Like Tree41Likes
 Old 07-28-2011, 07:25 AM   #41
708
Erich's Avatar
Posts: 4,274   (View Stats)
Originally Posted by jracer View Post
is the clutch a one off custom ? whats the flywheel weight ?
cost for that set up ?
Custom yes, doesn't have to be one off though. I am not 100% sure on the flywheel weight, I can say it feels good though... not temperamental for daily driving at all. Will get the actual weight of the flywheel later today. It also required a spacer on the end of the slave piston (between the piston and the fork) because it is thinner than stock. It is also larger radius but does clear the bell housing with no interference.
The Following 6 Users Say Thank You to Erich For This Useful Post:
AJ713 (07-29-2011), Alpha (07-28-2011), djuosnteisn (07-28-2011), jracer (07-28-2011), kmac (07-28-2011), MS3-a(sore)ASS-rex (07-28-2011)
 Old 07-28-2011, 04:11 PM   #42
708
Erich's Avatar
Time to start giving it some mild boost. Trip A is since the engine went in.
The Following 11 Users Say Thank You to Erich For This Useful Post:
06Speed6 (07-29-2011), 802MS3 (07-29-2011), AJ713 (07-29-2011), djuosnteisn (07-28-2011), dougefresh_ (07-28-2011), essejkcamraw (07-30-2011), jracer (07-28-2011), kmac (07-28-2011), mason (07-31-2011), MS3-a(sore)ASS-rex (07-29-2011), Realgib3 (07-28-2011)
 Old 07-28-2011, 04:28 PM   #43
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
cant wait to see the numbers this thing puts up!
Whoever made your IM, should start making more/selling them! haha
860whp/677wtq
2.7 V6 Ecoboost
Erich (07-28-2011)
 Old 07-28-2011, 05:29 PM   #44
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Nice.
Erich (07-28-2011)
 Old 07-28-2011, 05:50 PM   #45
mason's Avatar
Posts: 946   (View Stats)
Holy fuck! this thing looks so bad ass! GREAT WORK
The Following 2 Users Say Thank You to mason For This Useful Post:
Erich (07-28-2011), kmac (07-28-2011)
 Old 07-28-2011, 07:46 PM   #46
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
Whoever made your IM, should start making more/selling them! haha[/QUOTE]
If you wanna pay between $1850 to $2300 lol..
SPEED6 KILLAH is offline   Reply With Quote
The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
Chimmike (07-31-2011), Erich (07-28-2011)
 Old 07-28-2011, 07:48 PM   #47
BrianB6's Avatar
Posts: 400   (View Stats)
this thread is making my pants go crazy
2016 - WRX -Cobb AP - Perrin Shift Stop - Perrin Trans Mount - Whiteline Positive Shift Bushings
2006 - MS6 - Dead RIP
The Following User Says Thank You to BrianB6 For This Useful Post:
Erich (07-28-2011)
 Old 07-29-2011, 08:45 AM   #48
ViRtUaLheretic's Avatar
Posts: 38   (View Stats)
ViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant futureViRtUaLheretic has a brilliant future
I love the water/air IC setup and direct port w/m setup on the Intake Manifold!
What sort of temps are you seeing?
Are you able to reach sub ambient temps?
I don't care if it's filled with horse semen so long as it fixes my car
ViRtUaLheretic is offline   Reply With Quote
The Following User Says Thank You to ViRtUaLheretic For This Useful Post:
Erich (07-29-2011)
 Old 07-29-2011, 08:58 AM   #49
708
Erich's Avatar
Right now our temps are high because the intake air temps are high. Either this weekend or next we are going to build a box for the filter so it pulls its air from the fender in front of the wheel instead of the engine bay. With intake air temps at around 125-130 (way too high) we are seeing boosted air temps starting around 100 and climbing to about 108 after several long pulls in rapid succession. Also, that is just on 100% water for now. After we pull it apart to clean and powder coat it we plan to put fluid in meant for w/a applications.
Also, we haven't started upping the boost yet, but have started working on fuel and timing. The car pulls hard on 16 pounds of boost all the way to 7200, which is where we have the red line set for now.
The Following 4 Users Say Thank You to Erich For This Useful Post:
jracer (07-29-2011), Realgib3 (07-29-2011), rfinkle2 (08-01-2011), ViRtUaLheretic (07-29-2011)
 Old 07-29-2011, 12:12 PM   #50
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
On your IM did they use the OEM flange and 2" of the runners and then just weld a extra piece between it and the plenum?
2006 Mazdaspeed 6
 Old 07-29-2011, 12:15 PM   #51
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
yes.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Erich (07-29-2011), MS3-a(sore)ASS-rex (07-29-2011)
 Old 07-29-2011, 01:11 PM   #52
708
Erich's Avatar
yes.
