| JAMES BARONE RACING JBR is a leading manufacturer of high-quality aftermarket parts for the Mazda community. We take pride in our reputation for providing the highest-quality performance products at the best values, and we back up that reputation with outstanding customer service and free shipping. We are committed to the Mazda platform and we actively partner with other members of the community in our selection, design, and testing of new products to make sure they meet their needs. We control every step in the engineering and fabrication process to ensure the highest standards of workmanship. The result is a line of products whose performance and reliability have been proven both on the street and on the track. Visit us at jamesbaroneracing.com |
![]() Join Date: Apr 2013 Location: MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 46
(Thread Starter) | Not Ranked : 0 score I'm thinking I need to get a helicoil kit, and maybe two new bolts, I've hear their M8 grade 8 with pitch 1.25 threads/mm? Does anyone know what spec they are, and what helicoil kit to get for the nuts. Or should I pay someone to grind it off and weld a new nut on?
__________________ %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%% % % Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe % Next up = Custom Tune %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%% |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
| Not Ranked : 0 score picture of said fail
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 |
![]() Join Date: Jan 2011 Location: Lynn Haven/Niceville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 831
Groans: 77
__________________ 2011 MS3 BLACK MICA W/TECH PACKAGE BNRSv3 - COBB 3 Port Boost Controller - BOSCH 3 Bar MAP Sensor - HTP 3" Intake (Candy Red)- CS Downpipe - CS LED Fog Lights - CS Interior LED Kit - CS Hood Strut Kit - COBB AccessPORT - JBR Adjustible Rear Sway Bar - JBR Solid Shifter Bushings - SURE Flow M3 W/ Res Delete - MangnaFlow 4x3.5" Stainless Exhaust Tips - AutoTech Internals - JBR 88a Dogbone RMM - H&R Lowering Springs - NGK Iridium Step Colder - Beachshoer's Pnp Intake Manifold W/ VTCS Delete - TurboSmart Plumb Black BPV - CX Racing FMIC - 18x8 Bronze MB Motoring Battles - Nitto Motivo 235/40/18 - Hawk HPS Brake Pads - Block8head Dual Gauge Pod - Prosport Evo Boost and Coolant Temp Gauges - Autodvdgps Touch Screen DVD Player W/ Navigation - CS Radiator Cover - CS Exhaust Manifold Cover - CS OCC Stratified Tune In Progress SCCA Member# 450495 Class - SMF TRMotorsport C3 17x9 Hancook 255/245 RS-3 LIQUOR AND WHORES | |
| Approved MSF Vendor ![]() Join Date: Sep 2009
Rep Power: 7118 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,203
| Not Ranked : 0 score Got your email...are the nuts stripped, bolts broke or both? |
Groans: 77
| Not Ranked : 0 score stirpped nuts? ouch!
(Thread Starter) | Not Ranked : 0 score Here's the pic, and I think it's the nut that's stripped, not the actual bolt. I'll post a bolt pic in a minute too.
(Thread Starter) | Not Ranked : 0 score And here are the 3 bolts I managed to remove, I may need to replace the two. But, judging from the one I was able to remove, it is most likely the nuts that are stripped not the bolts, unfortunately. A quick glance at the shop manual said to torque these bolts between 30 and 40 ft lb, any reason why the aftermarket RSBs say 50?
Groans: 77
| Not Ranked : 0 score If it's the bottom 2, I think you can drill them and use a nut and a longer bolt. |
(Thread Starter) | Not Ranked : 0 score There may be enough bolt sticking through, that a nut and washer could suffice, I'd have to go out and check first. However, it would probably be wise just to just bolts with some grip length. A helicoil seems like the most legit way, are you sure they're M10 bolts?
Groans: 77
| Not Ranked : 0 score i used the bolt and thread pattern at ricezone(autozone) to make sure the bolt was correct. Matched mine perfectly. M10-1.25 x30mm fit like stock
(Thread Starter) | Not Ranked : 0 score So helicoil it is, anything I need besides two new bolts, a helicoil set, tap wrench, thread lube, drill bit? What would be the best way to get this bolt out?
