| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() Join Date: Apr 2012 Location: Nashua, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score However I noticed lately that it has loosened up again, not as long as stock but almost there. I played around with the plate over the weekend, but it does not appear to have shifted or bent the plate/bolt and I could not get it to tighten back up. I am wondering if I stretched a cable or if anyone else has ideas as to what could cause this to happen? I am pretty sure I could not stretch a steel cable... Any ideas? |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score I noticed this when i installed my SURE stuff. felt really tight then loosened up over a week or so... When I mean loosened up, I mean the cage doesn't feel as tight anymore. It is still as short as before. Maybe your just used to it and now it doesn't feel short. Try removing and drive with it stock. I'm sure you will re-appreciate the plate! Or you can get another short throw for in the cockpit, like from CS. Now that is a short shift!
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? Last edited by jm211; 03-08-2013 at 06:56 PM. |
![]() Join Date: Dec 2012 Location: Bel Air, MARYLAND
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 871
| Not Ranked : 0 score This also happened on my TWM in my TC. Retighten and you should be fine.
__________________ |
![]() Join Date: Apr 2009 Location: Somerset NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,706
| Not Ranked : 0 score Or follow the how to on adjusting
__________________ ~~~NJ Nator OG~~~Then AND Now, Just Better~~~ ![]() |
![]() Join Date: Jul 2011 Location: Glendale Heights, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 507
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score Get the twm full replacement and I guarantee you'll feel like your shifting a miata. Mine is so short and nice. You do need to relighten and adjust things every so often though. Sent from my iPhone using Tapatalk 2
__________________ Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC// |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
| Not Ranked : 0 score You're probably just used to it now. The only thing I'd check is to make sure the riser/stud bolt is nice and tight and not loose on the plate. Otherwise, it's probably just you getting used to it.
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
| The Following 3 Users Say Thank You to Stealth01 For This Useful Post: |
| Not Ranked : 0 score Retightening helps. Red loctite is needed for sure. |
| Short Shift Plate Problems | SleeperHatch | JAMES BARONE RACING | 37 | 08-15-2011 01:22 PM |
| Ok, JBarone Short Throw Shift Plate (STSP) is TOTALLY WORTH IT! | goathearder | 2010 MS3 - Engine, Transmission & Driveline | 16 | 06-24-2010 11:47 AM |
| Snazzy short throw shift plate | darth vader | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 09-25-2009 03:19 PM |
