| Ultimate Racing Catback Exhausts, Test Pipes, High Flow Cats, Downpipes, Front Mount Intercoolers. We've got your 2010 Mazdaspeed3 covered! |
![]() | | #41 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 212 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
| Not Ranked : 0 score
Darryl Ultimate-Racing.com | |
| The Following 4 Users Say Thank You to Ultimate Racing For This Useful Post: |
![]() | | #42 | ![]() |
| MS3 Abuser ![]() Join Date: Aug 2009 Location: Dirty Jersey (Jersey City, NJ)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 119
I agree with what UR said, about not modifying their product to suit your needs. Too many "what if's" can happen should those holes not suit your needs. Have you called CP-E, and are they willing to drill holes for you on their product?
__________________ 12.653 @ 109.90mph, Stock K04 2010 MS3 | |
![]() | | #43 | ![]() |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score so much whining to vendors about this at that. If the product fits and does what it is supposed to do then the vendor did its job.
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
![]() | | #44 | ![]() |
![]() Join Date: May 2010 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
What IFs addressed above. Yes, I am concerned that we are removing the crash bar which is designed to transfer the load to the crumple zone. I will have the discussion with the other suppliers about the replacement bar.
And if trying to get the best quaility/engineered/warrantied product for the money is an issue, so be it. Z | |||
![]() | | #45 | ![]() |
| Not Ranked : 0 score "Sorry, we wouldn't be able to do that for you." I think I said "NO" very politely. If you wanted reasons, all you had to do was ask. I would've been more than happy to answer as I did with all of your previous emails. Emailing AND posting about my lack of customer service is uncalled for in my opinion. Darryl Ultimate-Racing.com |
![]() | | #46 | ![]() |
| Not Ranked : 0 score Z, the UR crashbar wasn't made the hold the FMIC up. In fact, the FMIC does NOT bolt onto the crashbar at all. I have it. You can go look at the pics on UR's site. The FMIC is bolted onto the radiator support on the bottom of the 2 sides, behind the inlet and outlet, and also in the middle, maybe 6" down from the hood latch. The crashbar bolts onto the car on the 4 holes on (2 on each side, onto the frame rail ends), where the stock crashbar bolts on. The FMIC sits behind the crashbar. You will not have to make any special modifications to mount the Hella horns, even without drilling into or through the crash bar. You can also mount them where the stock horn is, behind the bumper, on the left side. You can also mount them on the bolts that holds the crashbar onto the frame rails.
![]() | | #47 | ![]() |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
| Not Ranked : 0 score This kit fits perfectly. I opted out of a crash bar, so I don't have on, kit doesn't need it for mounting. I voiced some concerns regarding the clamps, however, they have held up perfectly, so I have no complaint about this kit. I don't care about a crash bar, so I got this kit for $405 less than the CP-E kit, which does come with a crash bar, but is useless to me. Z, their response was totally professional, not sure what you're upset about. This is a good kit for the price, you should get it
__________________ |
![]() | | #48 | ![]() |
| Not Ranked : 0 score A, just wanted a reason, that is all I wanted, if you wife/gf says no, do you want a reason or do you just go lick yourself like the dog. I don't have access to a drill press and I suck trying to drill thru square tubing. How is the fit going across the top, the pic from the OP shows this to be close and after a few hard accelerations I question if it hits. I agree the kit is nice, this is why I was entertaining the thought of buying, bigger exchanger that the other folks, I do like T-bolts rather than worm gear, I do like the other crash bar - little stouter and tow hook built in, like the UR option with the couplers, like the large outlet on the other, if you could blend the two products you would have a very nice FMIC. Hell, I was one of the first to get their CBE w/TI tips and have been pushing this CBE on everyone I come in contact with. A buddy actually tried to purchase on the TI tip but this could not happen. MY BAD, I JUST WANTED TWO 1/2" HOLES, I WILL JUST FIU WITH MY DRILL, OR FIND ANOTHER MOUNTING POINT. I am still concerned that the outlet piping will interfere with my OCC tubing but we will see about that later. Z
