| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() Join Date: Mar 2012 Location: Chicago suburbs
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
(Thread Starter) | Not Ranked : 0 score I recently bought and installed the JBR powerpath stage 2 on my 2012 speed3, first mod, and I love it to death. Jamie/Jennifer provided great customer service. The install guide is awesome, far better than some competitors, and it went without a hitch. Question: The install guide leaves the furthest upstream bits of the factory intake installed, not sure what to call them, air collector and hose? See attached picture, green circle, shows the hose i removed, but I left in the furthest upstream plastic piece (not pictured). Is it best to leave those installed? I see that it would direct airflow to the filter, but I was thinking that the hose itself was pointed slightly down. Leaving only the initial air collector/deflector will still generally direct ram air at the air filter. I can get some better pictures later if it helps, i stole the attached from JBRs install guide: http://jamesbaroneracing.com/support...structions.pdf Thanks! Last edited by classybum; 06-04-2013 at 09:53 AM. Reason: lost attached pic |
| The Following User Says Thank You to classybum For This Useful Post: | JBR (06-04-2013) |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Correct me if I'm wrong, but that hose in the green circle shouldn't be part of the OEM intake system at all...
(Thread Starter) | Not Ranked : 0 score It's definitely part of the stock intake system. It connects directly to the factory airbox. You can also see it in step 3 and 6 of the instructions linked above. |
| It's an MS3 thing. My factory air-box had only one ingress and one egress, and the ingress was located in the driver's side wheel well. There was no "ram-air" intake hose leading to the grill.
![]() Join Date: Jan 2013 Location: Sanford, Fl
Rep Power: 241 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score I took it out when I installed my intake, just seemed to be in the way and looked out of p lace without the factory airbox
__________________ VIP, Little over $2 a month to watch unlimited couches getting fucked 2013 MazdaSpeed3 w/Tech: JBR RSB, 80 Duro RMM, Shift Knob, Stage II Intake, ATP Catless Downpipe, FMIC, SSP: Autotech Internals SS Performance Group Mustang Dyno 301/320 Tuned by FLOWTUNED |
![]() Join Date: Sep 2012 Location: Orlando, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,140
| Not Ranked : 0 score You can remove it. Just leave the larger section of the tube as it has clips to hold some cooling lines to the radiator support
__________________ Black Mica 2013 Mazdaspeed 3 w/ tech GTX3076r EWG | CP-E ΔCore | CP-E Triton | CP-E LTRmani | CP-E DP AUTOTECH HPFP | HTP 3.5" | GFB RESPONS GRIMMSPEED EBC | CORKSPORT SSP | K-SPORT COILS JBR CAMBER ARMS | JBR SWAY BAR | JBR MOUNTED JBR TIGs | JBR ERG | JBR 51r TRAY |
![]() Join Date: Dec 2011 Location: Central PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 221
| Not Ranked : 0 score I left mine installed for a long time and then removed it last week. It is used to get fresh air to the stock intake box but it is not needed on the JBR intake. Mine was actually scrapping up against my Corksport intake so that is why I took it out but I don't think it will do that to the JBR intake.
__________________ 2014 Snowflake White Pearl Mazda 3 2.0l 6spd Hatchback 2012 Black Mica Mazdaspeed3 - Sold ![]() 2004 Strato Blue Mazda 3 2.3L 5spd Hatchback - Sold |
![]() Join Date: Mar 2013 Location: Sioux City, IA / Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score I was pondering that same thing the other day. Decided to just leave it attached on the off chance I need to stock out for some reason. One less thing to put back.
__________________ 2013 Black Mica MazdaSpeed 3 COBB AccessPORT // JBR Power Path Stage II SRI // AutoTech HPFP // CP-E xFlex RMM Stage II // JBR Short Shift Plate RSB// JBR Solid Shifter Bushings // H&R Springs // CorkSport RSB |
| Sideswipe Magnet ![]() Join Date: Aug 2012 Location: Clearwater, FL
Rep Power: 2827 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,163
Groans: 332
| Not Ranked : 0 score Off topic, but WTF is up with your avatar? Lol.
__________________ I would love to change the world, but they won't give me the source code. // Logic never changes, just the syntax. // To be the best, you've got to beat the best. Black Mica 2008.5 Mazdaspeed 3 GT // Totaled by 18 wheeler // rfinkle2 pump toon 309 HP - 327 TQ // E85 toon 336 HP - 357 TQ // Too many mods to list Emerald Green 2002 Miata Mods: Koyo 37mm Radiator // Tein Street Flex Coilovers // Flyin' Miata Front and Rear Sway Bars // 949 Racing Endlinks up front // 15x8 949racing 6UL Wheels // Toyo R1R tires // Hard Dog Roll Bar Waiting list: Full vinyl wrap Events: EMWNM '13'14 // MME '13'14 // MNM '14 // NATOR FL BBQ '13'14 LynzeCs bottom bitch. I shall call LynzeC my sloot and she will be mine and she shall be my sloot. Come on, sloot. Come on, little sloot. |
__________________ Black Mica 2013 Mazdaspeed 3 w/ tech GTX3076r EWG | CP-E ΔCore | CP-E Triton | CP-E LTRmani | CP-E DP AUTOTECH HPFP | HTP 3.5" | GFB RESPONS GRIMMSPEED EBC | CORKSPORT SSP | K-SPORT COILS JBR CAMBER ARMS | JBR SWAY BAR | JBR MOUNTED JBR TIGs | JBR ERG | JBR 51r TRAY | |
Groans: 332
| Not Ranked : 0 score Lol... never lived in an apartment with a loud ass neighbor toddler?
