| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() Join Date: Nov 2014
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 18
![]() ![]() Join Date: Dec 2011 Location: San Marcos, TX
Rep Power: 692 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,138
Groans: 38
__________________ 06 MS6 & 06 MS6 [SIGPIC][/SIGPIC] The beauty is the beast Daily driven | |
| The Following 2 Users Say Thank You to derek13p For This Useful Post: | hatchedspeed3 (12-04-2014), Speedracer69 (12-03-2014) |
It's wired like that. Intake mani and intake is blocked off, valve cover runs to the top of the T which connects with the PCV to the bottom port of catch can and then the top port on catch can is obviously the small k&n VTA filter | |
![]() Join Date: Apr 2013 Location: Chattanooga, TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,760
Groans: 42
| Not Ranked : 0 score You may have a bigger issue here if your oil level is dropping that quickly. The OCC shouldn't be getting THAT much oil through it.
__________________ Coming at ya with all 297/359 POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP ECU: self-tuned HANDLING: JBR RSB (Middle Setting) RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc. RADAR: Passport Escort 9500ci |
| The Following User Says Thank You to chaser27 For This Useful Post: | Speedracer69 (12-03-2014) |
Groans: 38
Might try out a compression check.
| The Following User Says Thank You to derek13p For This Useful Post: | Speedracer69 (12-03-2014) |
![]() Join Date: Sep 2013 Location: Albany, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
| Not Ranked : 0 score any loss of power? I'd do a compression test. weird issue
__________________ ![]() Built and stuff Most recent dyno: 559.7WHP 531WTQ |
| The Following User Says Thank You to MattyP617 For This Useful Post: | Speedracer69 (12-03-2014) |
| Not Ranked : 0 score Might see if the PCV valve is stuck open.
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | daafisch (12-03-2014), Speedracer69 (12-03-2014) |
(Thread Starter) | Not Ranked : 0 score No problem feel great, freek never mentioned anything weird before catchcan so I'm not sure what the deal could be, I thought about it being the pcv just sucks I have to take the intake mani to replace such a small piece Also my oil never drops that quickly when I don't have the catch can the reason it's getting drained so quick is because the catch can is sucking it all up im assuming( possibly through pcv) like mentioned above. |
| Not Ranked : 0 score OCC doesn't provide any vacuum; that's why it's connected to the intake manifold. You shouldn't see any difference in oil consumption. Can you draw a diagram of how you connected it and where the check valves are?
| The Following User Says Thank You to btstarcher For This Useful Post: | Speedracer69 (12-03-2014) |
![]() Join Date: Jul 2012 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 593
| Not Ranked : 0 score Recheck installation, per JBR instructions, Pg 7, #14 sounds like you installed the check valve incorrectly. |
| The Following User Says Thank You to Mattyhawk1 For This Useful Post: | Speedracer69 (12-03-2014) |
| The Following User Says Thank You to Speedracer69 For This Useful Post: | Mattyhawk1 (12-03-2014) |
(Thread Starter) | Not Ranked : 0 score This is how it's routed |
| Not Ranked : 0 score Why would you have a check valve inline with the PCV valve? They do exactly the same thing. Something is wrong.
(Thread Starter) | Not Ranked : 0 score That's how the JbR has it instructed man |
| Not Ranked : 0 score My opinion, it's a shitty way to route the OCC. You've removed the source of vacuum from the equation by blocking the IM port. In order to properly run a vented can, you need 2 OCC's: one sealed, between the IM and PCV valve, and one vented, between the VC and either the TIP of a slash cut into the downpipe (to provide vacuum under boost). My guess is that the oil is coming from the valve cover under boost, because there's nothing to pull it from the crankcase out of the PCV valve. Get rid of the VTA setup and run it as a sealed can.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress Last edited by btstarcher; 12-03-2014 at 11:28 AM. Reason: MSF Database - Automerged Doublepost |
The valve cover hose was bone dry so I don't think it's coming from there, the check valve on the hand drenched in oil. Maybe bad pcv? But wouldn't the check valve stop it? I know a guy running it the same exact way on his speed which is why I decided to do it because he hasn't has a single issue. I forgot to mention I ran a corksport with the way your saying to run and had the same thing happen as now would get full within 50 miles of driving so I removed it and cleaned out all my intercooler piping and intercooler because they were covered in oil. This time it's a little different because I don't have a hose routed to my intake so that's got me mind baffled. | |
| Not Ranked : 0 score It would have to be a bad PCV, because there's no vacuum source connected to it, yet oil is getting passed it.
