| Ultimate Racing Catback Exhausts, Test Pipes, High Flow Cats, Downpipes, Front Mount Intercoolers. We've got your 2010 Mazdaspeed3 covered! |
| FY"IED"N ![]() Join Date: Nov 2010 Location: Alexandria, VA
Rep Power: 602 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 919
__________________ 2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint. ![]() Last edited by dMuze; 12-04-2010 at 01:02 PM. Reason: Pics Added |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score Kit looks great, I would def upgrade the clamps..... just for peace of mind Doesnt look like it will rattle very much with the crashbar mount
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
![]() Join Date: Apr 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Yeah I was wondering how they were going to do the FMIC kits for the Genpu, crashbar mount.. clever clever.
__________________ 2012 BMW 135i //M-Sport |
![]() Join Date: Jul 2010 Location: Rochester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,462
Groans: 64
| Not Ranked : 0 score Looks great! Can't wait to hear the results after the tune.
__________________ Cp-e HPFP : JBR 80duro RMM : JBR Special Edition Heavy Shift Knob : JBR EGR Delete : Matt Damond OCC kit : Cobb AP : Cobb DP : Cobb BPV XLE : ETS TMIC : CP-e SRI : Cp-e TIP : Magnaflow CBE : Aeroforce Interceptor Dual Gauge : Blockhead vent pod :PERM Tuned : H&R Springs : TSW Nurburgring 18x8.5 w/ 235/45 Hankook Ventus V12 Evo : DDM 6000k Lows : DDM 3000k Fogs : Corksport LED light kit : 3M 35% color stable tint |
![]() Join Date: Jun 2010 Location: Jarrell, Tx
Rep Power: 418 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,812
Groans: 43
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Your car is just about exactly how I'm planning my car when the funds come in. Are you planning on getting it dynoed after everything is installed and tuned? I'm guessing you'll be about 315-320whp!
__________________ 2013 Black Mica Mazdaspeed 3 - Current daily 2006 WWP Mazdaspeed 6 - Soon to be daily 2006 BCM Mazdaspeed 6 - Project Tuned with by |
(Thread Starter) | Not Ranked : 0 score il be tuning it at john's shop in ct...we will prob do a before/after dyno.
__________________ 2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint. ![]() |
(Thread Starter) | Not Ranked : 0 score ok so an update...the FMIC is still sitting in my spare room. i contacted Home | Fastenal (aka fail-all) about my t-bolt clamp i ordered before thanksgiving. i submitted my order the monday of thanksgiving week and still haven't received any tracking info. i contacted the company twice and they stated they were out of stock and had to order through another company...but that order was lost over the holidays and they had to re-order. this other company is in TN...im in NC. they have to first ship to fail-all in like idaho first, then from there to NC. so they should be able to ship to me on the 8th....BS! anyhow im going to throw this kit on tomorrow morning in my driveway. il use the clamps it came with. il boost leak test, and if all is well...il then run some logs and post all my thoughts, pics and results...hopefully RPM will ship my CP-E HPFP soon so i can install before my trip up to CT to tune, then boston. il keep those of you interested, posted.
| The Following User Says Thank You to dMuze For This Useful Post: | smitty5788 (12-03-2010) |
![]() Join Date: Dec 2009 Location: Cincinnati, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,608
Groans: 215
| Not Ranked : 0 score looking forward to seeing this, get some good pics of the crash bar.
__________________ 2011 DGM STI Sedan - Fully Bolted FP Green Setup 368WHP / 335WTQ SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760 |
(Thread Starter) | Not Ranked : 0 score ok...just finished with this thing. not a bad install. did it alone in my driveway. took about 3 hrs making sure i took my time, and didnt miss anything. fitment is tight with the pipes. the supplied clamps dont yield any boost leaks as of yet. the hot pipe was the worst part to install, and the only rubbing occurs on the hot side, along the stock tmic mount. see the pictures. the horn bracket has to be reversed, since the stock location interfers with the cold pipe. i simply switched the bracket around and re-installed the horn with no issues. i thought of taking the grill insert out exposing the fmic fully but it would look retarded. all in all its a great piece. no cel's, cant wait to get it on the dyno and tune. the supplied instructions were pretty clear and straight forward...but common sense should guide you through this install.
| The Following 8 Users Say Thank You to dMuze For This Useful Post: | 12blkms3 (05-03-2014), Amazon (02-28-2011), Chupacabras (12-04-2010), DingoDave (12-04-2010), madjon (12-04-2010), madvillain (12-04-2010), PunjabiPlaya (08-01-2011), smitty5788 (12-05-2010) |
(Thread Starter) | Not Ranked : 0 score and the rest
| The Following 8 Users Say Thank You to dMuze For This Useful Post: | 12blkms3 (05-03-2014), Chupacabras (12-04-2010), Ckmazdaspeed3 (12-05-2010), DingoDave (12-04-2010), faeker (12-04-2010), madjon (12-04-2010), NCZ13 (12-04-2010), PunjabiPlaya (08-01-2011) |
![]() Join Date: Aug 2010 Location: Philly
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 163
| Not Ranked : 0 score Great photo essay! |
![]() Join Date: May 2010 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 369
Groans: 58
| Not Ranked : 0 score Great photo's. That crash bar looks really small compared to the OEM. It looks great though.