__________________ Zman 2010 L MS3 GTX3076 w EWG | CPE BT SRI/TI | Cobb DP | HKS SSQ IV | CPE FMIC | CPE HPFP | IM SSPMod/PnP | GS 3P EBCS | CPE Inj Seals | Sure TIG | UR CBE | CPE RMM/SMM | BC Coilovers (8/5) w/ Rear Camber Arms | RR RSB | TWM SS replacement | Forgestar F14 10/9.5 | JVC KWAVX830 HU w/ XD 600/1 XD600/4 amps JL subs/components | AP and tuned w/ Freak Parts to install: DO Meth |
![]() | | #49 | ![]() |
I appreciate your business, as well as all the positive words you've shared with others about our products. At the end of the day, we simply can't help with any custom requests like this one. No matter how simple it may seem to you. It isn't something we offer to anyone, so please don't take it personal. If my tone came off as negative in my email then I apologize. Hopefully, we can both learn from this. As for the fitment of the product, as Amazon has stated, it does fit very well. Fitment is always been something we have prided ourselves on. I did reply to the above fitment issue and even offered up a suggestion. Darryl Ultimate-Racing.com | |
![]() | | #50 | ![]() |
![]() Join Date: Jun 2010 Location: Tulsa, OK
Rep Power: 10322 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,599
| Not Ranked : 0 score Geez, he's the man that makes these kits, if he says no, then no it is. Don't whine about it and say it's poor customer service. Who cares if he didn't provide a reason, HE is the man behind the product, and he has the right to simply say no. It is not your God given right to demand a reason. You are the consumer, if you don't like it, don't buy it. My gosh too many people expect way too much from companies today. UR makes quality stuff, and there are other companies that make good stuff too. Get a drill and good bit and make two holes and stop crying. Reading your sniveling is making me somewhat embarassed to be a member here. That is all, I'm coming down from my soapbox now. |
![]() | | #51 | ![]() |
Groans: 214
| Not Ranked : 0 score In the business world, if you do something special for someone once, expect to have to do the same again and for other people. Customers, by nature tend to expect the same service repeatedly. And if you give them an inch, they'll gladly take the next 2 miles as well. A gesture of good faith can turn into a hellish bickering nightmare. 5 years of management has taught me this lol Once again, this kit is solid, it doesn't hit anything under hard acceleration. Bat's remain within 10 - 15* of ambient, and I can't say I can notice any added lag.
| The Following User Says Thank You to Amazon For This Useful Post: | airhunt2 (03-28-2011) |
![]() | | #52 | ![]() |
Airhunt you are right, no whining, fuck it, spend an extra 130 and money stays in the states, later. If you want some whinning go to thread concerning CPE FMIC, I am sure as hell no bitching about price. Last edited by ZPrice; 03-30-2011 at 08:49 AM. | |
![]() | | #53 | ![]() |
![]() Join Date: Nov 2010 Location: Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 206
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score What is the core size? Only says large on their site
__________________ 2010 Mica Black w/tech Cobb AP (DJ Tuned ) | TiAL QR BOV | CP-e FMIC | CP-e CAI | CP-e TIP | CP-e Catted Downpipe | CP-e HPFP | CP-e rmm-75 | TWM Full Replacement short shifter w/trans adap. | Denso ITV22 | DDM 55w 6000k | E4 Shift Knob | CP-e Tow Plate | Rally Armor Flaps | 20% Tint | |
![]() | | #54 | ![]() |
| Not Ranked : 0 score |
![]() | | #55 | ![]() |
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
| Not Ranked : 0 score I was going to be buying this kit out right from UR, but i got lucky and picked up a new one in the for sale forums on here for a very good price with black piping and some vibrant tbolt clamps, i will be installing this kit next week. (Going TDY this week and wont be able to) I will be glad to post up detailed pics of the install to show everything with clearances and all. Darryl I will be ordering a crash bar from you within the next couple of weeks if thats possible, thats all that i need for the complete kit?
