Like Tree5Likes
 Old 12-31-2010, 01:08 PM   #601
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
hahah yeah...i say we do 25.... get me to 400 gm/s and then we will make a video sped up in time to back up the claims!!!
aaronc7 (12-31-2010), Dano (12-31-2010)
 Old 12-31-2010, 01:11 PM   #602
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
darksun would still hate....no?
400 g/s @ 11.99 1/4 LOL
 Old 12-31-2010, 01:23 PM   #603
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
im gonna make a video i never got a chance to make..... will be dark out, i will have the fucken car up on stands and ill video the speedo on a 40-120 roll.... i predict I will reach 120 in under 3 seconds..... MAD POWAH!!!!!!!! MAAAAAAAAAAAAAAD POWAH!!!!!!!!
ill even throw a "WHOOOAAAA" ala Joe (GSRTYPE1)
 Old 12-31-2010, 03:48 PM   #604
bmylez's Avatar
Posts: 3,197   (View Stats)
Yeah, Dano, you're right, I was talkin about Driver311. My bad. Lesson learned
 Old 12-31-2010, 05:17 PM   #605
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Lenny,
I would recommend putting in the ITV24's and see if the KR goes away with the 1° extra timing in.
If not then put the "7" nozzle in and then see if you can run the timing without KR.
FreeFlyFreak (12-31-2010), rodrigo (12-31-2010)
 Old 12-31-2010, 06:42 PM   #606
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
Lenny,
yeah, i got time this weekend , i gotta dig up the spark plugs somewhere, i got em all 22s 24s and stockers.
and the 7 nozzle gets to me Thursday so ill be putting it on next week. keep in mind my car could never run the OTS stage 2 fmic maps without meth.... it always knocked, maybe in 50k miles when i pull the motor apart u guys can see why lol
thanks !!! also track day saturday next week , i want to be able to run the car flat out to see if I can trap 112mph at least. (best of 107.5 b4)
 Old 01-01-2011, 03:08 AM   #607
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well, we reverted back to the original timing we were running and i turned the mbc all the way to full (light spring) looks like it tops out at 21.75psi or so....
KR still persists oddly enough after 5700 RPM ...that shits getting muted!!! we also upped the boost induced fuel cut just so i dont hit cut when I shift hard and spike to 22.5psi....its only happened once before but still... a lil headroom is nice.
oh and for the gm/s nutswingers.... i hit 312 gm/s yay!!! hahahah voltage did reach a high of 4.76V so I need to get this puppy to hit 22psi flat across (mbc has boost mood swings depending on ambient conditions)
once I quiet that KR to 5700 i'll be good until i swap the do7 nozzle in
datalog1.csv
datalog2.csv
datalog3.csv
datalog4.csv
 Old 01-01-2011, 03:23 AM   #608
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
upon further inspection i noticed the logs i posted yesterday i had about the same amount of KR and more timing ....and all of it comes around 5700 and up.... so im just gonna turn that shit off.
also..... why would my throttle position be 78 now instead of 77.xx as before??? curious
compare the KR and the timing on the logs I just made vs these from yesterday ...
http://www.mazdaspeedforum.org/forum/foru...tml#post670852
check out at 6k i seem to have 1-1.4 KR on both sets, boost is about 21 give or take .5lbs , temps are the same...fuel is the same.... but timing on the ones from yesterday are 2 degrees more advanced vs the ones from just now 2 degrees less.... yet the KR is about the same value.... I think from my perspective I have no choice but to shut that shit off at 5700.
 Old 01-01-2011, 09:23 AM   #609
Trail of Fail
Dano's Avatar
hum...your motor may just make too much noise at those RPMs. Mine doesn't seem to have that issue with the sensor enabled.
you could experiment with the multiplier and offset to make the sensor less...well sensitive but I don't know of anyone actually doing that and what values to change.
The cool thing is that the settings are per RPM so you only have to make the changes in the RPMs that you are having trouble in....IDK maybe that's something for Christian to tackle when he gets back on-line.
 Old 01-01-2011, 10:16 AM   #610
Eth/Meth Junkie
cld12pk2go's Avatar
I would leave it on and add another 1° and see if you still have ~1° of KR or if it starts to be more like ~2°.
If you can add more timing and it still sees only similar small amounts of KR then it is potentially mechanical/noise in origin.
Just be careful with this methodology. While short bursts ~2° of real KR shouldn't hurt, it isn't without some risk.
I would be very hesitant to just turn the sensor off above 5700 unless you are confident that it is not real.
