Like Tree5Likes
 Old 11-14-2010, 06:26 PM   #81
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I hope you clean all the shit out of that hose you cut before you put it on.
Suspension:
 Old 11-14-2010, 06:31 PM   #82
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
there's a lot of shit that is staged and or edited for time constraint purposes, sponsor cut ins etc etc.....all very technical all very hush hush
i just put that shit together to show u guys.... it ain't done in the least lol
FreeFlyFreak (11-14-2010)
 Old 11-14-2010, 08:22 PM   #83
driver311's Avatar
Posts: 1,769   (View Stats)
Looking good Lendog! Keep up the good work. Im excited to see how your beast runs.
Mazdaspeed
 Old 11-14-2010, 11:28 PM   #84
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
haha thanks anthony... it will run ok... dont expect any record breaking shit... im only aiming for 340whp at hopefully 17-18psi and ill call it a day until i buy the rods and pistons.
i am super excited though... clutch in a week and a half and turbo 203 weeks after that.
 Old 11-15-2010, 05:13 AM   #85
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
What clutch are you going for?
I need to get off my rump and order an ACT with street disk.
 Old 11-15-2010, 09:13 AM   #86
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i was going with the 6 puck sprung...but due to time constraints and its back order status i bought an act street disc kit
 Old 11-15-2010, 09:17 AM   #87
2-3 right? not 203 because that's 4 years.
djuosnteisn (11-16-2010)
 Old 11-15-2010, 10:01 AM   #88
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
oh gawd ill kill myself if its 203 weeks later lololol
clutch will be on sat nov 27th...and turbo a weekend in december when philly confirms date...if it all holds together the combo will wake my car the fuck up!!
 Old 11-15-2010, 10:04 AM   #89
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
clutch will be on sat nov 27th...and turbo a weekend in december when philly confirms date...if it all holds together the combo will blow my car the fuck up!!
fixed
FreeFlyFreak (11-15-2010)
 Old 11-15-2010, 10:06 AM   #90
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
hahahhahahahahhah epic vta block
 Old 11-15-2010, 06:29 PM   #91
Trail of Fail
Dano's Avatar
ok.... BT bracket is done.... thanks dano for getting me to think the stocker would work...thank you njspeed for bringing up the slotting idea....
thanks to all the lil people that made this dream become a reality,... like my cousin vinnie the midget and his wife dorothy the bar stool.
anyways.....
confirming that both slots vertical ID are .800" now
oh my gawd...LOL...is it necessary to put a caliper on the slots to confirm they are the perfect size!!!!!
This lack of precision must be why my car is slow!
now since you have gone this far with the hole size...I don't like the zip tie holding the header wrap on the bracket nor the freyed edges on the wrap...can we move to v2 of that with a better retention method? Maybe just double up on the ties so they are even looking and IDK what to do about the edges of the wrap...maybe tuck them under?
hahahahaha
Broxer (02-20-2012), madvillain (11-16-2010), NJSPEED3 (11-16-2010)
 Old 11-15-2010, 06:45 PM   #92
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
hahahahaha
technically if the bracket top is to remain horizontal yes it is important to ensure that the slots are equal in vertical dimensions unless u want it to get cockeyed and eventually snap one of the bolts holding it
as far as the zip tie..it is high temp steel and is what is used on all headers I have used over the years.... technically I could have added a hole along the backside of the bracket and used another tie through it and the original bolt hole (that was for the ko4 mount) to keep the wrap from sliding out.
u also have to consider that the height of the bracket was an estimation and i can close the gap by either adding more padding (which i dont want to do) or use bushings sliced in half as basically spacers in the slots to achieve the perfect snug height....
remember that me tightening on the bracket can achieve only so much sturdiness since i am not going to be able to crank down them bolts to 100ft lbs tq
as far as the the edges...they are fine...im not going for pretty..just functional...after all this is just a ford in disguise.
 Old 11-15-2010, 08:24 PM   #93
Trail of Fail
Dano's Avatar
of course you know I am yanking your chain....glad to see your progress.
FoMoCo FTW!
