Like Tree9Likes
 Old 08-18-2011, 09:54 AM   #1
Arrow JBR MAZDASPEED 3/6 & CX-7 Thermal Insulating Gaskets In Stock!!
James Barone Racing
Performance Aftermarket Parts & Accessories
Thermal Insulating Intake Gasket Kit
Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit
The Mazda 2.3L MZR DISI engine is assembled using paper thin metal gaskets between the intake manifold and cylinder head. The same paper thin style metal gasket is used between the throttle body and intake manifold. This design allows intense heat to be transferred to both, greatly increasing boost air temperature and robbing you of horsepower.
The JBR Thermal Insulating Intake Gasket Kit prevents this unwanted transfer of heat thus reducing boost air temps and increasing horsepower.
Constructed out of .062 virgin grade PTFE with a temperature rating of 500°F. CAD designed and ported to ensure there’s no reduction in flow. Thin enough to be effective without the risk of cracking your intake manifold. And it’s reusable too!
The JBR Thermal Insulating Gasket Kit is stackable up to 4 thick while utilizing stock mounting hardware.
LINK TO PRODUCT PAGE
Application: Mazdaspeed 3/6, CX-7 All
Kit Includes:
1 Insulating Intake Manifold Gasket
1 Insulating Intake Manifold Gasket Spacer
Detailed Online Installation Instructions
Free Shipping
The JBR Thermal Insulating Throttle Body Gasket & Coolant Bypass Kit prevents this unwanted transfer of heat from the intake manifold and eliminates the 200°F coolant from flowing through it. This reduces boost air temps and increases horsepower.
Constructed out of .062 virgin grade PTFE with a temperature rating of 500°F. CAD designed and ported to ensure there’s no reduction in flow and it’s reusable too!
The JBR Thermal Insulating Throttle Body Gasket Kit is stackable up to 4 thick while utilizing stock mounting hardware.
Kit Includes:
1 Insulating Throttle Body Gasket
1 Brass Barbed Coupler
2 Coolant inlet caps
Free Shipping
The JBR Thermal Insulating Intake Gasket Kit & Thermal Insulating Throttle Body Gasket Kit perform even better when combined with the JBR EGR Block off Kit. What’s the point in re-circulating hot exhaust gas in to a cool intake plenum?
The Following 23 Users Say Thank You to JBR For This Useful Post:
atvfreek (08-18-2011), bazzarino (10-23-2011), Black Metal (08-19-2011), Ckmazdaspeed3 (09-04-2011), Dash08 (08-19-2011), daztdMS6 (08-18-2011), Easter Bunny (08-22-2011), Enki (09-05-2011), HaXiR (01-28-2015), helmetface (09-03-2011), JacksonMS30 (08-31-2011), jracer (09-02-2011), karl-hungus (08-29-2011), kunfu (08-19-2011), littleloogy (11-14-2015), Monotonous ONE (08-21-2011), RayRay (02-10-2012), shadesofgray19 (08-19-2011), Sid3wayS (11-01-2011), SLOWHATCH (08-21-2011), TexasSpeed3 (08-29-2011), wolly6973 (08-18-2011), zxhoya (05-10-2013)
Page generated in 0.60700 seconds with 37 queries