__________________ [SIGPIC][/SIGPIC] 2013 CWP (DD)COBB AP| JBR HSK| JBR RSB| JBR SSP| JBR Shifter Bushings| AT Internals| Ksport Kontrol Pro Coilovers| 3.5 MAF HOUSING| 3' HTP TIP| UR FMIC| TIGS| GTX2867| EBAY 3' DP TUNE IN PROGRESS (RFINKLE2) 1999 Mazda Miata (PROJECT) (blown motor) BEGI Cast Manifold| BEGI DP| SR20 Turbo (GT2554)| Flying Miata Silicone IC Piping| Cx Racing IC| HKS BOV| TEIN SA| Harddog Rollbar|Sparco Spint V| TRmotorsports C1 15x8 |
Groans: 43
| Not Ranked : 0 score Dude, thanks for posting up the photos of the install. Yeah that bolt is gonna give that hot pipe problems. Any plans on insulating the pipe, bolt, or both to prevent further scratching?
(Thread Starter) | Not Ranked : 0 score i dont want to cut the bolt incase i need to stock out for anything. i went to autozone, and got some of that metal strapping stuff. like what they use for exhaust pipes. i just wrapped it around the hot pipe for now and secured it to the stud. thats a safe temporary fix until i heat wrap that section of pipe, or find something better. its solid now though, no more rattle.
![]() Join Date: Jun 2010 Location: Tulsa, OK
Rep Power: 10322 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,599
| Not Ranked : 0 score Wow your smiley face blocks a lot of the FMIC though. Wow. Great install pics though. |
| The Following User Says Thank You to airhunt2 For This Useful Post: | dMuze (12-04-2010) |
(Thread Starter) | Not Ranked : 0 score i considered removing it...but it would look like i needed dentures. maybe cutting or painting the insert would be better.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score install looks great.. good job wish they made one for the ms6
__________________ ![]() SU Test Pipe - HP TIP More to come.. |
![]() Join Date: Nov 2010 Location: Montréal, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,093
Groans: 58
| Not Ranked : 0 score Great pictures and that kit look's really good too bad that the smiley face blocks most of it..
__________________ Mazdaspeed3 2008.5 black mica. [SIGPIC][/SIGPIC] SRI - COBB / TIP - COBB / Accessport - COBB / RMM - TRZ / HF cat DP to come |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
__________________ |
| The Following 2 Users Say Thank You to Amazon For This Useful Post: | dMuze (12-04-2010), jack_hammer (12-04-2010) |
![]() Join Date: Sep 2009 Location: East Brunswick NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,573
Groans: 44
| Not Ranked : 0 score you should cut the plastic that is behind the smile. it will look better, and get more air to the intercooler
__________________ 2010 Black Mica Speed3 SOLD 2005 Jeep Wrangler X Impact OrangeSOLD 2015 Subaru XV Crosstrek Tangerine Orange Pearl |
Groans: 215
| Not Ranked : 0 score With some nasty spikes and uncontrollable boost
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score i think i see what you might have done there
| The Following 2 Users Say Thank You to Monotonous ONE For This Useful Post: | Amazon (02-28-2011), smitty5788 (12-05-2010) |
![]() | | #24 | ![]() |
Groans: 215
| Not Ranked : 0 score Did you contact UR about the hot pipe fitment?
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score a few logs. first is WOT, 2nd is 30mph pull, 3rd is normal driving from a stop light. I need my CP-E pump delivered this week...ive had my car 4 months, but im around 800 psi sometimes after the fmic install. these are the first logs ive posted. if they aren't done right go easy...lmk how i can make them easier to read. i havent contacted them yet. getting the pipe in place was a bit of a bitch. the coolant lines coming off the radiator made it a little tough. there is a nice open spot closer to the belts but that would be asking for trouble if the pipe moved an inch or two...so im pretty sure its in the intended place. i checked the pipe after a few runs today. that bracket i fashioned keeps it completly still...no rattle. im going to make a few suggestions to UR. one being a welded bracket which secures the pipe to the tmic stud. another for the directions to ensure the bolts holding the fmic in place aren't torqued. they need to be a little more than finger tight or the threads will strip. i needed to replace one bolt with a longer one. finally, the foam bumper piece that sits behind the smile should prob also be removed. it will help the skid plate go back on easier. the car feels more responsive. i dont have dyno numbers and im not going to use ricer math; however the cold side was cold to touch after all those runs, the car felt more responsive...no lag was detected...and even after a few pulls it still ran the same, no heat soak issue. im not going WOT until my pump is installed. wish i could monitor BAT's and Kr to give a better review.
| The Following User Says Thank You to dMuze For This Useful Post: | smitty5788 (12-05-2010) |
![]() | | #26 | ![]() |
Groans: 215
| Not Ranked : 0 score I would suggest including the key that is on the right in logworks and maybe adding a few markers so its easier to see what line is what.
| The Following User Says Thank You to smitty5788 For This Useful Post: | dMuze (12-05-2010) |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score will do. first time using that program. i had my trims and throttle position in there also but it was too congested.
