 Old 02-02-2012, 03:09 PM   #1
MS3KO's Avatar
Posts: 579   (View Stats)
MS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the worldMS3KO is the leader of the world
Default BT Help
Whats up guys, so I finally got around to finishing up my turbo build. But im running into an issue. When i go to start up the car it revs to about 2k but then just dies immediately, even when i throttle the gas it revs a little bit but then dies. I checked all my lines and everything is hooked up nice and tight to my knowledge. Right now im still on a stage 2 base map, so i was thinking the tune might be the issue but im not 100% sure. Any help is appreciated. All mods are in my sig. Thanks in advance!
2009 MazdaSpeed 3 Metro Grey-T3 Gt3071, Re-flanged RR mani, 44mm Tial WG, Cusom DP, Custom 4in to 3.5in intake, Custom 3.5in maf, Custom FMIC kit, Tial BOV, EVO Prosport Boost gauge, EVO oil temp gauge, AEM wideband, TRZ RMM, JBR PMM, JBR TM, JBR Shifter Plate, TWM SS, Hks CBE, COBB AP, Road Magnet Springs.
PERM Tuned!///389hp 360tq///Best time:12.2 @117 (with new tires 11's here i come!)
Hit up BC Autoworks for all your powder coating needs!
MS3KO is offline   Reply With Quote
 Old 02-02-2012, 03:11 PM   #2
XLT_66's Avatar
Posts: 850   (View Stats)
Have you done any work to your MAF scaling since you increased it to 3.5"?
2009 CWP MS3 Sport
SOLD!
XLT_66 is offline   Reply With Quote
The Following 3 Users Say Thank You to XLT_66 For This Useful Post:
atvfreek (02-02-2012), MS3KO (02-02-2012), rfinkle2 (02-02-2012)
 Old 02-02-2012, 03:14 PM   #3
MS3KO's Avatar
Nahh I haven, I really didnt mess with anything involving the tune since im not very knowledgable about it.
 Old 02-02-2012, 03:34 PM   #4
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
You need to scale you MAF or your car wont run.
Contact one of the good tuners on here.
Beanfab / Tuned by Nishan
The Following 6 Users Say Thank You to doubleflusher For This Useful Post:
Chimmike (02-02-2012), Don06speed6 (02-02-2012), dougefresh_ (02-03-2012), MS3KO (02-02-2012), rfinkle2 (02-02-2012), trf5000 (02-04-2012)
 Old 02-02-2012, 03:35 PM   #5
MS3KO's Avatar
Sweet deal man thanks, ive been on the waiting list for a perm tune for months now im just gonna contact dustin and see what he says
The Following User Says Thank You to MS3KO For This Useful Post:
doubleflusher (02-02-2012)
 Old 02-02-2012, 05:10 PM   #6
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
@Lex!! Get in here and whip this dude into shape!
2006 Mazdaspeed6 GT BCM
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP
HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM
Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate
Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN
psychophyr is offline   Reply With Quote
The Following User Says Thank You to psychophyr For This Useful Post:
MS3KO (02-02-2012)
 Old 02-02-2012, 08:19 PM   #7
atvfreek's Avatar
Posts: 7,787   (View Stats)
If you have a 3.5" maf housing multiply your maf curve by 1.3074
Highlight the maf values>enter "m" > then 1.3074 across the whole maf cal. That should get you in the ballpark
You have to do this on both maf table a and b
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 02-02-2012, 08:56 PM   #8
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
this is too small. A 3.5" maf housing, probably has a .125" thick wall giving an ID of 3.25". Stock ID is like a 2.62" iirc. (3.25/2.62)^2 = 1.54. Scale by that much and that should get you close
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
atvfreek (02-03-2012)
 Old 02-02-2012, 08:28 PM   #9
bmylez's Avatar
Posts: 3,197   (View Stats)
1.3074? Interesting. I have cp-e big MAF and I started off with 1.6. It was pretty damn close.
2007 CTS-V - Trying to sell
The Following 2 Users Say Thank You to bmylez For This Useful Post:
86AmishMs3 (02-02-2012), atvfreek (02-02-2012)
 Old 02-02-2012, 08:39 PM   #10
atvfreek's Avatar
Hmmm, I simply did the math for 3.5"(88.7mm) divided by 68mm which is what most aftermarket maf housings are.
Tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 02-02-2012, 09:02 PM   #11
86AmishMs3's Avatar
Groans: 338
Tappin
Cross sectional area of a circle = pi*r^2. To get the scaling take fraction of the two.
To OP
CA1= pi*r1^2
CA2= pi*r2^2
r=d/2
Scaling factor = CA2/CA1 = (d2/d1)^2 pi cancels out and just becomes a squared ratio of the internal diameters.
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
 Old 02-03-2012, 04:51 AM   #12
bmylez's Avatar
Yes, you get 1.54 when you compare their surface areas, however, the MAF sensor is now sitting even farther away from the center of the pipe. This means you need to add a little extra to compensate for that. Like I said, 1.6 (which was recommended by aaronc7, btw) was a very good starting point. I think my idle trims were like +6.
 Old 02-03-2012, 05:40 AM   #13
atvfreek's Avatar
That's good to know.
Sorry if I gave the incorrect data, I used the help file spreadsheet, and just rechecked it in there again, which still gives the incorrect #.
Although I used that spreadsheet for a 3.25" intake a while back, and it didn't seem that far off. And got me within 7%.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 02-03-2012, 03:03 PM   #14
bmylez's Avatar
The help sheet is *wrong*. They use the area for a circle, not the surface area for a sphere. So all they do is compute the ratio of the radii.
 Old 02-03-2012, 10:05 PM   #15
MS3KO's Avatar
So dj hooked up with a base tune for my 3.5 intake and the car is running! Its rough but thats what i expected. More updates and pic coming soon!
The Following 2 Users Say Thank You to MS3KO For This Useful Post:
atvfreek (02-04-2012), doubleflusher (02-04-2012)
 Old 02-03-2012, 11:43 PM   #16
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
let me see a pic of your intake bro, majority of people can cal your maf, if the how to looks too crazy.
 Old 02-04-2012, 07:09 AM   #17
MS3KO's Avatar
Truee no doubt man im gonna take some pics soon and post them up.
Page generated in 0.35808 seconds with 26 queries
