Like Tree5Likes
 Old 12-14-2010, 10:56 PM   #281
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
zero spikes, zero creep with mbc lol
we'll see how the ebc set up goes....
ill do a couple of 4th gear pulls tonight and post em , wont be anything impressive... I ll set the boost to around 19-20 and we can see what we see...the logs look seriously just like my ko4 did, just added flow.... richer AFR and a bit lower timing.
rigor (12-15-2010)
 Old 12-14-2010, 11:06 PM   #282
Awesome, post-em up!
 Old 12-14-2010, 11:08 PM   #283
ljudgeii's Avatar
Posts: 180   (View Stats)
ljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond reputeljudgeii has a reputation beyond repute
Thanks Lenny, Socks, and Dano for the clarification on the EBCS.
07 Black Mica with Sunroof"
11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles)
"I'm back Baby" says the almighty Bender
CURRENT MODS:
Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN:
VDyno 351hp and 331tq
BEST 1320:
COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear)
ljudgeii is offline   Reply With Quote
 Old 12-15-2010, 01:03 AM   #284
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ok, here are 3 logs. 2 4th gear wot pulls and one 5th gear wot pull..... until I get used to the car and stop fearing boom boom I sort of roll into the throttle rather than stab at it.
anyways, this is my old ko4 map just running it on my 3071... AFR kinda rich, timing is decent but not super advanced..... I mean basically the car runs the same way....except faster.
all logs were done at 19psi.... keep in mind that with this same map and the ko4 boosting 21+psi I never saw more than 250 gm/s or so.
hopefully with some tuning I can land around 350whp which is my goal.
4th gear log 19psi.csv
4th gear wot 19psi.csv
5th gear wot 19psi.csv
like i stated, by no means am I the benchmark of what this turbo can do.... so do not try to compare to the results of others for 2 reasons a) I am untuned b) worn fucken motor with most likely low compression
either way, I am pretty fucken impressed the kinda power these fucken turbos can make.....I m gonna have me some fun hunting down races
Docnox (01-02-2011), rigor (12-15-2010)
 Old 12-15-2010, 05:36 AM   #285
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
remember lenny, your maf g's are only accurate if your maf is properly calibrated.
but, looking at your LTFT before you hit it hard, your maf is relatively close.
 Old 12-15-2010, 06:01 AM   #286
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
All i learned, i learned from WikiPedia... lol..
I just read up on CC's when I was hearing people talk about how needed they were on our cars...
From a unit operations standpoint, catch cans are just demisters.
The baffles are essentially just coalesing pads that give a high surface area surface with low pressure drop for mists to hit/combine into drips and fall to the bottom instead of carry over with the bulk of the air.
In my current facility, we use a high density plastic mesh for this function, but anything that won't corrode will work.
Which map are you running?
Last edited by cld12pk2go; 12-15-2010 at 06:01 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-15-2010, 06:44 AM   #287
driver311's Avatar
Posts: 1,769   (View Stats)
Why so rich on meth lenny? YOur leaving a bunch of power on the table. It would be nice to see your fp's holding in the 1800s! otherwise looks decent.
Mazdaspeed
 Old 12-15-2010, 07:08 AM   #288
socks's Avatar
Groans: 125
Where are you currently working? I have quite a bit of experience in chemical plants all over North America. Would be funny to find out we've crossed paths.
 Old 12-15-2010, 08:26 AM   #289
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
pretty much ots stage 2 sri fmic 93 oct with some added load... just to get started
well thats just how it landed.....besides for initial running , to establish that boost isnt nuts, nor timing, nor anything weird a nice margin of safety is good. i havent done jack to the map also
Last edited by rodrigo; 12-15-2010 at 08:26 AM. Reason: MSF Database - Automerged Doublepost
rigor (12-15-2010)
 Old 12-15-2010, 08:51 AM   #290
Looks good Lenny. You're probably around the 330whp point now. How does the butt dyno feel?
jwilkins88 (12-15-2010)
 Old 12-15-2010, 09:19 AM   #291
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
looks like a pretty solid start for an OTS map.
