![]() | | #201 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score i wouldn't worry about it! you know what you've done to your car... if you haven't pulled to many boner moves, you will be alright ... pm me when videos are up !
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| The Following User Says Thank You to rigor For This Useful Post: | socks (12-13-2010) |
![]() | | #202 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score alright ...car is set..wga adjusted and locked down. mbc has softer spring and ball and will start running wg spring pressure to see what wot does on logs..... as far as the person that blew up it was hnda etr ... he swapped ko4 for pg reworked... did some runs last night and car pulled strong... today idk what happened but he shot up to 24psi and now has some serious fucken head noise... no hole in block. idle car sounds normal...but step on it a hair and u hear rattling up on the top end... compression is 145-160-160-160.... ill let him add to thsi if he wants.... but pretty demoralizing so ill do what i can to help
| The Following 5 Users Say Thank You to rodrigo For This Useful Post: | djuosnteisn (12-14-2010), Lex (12-14-2010), NJSPEED3 (12-13-2010), rigor (12-13-2010), skeeter149 (12-13-2010) |
![]() | | #203 | ![]() |
if you will leave the lock nut lose on the wga arm it is easily adjustable from the top of the car. Leave it lose for like a week or two until you get everything dialed in. It can't turn by itself.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 12-13-2010 at 03:51 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #204 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: Greenville, SC
Rep Power: 2562 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,586
Groans: 125
| Not Ranked : 0 score i wonder if he had a boost source to his wastegate pop off, this has happend to alot of people.... make sure you somehow secure all vac lines to and from the turbo. one popping off (especially on the atp turbos, they only have one line on the actuator), the boost will skyrocket.
__________________ 1994 Mazda RX7 - 20b-rew - S480sx - Injector Dynamics - Xcessive Manufacturing - Full Function Engineering - Haltech Elite 2500 |
| The Following 3 Users Say Thank You to socks For This Useful Post: |
![]() | | #205 | ![]() |
![]() Join Date: Mar 2010 Location: Washington
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 778
| Not Ranked : 0 score I wasnt planning on messing with my wg arm. But maybe I need to look into this. As for hnda etr..fuck...Hope in the end that its not a bad prab,though it sounds like it is. Ill will pray to the cargods that his car will be fine. I too have heard the vac lines poping off and causing insane boost. Is it that people are not clamping them down?
__________________ 2009 MS3 COBB AP COBB INTAKE COBB/TURBOXS TBE DNP TURBO MANIFOLD CXRACING FMIC TURBOSMART BPV JBARONE RMM TURBOSMART BPV JBARONE SHIFTERPLATE COBB RSB KONIG WHEELS/HANKOOK TIRES TIM BAILEY PROTUNE 291WHP/310WTQ *AWD MUSTANG DYNO* |
![]() | | #206 | ![]() |
| Not Ranked : 0 score zip tie everything guys...esp if you are using silicone hose if its close to heat use heat resistant ties... @ zx2 factory set preload on the ATP should net you around 12PSI pressure from my test. Loosen it up and you end up with ~11...tighten all the way ~14 BUT that isn't a stable way to leave it...much boost occiliation...
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 12-13-2010 at 04:20 PM. |
![]() | | #207 | ![]() |
Groans: 40
| Not Ranked : 0 score that is what i did ^^^^
![]() | | #208 | ![]() |
| Not Ranked : 0 score if the noise Roy is having is topside toward the passenger side he may have busted his VVT, which in turn may have bent some valves. if this is the case a much better outcome than a VTA block experience. Roy I am pullin for ya!
