Like Tree22Likes
 Old 07-10-2016, 05:45 PM   #201
Djohns's Avatar
Posts: 3,944   (View Stats)
Wasn't possible to take his friends pump out just for a quick test?
2010 black mica speed3
Soon:built motor
monkey.bones.007 (07-11-2016)
 Old 07-10-2016, 06:14 PM   #202
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
True, we could also swap pumps with his friend to see if that fixes it. I didn't have my deep 18, impact, and 19 mm wrench on me though.
2007 Mazdaspeed3 GT
 Old 07-20-2016, 07:20 PM   #203
MD1032's Avatar
Groans: 143
The problem has been identified and resolved (for now). OP purchased a new pump at my request. When I pulled the original pump, the first thing I noticed was that the stock internals' retainer had failed in the exact same manner as the Autotechs. I was very confused. When I pulled the cylinder retainer, all became clear. It was cross-threaded.
There was some decent carnage. There were metal shavings everywhere. The stock internals ate themselves up. The cam follower had a little bit of atypical wear (may have been left over from the AT retainer failure) - I advised OP he might want to replace it in the future. Unfortunately I forgot to bring my spare with me.
It's clear to me that during the original installation of the Autotechs, OP's friend cross-threaded the retainer. This isn't terribly surprising since the retainer has a pretty low thread pitch.
So where did we end up?
1) OP's car is running normally for now and has autotechs installed. He doesn't have any pending codes and fuel pressure is normal. The car has normal driveability and acceleration.
2) There is very likely metal shavings in the hard line and rail, and possibly the injectors as well. I told OP, expect to need to replace all of these items in the future if he starts getting misfires, or if his fuel pressure sensor dies.
What happened during the original diagnosis at Mazda?
Two possibilities in my mind, possibility #1 , they took the pump off, saw what OP's friend did, along with the carnage, and recommended replacing everything (which is what I would do in this scenario honestly). #2 , they really were completely clueless and just took the shotgun approach.
I would actually put money on #2 because they kept insisting that the pump was aftermarket, which it is most definitely not (remember, at the time he took it to the dealer, it had stock internals).
LowFlyin likes this.
2007 Mazdaspeed3 GT
The Following 8 Users Say Thank You to MD1032 For This Useful Post:
Djohns (07-20-2016), g00s3y (07-21-2016), Gerbilo (07-21-2016), JgamB (07-20-2016), KiwiFlavor (07-20-2016), monkey.bones.007 (07-20-2016), voodoo2crue (07-21-2016), WetzMS3 (07-21-2016)
 Old 07-20-2016, 07:24 PM   #204
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Damn... That is crazy. OP I've never seen this before. I guess there's always a first for everything.
Glad everything is solved for now! @MD1032; you da man sir!
2012 NASA Spaceship Gray MS3
 Old 07-20-2016, 07:36 PM   #205
sleeveless's Avatar
Posts: 462   (View Stats)
sleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the worldsleeveless is the leader of the world
Good eye seems to me the plunger wasnt straight I'm assuming. As for the dealership, they most def took the "when in doubt, take it out approach. Mazda would never have us rip the fuel pump apart. Ever!!!
How the hell was it cross threaded though? That's crazy almost as if a couple turns with the good ol' hand wernt enough just run it with an impact straight I guess.
2012 black Mica MS3
sold
06 Mazdaspeed 6
LED turns, front switchbacks, 7000 lumen fogs, fancy boost gauge, dipped ms3 wheels
Last edited by sleeveless; 07-20-2016 at 07:36 PM. Reason: MSF Database - Automerged Doublepost
sleeveless is offline   Reply With Quote
The Following User Says Thank You to sleeveless For This Useful Post:
 Old 07-20-2016, 07:55 PM   #206
kryskunka's Avatar
Posts: 83   (View Stats)
kryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to allkryskunka is a name known to all
Glad everything is working just the way it's supposed to. @MD1032 is defenitely a great guy. He has so much knowledge. He is defenitely the man. Now time to buy an intake and turbo inlet pipe
kryskunka is offline   Reply With Quote
 Old 07-20-2016, 08:07 PM   #207
sleeveless's Avatar
Hmmm I'd hold that money for a little bit just in case the rail and injectors have an unpleasant surprise inside of them but to each his own
2012 black Mica MS3
sold
06 Mazdaspeed 6
The Following 2 Users Say Thank You to sleeveless For This Useful Post:
KiwiFlavor (07-21-2016), MD1032 (07-20-2016)
 Old 07-20-2016, 09:27 PM   #208
nindoja's Avatar
Posts: 2,395   (View Stats)
HAHAHAHAHA, if only you knew @MD1032;'s story of him swapping rear suspension in my garage 18 hours from home. Why don't you tell them what happened @MD1032;?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 07-21-2016, 03:49 AM   #209
MD1032's Avatar
Groans: 143
He knows @nindoja;, he's been under my car recently. And if you recall, I did give that bolt a couple turns before hitting it with the impact and it cross threaded anyway.
2007 Mazdaspeed3 GT
 Old 07-22-2016, 09:04 AM   #210
sleeveless's Avatar
Yes I know the story, I didn't know it was 18hrs from home though
2012 black Mica MS3
sold
06 Mazdaspeed 6
 Old 07-22-2016, 09:23 AM   #211
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
could lead to a clogged injector. hope it doesn't Boom on ya from a tiny piece of steal blocking an injector.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 07-22-2016, 09:30 AM   #212
MD1032's Avatar
Groans: 143
It was like 13. He's exaggerating.
I think all of us are in agreement, if it were our own personal vehicles, we would go ahead and replace the rail, injectors, and hard line. But your call OP.
2007 Mazdaspeed3 GT
KDM Internals soaringeagle129 Mazdaspeed3/6 General Discussion 6 02-07-2012 02:13 PM
Page generated in 0.33486 seconds with 27 queries
