| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() | | #41 | ![]() |
| patrick failman ![]() Join Date: Mar 2009
Rep Power: 2905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,275
Groans: 74
| Not Ranked : 0 score Craftsman 10 pc. Damaged Bolt/Nut Remover Set, Low Profile Bolt-Out Reviews - Craftsman Community
__________________ 2012 ingot silver mustang gt w/ 6 speed, 3.73 rear end, bama 93 tune, cat deletes, boss 302 oil cooler, roush cai, dynotech aluminum driveshaft, ford racing strut tower brace, dampers & springs, boss 302 sway bars, gt500 strut mounts, lower control arms & axle backs, j&m adjustable panhard bar, steeda upper control arm & 3 point braces, jlt catch can, barton short shifter & shift bracket |
![]() | | #42 | ![]() |
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score Damn failman
__________________ |
![]() | | #43 | ![]() |
Groans: 74
| Not Ranked : 0 score faliure is an excuse to run to sears and buy more tools.
| The Following 5 Users Say Thank You to karl-hungus For This Useful Post: | 86AmishMs3 (09-05-2011), b1iNkl82 (09-07-2011), rfinkle2 (10-11-2011), ScarMS3 (12-10-2011), SLOWHATCH (03-08-2012) |
![]() | | #44 | ![]() |
![]() Join Date: Dec 2009 Location: layton, UT
| Not Ranked : 0 score +1 for above comment lol!!
__________________ In progress: Engine: Built long block by Keefover. Keyed crank,keyed cams/VVT,Crower 65lb valve springs,Wiseco pistons,Manley H beam rods,AFI t3 stock location mani,Comp turbo CT4x 53-56,Kozmic 6th port PI with 2200cc bosch injectors,N2MB WOT box,Relentless ported intake mani,Kozmic oil feed line,Custom oil return line,Ramfab 3.5" intake,Ramfab alum. crash bar,Ramfab IC piping,TR10 IC,Saiko Michi and JBR dual custom catch can setup, Guardian angel v3 with 4bar map sensor,Dual Deatschwerks in-tank fuel hat with bigger pickup,-6an nylon braided fuel lines,Fuel labs FPR,SP63 3 port EBCS,Mishimoto oil cooler, HKS SSQV1,BSD,Autotech FP internals,CPE injector seals EGR delete,TB coolant bypass delete,M2 Ebay DP Suspenion/Bracing: Sonic tuning CO's revalved by Feal Suspension, QA1 600lb rear springs, 750lb front Swift springs,AWR front and rear sway bar endlinks,Whiteline RSB,SPC front adjustable ball joints,GT spec ladder brace,SU rear interior brace,NRG harness bar. Drivetrain:SS brake lines,SS clutch line,Carbotech ax6 F&R, Southbend STG 3 endurance clutch and flywheel,SU rear diff mount,SU front rear diff mount,SP63 TC caps,DSS rear axles,AWR Trilogy mounts 70A,Hubcentric centering rings,2" brake ducting F&R,TWM STS stg 1 with bushing kit Interior:Redline custom shift boot,Redline custom steering wheel cover,Redline custom ebrake handle cover Bride Stradia V.2 rep seats,Corbeau seat brackets,JBR heavy shift knob,Custom LED gauge cluster,Custom Steering column dual gauge pod,AEM wideband failsafe,AEM oil pressure gauge,Schrothe Rallye 4 harnesses,Escort 9500ix with mirror mount and hard wired with external controller,DIY ipod adapter. Exterior: STI front lip,Enkei PF01SS 17x9 +48 wrapped in Bridgestone Potenza RE-71R's 245/45/17,Full clear bra,Muteki SR48 blue locking lug nuts,RHO side plate mount,Smoked side markers, Shark fin antenna |
![]() | | #45 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold | |
![]() | | #46 | ![]() |
Groans: 74
| Not Ranked : 0 score i bought the craftsman kit (saved 5 bucks buying online) so i'll try again next week. also the black electrical connector is a fucking bitch.
![]() | | #47 | ![]() |
Groans: 74
| Not Ranked : 0 score got the ps bolt to turn using the #4 bolt remover and some more pb. will re-attack next weekend. my only remaining fears are hulking the ps pump back into place and that black electrical connector.
![]() | | #48 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
(Thread Starter) | Not Ranked : 0 score When putting the PS pump back in place grab it by the pulley; real easy to do. |
![]() | | #49 | ![]() |
![]() Join Date: Mar 2011 Location: Hampton, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 28,760
| Not Ranked : 0 score Installed both TIGs on Sunday with help from @Geo13. I just wanna say how amazed we both were with the detail of the instructions. Then again, I've never seen anything less than thorough from JBR, so it was to be expected. ![]() Didn't experience a single problem.... except for my own stupidity when I dropped a socket into the radiator. Thank god for magnets!!!
