% variance.
It's simple to figure out your mixture by multiplying the gallons of ethanol by its E rating and then the gallons of regular fuel by 10. Add those numbers together and then divid by your total fuel capacity.
E85 x 4.5 =382.5. 11.4 x E10 = 114
382.5 + 114 = 496.5 ÷ 15.9 = E31.22
You can use this on the fly to alter your mix volumes to stay at your tuned Ethanol content but obviously you have to use a tester.
 Old 01-17-2017, 06:59 AM   #16
We have another station offering flex-fuel now. Unlike the first station that labels their fuel as E85 but with a possible minimum of 51%, this new station just calls their's "flex-fuel" and label it as being between 51%-83%. Crazy. They even have an E15 offered (88 octane).
 Old 01-17-2017, 07:58 AM   #17
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
This whole thread is the reason I gave up on my E85 tune dreams. Too big of a hassle to confirm appropriate ethanol levels in the fuel and not worth the potential zoom zoom boom. I'm pushing a conservative 307 hp at the wheels on standard 93 octane and only use WMI for the hot summer days. Drive to Newark, DE every 6 months or so to pickup VP Racing Ethanol barrels from their DC.
P.S. Shout out to the Jackson County OP. Let's Go Mountaineers!
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
The Following User Says Thank You to MazdaspeedKills For This Useful Post:
TORQUERULES (01-17-2017)
 Old 01-17-2017, 07:06 PM   #18
sheston's Avatar
Posts: 1,847   (View Stats)
Just go Meth and stop worrying about corn. Meth is better and if you spray as well, you only have to worry about one extra fuel. 2 gallons in every tank (better for me than 4.5 gallons E85) and spray a equivalent of D10 :-)
Side Note: I just bought one of those 14 gallon gas caddies for holding and pumping my Meth and love it. Added a air quick disconnect to I can pressurize it slightly so it "pumps" itself.
 Old 01-17-2017, 07:20 PM   #19
jtday's Avatar
I just moved to Oklahoma City and e85 is faily easy to come by. But a TON of the stations here offer E10 (87 blend). Most of them advertise that their gas is ethanol free. And MANY stations around here have CNG. So strange.. The one time I've tried to get 93, it was 3.88 a gallon.......
2009 MS3 GT
 Old 01-18-2017, 02:23 AM   #20
1. Make a test bottle. $2 at Walmart in the baby section.
2. Skeet some in the tester and do all that hocus pocus shit before you pump any in the car.
3. Take result and do maths on it.
4. Put in the amount needed for tune.
5. Repeat a few times per year or until you are confident about your source. Also repeat any time you try a new source.
6. Don't try new sources. If you are traveling outside the range of your known good source, flash the 93 tune any winner would have also purchased.
Sent from my SCH-I545 using Tapatalk
 Old 01-18-2017, 08:05 AM   #21
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I don't use meth or corn yet, but I was thinking the same thing. Forget corn if it's that complicated. 93 tune and meth. Call it a day.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
4wd issue kondzio MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 04-04-2015 06:32 AM
An issue maybe? Zohar MazdaSpeed 3 - Engine, Transmission & Driveline 5 02-21-2012 07:32 PM
BT Issue adrager622 2010 MS3 - Car Audio & Electronics 12 02-08-2012 09:36 AM
Page generated in 0.39913 seconds with 30 queries
