| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() Join Date: Jul 2014 Location: savannah ga... area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 17
(Thread Starter) | Not Ranked : 0 score any and all input is welcomed..
__________________ 2012 white ms3|G2 caliper paint|jbr shifter bushings|jbr short shift linkage|jbr shifter weight| matt damond 3some\3 bar map\3 port ebcs\3.5 htp intake\egr delete\coolant bypass\ets tmic\small batterybox\yellow top battery\autotech hpfp/accessport v3\corksport bpv\corksport springs\koini yellows\freektuned on 93\ UR race pipe\jbr com rear swaybar\ebc redstuff pads\ |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score Pros and cons for both, detailed in many other threads. In your case, I would go aluminum so you could change the coupler out if needed to fit the BNR or whatever turbo you go with in the future.. I'm pretty sure that is detailed as well. Based on the mods listed in your sig, I would suggest you put the money toward something else first like an Accessport and/or hpfp internals. Especially considering you need a tuning device for that intake.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
| The Following User Says Thank You to Thepedigree13 For This Useful Post: | Easter Bunny (03-18-2015) |
(Thread Starter) | Not Ranked : 0 score yes a ap3 and internals are on very top of my list.. im trying to get all my mods on paper..and make sure I'm getting good parts that I don't have to swap out later down the road. .I have been reading and researching to find out..but came up empty on these two.. I know aluminum will make more noise.. but any other benefit? silicon will have less clamps..less likely to leak.. any thing else I'm missing?
![]() Join Date: Feb 2013 Location: Broken Arrow, OK
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 651
__________________ 2013 Mazdaspeed 3 VRM Cobb AP V2 / JBR SRI / JBR TIP / CP-e xFlex RMM / Forge V1 BPV / AT Internals / eBay TP / Hypnotic Tune in progress 8K Low Beams / Optilux Yellow Fogs / Plastidipped Emblems / Painted Calipers / Rear Wiper Delete / Resonator Delete Thou shall sweep the fucking popcorn and keep dicks out of thy mouth. - Dan 3:16 | |
| The Following User Says Thank You to danmillerok For This Useful Post: | Thepedigree13 (03-18-2015) |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
| Not Ranked : 0 score It's an intake and you're on a k04...any pros or cons for either will be minimal in comparison to each other. The only benefit with the aluminum is the ability to swap couplers in case you turbo swap down the road, like mentioned above. The quality of the part is what you should be concerned with and in my personal experience, JBR has never let me down. I am currently running their 3.0 sillicone intake before the TRU revision and have zero complaints. I was able to run it with the stock battery box and stock ecu location. However, the bracing clamp was rubbing the ECU cover so I opted to relocate my ecu. Just food for thought. You should really go AP and internals before all else. Like, you don't even need to put it down on paper, it's a staple in the speed3 mod path. Also keep in mind you will need a tune on deck once you opt for a larger than stock intake. I believe Stratified has MAF cal tables to get you up and running but you should consider an E-Tune after that.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
![]() Join Date: Oct 2013 Location: Raleigh, Charlotte NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
| Not Ranked : 0 score The idea of silicone vs aluminum is that silicone keeps IATs lower before entering the turbo. But at the end of the day, your still adiabatically compressing air in a turbo that most people run out of its efficiency range, thereby producing a shit ton of heat. Even if you see a degree or two pre-turbo, it's coming out post-turbo hot as fuck, so who cares. You're not going to be able to tell a difference. Get the aluminum for flexibility to switch setups down the line.
__________________ 2013 Liquid Silver Metallic MS3 GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks TunedbyNishan Last edited by mize13; 03-18-2015 at 07:29 AM. |
| The Following 4 Users Say Thank You to mize13 For This Useful Post: |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
| Not Ranked : 0 score Normally I would be the guy to argue one over the other... but all I have to say to this one is that the aluminum makes more pssssh noises and if you upgrade turbos you can swap the coupler for a different one. The silicone is quieter and a bit more insulated to engine bay heat. Pick whichever looks better to you.