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost |
![]() | | #56 | ![]() |
![]() Join Date: Mar 2011 Location: Boca Raton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,500
Groans: 669
| Not Ranked : 0 score @dMuze Can you please give us an update on how the FMIC is running after a few months? I may be purchasing this in the near future. Thanks
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq |
![]() | | #57 | ![]() |
| Not Ranked : 0 score I've had mine on for a good while now and it has no problems what so ever. Great product. Tapafucku!
| The Following User Says Thank You to PapaSmurf For This Useful Post: | adlpb (08-01-2011) |
![]() | | #58 | ![]() |
| FY"IED"N ![]() Join Date: Nov 2010 Location: Alexandria, VA
Rep Power: 602 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 919
__________________ 2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint. ![]() | |
| The Following User Says Thank You to dMuze For This Useful Post: | adlpb (08-01-2011) |
![]() | | #59 | ![]() |
Groans: 669
Good luck out there. I myself was with 1/6 B.Co. from 05-08.
__________________ Fast cars are for straight lines. Corners are for fast drivers. 2006 Corvette Z06 - AKA "El Zorro" Sold: 2012 Evolution X GSR - 394awhp / 378awtq Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq | |
![]() | | #60 | ![]() |
![]() Join Date: Nov 2008 Location: Hutto, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score Ah, there's the trouble.... Motherfucking "Project Managers", they server ZERO fucking purpose except to be a pain-in-the-ass to those of us who actually work for a living.
__________________ 2012 Black Mica with Tech package. Chock full of goodies and Dizzy tuned |
![]() | | #61 | ![]() |
| Not Ranked : 0 score Since it took a year to respond, I guess you have been actually working. 320 HP on your mods? |
![]() | | #62 | ![]() |
![]() Join Date: Jun 2012 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
This guy went out there with his install thread and you tossed it in the shitter with your public display of estrogen letting. Nice job "engineer".
__________________ Autotech CDFP internals, Cobb AP, CS Stage II PS SRI/TiP with Airbox, JB RMM, CS SSP ~ Fast---Cheap---Reliable.....you can only pick 2 ~ | |
![]() | | #63 | ![]() |
![]() Join Date: Oct 2013 Location: Memphis, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 34
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score Just installed one today with no crash bar! Fitment is perfect! I'll update in the future if any problems arises, but I'm positive it's fine. Thanks for a great product UR!
__________________ '13 BM w/ tech Autotech HPFP - Cobb AP v3 - CP-E Catted DP -OBX Cat-back - CS SRI/TIP - UR FMIC - HKS SSQV4 - JBR RMM - Stratified Tuning ------------------------------------------------------------- Eibach Springs - SPC RCA- Ralliart MF - Mugen Visors - 06-07 STI lip - MZ sides/rear - Glowshift A-Pillar Pod/Gauges - DDM 6k low/3k fog - Lamin-x yellow fog light cover - Bluebatmobile red tail light overlay - CS led kit - BLOX Neochrome shift knob - 20% all around |
![]() | | #64 | ![]() |
![]() Join Date: Dec 2011 Location: Hampton Roads, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,415
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score in b4 engine through firewall
