 Old 05-21-2013, 05:21 PM   #1
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Default 3" intake
Do you guys have one that will work with a GTX2867R?
 Old 05-21-2013, 06:35 PM   #2
King Scumbag's Avatar
Posts: 2,384   (View Stats)
3.0" Wide Path Full Silicone Intake System IAS GT
Coupler
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
 Old 05-21-2013, 06:39 PM   #3
NCspecV81's Avatar
Gtx2867 is 3 inch
 Old 05-21-2013, 06:42 PM   #4
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
If you have a 3.5" TIP get a 3.5"x3" silicone coupling. 3" intake, get a straight 3" silicone coupling...etc...
King Scumbag (05-21-2013)
 Old 05-21-2013, 06:43 PM   #5
Could you couple or adapt the 4" inlet down to three is the question tho.
Or this. Im a little toasty right now don't mind me
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 05-21-2013, 06:46 PM   #6
Dmurray06's Avatar
Groans: 189
Well if I was running a aftermarket turbo, I wouldn't run a stock size TIP. Which I believe is the only silicone intake JBR sells. Otherwise his other TIPs are aluminium.
 Old 05-21-2013, 06:51 PM   #7
The wide paths are full silicone. one has a 2.5" inlet and one with 4" inlet. You would just need a 4" to 3" coupler?
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 05-21-2013, 06:53 PM   #8
Dmurray06's Avatar
Groans: 189
God damn, your right...he changed his intakes...the WP used to be aluminum. My bad.
 Old 05-21-2013, 07:48 PM   #9
agentgordon27's Avatar
Posts: 560   (View Stats)
A 4" to 3" coupler that's made out of silicone wouldn't work.
The intake is now all silicone so you would need a aluminum reducer which would either be hard to find or if it could be found it would end up pushing the intake too far out with the extra couplers you would have to add to make it work.
The idea I had is in this thread:
GTX 2867 Installed and Reviewed
bout half way down I even have pictars for them simple folk.
Stock as fook.
 Old 05-21-2013, 08:03 PM   #10
But what if you had a coupler that could fit inside of the inlet of the intake housing (snug fit) with a tclamp around that. Then at the turbo full 3 inch clamp fitting half on the turbo half on the coupler if you could but it up to the turbo?
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 05-21-2013, 08:05 PM   #11
Are you talking an aluminum coupler or another silicone piece?
Stock as fook.
 Old 05-21-2013, 08:09 PM   #12
Any type of reducer that is the same diameter as the turbos's inlet or close that could but strait up to it. Then use a clamp that would tighten around the turbos inlet and the coupler. Half on the turbo, half on the coupler.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 05-21-2013, 09:24 PM   #13
alex_speed13's Avatar
Posts: 162   (View Stats)
alex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond reputealex_speed13 has a reputation beyond repute
Man... I went through this... i actually was thinking of even mutilating the silicon intake, but it doesn't go that way, I hope the market expands for the 2867's so Vendors see that there's a good area of opportunity. as Atvfreek said: dont mickey mouse shit.
I was thinking of cutting the inlet -> 3" to 3" aluminum copler -> Silicon 3" straight extension -> turbo. but trust me... it's a bad idea, and really propense to leaks... better search for a used JBR alluminum wp and use a coupler. Personally i'll hold, i prefer silicone
Subbed since im interested in James answer, i actually asked him in another thread.
GenPu:
Cobb AP (Freek tuned ) RMM // AutoTech int. // Jamies 3"cher/ JB TIG's// JB's shortcut// Stratified 3port ebcs// MAttdamond OCC kit// // CPE DP/Triton // ETS TMIC // HKS ssqv IV //Sure s3 track grade (surprisingly good so far)
Someday, i will just get drunk and randomly order a GTX2867 or even a ewg GTX3071, when the bill comes ill shit my pants, but when i'll install it, ill go nuts...
alex_speed13 is offline   Reply With Quote
 Old 05-22-2013, 06:17 AM   #14
We don't have anything in silicone. I do have 2, 3.5" aluminium non recirc intakes that I will let go at a great price. You can use a reducing coupler with these.
alex_speed13 (05-22-2013), Dmurray06 (05-22-2013)
 Old 05-22-2013, 04:01 PM   #15
NCspecV81's Avatar
PM'd about 3.5" aluminum intake..
Also will this require battery or ecu relocation?
 Old 05-23-2013, 07:19 AM   #16
@NCspecV81; replied to your PM.
 Old 05-22-2013, 10:56 PM   #17
Carlo1170's Avatar
Posts: 232   (View Stats)
Carlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the world
ECU relocation, But its simple. You just have to take off the plastic harness loom that is hiding underneath your intake and that will give you plenty more length to relocate. I've attached a picture at what I, and what most other people have done. Also, instead of using the HD double sided tape to secure the ECU to the fuse box I went and used the 3M Superlock "velcro" instead so that I can move it if need be. Its basically a plastic hook and loop fastener with the some really strong adhesive on the backside.
Or you can purchase the pretty 51R Battery tray from JBR (Wish this was out a few months ago when I had to replace my battery!)
2007 True Red Speed3
--Cobb TIP--Cobb SRI--Sure Shifter Bushings--Prosport Premium Boost Gauge--Block8head Gauge Pod--
2002 Honda RVT1000R RC51
Carlo1170 is offline   Reply With Quote
 Old 05-23-2013, 12:29 PM   #18
NCspecV81's Avatar
Yeah was wanting to avoid any relocation of anything. I think 3 inch is going to be the better option.
 Old 05-23-2013, 12:33 PM   #19
LumberJack's Avatar
Groans: 57
Why worried about relocating? Go 3.5 and get HTP small battery tray, works perfectly
10.36@148 Fastest Gen 2
 Old 05-23-2013, 12:36 PM   #20
Dmurray06's Avatar
Groans: 189
JBR also sells small battery tray...one stop shop.
The Following 2 Users Say Thank You to Dmurray06 For This Useful Post:
JBR (05-23-2013), LumberJack (05-23-2013)
Questions before ordering a "Path Stage II Power Intake" levon.mark JAMES BARONE RACING 37 03-26-2013 05:01 PM
Anyones 2010 "BOGGING" with intake? Mine is... DarkSpeed3 2010 MS3 - Troubleshoot/Diagnostics 21 07-10-2010 04:39 PM
Page generated in 0.38556 seconds with 27 queries