 Old 11-15-2010, 11:13 PM   #94
Ziggo's Avatar
Posts: 3,843   (View Stats)
Is there not enough meat on the turbo housing to drill and tap a blind hole?
Ask Me About My:
 Old 11-16-2010, 12:11 AM   #95
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
im not drilling the housing.... not on the turtle part of it.... i mean u could i guess attach a bracket to the dp studs closest to the firewall between the dp flange and the nut....
but i aint doing that....
my bracket is good enough for me.....
or maybe just tack the bracket to the housing hahahahahahah...hmmmmm.... hahahhaah....hmmmmmm
 Old 11-16-2010, 12:27 AM   #96
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Dont over think this. Your idea will work just fine.
 Old 11-16-2010, 12:32 AM   #97
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
oh i know man.... i know.... im all about mickey mousing shit
 Old 11-16-2010, 12:36 AM   #98
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
^^^ Werd
 Old 11-16-2010, 08:50 AM   #99
Trail of Fail
Dano's Avatar
I think if you did want to over do it even more you would be best served to go from the OEM bracket to a DP stud as lenny indicated but you would need a longer stud.
 Old 11-18-2010, 10:32 PM   #100
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
no updates on turbo....still waiting on philly.... time is nearing and queer bait still has no def date he s coming.....ugh .....
anyways...... got this in the mail today... will go on next sat 27th....
act flywheel
act pressure plate
act street disc
of course it comes with a pilot bearing, throw out bearing and alignment tool
and the rice is for my son....he puts all these fucken stickers and shit on his folders..... fucken ricer
once again BIG THANK YOU TO MARK AT SU for getting me this shit asap when it was out of stock at every vendor including them.
The Following 4 Users Say Thank You to rodrigo For This Useful Post:
djuosnteisn (11-19-2010), madvillain (11-19-2010), the_rolex_guy (01-24-2012), ZoomZoomPSSH (01-31-2011)
 Old 11-18-2010, 10:42 PM   #101
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
SpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the worldSpeedSixxx is the leader of the world
Groans: 778
nice clutch dude.
2003 SilverStone Grey Honduh S2000
SpeedSixxx is offline   Reply With Quote
 Old 11-18-2010, 10:44 PM   #102
zx2man's Avatar
Posts: 1,356   (View Stats)
Lenny has a super nice crotch.....eeer clutch
2009 MS3
COBB AP
COBB INTAKE
COBB/TURBOXS TBE
DNP TURBO MANIFOLD
CXRACING FMIC
TURBOSMART BPV
JBARONE RMM
TURBOSMART BPV
JBARONE SHIFTERPLATE
COBB RSB
KONIG WHEELS/HANKOOK TIRES
zx2man is offline   Reply With Quote
 Old 11-18-2010, 10:53 PM   #103
driver311's Avatar
Heres a little motivation for you Lenny. I made 340whp 340ftlbs today on 18psi and conservative timing. More to come!
Mazdaspeed
The Following 2 Users Say Thank You to driver311 For This Useful Post:
Dano (11-19-2010), zx2man (11-18-2010)
 Old 11-18-2010, 10:57 PM   #104
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
hahaha anthony.....like u didnt rub it in 10 times via text today already.... make a thread already man... u lost yours....especially so darkgums280 can hate
but ya.... i think my set up might not make the same power as u cuz i haz 78k miles....but close enough i guess.... 340whp and ill be content at 18-19psi though until i save coin for proper engine build
zx2man (11-18-2010)
 Old 11-19-2010, 01:49 AM   #105
Shanems3's Avatar
Posts: 916   (View Stats)
Shanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the worldShanems3 is the leader of the world
just crank it up, 78k on motor means its broken in.............................................
Shane
2011 Mustang GT Premium
Performance White
Sync | Shacker 500 | Rapid Spec 401A | Exterior Package 5 | California Special Valance | Boss 302 Splitter | Bama Tune | Bassani Axleback
Shanems3 is offline   Reply With Quote
The Following User Says Thank You to Shanems3 For This Useful Post:
SpeedSixxx (11-19-2010)
 Old 11-19-2010, 07:55 AM   #106
Trail of Fail
Dano's Avatar
act flywheel
act pressure plate
act street disc
mine is going in as we speak!!!