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score @jbarone; take a look and help this guy out.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
| The Following User Says Thank You to ASHMS3 For This Useful Post: | Speedracer69 (12-03-2014) |
That's honestley my best guess as to why it's happening, my problem is understanding why the oil is being burned off by the exhaust if there isn't any trace of it in the intake or turbo? | |
| Not Ranked : 0 score Quantify what a "bunch" of smoke is. Are we talking same as a smoking K04 here? |
![]() Join Date: Jan 2014 Location: Tampa Florida Area
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 222
| Not Ranked : 0 score So you had no smoke before the catch can and now you do hmm. There isn't any reason a catch can would do that. I'm thinking bad PCV too especially if your valve cover hose was dry |
| The Following User Says Thank You to Z32_MS3 For This Useful Post: | Speedracer69 (12-03-2014) |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score Not sure...even if the PCV was bad he has the CV there which is pretty much the same thing. He indicates he had another OCC installed and configed the same way with the same issue. It's something else but what? edit: Try reconnecting the VC to the intake and running the line from the PCV with the CV direct to the lower port on the can and leave the breather in place. |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | btstarcher (12-03-2014), Speedracer69 (12-03-2014) |
| Not Ranked : 0 score How many miles are on this car and is the motor built? |
| The Following User Says Thank You to JBR For This Useful Post: | Speedracer69 (12-03-2014) |
![]() | | #24 | ![]() |
| The Following 2 Users Say Thank You to Speedracer69 For This Useful Post: | Mattyhawk1 (12-04-2014), Z32_MS3 (12-04-2014) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well I took the catch can off and ran the car the stock way valve cover to intake and intake mani to pcv. Car stopped smoking, but car doesn't feel 100% so I know that the issue may be elsewhere. The car has 88k on it and it's fully stock besides basics 3.5 JbR intake, autotech fuel pump internals, bnr s3, Catback exhaust no cats, pretty much it for performance parts. Before the valve cleaning and JbR manifold TIG and throttle body TIG and egr delete primary and secondary car ran great. I'm currently tunning with freektune and he never mentioned anything strange. I feel like the car shouldn't be drivin hard because it's stalling now. Only codes im throwing is egr, and secondary O2 sensor sometimes. |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I think a compression test is in order. Sounds like massive blow by. Anyone else want to chime in here?? |
| The Following 2 Users Say Thank You to JBR For This Useful Post: | Speedracer69 (12-03-2014), Z32_MS3 (12-03-2014) |
![]() | | #27 | ![]() |
That's what me and a few of my friends were also thinking. Car just stalled driving home a few minutes ago going into light boost in third gear so just because no smoke doesn't mean all is well. Just strange that it would do all this after car was running perfect before all this happened. I guess when my engine starved from the catch can stealing all my oil must have screwed something up internally. | |
| The Following User Says Thank You to Speedracer69 For This Useful Post: | Z32_MS3 (12-04-2014) |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Unless you lost all the oil internal damage is unlikely. I'm guessing fouled plugs from oil. |
![]() | | #29 | ![]() |
![]() | | #30 | ![]() |
![]() Join Date: Nov 2013 Location: Killeen, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 724
| Not Ranked : 0 score @Speedracer69; check that PCV immediately. I had the same fucking issue, and it ended up eating my motor....dont learn the hard way like I did. are you seeing oil in any places it shouldnt be when you dont run the can?
