| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
(Thread Starter) | Not Ranked : 0 score Also is 1/16th or 1/32 inch thick material available? I dont need the thermal component as much as I want an smooth transition from the im to head. If anyone can do it, its gonna be you. Lemme know.
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score Our PTFE gaskets are ported and 1/16 thick so I think you'll be good to go. |
(Thread Starter) | Not Ranked : 0 score Gasket matched? My ports are larger than the gasket.
| Not Ranked : 0 score You ports are larger then the gasket we provide or larger then the stock gasket? The ports on our intake gasket are larger then the stock ports. |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | 06Speed6 (04-15-2012), Easter Bunny (04-09-2012) |
![]() Join Date: Aug 2008 Location: Ashburn, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 305
| Not Ranked : 0 score I think he is trying to say that his ports are larger than the gasket itself, as there is not enough material remaining after he ports the gasket to match his head. I didn't think it was possible to remove that much material from the head/Intake manifold.
__________________ 2006 Black Mica MS6 - Sold 10/15 |
(Thread Starter) | Not Ranked : 0 score ^^^ what he said. My ports are too big and there isnt enough room on the oem gasket so I need something aftermarket.
| Not Ranked : 0 score I'll need a template. |
| Everyone that ordered an intake gasket, look in here! | ptperformance | Mazdaspeed3/6 General Discussion | 36 | 07-09-2009 05:40 AM |
| intake manifold gasket for speed6 | johnac08 | Mazdaspeed3/6 General Discussion | 0 | 06-23-2009 02:50 AM |
| Intake manifold gasket install | cm-jp1 | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 06-01-2009 04:31 AM |