I am very excited to be able to floor it again and hope to get my 350WHP to 370WHP..
Lenny you might need to start looking for another lackey incase philly falls thru.
Love the new SN...did aaron give you that one?
 Old 11-19-2010, 08:38 AM   #107
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ehhhh..... new sn was aarons idea and fucknut haltech all to eager to please......
i paid good money for my BT but i guess it wasnt enough....sigh
 Old 11-19-2010, 09:21 AM   #108
Trail of Fail
Dano's Avatar
time for payback???
new killer ATR will be released on Monday!!!!
ATR wish list
MAP scalers
CDFP scalers
Boost targeting
MIL deletes
and much much more!!
I think this may help with BT boost targeting with EBC lenny...I know you are eager to try this
mason (11-19-2010)
 Old 11-19-2010, 09:24 AM   #109
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
 Old 11-19-2010, 09:25 AM   #110
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Yay for MotherInLaw deletes!
The Following User Says Thank You to triplejumper18 For This Useful Post:
Dano (11-19-2010)
 Old 11-19-2010, 09:28 AM   #111
Trail of Fail
Dano's Avatar
if only!
 Old 11-19-2010, 02:58 PM   #112
SpeedSixxx's Avatar
Groans: 778
is the new ATR gonna have the load cap fix? if not WHO GIVES A CUNT FUCK.!
 Old 11-19-2010, 03:02 PM   #113
Eth/Meth Junkie
cld12pk2go's Avatar
You pull a Rip Van Winkle since June?
 Old 11-19-2010, 03:44 PM   #114
SpeedSixxx's Avatar
Groans: 778
lol, yeah I did
I was banned for 6 months and beofe that 3 months...
is it known fact that they have found out what cp-e knows?
 Old 11-19-2010, 03:54 PM   #115
Eth/Meth Junkie
cld12pk2go's Avatar
lol, yeah I did
Load cap is dead and buried since v1.07 this summer.
An shit-ton of new features should be coming next week in v1.08 (including DI fuel press control).
 Old 11-19-2010, 04:01 PM   #116
SpeedSixxx's Avatar
Groans: 778
how come I havnt seen any threads with dude on AP maing over 400 whp?
as soon as cp-e flashes came out there were like 3 guys over 400 whp..
dustin being one..
oh +, If an AP goes for 700 new? 400 used and you get the load cap fix + now all these other things..
why are ppl still buying a SB for 700+ and then bending over and getting raped for 2,3,400 dolla flash charges?
 Old 11-19-2010, 04:02 PM   #117
DSIT995's Avatar
Posts: 1,768   (View Stats)
MLC Lenny?...... what does the MLC mean?
I like BT Lenny better..................
99 Miata NB - Stock for now
rodrigo (11-19-2010)
 Old 11-19-2010, 04:03 PM   #118
SpeedSixxx's Avatar
Groans: 778
My Large Cock Lenny
The Following User Says Thank You to SpeedSixxx For This Useful Post:
 Old 11-19-2010, 04:21 PM   #119
hnda etr's Avatar
Groans: 90
lol, yeah I did
Wow.... Just.... Wow...
 Old 11-19-2010, 04:37 PM   #120
SpeedSixxx's Avatar
Groans: 778
yes, wow....
again I was banned forever. how does that make it retarded of me not to know whats been going on?
i don't follow cobb with a cum bucket.....
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/atp-3071r-swap-how-lenny-gets-bt-63559/
Boost Tapering Suggestions (GT3071R - Stock Block) This thread Refback 06-15-2011 04:10 AM
Turbo upgrade? This thread Refback 03-31-2011 01:44 PM
Turboaufladung » Internes Wastegate This thread Refback 01-31-2011 11:05 AM
APT 3071R ANMSPD3 MazdaSpeed 3/6 - Big Turbo Builds 47 04-16-2014 11:51 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-12-2008 07:20 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-11-2008 05:50 PM
Page generated in 0.56023 seconds with 35 queries