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following 5 Users Say Thank You to Dano For This Useful Post: | djuosnteisn (12-14-2010), FreeFlyFreak (12-13-2010), hnda etr (12-13-2010), NJSPEED3 (12-13-2010), rigor (12-13-2010) |
![]() | | #209 | ![]() |
| Fuck that PG turbo.... Glad we had some fail out of all of this... The suspense was killing me. Told you that your car is fine and your engine isnt beat... now lets get a real tune on there.
| The Following User Says Thank You to Haltech For This Useful Post: | NJSPEED3 (12-13-2010) |
| The Following User Says NO Thank You to Haltech For This Un-useful Post: | hnda etr (12-13-2010) |
![]() | | #210 | ![]() |
| Not Ranked : 0 score Thank you Dano Looks like Ill just leave it alone then. Think thats what Anthony=driver311 did, and hes running great. Think ill run ninja clamps and zip tie living shit out of all my connections, then have Peter North shoot some man glue on em to seal the deal lol...Dont wanna play the zoom zoom boom game because of a simple overlooked install step.
![]() | | #211 | ![]() |
| Not Ranked : 0 score Peter North FTW....get you some heat resist ties for the WGA nipple...gets hot down there... Tefzel ties 300* operating temp..they only come in ghey blue and teal but they are good chit. Heat stabilized nylon 257* and come in any color... http://www.cabletieguys.com/specialt...htm#tefzelties
| The Following User Says Thank You to Dano For This Useful Post: | zx2man (12-13-2010) |
![]() | | #212 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score ok...had to wait for my son to get out of school to go drive around. mbc turned all the way to zero leaves me with 15psi in 2nd.. 16psi in 3rd and about 16.5psi in fourth.... zero spike zero creep. its still daylinght and too many cars so i wont log until tonight. the car feels decent... i dont expect much with 15-16psi only i just want to get everything dialed in before i start messing with boost. incidentally once i had fixed wga i turned the mbc one click down and went out... touched..and i mean touched the gas in 2nd gear and fucken spun like it was on water.... i let off soon as i saw 21psi in 2nd and went back to soft spring and zero d out. egts are so much lower its not even funny...im talking about 2-300 degrees lower. ill take some below pics...right now im super tired, i took a couple lame ones from top. u can see a tapped silicone coupler for boost source. , u can also see how the cpe inlet doesnt actually mate up to the end of the machined turbo inlet. but its there and no leaks. ill add more shit as i go along.
| The Following 8 Users Say Thank You to rodrigo For This Useful Post: | 802MS3 (12-14-2010), djuosnteisn (12-14-2010), DSIT995 (12-13-2010), JacksonMS30 (12-13-2010), madvillain (12-13-2010), pearl_ms3 (01-01-2011), skeeter149 (12-13-2010), zx2man (12-13-2010) |
![]() | | #213 | ![]() |
| Not Ranked : 0 score so all it was was the WGA preload?? my CPE inlet is a POS as well and looks about like yours...you'ed expect better from them...What is another 1/4 inch of material gonna cost. edit: better get that boost source zip tied! I know it fits tight but well worth the .5 minutes to throw one on there.
| The Following User Says Thank You to Dano For This Useful Post: | rodrigo (12-13-2010) |
![]() | | #214 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score I used heat sleeves on the vac lines near the turbo and zip ties for the peace of mind. |
![]() | | #215 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score will do soon as i wake up from my nap. one thing worth mentioning i had to clock my turbo and cut firewall shielding off to clear the nipple from it...or wouldnt have been able to put a vacuum line on it
![]() | | #216 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score Nice and clean Lenny, cant wait to see some logs tomrw & Hnda etr - that sux so bad man, sorry about ur luck
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
| The Following User Says Thank You to DSIT995 For This Useful Post: | hnda etr (12-13-2010) |
![]() | | #217 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score so we took off the valve cover and took a look around... physically, everything looks fine... we cranked the motor over (without coils attached) to look at the cams and valve buckets and vtc and everything looked fine - no collapsed valves, no physical damage to the VTC or cams... So I button everything up and fired it up to see if the clattering sound is still there - yup... only now I can feel the clutch pedal vibrating when I let it out almost all the way... so looks like it's a bent rod... FML... Not sure what I'm gonna do at this point... Thanks for the well wishes guys (except Kevin - smnf)
__________________ ![]() [SIGPIC][/SIGPIC] |
| The Following 12 Users Say Thank You to hnda etr For This Useful Post: | -cj- (12-13-2010), 802MS3 (12-14-2010), cld12pk2go (12-14-2010), Dano (12-13-2010), djuosnteisn (12-14-2010), Docnox (01-02-2011), DSIT995 (12-13-2010), Fobio (12-13-2010), Lex (12-14-2010), madvillain (12-13-2010), MATT DAMOND (12-14-2010), skeeter149 (12-13-2010) |
![]() | | #218 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score fycn |
| The Following User Says Thank You to phillyb For This Useful Post: | hnda etr (12-13-2010) |
![]() | | #219 | ![]() |
Groans: 40
| Not Ranked : 0 score sorry to hear that man
| The Following User Says Thank You to rigor For This Useful Post: | hnda etr (12-13-2010) |
![]() | | #220 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score damn roy sorry to hear and hope you get back up and running asap ![]()
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
| The Following User Says Thank You to skeeter149 For This Useful Post: | hnda etr (12-13-2010) |
![]() | | #221 | ![]() |
Groans: 90
| Not Ranked : 0 score It been fucked good Thanks Guys! I would have bet money it would have happened to Lenny and not me... lol...