 Old 01-01-2011, 11:12 AM   #611
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well but that was the point of looking at the logs from the previous page vs the ones from this one.... all the PIDS are basically the same, its the same tune, except for one thing.... timing, its 1.5 to 2 degrees more advanced in the previous page s logs and the same amount of KR shows. in fact the only map changes between the 2 logs is timing and about 3/4 of a turn on mbc but because of i guess humidity factor or w/e the boost is about .5 off only.
i get what you are saying though, ill continue with caution. i am confident the do7 will eradicate all my KR, it always does when its below 2.0 and i move up in nozzle size.
thanks for the input. ( I Just need a new M3 and Mustang GT to go test pulling powah now)
 Old 01-01-2011, 02:45 PM   #612
I would pull a healthy 4 degree of timing up top. Run the log and see if you get the KR. If you do, then you know it's just noise.
Dano (01-01-2011), FreeFlyFreak (01-01-2011)
 Old 01-01-2011, 07:29 PM   #613
not to rain on your parade lenny but,
how do you like them apples? haha im rooting for ya buddy!!!
P.S. thats a no meth tune still with reasonably conservative timing.
 Old 01-01-2011, 07:33 PM   #614
bmylez's Avatar
Ok, I won't mention the g/s now, but the load....damn, 3.1?
 Old 01-01-2011, 07:33 PM   #615
Super, you really commanding 11 AFR up top?
 Old 01-01-2011, 07:36 PM   #616
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
damn kneegrow.... u keep pushing it on stock internals?? only thing left standing will be your green/orange wheels me thinks lol
good shit man, maybe now u can reclaim the "world's fastest ms6"
he has a 3inch maf so his voltage reflects a higher number than our 2.75 stocker
Last edited by rodrigo; 01-01-2011 at 07:36 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-01-2011, 07:39 PM   #617
lol max load is 3.5 and im only commanding like 2.5
yah only 11 right now. i was basically calibrating my upper MAF curve with this log and im sticking with MBC so all i need to touch is timing to make sure my KR stays in check.
im actually running the CPE 3.25 right now, my custom 3" is for sale though!!!
 Old 01-01-2011, 07:43 PM   #618
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
damn anthony good shit man, i wish i had mad powah... i got measly beat on ko4 powah
 Old 01-01-2011, 07:46 PM   #619
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
gt5 niggah, who cares about real cars
triplejumper18 (03-30-2011)
 Old 01-01-2011, 07:47 PM   #620
the gift of speed will soon be with you my son. good things come to those who want it the most
 Old 01-01-2011, 08:27 PM   #621
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
lenny do you experience any missing, when the kr rears its ugly head?
at 104000 2 bent rods
tuned by nishan
 Old 01-01-2011, 11:00 PM   #622
Tony, if the g/s are calibrated correctly, you're clearing 400whp easily.
 Old 01-02-2011, 12:04 AM   #623
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
not really, but u can never tell when kr is only 1.0.... i dont feel any power drops ever unless its about 3kr
im o do some logs tonight with that pos kr off lol...... didnt need it b4 , dont need it now lol
 Old 01-02-2011, 01:08 AM   #624
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
alright, here are tonights logs, some KR ... not too bad, fuck 5700 rpm KR... ut of mind out of sight. next week do7 nozzle goes in and it will all go away anyways.
car is pretty consistent except for boost, MBC runs what it runs....some logs im closer to 22psi (#1) and some I am closer to 21psi.... but i like the mbc, fast acting no fuzz no muss.
datalog1.csv
datalog2.csv
datalog3.csv
datalog5.csv
by the way , when I got off the fwy to get back on the return trip from logging I ran into a new M3 coupe, we did a roll from about 45mph and we were dead even until 120mph... and i mean DEAD EVEN!! until he almost ran into the back of an SUV coming out of a tune lol
NJSPEED3 (01-02-2011), psychophyr (01-02-2011)
 Old 01-02-2011, 06:59 AM   #625
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
Glad to see it's working out for you lenny, enjoy your car!
2006 Mazdaspeed6 GT BCM
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP
HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM
Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate
Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN
psychophyr is offline   Reply With Quote
 Old 01-02-2011, 07:54 AM   #626
MSP611's Avatar
Posts: 2,291   (View Stats)
Excited to c how this turns out. I've gotta say u got a lotta balls goin BT with tht many miles. Almost makes me want to do it without rebuilding but I'm a scaredy cat
In progress:
 Old 01-02-2011, 08:27 AM   #627
bmylez's Avatar
Alright, since you mentioned the M3, it's time for...dun dun dun...RICER MAAAAATH.
M3 weighs 3706 and has 414hp. That is a lb/hp ratio of 8.94.
