> 2010 MS3 - Car Audio & Electronics
Like Tree4Likes
  • 1 Post By WetzMS3
  • 3 Post By SofaKingAwesome
 Old 01-13-2017, 11:44 AM   #1
Chrisap29's Avatar
Posts: 13   (View Stats)
Chrisap29 will become famous soon enoughChrisap29 will become famous soon enough
Default Alternator change
Yesterday I put a new alternator in my 2012 MS3 sense my old one was going out, I got it in and working drove it home and the battery light was on but then it went away. When I got up this morning I started my car and let her warm up, but once I went to back out of my parking spot my power steering went out, my head lights flickered, my radio wouldn't work, my ac wasn't going. Then like 1 minute later it all started working and all the lights on the dash board went off and it was completely fine. I park the car at work, and go out on lunch and my cars interior turns on, radio works, ac works, all lights work, but it just won't start. It makes a clicking sound like it's trying but it just doesn't actually turn. After looking in the battery, I checked the connectors and they seemed tight, then I check the alternator connectors sense they were a pain yesterday taking out. My connector on the bottom is in good, but I took the tweezers in my car and checked to see if the grounding bolt was tight and it still turned, could that be the issue or could something else went wrong that I'm missing? Do I just need to jump it and tighten the bolt and try to clean off the connectors and stuff? Thank you for the help!
Chrisap29 is offline   Reply With Quote
 Old 01-13-2017, 11:49 AM   #2
A loose ground would cause that, yes.
Chrisap29 likes this.
 Old 01-13-2017, 11:51 AM   #3
Chrisap29's Avatar
Should I just tights it as much as I can and then jump start it?
 Old 01-13-2017, 11:53 AM   #4
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
Is this real life? Yes, tighten it up numbnuts
WetzMS3 (01-13-2017)
Alternator Help SyCoTiCK4rMA MazdaSpeed 3 - Engine, Transmission & Driveline 3 11-30-2014 05:24 PM
Man buys truck with change, LOTS of change Haltech Automotive News 1 08-14-2008 09:15 AM
Page generated in 0.25336 seconds with 22 queries