__________________ ![]() [SIGPIC][/SIGPIC] Last edited by hnda etr; 12-13-2010 at 06:22 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to hnda etr For This Useful Post: | rigor (12-13-2010) |
![]() | | #222 | ![]() |
| Not Ranked : 0 score yes very sorry to here about the diagnosis... still bent rod better than VTA rod...right? you don't need to source a block now. it still sucks nuts though....
![]() | | #223 | ![]() |
Groans: 90
| Not Ranked : 0 score Thanks Dano... The irony of it all is, I just got a torn down motor from Ken at PG (after making payments for the last 10 months lol) about 2 weeks ago... it's sitting on a pallet in my driveway...
| The Following User Says Thank You to hnda etr For This Useful Post: | djuosnteisn (12-14-2010) |
![]() | | #224 | ![]() |
| Not Ranked : 0 score well FML at trying to cheer you up! LOL i'll just keep my fingers to my self...wait...no I mean keep my mouth shut...wait...no not that either....fuck it!
| The Following User Says Thank You to Dano For This Useful Post: | hnda etr (12-13-2010) |
![]() | | #225 | ![]() |
Groans: 90
| Not Ranked : 0 score lol... no problem bro... anything to cheer me up!
![]() | | #226 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score idk wtf but im so tired i cant sleep...there goes my godamn nap. oh well, ill go lift the car up and take some below pics, plus i gotta bolt back up the bellypan (left it off purposely to reveal any possible leaks. ill post up some pics in an hour
| The Following User Says Thank You to rodrigo For This Useful Post: | zx2man (12-13-2010) |
![]() | | #227 | ![]() |
Groans: 1,940
| Not Ranked : 0 score this is how i found out... lenny called me (that's right, he actually called me). he said, i have good news and bad news. now, normally i ask for the bad news first so the good news seems better, but this was car related, so i said something along the lines of, "i want the good news first, cause i'll care more about the bad news." lenny goes on to describe what he did to the wastegate and i said, "yeah yeah yeah, way to go...bad news is...you blew?" he said no, buuuuuuuuuuuuuuuuuuuuuuuuuuuuuut, "roy did" laughter ensued afterward... fuck you roy. |
![]() | | #228 | ![]() |
| Not Ranked : 0 score Yeah sucks Balls for Hndr etr....but looks like hes got a option sitting in his driveway. Maybe one of your rods was already tweaked, and that 24 psi of love did it in, who knows. But best of luck to you in getting your car up and running. Lenny-Looking good, thanks for taking pics, and looking for further progress. Is that the ideal location for the boost source? Do you make a pre-hole first? ie like pre-drill.
![]() | | #229 | ![]() |
Groans: 113
| Not Ranked : 0 score Yup you do need to drill and install you're self Dave. That is just a fitting the comes from ATP with the turbo. |
| The Following User Says Thank You to NJSPEED3 For This Useful Post: | zx2man (12-13-2010) |
![]() | | #230 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1905 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score Move the boost source to the intake manifold and you will have more consistant boost, that my suggestion. My boost holds the same in every gear. Also when I turn my bc all the way down its at 12psi I believe. Glad to hear all is well.