__________________ 08 TR MS3 - totaled and stocked out 1-5-2014 Daily Driver - 2016 WRX w/STI lip kit 2009 CWP MS3 1-23-2014 CXRacing FMIC with TR8 Core /// HKS Turbo Timer /// 6000k HIDs /// Yellow Fog Covers /// Cobb SRI /// Ultimate Racing TBE /// White Avid 21 18x8.5 Wrapped In Kuhmo 225-40-18s /// Short Throw Shifter /// Kozmic Motorsports EGR Delete /// Corksport HPFP internals /// CS Front Sway Bar /// /// JBR RMM, TMM, and PMM (all 80a) /// Slotted Rotors /// CS Foglight Kit /// CS License Plate Bracket /// CS Bypass Hose /// Rolled Fenders /// JBR Weighted Red Shift Knob /// Cobb AP //////![]() |
| The Following 3 Users Say Thank You to hatchedspeed3 For This Useful Post: |
![]() | | #31 | ![]() |
I already prepared for the worst I know motor will probably need to be rebuilt so just taking it one step at a time to figure out this issue. I haven't found oil anywhere else, where do you think I should look? My intake is clean, intercooler/pipes are clean, turbo is clean. Did you ever figure out what made your motor pop? | |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok so just got done doing my compression test, the spark plugs looked good IMO, the compression test wasn't the worst thing ever either. I got 185,180,180,180 cylinder 3 I added a little oil because it was at 165. So maybe an issue with cylinder 3? |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are the spark plugs |
![]() | | #34 | ![]() |
Groans: 126
| Not Ranked : 0 score Leakdown sounds to be in order as well. Using bad grammar from my cell phone.
| The Following User Says Thank You to ASHMS3 For This Useful Post: | Z32_MS3 (12-06-2014) |
![]() | | #35 | ![]() |
__________________ 08 TR MS3 - totaled and stocked out 1-5-2014 Daily Driver - 2016 WRX w/STI lip kit 2009 CWP MS3 1-23-2014 CXRacing FMIC with TR8 Core /// HKS Turbo Timer /// 6000k HIDs /// Yellow Fog Covers /// Cobb SRI /// Ultimate Racing TBE /// White Avid 21 18x8.5 Wrapped In Kuhmo 225-40-18s /// Short Throw Shifter /// Kozmic Motorsports EGR Delete /// Corksport HPFP internals /// CS Front Sway Bar /// /// JBR RMM, TMM, and PMM (all 80a) /// Slotted Rotors /// CS Foglight Kit /// CS License Plate Bracket /// CS Bypass Hose /// Rolled Fenders /// JBR Weighted Red Shift Knob /// Cobb AP //////![]() | |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
| Not Ranked : 0 score judging from all the oil around it, and in the can, Id say thats what it was. Then again, I also had oil in my intercooler, intake, etc, etc
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Here are the results on the leak down. The percentage of leak in the cylinder number, where I coukd hear the leak and the last two spark plugs had very light dark black oil around the threads. |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
| The Following User Says Thank You to hatchedspeed3 For This Useful Post: | JBR (12-08-2014) |
| Quick question | kbz0129 | Gen2 MS3 General Discussion | 5 | 09-30-2013 08:31 PM |
| Quick question on a quick potential sale... | HeliBif | MazdaSpeed 3/6 - Wheels & Tires | 0 | 05-10-2012 02:48 PM |
| quick question | 2006MS6 | Mazdaspeed3/6 General Discussion | 6 | 01-22-2012 07:07 PM |
| quick ap question | SMC | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 07-13-2009 04:34 PM |
| Quick Question... | Invictus | Mazdaspeed3/6 General Discussion | 10 | 11-26-2008 12:32 AM |