timing is flatlined at 7.5 in the meat so much room for improvement there hahaha, I am now a timing expert....not
so I have been an advocate for EBC boost control from day one and I am glad to see that you are giving it a try...I need to look back and see if all those quotes of yours to me about MBC MBC MBC are still there and compile them into one post hahaha
Believe it or not, I just about have my Grimmspeed EBC fine tuned with no boost occiliations. It was a long road trying to figure out the ECU logic but once I threw out all the Boost tables, via tuning them out, I narrowed my efforts down to the Load Dynamics table which has all but eliminated my occiliation...I am guessing 2 more map revisions and I'll have it nailed down. [famous last words here] This timing stuff has slowed progress but I am done with timing for now.
All that to say I have absolutely no doubt Christian can make you want to sell your hallman in a week or two of tuning the EBC.
Enjoy the fun!
Lex (12-15-2010)
 Old 12-15-2010, 09:47 AM   #292
Enjoy the fun!
How much timing headroom do you think he has Dan? I see a little knock creep in near that 5500 point.
 Old 12-15-2010, 10:07 AM   #293
Trail of Fail
Dano's Avatar
yes the KR is consistently there at 5-5.5k so I doubt he could go up there but as I had to do, he could lower advance prior to 5K so that he keeps advancing through that RPM??
note that I phrased that answer as a question because I was being totally sarcastic about knowing chit about timing
so is it better to flatline timing to quell KR or is it better to lower timing prior to the KR and let timing advance thru the event??
Edit: BTW around 4.5 K is where I was flatlining advance at 8* to kill the KR so an answer to my above question is of great interest to me as well.
Edit 2: I could live with .7 KR there as long as the sensor was turned on above that point...right now that .35 could increase to .7 or 1.0 above 5.7K in the very next cell but we don't see it.
 Old 12-15-2010, 11:05 AM   #294
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ya from what i calculated based on my logs from old vs now, and jcms07s new s2 bnr logs and his dyno I figured about that same number lol the car feels great, its hard to describe without sounding like everyone else, but the fucker pulls pulls pulls and then u hit 7k lol ..... spool up is quick and even...im loving it , I just want to get a solid 350whp map and be done..... that lil mbc knob is pretty fucken tempting !!!!!!!!!!!!!
aaron asked me this morning, do u wish u would have gotten a 28 or a 76 rather?...no way, this turbo is perfect.
Enjoy the fun!
i am enjoying the fun, timing i can never have as much as u guys...my car loves knocking... but for my goals i think i have more than enough turbo to get a super safe tune ...might require more boost and less timing to keep that KR from showing its face
also guys, why did load logging change from % to now 1.xx or w/e..... i never changed any pid on the data log list and now it reads 1.xx rather than 180-210 or w/e...
Last edited by rodrigo; 12-15-2010 at 11:12 AM. Reason: MSF Database - Automerged Doublepost
jwilkins88 (12-15-2010), rigor (12-15-2010)
 Old 12-15-2010, 11:26 AM   #295
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
I was thinking the exact same thing when I was looking at your logs....
 Old 12-15-2010, 11:26 AM   #296
Trail of Fail
Dano's Avatar
dont' knwo why cobb changed it but they did move the decimal around a bit. I guess so it now looks like the load axis in the ATR tables. IDK
 Old 12-15-2010, 12:56 PM   #297
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
oh so 1.80 now is what 180 used to be before??? I didnt want to assume they had just moved the decimal place
djuosnteisn (12-15-2010), rigor (12-15-2010)
 Old 12-15-2010, 03:28 PM   #298
yup, there was a load parameter before that was x.xx instead of XXX. I guess they standardized.
 Old 12-15-2010, 03:30 PM   #299
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well im kinda scared of flooring it at 3k to see if it goes over 2.0 lol ... I need to get used to flooring it and believing it wont come apart before I go trying out to see how much load it makes down low
 Old 12-15-2010, 03:33 PM   #300
Baby steps ... make sure all boost lines are secured first though.