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp Last edited by driver311; 12-13-2010 at 07:42 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to driver311 For This Useful Post: | zx2man (12-13-2010) |
![]() | | #231 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score zx2 ..yes u gotta drill the coupler or tap the compressor housing and get a bronze one threaded in there. i waited until everything was in place before drilling.... i like to do things in order and drilling prior didnt seem prudent... plus i tried keeping the vacuum lines as short as possible for the mbc. alright took some more pics from the bottom where u can actually see the turbo. i also got some of the ko4 v2 I had on there . U will see all the stainless lines, the one water line i was to lazy to cut to size so i just looped it... it clears the dp and the axle so it just looks funky but works perfect. got pics of the bracket and worked like a fucken charm...was able to push it up there to desired height and bolt it down tight... the turbo feels super solid there u can also see where i had to cut a lil off the firewall heat shielding (the metal one not that cardboard one) just to clear and give the wga some room..... (zx2 remember u might run into issues man.... clocking the turbo was perfect) also I took a pic of the axle seal we replaced. all in all i am super content that everything seems in order... im pretty bummed roy is feeling the opposite...but you know we will help u figure this shit out man. here s some pictars ko4 v2 i bought from anthony (driver311) looks a lil white ... (race gas , leaded...turns yo shit light gray) oil return line (didnt have to shorten it.... (trick is mounting the fitting to the block first and then hooking up the hose to it lil long on the waterline to the heater lol oh shit.... did i forget a sock up there?? oh no...thats ma awesome bracket!!!!!!!!!!! lil bit wider shot of the set up.....lines have no way to hit anything as odd as they might look heres a nice shot of the subpar inlet from cpe... (great job guys!!!) so far i have talked to at least 4 other guys that noticed this!!!)...btw i got an email today from cpe trying to offer help or how they could fix the situation... ill respond later theres the shielding i cut off... at the point i cut it it really isnt blocking the brake lines so fuck it for reference on rod length heres the wga rod adjusted and heres the axle seal we replaced.... hope i can help anyone trying to go for an atp iwg set up..... i see no issues with this set up... turbo spool is quick... there is no creep... no spike.... just super fun turbo. as the weeks go ill be getting some help tuning this and ill post some results. .... dont expect dynos.... i never go to them., i have my own views on that scene..... when the time comes ill dyno it by trap speed.... thanks for the support and the help , dano, dj, sean, cldpck, mark for the hook up... the local socal guys tha helped me yesterday , tony, roy , julio....everyone that i have learned from i am truly very appreciative that this turned out successfuly anyways enough bullshit for one day.... whos next?????
| The Following 13 Users Say Thank You to rodrigo For This Useful Post: | -cj- (12-13-2010), Addikted To Boost (12-14-2010), alien_sporez (03-23-2011), cld12pk2go (12-14-2010), Dano (12-13-2010), djuosnteisn (12-14-2010), Fobio (12-13-2010), NJSPEED3 (12-15-2010), PaPaSpeed (12-13-2010), predapio (12-14-2010), rigor (12-13-2010), socks (12-13-2010), zx2man (12-13-2010) |
![]() | | #232 | ![]() |
| Not Ranked : 0 score good job and good pictoral... BTW...only way CPE can fix their POS inlet is to re-tool their mold...I had forgotten all about my anger with this...I expected more from CPE...oh well no vendor is perfect...thanks for bringing it back to the surface Lenny ![]() enjoy the new powa! I guess a 3071 is enough bigger to require cutting the shielding from the firewall. I didn't need to do that and I think I have 1/2 inch to spare... Anthony, The CPE inlet bottoms out on the inside taper in the inlet before the outside bottoms out on the turbo flange. You end up with just enough surface contact between the inlet pipe and turbo flange to just barely get the clamp down. If it isn't lined up just right it will come off. When mine is lined up good enough to clamp the inlet is not even square with the turbo flange. 12PSI is also what I saw with factory ATP preload.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 12-13-2010 at 08:46 PM. |
![]() | | #233 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score dang wheres my mention... i even dropped $90 on crows foot tools because i care lenny, because i care... im just glad we werent stuck there all night and tony got is family dinner in.
