 Old 11-17-2011, 01:39 PM   #1
Default JBRFMM?
so one of the best mods i have done to date is the turbine tech front motor mount. anyone else who also has this would agree it keeps the engine straight planted because most of the engine movement is front to back and the RMM just doesent do enough to calm it down.
being it has such a high price tag from TT (~$300) and they are few and far between in used condition, would you be willing to pick up this task and do a redesign in JBR super awesomeness?
MS6:
MS3:
The Following 15 Users Say Thank You to superskaterxes For This Useful Post:
4G63 (11-17-2011), 86AmishMs3 (11-21-2011), AJ713 (12-05-2011), BobtailedSnail (11-17-2011), DingoDave (11-22-2011), greenespeed (11-21-2011), JBR (11-18-2011), JmkC (11-18-2011), josurr (11-21-2011), MGM_GT3 (11-29-2011), myt_tuf1 (11-17-2011), robertof (11-23-2011), Rokusek (11-28-2011), ryno077 (11-20-2011), speedms6 (11-17-2011)
 Old 11-17-2011, 01:48 PM   #2
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
Do many people even have enough power to even worry about needing a FMM? It's something I too would like to see developed but didn't driver311 run 11s in his MS3 with all stock motor mounts? Minus the new bushing i believe he said he had in his RMM
Do you have any pics of it installed on your car? That would be something I'd like to see
2003 Evo VIII
 Old 11-17-2011, 01:50 PM   #3
Alpha's Avatar
Posts: 3,711   (View Stats)
Dude, the FMM made WORLDS of difference on my MS6 when all I had was a SRI.
I can only speak for the 6, but this was one of my best driveline mods I've done by far.
4G63 (11-17-2011)
 Old 11-17-2011, 02:55 PM   #4
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Been looking into for a while
Skreets be calling...
 Old 11-17-2011, 05:36 PM   #5
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
oh gawd not again...
more JBR stuff I would have to buy...
The Following 3 Users Say Thank You to breakfstincluded For This Useful Post:
AJ713 (12-05-2011), DingoDave (11-22-2011), kritz (11-17-2011)
 Old 11-17-2011, 06:25 PM   #6
laxplayermjd's Avatar
Posts: 779   (View Stats)
sounds like a great idea to me. my cp-e fail rmm doesnt keep mine planted. So i picked up a awr trans mount in hopes to help.
JBR needs more mounts for 6!
laxplayermjd is offline   Reply With Quote
 Old 11-17-2011, 06:36 PM   #7
Masterofnone's Avatar
Posts: 142   (View Stats)
Masterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the worldMasterofnone is the leader of the world
I'm interested too, subbed for word from Jamie.
Acceleration = crack you do with your right foot!
Last edited by Masterofnone; 11-17-2011 at 06:36 PM. Reason: I can't freakin spell!!
Masterofnone is offline   Reply With Quote
 Old 11-18-2011, 07:28 AM   #8
Hmmmm.....Interesting. After the trans mount and a couple of side projects I have that should be wrapped up by mid December I'm going to take a break, I'll take some time to look at several items I plan to tackle for next year. I'll add this to that list.
Thanks for bringing this to me.
Jamie
The Following 10 Users Say Thank You to JBR For This Useful Post:
AJ713 (12-05-2011), BobtailedSnail (11-21-2011), breakfstincluded (11-18-2011), DingoDave (11-22-2011), Easter Bunny (11-18-2011), robertof (11-23-2011), Rokusek (11-28-2011), superskaterxes (11-18-2011), Vader (11-21-2011), wolly6973 (11-21-2011)
 Old 11-18-2011, 07:36 AM   #9
FY"IED"N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
in for possible fmm and tubular EM
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
The Following 2 Users Say Thank You to dMuze For This Useful Post:
AJ713 (12-05-2011), superskaterxes (11-18-2011)
 Old 11-21-2011, 03:04 AM   #10
eppopipe's Avatar
Posts: 601   (View Stats)
eppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the worldeppopipe is the leader of the world
Interested if you can make it work well with FMIC's
2010 Blue Mazdaspeed3
CP-E Nano Intake - JBR 88D Trilogy - Cobb AP - Sure Shortcut - 20% tint - Blox 490g shift knob - Big stereo system (WIP) - Singer 400AMP alternator - Turbosmart dual port - KDM V2 FP Internals - 10k DDM HID's (lows) - 12k HID's (fogs) - UR CBE (no mufflers) - Vibrant Ultra Quiet resonator - CP-E TMIC - UR Resonated Test Pipe - Dano Perm Tune - Blockhead Dual Gauge Vent Pod (painted) - Aeroforce Interceptor x2 - 19 inch RonJon Inspyres
eppopipe is offline   Reply With Quote
The Following 2 Users Say Thank You to eppopipe For This Useful Post:
JBR (11-21-2011), skeurton (11-22-2011)
Page generated in 0.31640 seconds with 28 queries