 Old 12-15-2010, 03:48 PM   #301
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
oh i did that....zip tied them all.... everything looks really good, just a bit of a mind fuck knowing that you are making more power and the fear of everyone u know that has blown......including the person that swapped turbos in the same driveways on the same day as you lol
baby steps indeed
djuosnteisn (12-15-2010), NJSPEED3 (12-17-2010), rigor (12-15-2010)
 Old 12-15-2010, 04:05 PM   #302
Eth/Meth Junkie
cld12pk2go's Avatar
I am currently working around Columbus, OH for DuPont making Polyimide films.
I have previously worked for a steel cord plant in Dyersburg, TN, a zinc smelter in Clarksville, TN, and a specialty chem company in Chattanooga, TN.
 Old 12-15-2010, 04:13 PM   #303
Trail of Fail
Dano's Avatar
baby steps indeed
the next series of pics we see from Lenny will be tripple zip tied EVERYTHING...
 Old 12-15-2010, 04:15 PM   #304
Eth/Meth Junkie
cld12pk2go's Avatar
I prefer hose clamps myself...
 Old 12-15-2010, 04:25 PM   #305
Trail of Fail
Dano's Avatar
yes I use the little OEM clamps in the high heat areas and heat resistant zip ties everywhere else.
 Old 12-15-2010, 04:28 PM   #306
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
like rubbers man, u always gotz to double bag it
 Old 12-15-2010, 04:29 PM   #307
Trail of Fail
Dano's Avatar
werd
 Old 12-15-2010, 04:36 PM   #308
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Lenny, torque is what kills. Your doing a smart thing by going bt. Your EGT comment alone shows how strained the k04 was in higher rpms (way out of its efficiency)... and we all know who quick the boost comes on with it.
If your really concerned, be sure to tell christian. He'll keep the power in the upper rpms for you.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Dano (12-15-2010), rigor (12-15-2010), rodrigo (12-15-2010)
 Old 12-15-2010, 05:39 PM   #309
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
ya definitely , I know you guys think its overcaution or w/e, but I am not exaggerating when I tell you that I beat the shit out of my car... I have proven it with my cracked turbo, beat to shit clutch, logs of KR at the strip etc etc.....
and since I never really floor it until at least 3700 how well or powerful the car runs below that is completely inconsequential to me
but i will surely address my concerns to xtian.... besides he has never struck me as a super agressive tuner that likes to take chances..... I have dealt with him before when we were developing the 1.01 maps and shit.... he s good peeps.
djuosnteisn (12-16-2010), rigor (12-15-2010)
 Old 12-15-2010, 06:54 PM   #310
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
were is the video faggot! you had me run the dog shit out of mine! for your pleasure!
wtf double standard?!?
i don't care if your shitting down one leg, and wiping with the other....
VIDEO BITCH!
HAHA!
kinda nerve racking isn't it ?
at 104000 2 bent rods
tuned by nishan
The Following User Says Thank You to rigor For This Useful Post:
 Old 12-15-2010, 07:12 PM   #311
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
i no has video recorder..i haz a camera (digital for pics) it records but the shit is just like whitenoise on tv.....
besides man....all i will hear is ...u sure the BT is in there lol... my shit aint quick like u guys .....not yet anyways.
and yeah its super nerve racking ..... i start hearing ticks and shit and im like "fuck is that rod knock? piston slap? ....... but damn feels good to floor it and let it wind up to 7k
djuosnteisn (12-16-2010), NJSPEED3 (12-17-2010), rigor (12-15-2010)
 Old 12-15-2010, 07:33 PM   #312
I know i would blow my car up with a BT because of how i drive my car.. i like boost and i like it down low for starters. If you can get the boost spikes tamed with the EBC, then its going to have to be standard for everyone to go this route for the map to be compatible. Perhaps a comprehensive big turbo FAQ is now in order.
 Old 12-15-2010, 07:46 PM   #313
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
well like I said, I was fine with just going with mbc and just tuning AFR and timing.... but I dont give a shit about tuning for gears, nor do we have such drastic weather changes, nor am I that picky.
but, the leading Cobb tuner says he was confident in his ability to tune BT cars with oem bc that I cannot ignore what he said.... soon as we begin I'll share what we find.