![]() | | #28 | ![]() |
Groans: 215
| Not Ranked : 0 score its kind of a pain to set up and i dont think its as easy to read as logs from a dashhawk. Im going to try and use Excel for my logs so you can adjust the axes easier.
![]() | | #29 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score nice to see a fmic on a 2nd gen. sleeper, cant even tell you have a fmic unless you look really close |
| The Following User Says Thank You to forcedinduktion For This Useful Post: | dMuze (12-05-2010) |
![]() | | #30 | ![]() |
![]() Join Date: Aug 2009 Location: Albany, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 867
Groans: 39
| Not Ranked : 0 score yeah all that plastic is definitely blocking a shit load of air flow. you needz to do somethin bout that
__________________ NO! No way am I havin a dick made outta hamburger! stocking out, buy my big turbo shit here, http://www.mazdaspeedforum.org/forum/forum/f229/bye-bye-big-turbo-dreams-82241/ more to come as stock shit arrives |
![]() | | #31 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 212 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Let me know if you that works out for you. Darryl | |
![]() | | #32 | ![]() |
Groans: 214
| Not Ranked : 0 score Just got my UR in, you weren't kidding when you said the clamps are weak. I'd suggest UR send some better clamps with the kit, other than that, the core and piping looks good!
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score yea i have some tbolt clamps sitting in a box right now. i need to get those on and fab a boost leak tester. been pretty busy since xmas. hope i can reach all the couplers without removing the bumper again...maybe just taking off the skid plate
![]() | | #34 | ![]() |
There really isn't anything wrong with the clamps we provide. We've used them on applications that exceed 40psi without issue. They are used on street and race cars. The pipes ends are all bead-rolled, and we supply quality 3-ply silicone hose that's made in the USA (not the junk that comes from Asia). The worm gear clamps we supply also won't shred silicone couplers like the others out there. When installed correctly (and I stress the word "correctly") you won't have any issues whatsoever. Anything else would be overkill. Darryl Ultimate-Racing.com | |
![]() | | #35 | ![]() |
Groans: 214
| Not Ranked : 0 score Ok guys, I'll take your word for it. FMIC goes on tonight!
![]() | | #36 | ![]() |
![]() Join Date: May 2010 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Neutral : -1 score Kit looks nice, IC is large and was thinking about pulling the trigger this week. I already have UR cat back combined with Cobb DP, sound is fantastic and I love the TI tip look. I have had UR CBE for 13 months and the welds still look good. I currently have an upgraded TMIC (for sale soon) but not satisfied with the temperatures and have decided to go with a FMIC system. I was interested in the UR system but the outstanding customer service has made me rethink the direction that I might be going with the IC. Let me insert the emails from last Friday. Sorry, we wouldn't be able to do that for you. Darryl Ultimate Racing 20 Cosentino Drive Toronto, Ontario M1P 3A2 Canada On 3/25/2011 12:40 PM, I wrote: Thought of one other, the existing crash bar is where I mount my Hella Horns, could you drill some holes in the bar before it would ship. Close to US$1200 order and UR can not drill two 1/2" (12mm) holes thru the bar, now that is what I would call CUSTOMER SERVICE, EH. And CPE is getting brutalized for the cost of their system, at least they are concerned with CUSTOMER SERVICE. Z |
![]() | | #37 | ![]() |
![]() Join Date: May 2010 Location: Homestead, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,375
__________________ Precision 6466, Golden Eagle Sleeves, Headgames Motorworks Head Fastest ET: 11.776 @ 123.161(35r setup, 7000ft DA, 450hp uncorrected) 3M Matte Blue Metallic Wrapped 860whp/677wtq 2016 Ford F150, XLT, 4x4 Supercrew 2.7 V6 Ecoboost | |
![]() | | #38 | ![]() |
| Not Ranked : 0 score |
![]() | | #39 | ![]() |
We will not modify our products as per customer requests. There are just far too many things that can go wrong. I also think it's unfair of you to judge our customer service based on only one of a handful of emails we had exchanged regarding our FMIC kit. I answered several of your emails, and not once did I think customer service lacked. I provided you with pricing, dimensions, and temperature data that you had requested. I'm sorry you won't be purchasing our FMIC kit, but at the end of the day, I still stand by my decision. Darryl Ultimate-Racing.com | |
| The Following 4 Users Say Thank You to Ultimate Racing For This Useful Post: |
![]() | | #40 | ![]() |
When it is all said and done, a few extra bucks to keep the money south of border is not a big issue. Z | |
| My review of the UR Turboback (catted) for Genpu | dMuze | Ultimate Racing | 12 | 07-21-2012 08:51 AM |
| Genpu Vs Cobra | treyclash | Street Racing Stories ( Bench Racing ) | 17 | 12-04-2010 05:56 PM |
| Genpu Smoke | kngeducate | 2010 MS3 - Turbo Induction | 41 | 11-15-2010 05:29 PM |
| Ms3 vs Ms3 (Genpu) | Andrew85 | Street Racing Stories ( Bench Racing ) | 9 | 07-21-2010 08:23 PM |
