Like Tree13Likes
 Old 10-06-2014, 01:54 PM   #41
Originally Posted by ilight View Post
Just curious if anyone else has had "issues" getting into first gear after installing this plate?
I needed to double clutch to get into first gear half the time and never had to do that before the plate. I uninstalled it and I have no problem with first again. Thoughts? I wonder if it moves the shift lever just a little too much to the right, but I don't know how much forgiveness there is in that mechanism...
There is an adjustment for gate alignment.
 Old 10-06-2014, 06:24 PM   #42
ilight's Avatar
Posts: 20   (View Stats)
ilight is just really niceilight is just really niceilight is just really niceilight is just really niceilight is just really nice
Maybe you should include those instructions with the product? I wasn't aware that could be an issue when I bought it... Thanks for the tip though.
ilight is offline   Reply With Quote
The Following User Says Thank You to ilight For This Useful Post:
breakfstincluded (10-18-2014)
 Old 10-06-2014, 06:30 PM   #43
The instructions are in the support section of our website and have been for 4 years.
 Old 10-07-2014, 05:49 AM   #44
ilight's Avatar
Sorry, I'm not an expert at everything automotive (always trying to learn). All I had questioned was whether or not it might have been a good idea to mention that the use of this plate might require the shifter to be adjusted. As a fellow small business owner, I know the importance of keeping my clients/customers happy. I just thought you could have been a little more friendly with your advice (rather than standoffish). I'm sorry for questioning your companies professionalism. Take care.
jdmage_mx5 (10-07-2014)
 Old 10-07-2014, 04:13 PM   #45
I respond with help to your problem in under two minutes and you respond with...
and I'm being standoffish? You can't help anybody no a days.
Philthyphil (08-19-2015), SarcasticOne (10-07-2014), volcomcinematic (10-14-2014)
 Old 10-18-2014, 12:27 PM   #46
Badger_'s Avatar
Posts: 1,572   (View Stats)
Badger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the worldBadger_ is the leader of the world
Bought this along with solid shifter bushings. Night and day. I didn't realize how far gone my lockout was until I slapped this bad boy in. No wonder my 1st and 2nd shifts were so out of whack. I was all the way in reverse territory. Thanks for the product! Now I'm eyeing up that short shifter. Hmm...
2007 MS3
Injen SRI | CS TIP | CS TP | 3" TP-Back Straight Pipe | AT Internals
All Mounts | Koni Oranges | Eibach Springs | Moog Endlinks
Thermal Insulating Gaskets | TB Coolant Bypass
AP V3 | FreekTune | Russian Dashcam Mod
Badger_ is offline   Reply With Quote
 Old 11-23-2014, 05:41 PM   #47
FenixTX717's Avatar
Posts: 246   (View Stats)
FenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant futureFenixTX717 has a brilliant future
Will be ordering this and base bushings this weekend!
FenixTX717 is offline   Reply With Quote
 Old 11-23-2014, 08:47 PM   #48
Djohns's Avatar
Posts: 3,944   (View Stats)
Hope the gen pu comes out soon! like very soon. Had alot of notchy feeling in my shifts so I checked out the shifter and found plastic shavings all caught in the grease
 Old 04-13-2015, 07:54 AM   #49
ItsNox's Avatar
Posts: 3,076   (View Stats)
Damnit I need this for the MS6 . Should i go ahead and squash those dreams now? Or is there a chance in hell this will be made for the 6?
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
veritas-truth (04-13-2015)
 Old 04-16-2015, 09:24 PM   #50
TJ446's Avatar
TJ446 is a jewel in the roughTJ446 is a jewel in the roughTJ446 is a jewel in the rough
Just received mine today. Well made and perfect fit. Takes about 10 min to install and a slight adjustment of the shifter cable. Thanks JBR! Putting it into reverse is solid as well as the shift from first to second. My original plastic wasn't worn too much either.
