![]() Join Date: Jun 2013 Location: New Orleans, LA : From LI, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
(Thread Starter) | Not Ranked : 0 score So today on the way to work , I went WOT merging onto HWY and car was limp. Would hit boost and then falls flat. Not sure if it's a boost leak or what. I sent an email to Justin but figured I would post here as well for any advice. Might have to take things apart and look for a leak if that's what it might be (at least I hope that's all it is).... Any advice please.. @Justin@Freektune; @rfinkle2; @Lex; Took a log but didnt go WOT all the way through RPM range because of how it falls on its face. You can see in the log attached, I hit about 10/11psi and then it drops to 8ish. AFR's are also very low at 8ish. Car has been running strong for the past 6-7months or so since it was tuned by Justin with no issues... All my mods are in sig.
__________________ 2013 CWP MS3 w/Tech Pkg Performance Mods Cobb AP V3 ~ JBR 3" WP Intake + Turbo inlet ~ JBR IC Boost tubes ~ AT hpfp Internals ~ ETS TMIC ~ CS Catless DP ~ CS Race pipe ~ CS Catback ~ CP-E Stg2 RMM ~ NGK Iridium IX's (1 step colder) ~ Turbosmart 50/50 ~ KSport Pro Coilovers [SIGPIC][/SIGPIC]on 93 307whp 339lbft Exterior mods: ESM 004s - Hankook Ventus V12 Evo2 225/40/18 - Gloss Black Vinyl Roof - Gloss Black emblems - 15% tint - Rear Wiper delete - OEM window visors On Order: GT2871r, Freektune 3.5" Intake, Bosch 3.5 Bar Map sensor, Cobb EBCS |
![]() Join Date: Jun 2012 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,322
Groans: 156
| Not Ranked : 0 score Really rich afr's, I would say a big boost leak (after turbo).
__________________ -2012 CWP MS3 - - COBB AP V2b - Autotech HPFP Internals - JBR 3.0 WP - CP-E TMIC - UR TP - NGK ILTR6A-8G # 3787 plugs - EGR delete - Bosch 3-bar TMap - DO WMI 50/50 - JBR RMM 88a - JBR PMM 70a + JBR TMM 70a - JBR OCC S2 - JBR SSP - JBR SSB - JBR RSB - - Block8head single defrost pod - VDO Vision Boost Gauge - Maisonvi Custom Stainless Steel Ball Shift Knob - - Self Tuning 91 octane of fail with 50/50 WMI of win - |
| The Following User Says Thank You to Hush For This Useful Post: | BooSTed_Hatch (07-02-2014) |
(Thread Starter) | Not Ranked : 0 score Thanks Hush, Any other idea's??
| ms6 boost problem...2 psi | Stealthvr4 | MazdaSpeed 3/6 - Turbo Induction | 17 | 06-14-2014 01:36 AM |
| Had a boost problem :/ | Evolution99 | MazdaSpeed 3/6 - Turbo Induction | 2 | 03-29-2013 05:43 PM |
| same problem... boost spike | LiEast | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 10-11-2009 10:31 AM |
| sb boost control problem | speed_3 | MazdaSpeed 3/6 - ECU Computer Tuning | 20 | 07-01-2009 04:53 PM |
