![]() Join Date: Dec 2016 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score I got the car with the full Corksport Intake and there was definitely and exhaust on it at some point (I dont think the DP was removed ever) I was going to go ahead and get the DP back exhaust and accessport taken care of this weekend but I'm hoping to not have the spend the 350 on the HPFP if it's already in there. |
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| Best bet is to pull the pump out and check.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
(Thread Starter) | Not Ranked : 0 score Bleh. I was hoping to avoid that. |
Groans: 122
| Better safe than sorry. You could try checking to see if they left a ziptie on the hardline. That won't tell you anything if its not there, but if there is one, then they probably changed it out. Then again, could have stocked it out as well. Recommendation: Pull it and check.
(Thread Starter) | Not Ranked : 0 score Well I know what i'm doing this weekend! |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score It's very easy to do. Literally the only things you need to remove are the intercooler shroud and the valve cover breather line. You will need an inverted torx (E8?) for the pump bolts. Make sure to put a ziptie just below the nut on the HPFP hard line to prevent it from falling into an inconvenient position.
__________________ 2007 Mazdaspeed3 GT |
![]() Join Date: Apr 2015 Location: Sterling Heights Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Yes, it is an E8. I picked mine up at autozone.
__________________ Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks. Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A. |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score Aftermarket larger pump piston on left. Note large bulb on end. Stock on the right. Straight shaft all the way to the end.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Varomnia (02-11-2018) |
Groans: 143
| Not Ranked : 0 score Holy thread revival, batman.
![]() Join Date: Sep 2016 Location: Ringgold, Georgia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 411
| Not Ranked : 0 score But with a meaningful showcase of evidence, i'll allow it.
__________________ ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar |
| Way to tell if I have an upgraded HPFP? | freshmex28 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 01-08-2015 03:26 PM |
| Do I need an upgraded HPFP | slowspeed3 | Mazdaspeed3/6 General Discussion | 28 | 09-11-2012 02:49 AM |
| Is this HPFP upgraded? | rob ms6gt | Mazdaspeed3/6 General Discussion | 12 | 03-05-2012 03:43 AM |