__________________ 2012 Mazdaspeed3 Black Mica Cobb AP // Stratified S-OTS+ Stage 2 Tune // Autotech Internals // CorkSport 3" Intake // CX Racing FMIC // NGK Iridium One Step Colder Plugs // JBR Throttle Body Gasket Kit & Coolant Bypass // SURE Return (w/ Dremel mod) // GFB Respons BOV // UR V2 Metal Catted DP // SURE Flow M3 // UR Catback Exhaust // StopTech Front Slotted Rotors + Performance Brake Pads // TWM Phantom Shift Knob // TWM Leather Shift Boot // CorkSport Adjustable Shortshifter // SURE Anchors // Tanabe NF210 Springs // JBR Tru-Torsion.125 Rear Sway Bar // Tanabe Sustec Tower Strut Bar // Tanabe Sustec Front Under Brace // JBR 88a RMM // Rally Armor Mudflaps // CorkSport Hood Scoop // CorkSport Battery Box // CorkSport LED Light Kit // CorkSport LED Fogs // GTA Car Kits iPod Adapter // Weathertech Floor Mats // Motorcraft Unicorn Tranny Juice // Pentosin Super DOT 4 Brake Fluid // Purple Effect Stock Rims // Falken Ziex ZE 329 // Plastidip'd Fog Light Bezels Waiting for install: StopTech Rear Slotted Rotors + Performance Brake Pads, StopTech SS Brake Lines ![]() Soon: Custom Tune by Stratified // Guardian Angel // BT, CorkSport Puppy or BNRs3??? |
| The Following User Says Thank You to Cujo For This Useful Post: | adlpb (01-27-2014) |
![]() | | #65 | ![]() |
![]() Join Date: Apr 2013 Location: Wilkesboro, North Carolina
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,221
| Not Ranked : 0 score For those of you going with a big turbo if you want the kit to fit correctly you need to grab a 45° reducing coupler that is 2in to 2.5in. Also if you tighten the clamps down that come with the kit it's not going anywhere. The clamps are actually really good. I prefer them over t-bolt since they are thinner since they have thinner bands. Theoretically should put more pressure down across the surface of the band, and aren't as bulky. Also to isolate where the the tmic mounting points won't rub on it I made a mount using a 2.5 inch loop clamp. I've made a few more revisions but this is all I have a picture of right now since my car is in the shop. |
| The Following User Says Thank You to NCspecV81 For This Useful Post: | kashbringer (05-15-2014) |
![]() | | #66 | ![]() |
![]() Join Date: Jun 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 201
| Not Ranked : 0 score My intercooler shipped wihout the bolts that should have been supplied.. Anyone have the bolt size? I think its even on the instructions (They are in my car.. at the shop that is installing the kit.. along with 5thport, headbolts, vvt, etc etc.) Also im assuming it should be 2 bolts, washers, and 2 nuts.
__________________ 2012 MazdaSPEED 3 - Crystal White Pearl Performance - Precision 5858 - Built motor (K1 Rods / Wiseco Pistons / ARP main studs / Stock head bolts) - Cobb V3 AccessPORT - PERM 5th port kit, PERM Plate - HTP 3.5" Intake (Powder Coated Pure Orange) - Autotech HPFP Internals – CPE Vband Exhaust Manifold - Kozmic Vband Downpipe, Dumptube, Oil feed / Return lines, Vented OCC, Primary EGR delete – Ultimate Racing Catback, FMIC modified for 5th port by Kozmic Motorsports - Turbosmart dual port , 45mm EWG - JBR Coolant Bypass, EGR Delete, Throttle body TIG, Dogbone RMM, Transmission Mount, Sealed OCC - Grimmspeed EBCS - NGK plugs - Bosch 3.5 Bar MAP w/MattJackson86 PnP Harness – Ported Intake manifold with VCTS delete, 1/8" Intake manifold TIG by Zack - Spec Stage 3+ Clutch and flywheel Tuned by Voltwings (OLD k04 SET UP ) 374.5 WHP 447.2 WTQ with stock K04 - 1-17-14 Dynocom dyno (New BT numbers soon) ~487WHP 455wtq Virtual Dyno and out of fuel... moar injectors! Looks - Pure Orange Powder Coated Gen Pu Stockers - Muteki SR48 Lugs - 5k HIDs / 3K HID Fogs |
| My review of the UR Turboback (catted) for Genpu | dMuze | Ultimate Racing | 12 | 07-21-2012 08:51 AM |
| Genpu Vs Cobra | treyclash | Street Racing Stories ( Bench Racing ) | 17 | 12-04-2010 05:56 PM |
| Genpu Smoke | kngeducate | 2010 MS3 - Turbo Induction | 41 | 11-15-2010 05:29 PM |
| Ms3 vs Ms3 (Genpu) | Andrew85 | Street Racing Stories ( Bench Racing ) | 9 | 07-21-2010 08:23 PM |
