> Ultimate Racing
Ultimate Racing Catback Exhausts, Test Pipes, High Flow Cats, Downpipes, Front Mount Intercoolers. We've got your 2010 Mazdaspeed3 covered!
  • 1 Post By dMuze
 Old 11-16-2010, 04:54 AM   #1
FY"IED"N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
Default My review of the UR Turboback (catted) for Genpu
This is the review i sent to UR after the install. I hope it solves future CEL issues with their system...
good morning, i wanted to write and give some feedback on my recent purchases. over the last month i purchased your test pipe, ceramic catted dp and cat back for the 2010 ms3. shipping on all items was really fast. they all arrived within 3-4 days of the orders. packaging, welds and fitment were all as expected. install was much easier then expected. the TP was very simple, DP was much easier than i was told it would be...i thought this would be a horror story from the forums, but i took my time and did it on a lift, alone in 4 hrs. the cat back was also simple to install after some on the phone coaching with the piece that goes over the axle.
now...i did have 3 codes pop up with a check engine light...as the site says, you dont promise to prevent one. i wanted to be sure i figured out and fixed the cause of these codes... i was reading- lean post cat, rear o2 low voltage, rear o2 slow response. these codes were making my car run super rich, afr's and trims were off...and mpg went way down. i ran a few logs and noticed the o2 voltage didnt have any reading at idle or when letting off the gas. my original intent was to drill out the bung after the cat, but after getting back up on the lift, realized this would be near impossible without messing up the threads. so i then decided to seal the rear bung and weld in another. this would put the rear o2 back in the exhaust flow, and since i have a catted dp...should avoid a cat inefficiency code. i now have put almost 50 miles on the new modification...mpg, trims, afr are back to normal for a stock tune, no cel and the car pulls the way i thought it would with an aftermarket turbo back exhaust.
all in all my experience with ultimate-racing has been a great one. i am by no means a mechanic or engineer...but in my personal opinion, for the 2010 mazdaspeed3 with a catted dp, an extended diagonal rear bung will do more bad then good. i have already highly recommended your company on the mazdaspeedforums website and will continue to do so. i have shared my solution on a thread and will be posting my before and after logs this afternoon as proof. i plan on purchasing your fmic kit with crash bar this spring and really appreciate the customer service.
Dan Pare
I sealed up the original rear bung to prevent future leaks. i hope this helps you decide on a purchase. i do recommend this company.
Kdawg207 likes this.
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
The Following 3 Users Say Thank You to dMuze For This Useful Post:
Code Monkey (07-21-2012), jallways (12-01-2010), Kdawg207 (07-10-2012)
 Old 12-01-2010, 12:05 PM   #2
jallways's Avatar
Posts: 41   (View Stats)
jallways is just really nicejallways is just really nicejallways is just really nicejallways is just really nicejallways is just really nice
Default New bung
Have you had any more issues (codes) with the UR DP since you relocated the O2 sensor bung?
jallways is offline   Reply With Quote
 Old 12-01-2010, 12:33 PM   #3
FY"IED"N
dMuze's Avatar
none what so ever. the codes never came back.
 Old 12-01-2010, 12:44 PM   #4
jallways's Avatar
Default DP codes
I am about to install the hi-flow UR DP. Welding on a new bung looks like the best way to go.
 Old 12-01-2010, 02:45 PM   #5
FY"IED"N
dMuze's Avatar
its a pretty easy install if you have a lift and no seized bolts.
 Old 12-02-2010, 06:28 AM   #6
jallways's Avatar
No lift available.
Have you or are you upgrading your fuel pump?
 Old 12-02-2010, 06:51 AM   #7
FY"IED"N
dMuze's Avatar
i ordered mine through CP-E a few weeks back...they just finished their most recent batch yesterday. i should hopefully have it delivered early next week. i dont drive WOT everyday and monitor my fuel rail pressure with my dashdaq. stock pump still handles perfectly. im throwing the hpfp in as a precaution since im also adding an fmic and getting tuned this month.
 Old 12-02-2010, 10:44 AM   #8
Speedstick's Avatar
Posts: 34   (View Stats)
Speedstick will become famous soon enough
I am definitely not trying to do that extra task to solve the cel since I have no ability to weld shit haha do you know if this is the case for a lot of people and if I get
It installed by a mechanic would they notice the problem and fix it?
2010 Black Mica MS3 with Tech Package
--Cp-e SRI
--Cp-e Turbo Inlet Pipe
--Cp-e 60 duro rmm
--HKS Hipermax V Sport Coilovers
--20% Tint (Windows, Windshield Strip and Side View Mirror Blinkers)
--Tinted Tails
--Yellow Fogs
--Rally Armour Mud Flaps
Speedstick is offline   Reply With Quote
 Old 12-02-2010, 12:47 PM   #9
FY"IED"N
dMuze's Avatar
Check Engine Light (P2098)
this is the thread where me and a few others on here had a similar issue, and solved it by changing the angle and length of the bung. its not something a mechanic will notice, and you may not even get a cel for a few days...not until its cold out. if you tell them up front, they may charge you an extra $10 to seal the rear bung and weld in a new one. this wont be something they do without your request though.
 Old 04-01-2012, 03:13 PM   #10
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
Dan Pare
Hey man. I think they took this review under advisement. I bought mine earlier this month and the 2nd O2 sensor looks like the one you added, rather than the one sticking out the back.
Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11
Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS
Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS)
K04 POWER FIGURES
277HP/325TQ SixTuned On 93
314HP/356TQ Rfinkle2 Tuned With 33% Corn
S360 POWER FIGURES
365HP/356TQ Purple Drank Tuned ON 93
421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX
NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING
Ray Danger 2020 is offline   Reply With Quote
The Following User Says Thank You to Ray Danger 2020 For This Useful Post:
dMuze (07-10-2012)
 Old 07-10-2012, 07:02 PM   #11
Sig_Nasty's Avatar
Posts: 272   (View Stats)
Sig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the world
Groaned at 4 Times in 1 Post
same ^^
Sig_Nasty is offline   Reply With Quote
The Following User Says Thank You to Sig_Nasty For This Useful Post:
dMuze (07-10-2012)
 Old 07-10-2012, 08:15 PM   #12
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
Props for well put informative post
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 07-21-2012, 08:51 AM   #13
eli
eli's Avatar
Posts: 16   (View Stats)
eli is an unknown quantity at this point
good information
eli is offline   Reply With Quote
My Review: cp-e catted downpipe the_caruch MazdaSpeed 3 - Engine, Transmission & Driveline 5 06-05-2013 08:00 PM
Dp + Turboback frontrightpocket MazdaSpeed 3/6 - Turbo Induction 12 12-24-2009 09:17 PM
Turboback is squeaking KeysMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-16-2009 12:19 PM
Page generated in 0.33890 seconds with 27 queries