Lenny weighs 3153 and has X hp. To be dead even, he must have approximately 352 hohspaw at da crank.
 Old 01-02-2011, 08:38 AM   #628
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
if you wana go by weight to hp i would say he is making more than that. I'll let Lenny explain this one.
The Following 4 Users Say Thank You to NJSPEED3 For This Useful Post:
Dano (01-02-2011), FreeFlyFreak (01-02-2011), manelscout4life (01-02-2011), rigor (01-02-2011)
 Old 01-02-2011, 08:47 AM   #629
bmylez's Avatar
Well, like I said, it's a rough estimate, but it's a decent ballpark. If he were making 400hp and weighed that much less, he would have freight trained the M3.
 Old 01-02-2011, 08:56 AM   #630
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
and power to weight isn't everything
how about the fact m3 is rwd, is balanced much better, and has much better gears - ditto for the mustang
it would take a hell of a driver to stand up to one of those cars in a ms3 down the 1/4
sushi roll is very possible tho....
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following User Says Thank You to cpolly69 For This Useful Post:
 Old 01-02-2011, 09:00 AM   #631
bmylez's Avatar
Oh I'm sure he's making more than 350, but even though weight/power isn't everything...if you weigh 600 lbs less than a car and have the same power...it would be very very sad to lose from a roll.
 Old 01-02-2011, 09:22 AM   #632
Trail of Fail
Dano's Avatar
now I have seen partial pics of lenny and...although he looks like a sturdy built guy...well he doesn't weigh 3100LBS....
Lenny, In that 3rd log it looks like your KR probably continued to climb past the sensor cutoff at +1 KR...you needz that nozzle and maybe try the plugs
on the subject of roll racing badass BMWs...what are those newer cars with the big buldge in the hood...flared fenders...come in 2 door and sedan...[are those an M3 or M5 or something] well I have pulled the same guy [sedan] numerous times in my car from like 60-120ish.... pulled about car length on him and we started dead even...I think he may have been starting to catch up toward the end but we did this about 5 different times over the course of a month or so...and as soon as we went I jumped a length on him real quick and held it almost the whole time
he pulled up to me afterward and shrugged his sholders and smiled...his smile wasn't as big as mine LOL
fun times
jussayin....
802MS3 (01-02-2011), NJSPEED3 (01-02-2011)
 Old 01-02-2011, 09:40 AM   #633
Trail of Fail
Dano's Avatar
Lenny, have you increased the throttle pos in the DBW tables? I noticed your TPS reads 77 and most OEM DBW setups read ~74...That right there should increase g/s..no?
I think I'll open mine up from 80 to like 90...does anyone know if that overdrives the TB sol?
 Old 01-02-2011, 10:01 AM   #634
aaronc7's Avatar
Groans: 370
his DBW tables are set to 100 max vs 80 that's stock in OTS maps
The Following 2 Users Say Thank You to aaronc7 For This Useful Post:
 Old 01-02-2011, 12:22 PM   #635
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i can haz 4 bills + at the baffroom scale?
 Old 01-02-2011, 12:35 PM   #636
bmylez's Avatar
Yes. Yes you can.
rodrigo (01-02-2011)
 Old 01-02-2011, 03:58 PM   #637
: biggest possible shit eating grin icon :
lenny what plugs are you running? it sounds like your ready for some 2step colders with a tiny gap. are you breaking up at WOT at all?
 Old 01-02-2011, 05:05 PM   #638
bmylez's Avatar
Not trying to be a downer at all, but he said "IF"....just get it over with and get to a dyno
 Old 01-02-2011, 09:16 PM   #639
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
fuck dynos anthony, go hit a track and show us 117-118mph dyno-traps
IshiKage (01-05-2011), rigor (01-04-2011)
 Old 01-02-2011, 09:26 PM   #640
bmylez's Avatar
Yeah, that works too
I used to be caught up with just ETs...but now I almost care more about the trap.
djuosnteisn (01-03-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/atp-3071r-swap-how-lenny-gets-bt-63559/
Boost Tapering Suggestions (GT3071R - Stock Block) This thread Refback 06-15-2011 04:10 AM
Turbo upgrade? This thread Refback 03-31-2011 01:44 PM
Turboaufladung » Internes Wastegate This thread Refback 01-31-2011 11:05 AM
APT 3071R ANMSPD3 MazdaSpeed 3/6 - Big Turbo Builds 47 04-16-2014 11:51 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-12-2008 07:20 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-11-2008 05:50 PM
Page generated in 0.56815 seconds with 32 queries