__________________ 2011 MAZDASPEED 3 BNR: 352 hp / 342 ft-lbs K04: 296 hp / 343 ft-lbs BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges |
![]() | | #50 | ![]() |
| Not Ranked : 0 score hmmmm. Contemplating this daily. |
![]() | | #51 | ![]() |
![]() Join Date: Nov 2010 Location: Hampton Roads, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,379
Groans: 107
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score DO IT @rfinkle2!! You know you want too (I know I want too).....cause after hearing @skeurton talk about his lower BAT's it's worth it...
__________________ SPONSORED BY MY WIFE- 2010 Mazdaspeed3 Black Mica (DeadPool): COBB AP Stage 2+(Custom skeurHYPNOTICton Tune), JBR TRILOGY 88D DogBone, 70D TMM & PMM, RSB, OCC, EGR Block Off, Mudflaps, TURBOSMART 50/50 BOV, Tanabe Strut Tower Bar, Moddiction Anvil, TWM Full Replacement Shifter, Fortune Auto 500 Coilovers, SPC Adjustable Camber Arms, Autotech Internals, Denso ITV24, ETS TMIC, UR Catted Down Pipe & Resonated Test Pipe, Corksport 3" Power Series Intake, CBE, GrimmSpeed 3 Port EBCS, Proto Tuning AP Holder, ProSport EVO Boost & AFR Gauge, Ultragauge Classic, Block8Head Dual Vent Pod, DDM Lows: 35w/6K & Fogs: 35w/3k HIDs, Headlight Armor Yellow Fog Overlays, some SURE stuff...still iNATORva2 Reckless By Speed + 3 Speeding = Mazdaspeed3 (no more parts and a pissed off wife) |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score It really is easy if you can read. |
![]() | | #53 | ![]() |
| Not Ranked : 0 score |
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score Whom ever you prefer. Thanks, Jamie |
| The Following User Says Thank You to JBR For This Useful Post: | rfinkle2 (10-11-2011) |
![]() | | #55 | ![]() |
![]() Join Date: Oct 2009 Location: Savannah GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 270
| Not Ranked : 0 score For us slow people Jamie, We can stack 1-4 with out any extra parts as long as we follow your instructions. If so I'll be ordering EGR and TB and 2-4 Mani Gasket kits. |
| The Following User Says Thank You to Lost hawaiian For This Useful Post: | rfinkle2 (10-11-2011) |
![]() | | #56 | ![]() |
Just a word of caution when using more than 3...In step 24 it says to loosen the 2 rear fuel rail cover bolts. I would suggest removing them, then complete the remainder of the installation. Then reinstall the 2 rear bolts ensuring that they line up and thread in properly. If they don't you can remove the front 2 fuel rail cover bolts, and enlarge the two rear cover holes with a file or drill until the bolts line up and thread properly. It's super easy. You can leave the rear two bolts out if you wish as well. Thanks, Jamie | |
![]() | | #57 | ![]() |
![]() Join Date: Dec 2010 Location: Whitehall PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 869
Groans: 56
Groaned at 37 Times in 18 Posts
| Not Ranked : 0 score hey jamie any pics of how thick are they? and installed?
__________________ 2007 CBM MS3 GT 66K Mods: --Cobb SF SRI--Corksport TIP-- Speed Daddy FMIC Piping w/ TR8 Core--CPE 75A RMM--Test Pipe--Both res delete--TWM Short Shifter--Custom Fabric wrapped A pillars & Side Pillars--Gunmetal PC Genpu Wheels--Mazdaspeed Red Calipers (front & rear)--Laminx Fog Overlays--Foglight Mod--3M Gloss Black Roof--Custom Mudflaps--Evil Flying M--CPE Triple Gauge Pod--Propsort Boost-Oil Temp-Oil Pressure Gauges--Prosport Sammich Plate--SU Oil Spin On Conversion--Magnetic Drain Plug--Raceland Coilovers--SPC Rear Camber Arms--15MM H&R Spacers--Hawk HPS pads--Turbosmart Plumb Back BPV---- New VVT as of 50K miles Thanks Young MazdaNew K04 Turbo as of 57K miles Thanks Young Mazda |
![]() | | #58 | ![]() |
Groans: 56
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score The only pictures I have are in the install instructions... www.jamesbaroneracing/support |
![]() | | #60 | ![]() |
![]() Join Date: May 2009 Location: Duarte, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 472
| Not Ranked : 0 score just did the tb tig and coolant bypass...10* of reduction in bats already. how big of a difference is seen if two gaskets are stacked vs one gasket?
__________________ -John ![]() | Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns | |
| The Following User Says Thank You to JohnMS3 For This Useful Post: | redboat (02-27-2014) |
![]() | | #61 | ![]() |
![]() ![]() Join Date: May 2011 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 336
Groaned at 33 Times in 10 Posts
| Not Ranked : 0 score Just ordered TB TIG. Thanks Jamie!
__________________ 2012 Toyota Tacoma |
| The Following User Says Thank You to NinjaT1985 For This Useful Post: | JBR (11-30-2011) |
![]() | | #62 | ![]() |
![]() Join Date: May 2011 Location: Chicago, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score I ordered and recieved my TB TIG. I can't wait to install it. Thank you Jamie.