__________________ https://www.youtube.com/user/JustinBieberVEVO |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score i thought bnr uses stock sized inlet?
__________________ it's fun to do bad things |
![]() Join Date: Jan 2014 Location: Raleigh. NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 109
| Not Ranked : 0 score The beaner has a slightly larger inlet than the K04 [~1/4"]. I think some have been able to muscle a stock-sized coupler onto the BNR -- I'd suggest saving yourself the headache, and getting an appropriately-sized coupler if you go BNR.
__________________ 2011 MS3 GT3071 EWG | Cobb AP v2 | Autotech Internals | HTP 3.5 | ETS TMIC | CP-E Downpipe | CP-E Triton | DIY PnP Intake Manifold | Cobb XLE BPV | Grimmspeed EBCS | Bosch 3-Bar MAP | DM OCC | DM PMM | JBR 88 Duro RMM | JBR 88 Duro TMM | Kozmic EGR Delete | JBR TB TIG & Coolant Bypass |
| Not Ranked : 0 score My S2 fit a stock sized intake. The S3 is kinda hit and miss it seems.
![]() Join Date: Oct 2012 Location: Round Lake IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score Jbr lists the bnr with stock so not sure how to get one sized right? May just use a heat gun and warm it up before forcing it on. |
| Not Ranked : 0 score I should've clarified that I meant S3
| Not Ranked : 0 score Just went back and referenced an old invoice. Looks like I got a 2.5" to 3" coupler [for the BNR S3] when I ordered my HTP intake.
| Not Ranked : 0 score @JgamB; did your intake fit the BNR S3V2?
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score If you have no plans to go with any other turbo setup then the stock KO4, the silicone intake is the better performing intake. If you're undecided about your future turbo plans, the aluminum intake would be the better choice. Both fit excellent, we have couplers for any size turbo inlet, they are currently on sale and shipping is included if you live in the US as well. |
| The Following User Says Thank You to JBR For This Useful Post: | Gr8Speed (03-18-2015) |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Actually, I have the best answer of anyone here for you. I've run both aluminum and silicone intakes and turbo inlets. I found that silicone allows for more adjustability with respect to location within the engine bay and alignment with other parts, but this isn't really much of an issue with any legit, well-manufactured parts. So... Buy the cheapest name-brand one you can find. Peruse the For Sale section here and find something for yourself. I'm running a CP-E Nano intake and 3" CP-E TIP that I bought for a total of $150.00. I previously ran the CP-E Nano and a CS TIP for $180.00 combined. Basically, as long as you're willing to fine-tune your MAF calibration, you can run just about any pieces of pipe you want for your intake, but you damn well better make sure that whatever MAF housing you use has a MAF air straightener in it, or you're gonna have a bad time.
| The Following User Says Thank You to Vansquish For This Useful Post: | g00s3y (03-18-2015) |
| Not Ranked : 0 score Convert to SD. Run open turbo. All the honda kids are doing it.
Groans: 438
| Not Ranked : 0 score Had a Cobb SRI with stock TIP when I bought the car Then Cobb SRI & TIP Then JBR original silicone 3" (w 2.875"? MAF) Now CS full aluminum 3" I noticed a difference from the SRI & stock TIP to the Cobb TIP. But after that, really not much until I started using e85. Then I went to the 3". Just make sure your MAFCAL is good and you will be fine with whatever you get. It's more personal preference than anything, unless you will be upgrading your turbo down the line also. If you want to hear more sound, go pipe. If you want it quieter, go silicone.
__________________ All good things must come to an end... |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) | |
| The Following 2 Users Say Thank You to JgamB For This Useful Post: | JBR (03-21-2015), WAMBUSHHHH! (03-18-2015) |
| Cold air intake vs short ram intake | knarfies | MazdaSpeed 3/6 - Turbo Induction | 3 | 04-27-2010 04:15 PM |