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| The Following 4 Users Say Thank You to m4tic For This Useful Post: |
![]() | | #234 | ![]() |
| Token black guy support.. only at Nator OG... See, Darkgums should take notice! Get your FP sorted out yet bro?
| The Following User Says Thank You to Haltech For This Useful Post: | m4tic (12-13-2010) |
![]() | | #235 | ![]() |
| Not Ranked : 0 score Dano, mine sits perfectly flush. Weird. Should I hack it up so it doesnt so I can be part of the group???
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
![]() | | #236 | ![]() |
| Not Ranked : 0 score Too late. You're and outsider. Hope you enjoy your properly fitted TIP.
![]() | | #237 | ![]() |
![]() yea swapped out the relief valve and im good to go
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // | |
| The Following 2 Users Say Thank You to m4tic For This Useful Post: | cld12pk2go (12-14-2010), djuosnteisn (12-14-2010) |
![]() | | #238 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score ^^^ thanks boynton... i seriously appreciated u flying to sears for that crows foot, saved my ass thank you very much.
| The Following User Says Thank You to rodrigo For This Useful Post: | m4tic (12-14-2010) |
![]() | | #239 | ![]() |
Groans: 356
(Thread Starter) | Not Ranked : 0 score ok, here some more pics of the day. here s the turbo in car b4 the inlet.... u can see there is plenty of room to get that inlet on there and it not leak... just looks like complete shit. heres a nice shot of my tits and gut.... oh ya... I forgot to mention...because the inlet is such a bad fit and the metal insert/reducer is so fucken odd shaped I had to cut the sri about an inch short for the bracket to line up..... here s the awesome insert/reducer..... makes it great having a ring basically that the clamp needs to fit perfectly over to seal....(<<< insert sarcasm here) home stretch ....(JCMS07, me, bmorrisj, tony) and here is yours truly hoping to god I dont get wedged under the car !!! (how u guys like my farmers tan?)
| The Following 12 Users Say Thank You to rodrigo For This Useful Post: | -cj- (12-14-2010), acmhd7 (12-14-2010), djuosnteisn (12-14-2010), JacksonMS30 (12-15-2010), jracer (12-14-2010), madvillain (12-14-2010), MATT DAMOND (12-14-2010), NJSPEED3 (12-15-2010), PaPaSpeed (12-14-2010), predapio (12-14-2010), SpeedSixxx (12-14-2010), zx2man (12-14-2010) |
![]() | | #240 | ![]() |
| COOL STORY BRO ![]() Join Date: Nov 2010 Location: Cape Girardeau Mo/San Diego CA
Rep Power: 2238 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,863
Groans: 179
| Not Ranked : 0 score good shit man, good luck with the car, enjoy the new found tire spinnage!
__________________ ![]() JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley ZOOM ZOOM BOOM |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/atp-3071r-swap-how-lenny-gets-bt-63559/ | ||||
| Boost Tapering Suggestions (GT3071R - Stock Block) | This thread | Refback | 06-15-2011 04:10 AM | |
| Turbo upgrade? | This thread | Refback | 03-31-2011 01:44 PM | |
| Turboaufladung » Internes Wastegate | This thread | Refback | 01-31-2011 11:05 AM | |
| APT 3071R | ANMSPD3 | MazdaSpeed 3/6 - Big Turbo Builds | 47 | 04-16-2014 11:51 AM |
| Toyota exec tries to cool plug-in fever | Haltech | Automotive News | 0 | 06-12-2008 07:20 AM |
| Toyota exec tries to cool plug-in fever | Haltech | Automotive News | 0 | 06-11-2008 05:50 PM |