TJ446 is offline   Reply With Quote
 Old 05-01-2015, 12:50 AM   #51
sds86's Avatar
Posts: 2   (View Stats)
sds86 is an unknown quantity at this point
Default 2012 shifter problems
hi everyone! i am brand new to the mazda world. i just bought a 2012 MS3 and i absolutely love it!! the only problem i have with it is the reverse lockout does not work so as you all know, it will shift right into reverse without pushing on the shifter :/. i saw the part from JBR to fix this problem but then realized it said its only for 07-09. my question is, will that part work for my '12 or is there another part i need that im not seeing? any and all help would be HUGELY appreciated. thank you!!
sds86 is offline   Reply With Quote
 Old 05-01-2015, 02:55 AM   #52
Spec's Avatar
Posts: 4,472   (View Stats)
Um... Do you not have a warranty?
 Old 05-01-2015, 05:44 AM   #53
frothy's Avatar
Posts: 1,067   (View Stats)
There's a different part for the 2nd Gen. Oddly, I only see it available as a package deal from JBR along with the adjustable short shifter for some reason.
@jbarone; is the 2nd Gen MS3 gate guide available for purchase on its own, or is it only compatible along with the short shifter?
 Old 05-01-2015, 06:31 AM   #54
sds86's Avatar
I'm not sure actually. I bought it from a private seller. I'll have to ask him about that. however, if I don't have a warranty where do I find The part I need??
 Old 05-01-2015, 07:02 AM   #55
We have it available but it only comes with our GEN 2 short shifter. The gate guide itself is not compatible with the OEM shifter.
frothy (05-01-2015)
 Old 08-18-2015, 07:16 AM   #56
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
I was just looking at my OEM shifter yesterday and noticed all the wear from the reverse lock out pin... I was wondering if someone made this and BAM JBR does.
You know.... Moose stuff
 Old 10-24-2015, 03:08 PM   #57
djrich26's Avatar
Posts: 39   (View Stats)
djrich26 has much to be proud ofdjrich26 has much to be proud ofdjrich26 has much to be proud ofdjrich26 has much to be proud ofdjrich26 has much to be proud ofdjrich26 has much to be proud ofdjrich26 has much to be proud ofdjrich26 has much to be proud of
Installed mine last night. Smooth as butter.
JBR likes this.
djrich26 is offline   Reply With Quote
The Following User Says Thank You to djrich26 For This Useful Post:
JBR (10-24-2015)
 Old 10-24-2015, 11:34 PM   #58
SeeMeGovan's Avatar
Posts: 945   (View Stats)
SeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the worldSeeMeGovan is the leader of the world
Had mine in for around 3 months now, great cheap & easy mod. JBR, you make my shifting feel so gooooooooood
NATOR-WA 'GOVAN'
'07 Sunlight Silver Mica MS3 GT
JBR SRI + TIP + 88a RMM + SSP + SSB + Giant red knob + Reverse lock-out guide
Michelin Pilot Sport A/S 3 215/45 R18 | Damond OCC | ebay Catless TP
Defi Red Racer 52mm boost gauge | Torque Pro Android App Dash Install
ebay All white LED bulbs + Custom LED strip hatch lights | 15% Tint + 5% Visor
Pending installs: JBR EGR Delete + TB TIG | Stealthbox w/ Kicker & amp | Ford magical tranny jizz
SeeMeGovan is offline   Reply With Quote
 Old 01-16-2017, 08:21 AM   #59
Get Guided!
 Old 05-25-2017, 04:20 PM   #60
Wolfeman11781's Avatar
Posts: 32   (View Stats)
Wolfeman11781 is a splendid one to beholdWolfeman11781 is a splendid one to beholdWolfeman11781 is a splendid one to beholdWolfeman11781 is a splendid one to beholdWolfeman11781 is a splendid one to beholdWolfeman11781 is a splendid one to beholdWolfeman11781 is a splendid one to beholdWolfeman11781 is a splendid one to behold
Get Guided!
Do you have a plate for the MS6 yet?
Wolfeman11781 is offline   Reply With Quote
 Old 05-26-2017, 05:36 AM   #61
We do not and there's no plans to make one.
New Product Release !! Big Brake Caliper Kit for the Mazdaspeed 6 CorkSport CorkSport 57 05-31-2014 07:21 AM
Product Release! CorkSport Mazdaspeed 3 and Mazdaspeed 6 Brake Pads CorkSport CorkSport 54 03-07-2014 07:50 PM
Page generated in 0.43831 seconds with 33 queries