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score This happened on a friends car. There was enough room to put a bolt, a lock washer, and a nut on there...we didn't have to do anything to the thread. We screwed the bolt in with whatever remaining thereads were left in the stock welded nut, then put a lock washer and nut on it with some blue Loctite. This is a permanent fix and cost a whopping $2. I don't know what length bolt we use...we just got a few from Lowes.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
__________________ %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%% % % Current Mods = JBR 88 RMM // Ultimate Racing Axleback // JBR RSB // Corksport Internals // JBR Stage II SRI // Cobb AP V3 // UR Race Pipe % Next up = Custom Tune %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% %%%%%%%%%%%%%%%%%%%%% | |
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
| Not Ranked : 0 score Judging by that shaving, it appears if you in fact cross threaded that specific bolt. Be careful when doing tightening any bolts, and make sure not to cross thread them or you will end up like this.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score I did the exact same when I tightened mine. Set the wrench at 40 lb/ft and they stripped before it clicked; The original owner may have fucked them though. In my case it was the bolts, not the nuts. I'm going to simply try new bolts first; if they don't hold I'll put nuts behind the welded ones.
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score I don't think I crossthreaded them, I started them by hand and they were nice and flush when tightening them down. I think it was simply a matter of overtorquing and crushing the threads. BigRed: unfortunately for me the car only has 3500 miles on it, so there was no other retard to mess it up before hand, just myself. I wish I had waited for a nice used MS3 instead of going new, cheaper and allows me to have no qualms over modding.
Groans: 77
| Not Ranked : 0 score Last night I checked and torque the replacement bolt I installed to @jbarone; recommended 50ftlbs. Felt like they were going to snap but they didn't. (thank fuck).
Groans: 56
| Not Ranked : 0 score Anything that can be rectified by adding two new nuts is pretty damn low on the Fuck-Up-O-Meter. Consider it a learning experience.
(Thread Starter) | Not Ranked : 0 score True, but I like things to be perfect.
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
| Not Ranked : 0 score Any luck? My dumbass just did this. @MechEnix;
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle |
| The Following User Says Thank You to manila For This Useful Post: | trancehead (04-25-2014) |
(Thread Starter) | Not Ranked : 0 score Yea, just grab a new locking but and throw that sucker over the other nut. Hopefully you have enough threads. One of these days I'm going to get under there and take a grinder to the welded nut. Sent from my Galaxy Nexus using Tapatalk
| Not Ranked : 0 score Shit should have got a locking nut instead...
![]() | | #24 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score Nylon locking nuts are the best damn thing ever invented for shit like this ... and red loctite I would not even consider helicoils as removing the old nut and putting a new one or even putting it over the old nut will hold much much stronger, i would not want a helicoil that can break free |
![]() | | #25 | ![]() |
![]() Join Date: Nov 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,192
Groans: 33
| Not Ranked : 0 score I drilled and retapped the top one. I had a locking nut up there but it was a huge PITA to maintain for someone who lives in the Midwest with our stupid weather patterns (and salt). Also AutoX seems to make it squeak faster.
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() |
![]() | | #26 | ![]() |
The top left RSB bolt is restricting me to get a nut behind. Not too much room to work with and hold a nut while getting the bolt in. *Forgot to mention I stripped more than one of the welded nuts
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle | |
![]() | | #27 | ![]() |
Groans: 33
Tappin'
__________________ 2012 Velocity Red Mica Fast: COBB AP | Autotechs | JBR 3'' WP | CS DP | CS ABE | MDM RMM | JBR RSB | NGK Plugs | JBR SSP | ETS TMIC Rice: Aeroforce Interceptor | AEM M 35psi | Konig Milligrams 18x8.5 + 35 | Z1 Star Specs | JBR Mudflaps ![]() | |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Did you have to drop the rear springs and control arm to get enough room to get a drill in there?
![]() | | #29 | ![]() |
Groans: 33
| Not Ranked : 0 score Nope.
![]() | | #30 | ![]() |
![]() Join Date: Mar 2010 Location: SOJO
Rep Power: 176 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 155
![]() | | #31 | ![]() |
Groans: 33
![]() | | #32 | ![]() |
Thanks. I was thinking that would be the case. @jbarone;, can your brackets handle a 12mm or am I going to have to drill that out as well? | |
![]() | | #33 | ![]() |
| The Following User Says Thank You to JBR For This Useful Post: | Tweaek (11-18-2014) |
| Stripped Transmission Stud? | SubyGF | 2010 MS3 - Engine, Transmission & Driveline | 13 | 08-12-2016 09:12 AM |
| M2 downpipe install stripped bolt going to mani | Chicagospeed6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 3 | 11-09-2012 09:15 PM |
| Subframe threads stripped for RMM | 09ms3gt | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 03-19-2011 07:22 PM |
| Fix for a stripped RMM holding nut | BeeZaa | 2010 MS3 - Engine, Transmission & Driveline | 7 | 02-23-2011 09:47 PM |
| stripped bolt | haskms3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 12-20-2010 04:23 PM |
