JBR MAZDASPEED 3/6 & CX-7 Thermal Insulating Gaskets In Stock!! http://www.mazdaspeedforum.org/forum/foru...atar4832_2.gif James Barone Racing Performance Aftermarket Parts & Accessories Thermal Insulating Intake Gasket Kit & Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit The Mazda 2.3L MZR DISI engine is assembled using paper thin metal gaskets between the intake manifold and cylinder head. The same paper thin style metal gasket is used between the throttle body and intake manifold. This design allows intense heat to be transferred to both, greatly increasing boost air temperature and robbing you of horsepower. http://www.jamesbaroneracing.com/sto...es/intk-ig.jpg The JBR Thermal Insulating Intake Gasket Kit prevents this unwanted transfer of heat thus reducing boost air temps and increasing horsepower. Constructed out of .062 virgin grade PTFE with a temperature rating of 500°F. CAD designed and ported to ensure there’s no reduction in flow. Thin enough to be effective without the risk of cracking your intake manifold. And it’s reusable too! The JBR Thermal Insulating Gasket Kit is stackable up to 4 thick while utilizing stock mounting hardware. LINK TO PRODUCT PAGE Application: Mazdaspeed 3/6, CX-7 All Kit Includes: 1 Insulating Intake Manifold Gasket 1 Insulating Intake Manifold Gasket Spacer Detailed Online Installation Instructions Free Shipping http://www.jamesbaroneracing.com/store/images/tb-ig.jpg The JBR Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit prevents this unwanted transfer of heat from the intake manifold and eliminates the 200°F coolant from flowing through it. This reduces boost air temps and increases horsepower. Constructed out of .062 virgin grade PTFE with a temperature rating of 500°F. CAD designed and ported to ensure there’s no reduction in flow and it’s reusable too! The JBR Thermal Insulating Throttle Body Gasket Kit is stackable up to 4 thick while utilizing stock mounting hardware. LINK TO PRODUCT PAGE Application: Mazdaspeed 3/6, CX-7 All Kit Includes: 1 Insulating Throttle Body Gasket 1 Brass Barbed Coupler 2 Coolant inlet caps Detailed Online Installation Instructions Free Shipping The JBR Thermal Insulating Intake Gasket Kit & Thermal Insulating Throttle Body Gasket Kit perform even better when combined with the JBR EGR Block off Kit. What’s the point in re-circulating hot exhaust gas in to a cool intake plenum? |
So for the TB bypass you just hook the 2 coolant lines together with the barb? |
Looks good jamie!! |
Quote:
Can you buy the bypass separate, or does it have to be with the TB TIG? |
this is exactly how i did my coolant bypass i think my barb is too small though...i bought 2 just in case...gotta try the other |
detailed instructions are a must, or people will be cracking their manifold left and right as they did with the sure tigs. people have a tendency to overtorque as well |
I'm so getting one of these.....TB. When are they going on sale? lol :yeah: |
Quote:
Thermal Insulating Gasket Kits |
Oh damn how did I miss this post. I have a question though, whats the benefit of selling them as stackable and not just making the thickest one possible that the stock components would allow? |
Quote:
The cost of raw PTFE in 1/4" thickness is very, very expensive; like $15-$1800.00 per 4x8 sheet. Stamping costs are increased as well. So the cost to the consumer would be too high and the gains in performance are not significant enough that the majority of guys would really benefit from it. Hope that makes sense. Thanks, Jamie |
Quote:
so what would be the point of capping off the tb, after the bypass of course....i did this with a spare piece of 1/4 inch hard line i had, but didnt cap the coolant barbs. |
Quote:
Quote:
Quick question I'm sure some people might wonder... Will these offer the same performance for a mild daily driver as for a fully bolted, BT motor? By mild, I mean a few bolt ons and maybe a tune. Or, would you need an aftermarket IC to really get the full effects? |
Bump! I missed this thread somehow, and I'm forever on the forums. Jbarone ftw. |
Quote:
so in order to take full advtange, you would have to buy each gasket x4 and stack them on top of each other? |
No...you see the most benefit with one and a little better with 2. I only tested with 2 and I know you can stack 4, so my assumption is there will be some better performance with 4. |
You need to stop coming out with stuff after I've already bought,bad timing! Already have the SURE's, but I'll buy your egr blockoff. |
should we anticipate manifold cracking problems that have plagued all of these gaskets? |
one would assume that JBR has learned from the SURE fiasco and complete dropping of the ball and fucking of atleast a dozen or so couches to include actual directions for this peice. |
Quote:
But at JBR's piece, are you including a lower spacer like SURE does. If people use two of these gaskets and crank the bottom bracket on the manifold down are customers going to get cracked manifolds. Just don't want your customer service blemished by something that is really finicky and fragile to install. |
Quote:
Thanks, Jamie |
jamie, how about a discount for buying both tigs? your detailed instructions having me finally wanting to buy them. i still have to install your egr block off kit. |
Quote:
Quote:
i refuse to believe that it doesnt make a substantial difference and if you have fucked with the intake mani before at all then its an easy install...otherwise take your time and take it slow oh...and fuck you stealth! why barb small? cause genpu? |
i pulled the trigger on both. interested to see how much the charge temp drops. |
Quote:
step # 24 (loosen rear fuel rail cover bolts)... how much do you loosen them and you don't re-tighten them, correct? i'm doing this over the weekend and don't want to get bnoon'd with incorrect / missing instructions. |
Quote:
Quote:
Thanks, Jamie |
thanks, jamie! |
If I live in a climate that can get cold from time to time, will the TB coolant bypass affect my car? |
how much for both for a speed6? |
Quote:
My last car didn't have a coolant in the TB. I don't see why this one does. |
apollo 13 fail. no one got hurt but mission failure. good news... got the tb bypass / gasket and egr block off done no problem. turbo and front of the tb looked good after 30k miles... http://i619.photobucket.com/albums/t...7/DSC04145.jpg http://i619.photobucket.com/albums/t...7/DSC04146.jpg inside tb pretty nasty... http://i619.photobucket.com/albums/t...7/DSC04147.jpg |
Pretty standard unfortunately |
| All times are GMT -7. The time now is 02:08 AM. |
