| Ultimate Racing Catback Exhausts, Test Pipes, High Flow Cats, Downpipes, Front Mount Intercoolers. We've got your 2010 Mazdaspeed3 covered! |
| FY"IED"N ![]() Join Date: Nov 2010 Location: Alexandria, VA
Rep Power: 602 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 919
(Thread Starter) | Not Ranked : 0 score good morning, i wanted to write and give some feedback on my recent purchases. over the last month i purchased your test pipe, ceramic catted dp and cat back for the 2010 ms3. shipping on all items was really fast. they all arrived within 3-4 days of the orders. packaging, welds and fitment were all as expected. install was much easier then expected. the TP was very simple, DP was much easier than i was told it would be...i thought this would be a horror story from the forums, but i took my time and did it on a lift, alone in 4 hrs. the cat back was also simple to install after some on the phone coaching with the piece that goes over the axle. now...i did have 3 codes pop up with a check engine light...as the site says, you dont promise to prevent one. i wanted to be sure i figured out and fixed the cause of these codes... i was reading- lean post cat, rear o2 low voltage, rear o2 slow response. these codes were making my car run super rich, afr's and trims were off...and mpg went way down. i ran a few logs and noticed the o2 voltage didnt have any reading at idle or when letting off the gas. my original intent was to drill out the bung after the cat, but after getting back up on the lift, realized this would be near impossible without messing up the threads. so i then decided to seal the rear bung and weld in another. this would put the rear o2 back in the exhaust flow, and since i have a catted dp...should avoid a cat inefficiency code. i now have put almost 50 miles on the new modification...mpg, trims, afr are back to normal for a stock tune, no cel and the car pulls the way i thought it would with an aftermarket turbo back exhaust. all in all my experience with ultimate-racing has been a great one. i am by no means a mechanic or engineer...but in my personal opinion, for the 2010 mazdaspeed3 with a catted dp, an extended diagonal rear bung will do more bad then good. i have already highly recommended your company on the mazdaspeedforums website and will continue to do so. i have shared my solution on a thread and will be posting my before and after logs this afternoon as proof. i plan on purchasing your fmic kit with crash bar this spring and really appreciate the customer service. Dan Pare I sealed up the original rear bung to prevent future leaks. i hope this helps you decide on a purchase. i do recommend this company.
__________________ 2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint. ![]() |
| The Following 3 Users Say Thank You to dMuze For This Useful Post: |
![]() Join Date: Jan 2010 Location: Outside Philly, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Have you had any more issues (codes) with the UR DP since you relocated the O2 sensor bung? |
(Thread Starter) | Not Ranked : 0 score none what so ever. the codes never came back.
| Not Ranked : 0 score |
(Thread Starter) | Not Ranked : 0 score its a pretty easy install if you have a lift and no seized bolts.
(Thread Starter) | Not Ranked : 0 score i ordered mine through CP-E a few weeks back...they just finished their most recent batch yesterday. i should hopefully have it delivered early next week. i dont drive WOT everyday and monitor my fuel rail pressure with my dashdaq. stock pump still handles perfectly. im throwing the hpfp in as a precaution since im also adding an fmic and getting tuned this month.
![]() Join Date: Dec 2010 Location: PA
Rep Power: 0 ![]() Thanks: 5
| Not Ranked : 0 score I am definitely not trying to do that extra task to solve the cel since I have no ability to weld shit haha do you know if this is the case for a lot of people and if I get It installed by a mechanic would they notice the problem and fix it?
__________________ 2010 Black Mica MS3 with Tech Package --Cp-e SRI --Cp-e Turbo Inlet Pipe --Cp-e 60 duro rmm --HKS Hipermax V Sport Coilovers --20% Tint (Windows, Windshield Strip and Side View Mirror Blinkers) --Tinted Tails --Yellow Fogs --Rally Armour Mud Flaps |
(Thread Starter) | Not Ranked : 0 score Check Engine Light (P2098) this is the thread where me and a few others on here had a similar issue, and solved it by changing the angle and length of the bung. its not something a mechanic will notice, and you may not even get a cel for a few days...not until its cold out. if you tell them up front, they may charge you an extra $10 to seal the rear bung and weld in a new one. this wont be something they do without your request though.
![]() Join Date: Mar 2012 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
Hey man. I think they took this review under advisement. I bought mine earlier this month and the 2nd O2 sensor looks like the one you added, rather than the one sticking out the back.
__________________ Power: BORG WARNER S360 TURBO w/ .70A/R SINGLE SCROLL HOTSIDE HTP 3.5" WHALE PEEN TIAL 44mm EWG (red) FJ PERFORMANCE TUBULAR MANIFOLD w/ VBAND EWG OUTLET/VBAND CATLESS DP/VTA EWG TUBE/FMIC PIPING - HOTSIDE ROUTED UNDER CAR/AN OIL FEED/DRAIN LINES ULTIMATE RACING CBE TREADSTONE TR1035 FMIC CORE AUTOTECH HPFP INTERNALS COBB TUNING ACCESSPORT GO FAST BITS TMS RESPONS BOV NGK LTR7IX-11 Handling: JAMES BARONE RACING RSB/88aRMM/88aTMM/80aPMM SONIC TUNING S3 COILOVERS STOPTECH SPORT STOP CROSS DRILLED ROTORS BRIDGESTONE POTENZA RE-11 235/40/18 SPC REAR CAMBER ARMS Extra Shit:SURE SHORTCUT/COUNTERSHIFT/ANCHORS JAMES BARONE RACING SPHERICAL HEAVY KNOB/51r BATTERY TRAY/STAGE II OCC CORKSPORT LED REAR BUMPER REFLECTORS/LED INTERIOR KIT/URETHANE EXHAUST HANGERS/GAS HOOD PROP STRUTS BOSCH 3-BAR MAP SENSOR BITWISE PnP MAP HARNESS COBB TUNING 3-PORT EBCS DDM TUNING 8000K LOWS/3000K FOGS O.Z. RACING ULTRALEGGERAS 18x8 +48 MUTEKI SR48 OPEN ENDED LUGS NUTS ARP 100-7708 EXTENDED WHEEL STUDS HELLA SUPERTONES RALLY ARMOUR MUDFLAPS (BLACK WTH RED LETTERS) [SIGPIC][/SIGPIC] K04 POWER FIGURES 277HP/325TQ SixTuned On 93 314HP/356TQ Rfinkle2 Tuned With 33% Corn S360 POWER FIGURES 365HP/356TQ Purple Drank Tuned ON 93 421HP/392TQ Purple Drank Tuned w/ 3 GAL E85 MIX NUMBERS LIMITED BY STOCK BLOCK ON STOCK FUELING TILL SPRING | |
| The Following User Says Thank You to Ray Danger 2020 For This Useful Post: | dMuze (07-10-2012) |
![]() Join Date: Jun 2011 Location: Edmonton
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score same ^^ |
| The Following User Says Thank You to Sig_Nasty For This Useful Post: | dMuze (07-10-2012) |
![]() Join Date: Apr 2009 Location: Somerset NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,706
| Not Ranked : 0 score Props for well put informative post
__________________ ~~~NJ Nator OG~~~Then AND Now, Just Better~~~ ![]() |
![]() Join Date: Feb 2011
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score good information |
| Display Modes | |
| My Review: cp-e catted downpipe | the_caruch | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 06-05-2013 08:00 PM |
| Dp + Turboback | frontrightpocket | MazdaSpeed 3/6 - Turbo Induction | 12 | 12-24-2009 09:17 PM |
| Turboback is squeaking | KeysMS3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-16-2009 12:19 PM |