I just wanna pop a wheelie in a car again, is that too much to ask for?
rigor (12-15-2010), Speed3eak (12-15-2010)
 Old 12-15-2010, 08:09 PM   #314
Going backwards?
djuosnteisn (12-16-2010), predapio (12-17-2010), rigor (12-15-2010)
 Old 12-15-2010, 08:11 PM   #315
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
Going backwards?
ill take it any way i can dude......even if the wheelie bar has to go on the front bumper!
in all seriousness, i am quite impressed with the mph I will be able to get out of this 4 cylinder.... would have never thought so in a million years.
 Old 12-15-2010, 08:20 PM   #316
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Sit in the trunk...
The Following 7 Users Say Thank You to hnda etr For This Useful Post:
cld12pk2go (12-16-2010), Dano (12-15-2010), djuosnteisn (12-16-2010), NJSPEED3 (12-17-2010), predapio (12-17-2010), rigor (12-15-2010), rodrigo (12-15-2010)
 Old 12-15-2010, 08:23 PM   #317
MS6 Alan's Avatar
Posts: 453   (View Stats)
MS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the worldMS6 Alan is the leader of the world
I'm pretty confident in "xtian's" abilities with the ECU controlling boost.
I've discussed these things many times with him, trey, and calvin. All very knowledgeable about this platform.
I'm ready to go BT but hesitate on my 106k motor without building up the extra motor I have. I don't want to pull out a perforated block.
I havent been on MSF in some time, but this thread has really peaked my interest, keep it up lenny!
'06 Mazdaspeed6 GT - Titanium Gray
- ATP 3076r - CP-e XCel Intake - CP-e FMIC - CP-e 4" TIP - COBB AccessPORT - Medieval EWG Manifold - Tial 44mm EWG - ATP Downpipe - Custom 3" Dual Magnaflow CBE - JBR EGR Block Off - HKS SSQV BPV - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - Technafit SS Clutch Line - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC -
MS6 Alan is offline   Reply With Quote
The Following 2 Users Say Thank You to MS6 Alan For This Useful Post:
djuosnteisn (12-16-2010), rodrigo (12-15-2010)
 Old 12-15-2010, 08:29 PM   #318
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
thanks alan.... i had to do a double take the other day in shout.... u dropped out for a while, i figured the law caught up to u and were doing time. lol
yeah i dont know what to tell u about 106k miles..... i have 80k.... and i burn a good qt of oil every 3-3500 miles.... so my 80k might be more worn than your 106k... really depends how hard u drive it. u been around long enough to know that the smart choice is always to build it first.... but , money, impatience etc etc makes us do dumb shit.
i think and hope this turbo is large enough where it doesnt generate enough low end grunt to bend shit and on the other side I will keep it at 350whp just to leave myself a margin of error... bending rods is one thing... there are alot of other ways to go boom boom with high mile cars.... so thats my plan, but u guys can bet that as soon as i feel more comfortable and the tune gets dialed in, im gonna treat it like before.... beat the living shit out of it..its the only way.
 Old 12-15-2010, 09:01 PM   #319
Trail of Fail
Dano's Avatar
thanks for the new sig lenny!!
rodrigo (12-16-2010)
 Old 12-15-2010, 09:13 PM   #320
rigor's Avatar
Groans: 40
im just teasing! good to see it going well !
i hear their is some gay rear wheelie bars, for front wheel drives to help keep the rear from squatting so bad, to help hook up the front end...
has anyone seen a set? and do they help?
tuned by nishan
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/atp-3071r-swap-how-lenny-gets-bt-63559/
Boost Tapering Suggestions (GT3071R - Stock Block) This thread Refback 06-15-2011 04:10 AM
Turbo upgrade? This thread Refback 03-31-2011 01:44 PM
Turboaufladung » Internes Wastegate This thread Refback 01-31-2011 11:05 AM
APT 3071R ANMSPD3 MazdaSpeed 3/6 - Big Turbo Builds 47 04-16-2014 11:51 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-12-2008 07:20 AM
Toyota exec tries to cool plug-in fever Haltech Automotive News 0 06-11-2008 05:50 PM
Page generated in 0.61987 seconds with 33 queries