__________________ MazdaSpeed 6 DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB. |
![]() | | #63 | ![]() |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 566
| Not Ranked : 0 score just ordered both today installing with new injector seals
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
| The Following User Says Thank You to speedms6 For This Useful Post: | JBR (01-31-2012) |
![]() | | #64 | ![]() |
![]() Join Date: Jul 2008 Location: Houston
Rep Power: 472 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| Not Ranked : 0 score It seems to me that using a hose barb for the bypass is a waste of time when you can buy 2 feet of 5/16" hose for less and not have a splice.
__________________ 360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust |
![]() | | #65 | ![]() |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
| Not Ranked : 0 score Or you can just reuse the stock line, no $$ necessary. |
| The Following User Says Thank You to wolly6973 For This Useful Post: | SLOWHATCH (03-08-2012) |
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score You're actually buying the gasket and getting the caps and barbed coupling for free. That Pretty cheap. |
![]() | | #67 | ![]() |
| Not Ranked : 0 score Nothing is "free". You presumably would charge a buck less or so if it didn't come with the barb. But I know you give good products and good prices. So its not a big deal. I think I'm more saying, in general, don't splice hoses if you can just as easily not.
![]() | | #68 | ![]() |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score I just ordered an intake mani tig. How does this compare in thickness to the 1/16" thick gaskets? Did a google search but it says its some weird number like 31/500???? |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Bump. I wish I hadn't waited this long to install the tig (for the intake manifold). Initial look @ BAT's show @ least a 10* drop in the gap between BAT's and IAT's. |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #70 | ![]() |
| Not Ranked : 0 score I told you!
| The Following User Says Thank You to skeurton For This Useful Post: | rfinkle2 (09-17-2012) |
![]() | | #71 | ![]() |
| Not Ranked : 0 score I listen to you very carefully! I just bitched out until this weekend when I saw the intake manifold debacle. To anyone wanting to install these, it really is pretty straightforward and assuming you follow the directions, you'll be happy you put the time in to install. @skeurton, I may even get really ballsy and put 2 on! |
![]() | | #72 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score I have mine waiting for whenever I want to/ have time to do seals and valve cleaning while I'm in there tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() | | #73 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thermal gaskets yield the best performance for the investment. |
| The Following User Says Thank You to JBR For This Useful Post: | Zdraveca (09-21-2012) |
![]() | | #74 | ![]() |
![]() Join Date: May 2009 Location: Melbourne, Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
| Not Ranked : 0 score installed TB TIG installing more JBR parts today
__________________ 06 Black MPS3 Sport Pack - Australia edition Cobb AP (RichTune e85 / 98 maps) - Autotech HPFP Internals, JBR WP, CorkSport DP, Catback, Forge v1 BPV, Denso ITV22, PG FMIC Pipes JDM Core - TWM SS, PG Shift Weight, JBR Heavy Knob - JBR 88 Trilogy - JBR Rear Sway bar, Yellowspeed Coilovers, Centric Slotted/Drilled Rotors, Hawk HP+ pads, RX8 gen1 wheels - HTP Battery Tray - JBR EGR delete, JBR TB TIG - Spin-on oil convert - Polarised HU Screen EXE-Crew |
| The Following User Says Thank You to KRNAGE For This Useful Post: | JBR (09-22-2012) |
![]() | | #75 | ![]() |
| Not Ranked : 0 score Well, hate to be a spoil sport, but, do you actually have any dyno reads to back that up? I rather doubt you do. On one hand, yeah, I think it is indeed generally worth it to have. Particularly on our cars. It does dramatically lower apparent BATs. But, the change is 99% apparent rather than real. The issue is, on our cars, the BAT sensor is attached to the IM. So, a hot IM raises the measured BAT a great deal. But, in reality, the air contact time with the IM is negligible and therefore actually transfers negligible heat to the air. So, it is kinda neat how dramatically cooler the IM is after installing a gasket. And it is good to improve the accuracy of the BAT. Which could possibly lead to some performance gain. But if you think you are actually lowering your BAT (as opposed to mearly lowering the readings) then you are mistaken.
![]() | | #76 | ![]() |
| The Following User Says Thank You to JBR For This Useful Post: | exentix (09-26-2012) |
![]() | | #77 | ![]() |
Groans: 63
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." | |
![]() | | #78 | ![]() |
| Not Ranked : 0 score Fair enough. But, many people think they are actually getting lower BATs. If, indeed, the more accurate measurement does result in more power, then great. But, I'd still like to see the claim backed up. Jamie just stated it like it is a fact that you will get performance gain. Perhaps you and he are right and you do. Fine, great. But, do you know that for a fact if you haven't dyno'ed it?
![]() | | #79 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score Well either way it works. If it cuts down actual heat or just helps cut down the amount of heat that actual reaches the sensor. The BATs the sensor reads are less which leads to more power. We all know that high BATs kill this car power wise. Thats no secret. @jbarone Count me in for a order!
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
![]() | | #80 | ![]() |
| Not Ranked : 0 score Don't get me wrong, I think it is likely worth having, and I have one. I currently run one "from another vendor" but only because I bought it before Jamie had his.
| Display Modes | |
