Mazdaspeed Forums
-   JAMES BARONE RACING (http://www.mazdaspeedforum.org/forum/forum/f493/)
-   -   Who's tired of broken yellow zink sway bar brackets? (http://www.mazdaspeedforum.org/forum/forum/f493/whos-tired-broken-yellow-zink-sway-bar-207915/)
JBR 12-28-2016 10:34 AM
Who wants inexpensive high quality replacement bracket and bushing kits that will never rust or break and carry a lifetime warranty? Look no further!! JBR now has our own line of replacement sway bar bushings and brackets for most all aftermarket front and rear sway bars. We also stock replacements for many OEM sway bars too!!
Did we mention these are warrantied for life and guaranteed never to rust or break??!!
If this wasn't already pretty awesome, these are now the standard bushings and brackets included with EVERY JBR sway bar kit. We know how tired everyone is having to replace broken sway bar brackets every year. NO MORE!!
Details:
No more cheap, rusted and broken yellow zinc coated sway bar brackets. JBR Sway Bar Bushings and Bracket kits are the toughest in the industry!
http://www.jamesbaroneracing.com/sho...T-Brackets.JPG
First, they're laser cut out of .180" thick stainless stainless steel which will never rust. This is nearly twice as thick as the typical bracket. They're then die formed using our own proprietary tooling that guarantees a perfect fit every time.
http://www.jamesbaroneracing.com/sho...rackets_04.JPG
After forming, each bracket is then tapped to accept a grease fitting making maintenance simple and easy.
http://www.jamesbaroneracing.com/sho...rackets_03.JPG
Included with every pair of JBR brackets are a set of 90a durometer bushings available in the most common OEM and aftermarket sizes.
http://www.jamesbaroneracing.com/sho...rackets_05.JPG
Once you have these installed, you'll never need to replace your sway bar brackets or bushings again.
Available Applications:
  • 2013+ Ford Focus ST OEM Rear
  • 2004-2009 Mazdaspeed 3 OEM Front & Rear
  • 2010-2013 Mazdaspeed 3 OEM Front
  • 2010-2013 Mazdaspeed 3 OEM Rear
  • 2004-2009 Mazda 3 OEM Front & Rear
  • 2010-2013 Mazda 3 OEM Front
  • 2010-2013 Mazda 3 OEM Rear
  • 2014+ Mazda 3 OEM Front
  • 2014+ Mazda 3 OEM Rear
  • 2006-2014 Mazda 5 OEM Front & Rear
  • 2013+ Mazda CX-5 OEM Front
  • 2013+ Mazda CX-5 OEM Rear
  • 2014+ Mazda 6 OEM Front
  • 2014+ Mazda 6 OEM Rear
  • 1.250" (32mm) Aftermarket Rear Sway Bars
  • 1.125" (28.5mm) Aftermarket Rear Sway Bars
Don't see your application? Contact us, we probably have it.
Features:
  • Designed and manufactured in the USA
  • Stainless steel die formed construction
  • 90 durometer bushings
The JBR Tru-Torsion Sway Bar Bracket Kit Includes:
  • 2 Stainless sway bar brackets with grease fittings
  • 2 New 90 durometer polyurethane bushings
  • Lifetime warranty
[R]usty 12-28-2016 10:54 AM
Good price point. Will get these if my prothane brackets break.
kolosok17 12-28-2016 11:33 AM
Nice! Ditto on what Rusty said. The sway bar has been squeaking lately, perhaps I should have a look down there.
flyhigh 12-29-2016 01:23 PM
Thanks for making these standard with new purchases.
MSP6 12-30-2016 11:34 AM
Are you shitting my face right now...I just replaced the bushing/brackets Front and rear like a month ago..Doh! Looks good, will buy in future when my knuckles have healed from the last go around.
kolosok17 08-26-2018 09:35 PM
What size should I order for:
Rear Sway Bar Kit - Black
Item# MS3RSB-BLK
The 1.125"/28.5mm ones?
JBR 08-27-2018 08:01 AM
Item# MS3RSB-BLK
No, our rear sway bar is 1.25"/32mm as indicated in the drop down.
kolosok17 08-27-2018 09:37 AM
1 Attachment(s)
Quote:
Thanks, Jamie! Going to put in an order. The original ones finally failed.
Page generated in 0.17412 seconds with 11 queries
