![]() | | #41 | ![]() |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score
Thanks!
__________________ | |
![]() | | #42 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score He is saying that he believes that the stock imbalance of the runners is so terrible that by simply evening out the flow might be why power is made, not because of more port volume/velocity. At the end of the day, the harder you push the car and the more psi you are running, the more the port work will begin to help and the bigger the benefits will be.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post: | 06Speed6 (03-04-2012), qtrmile beast (03-04-2012) |
![]() | | #43 | ![]() |
| Not Ranked : 0 score ^^ what he said.
![]() | | #44 | ![]() |
| Not Ranked : 0 score Ok guys, some impressions. The car pulls harder, everywhere. On VD the car makes more power and tq. It feels strong. The following VD graph was without having the tune dialed in. I am fine tuning now and will continue to do so as my exhaust manifold will be here later this week. For now, here is a teaser. Stock K04, no meth, no nitrous. @driver311 @Bucker @rfinkle2
| The Following User Says Thank You to mrmonk7663 For This Useful Post: | Bucker (03-06-2012) |
![]() | | #45 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
| Not Ranked : 0 score this is the dyno that was done after i ported this guys intake and we bumped it back up to 17 psi.. from 14psi
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
| Exhaust Manifold option- please look and respond! | Chimmike | MazdaSpeed 3/6 - Turbo Induction | 31 | 08-01-2011 08:17 AM |
| new intake manifold option.. somewhat. | Stockturbo_Ms3 | MazdaSpeed 3/6 - Turbo Induction | 6 | 08-03-2010 12:58 PM |
| Intake manifold this, intake manifold that!!! | ptperformance | Mazdaspeed3/6 General Discussion | 53 | 06-21-2010 02:51 PM |
| Intake manifold | QuickSpool | 2010 MS3 - Engine, Transmission & Driveline | 0 | 11-18-2009 06:19 PM |