![]() Join Date: Jan 2013 Location: South Boston, MA
Rep Power: 1402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,475
| Not Ranked : 0 score WTF is the name of that movie? Isn't it "Coming to America" or something. Dude just goes around murking fools lol.
__________________ 07 BLACK MICA MS3 PATTY/JEFF BUILT MOTOR BNRS3V2 349/344 VD 93 FREEKTUNE E25 382/375 GSD DynoJet 141020 STOCK BLOCK FREEK KORN TUNE 335whp/356wtq ENM 14 K04 ~ Ordnance, Droppn' Warheads of Foreheads Since 1922 ~ BOSTON STRONG |
Groans: 332
| Not Ranked : 0 score Haha nope!
| The Following User Says Thank You to Tremmy2 For This Useful Post: | Kyle Undefined (06-04-2013) |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score In SRI mode I left the factory ducting in place to direct fresh cool air at the filter. In CAI mode it probably won't help much. |
| The Following User Says Thank You to JBR For This Useful Post: | classybum (06-07-2013) |
![]() Join Date: Oct 2009 Location: Lynbrook, NY
| Not Ranked : 0 score I took the entire piece out and it does help bring down the Intake and BAt's as air now passes directly over the intake manifold. Also I have a FMIC and took out the scoop from the hood and you will be amazed how much more heat comes out now. One last thing if you decide to leave that piece of the OEM intake you could get the new Cobb SRI box that utilizes that section and acts as a ram air. Just my 2 cents enjoy the new intake!!
__________________ Mods: 35% Tint // OEM Window Visors / 8,000K HID Headlights & Fogs / Ultimate Racing High Flow Cat DP, Catless TP & CBE / CPE Full Replacement Fuel Pump / Cobb SRI, TIP & AP (Custom Tuned by Cobb & VTR / CPE FMIC / Jbarone Stage 2 Shift Kit w/Knob / Ford Motorcraft Transaxle Fluid / NGK Spark Plugs / Sure Torq 3 90 Duro RMM / JBR 88 Duro Side/Pass. Mounts / JBR Rear Sway Bar (Red) / Koni Yellow's W/Corksport Lowering Springs / Hankook V12 tyres / Dashdaq / JBR AP mount. |
| The Following User Says Thank You to Turbojoe For This Useful Post: | classybum (06-07-2013) |
![]() Join Date: Mar 2010 Location: BOCA RATON FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 524
Oem intake ducting meaning the one with the round end. That's the one i removed. The square one that clips to the radiator housing I left in. IAT's (under hood temps) got hotter when I removed it so I re installed it.
__________________ 2018 Audi S6 Prestige. APR Tuned 575 AWHP (current) 2017 Audi A4 APR tuned 315 AWHP (sold) 2014 IS350 (sold) 2013 MS3 Stage2 E85 (sold) 2011 MS3 Stage2 (sold) | |
| The Following User Says Thank You to warlord For This Useful Post: | classybum (06-07-2013) |
| Not Ranked : 0 score God Bless America or some such. Sent from my HTCONE using Tapatalk 4 Beta
__________________ 2013 Black Mica MazdaSpeed 3 COBB AccessPORT // JBR Power Path Stage II SRI // AutoTech HPFP // CP-E xFlex RMM Stage II // JBR Short Shift Plate RSB// JBR Solid Shifter Bushings // H&R Springs // CorkSport RSB Last edited by Tremmy2; 06-06-2013 at 01:37 PM. |
| James Barone Power Path SRI / TIP | bhamitgeek | JAMES BARONE RACING | 12 | 05-19-2013 03:26 PM |
| Questions before ordering a "Path Stage II Power Intake" | levon.mark | JAMES BARONE RACING | 37 | 03-26-2013 05:01 PM |
| JBR Power Path Stage 1 SRI | swerv0428 | JAMES BARONE RACING | 0 | 03-08-2013 10:54 AM |
| Stage 2 -Mod Path Dilemma | J_Logik | Gen2 MS3 General Discussion | 40 | 02-14-2012 05:31 PM |
| GenPu's factory fuel cut factory tune psi (relative pressure) | WRX_Fan_0717 | 2010 MS3 - ECU Computer Tuning | 1 | 03-09-2011 11:14 PM |