Correct. He recut one of the PTFE spacers to match the head porting and then ported the stock flange/runners to blend to the transition of the spacer into the head. Then welded the extra piece to get the angle he wanted and ported to blend with the existing runner.
The Following User Says Thank You to Erich For This Useful Post:
 Old 07-29-2011, 05:44 PM   #53
Speeeeeed
06Speed6's Avatar
Man that is ghettofabulous, it would be fairly easy to make an IM like that.
2006 Mazdaspeed 6
 Old 07-29-2011, 05:52 PM   #54
bmylez's Avatar
Posts: 3,197   (View Stats)
WTF WTF WTF motherfuck.
Ballin azz setup, mang. Finally someone got a REAL intake manifold. It is going to make such a ridiculous difference, people don't even know. You have the exact setup I want. Someday, maybe...
2007 CTS-V - Trying to sell
Erich (07-29-2011)
 Old 07-29-2011, 05:56 PM   #55
jwilkins88's Avatar
Posts: 3,675   (View Stats)
Groans: 126
The price on ghettofabulous just isn't what it used to be....
The Following 7 Users Say Thank You to jwilkins88 For This Useful Post:
Chimmike (07-31-2011), djuosnteisn (08-01-2011), doubleflusher (07-29-2011), jracer (07-30-2011), mtnrunner (07-31-2011), sellers (07-29-2011), SilverDemon (07-29-2011)
 Old 07-29-2011, 05:58 PM   #56
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Holy Fuck!!! I could make a killing selling the one I made for that kind of jack!!
Erich, you have nice build going on there!!!
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 8 Users Say Thank You to SilverDemon For This Useful Post:
AJ713 (07-29-2011), Alpha (07-30-2011), doubleflusher (07-29-2011), Erich (07-29-2011), jracer (07-30-2011), jwilkins88 (07-29-2011), Mizzle (07-31-2011), sellers (07-29-2011)
 Old 07-29-2011, 05:59 PM   #57
sellers's Avatar
Posts: 1,280   (View Stats)
sellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the world
Groans: 546
Groaned at 125 Times in 71 Posts
All aboard!
sellers is offline   Reply With Quote
 Old 07-29-2011, 06:01 PM   #58
nothing to see here....
drknyte's Avatar
Posts: 501   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
subbed for sex with your car!!!!!
Also how much for all the sexyness?!?!
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following User Says Thank You to drknyte For This Useful Post:
Erich (07-29-2011)
 Old 07-29-2011, 06:21 PM   #59
708
Erich's Avatar
Basically what he is saying is he doesn't want to make another one, but would if somebody wanted to pay that much. Took a lot of his time to get it right, and I think the flow charts and the way the car drives so far are doing a good job of backing up his work.
Was neither quick nor easy.
The Following 2 Users Say Thank You to Erich For This Useful Post:
btstarcher (05-06-2013), kmac (07-29-2011)
 Old 07-29-2011, 07:16 PM   #60
Speeeeeed
06Speed6's Avatar
Damn lol... well fml
2006 Mazdaspeed 6
 Old 07-30-2011, 11:11 PM   #61
708
Erich's Avatar
Got the air box made today. On the test runs, with the car moving the IAT's were within 10 of ambient. Best I saw was 87 IAT with an ambient of 81. With the car stopped temps rise, but fall almost instantly when the car starts moving again.
Fatguy729 (07-30-2011), kmac (07-31-2011)
 Old 07-31-2011, 06:53 AM   #62
bmylez's Avatar
A water/air I/C can't drop you below ambient. Think about it...the ambient air is hitting the heat exchanger, which transfers the heat of the water to the air....where in that system can the water be cooled to below the temperature of the air hitting it? You'd need to put a bunch of ice in your reservoir to drop below ambient.
Erich (07-31-2011)
 Old 07-31-2011, 07:59 AM   #63
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Insane setup. Glad to see a ms3 is stepping up to r34l ult1m4t3 POWAH, haha.
07 MS3
The original Genpoo Hater
Erich (07-31-2011)
 Old 07-31-2011, 08:52 AM   #64
drknyte's Avatar
Groans: 39
What he said....
Maybe you may want to consider spraying the heat exchanger with nitrous....
Just a thought.
60ft: 2.167
1/8: 9.052
Erich (07-31-2011)
 Old 07-31-2011, 09:10 AM   #65
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
the reason you not seeing the drop in temp when you start spraying meth is your sensor is not seeing the temp drop, see i spray in the cold pipe and see 30 deg, your not going to get that, cause of it spraying after the sensor!
so your timing will stay as if it is hot along with every thing else
when in reality it is much cooler
at 104000 2 bent rods
tuned by nishan
The Following 2 Users Say Thank You to rigor For This Useful Post:
jwilkins88 (07-31-2011), kmac (07-31-2011)
 Old 07-31-2011, 11:00 AM   #66
bmylez's Avatar
Yes, we understand that. Some people like the safety of meth vs. the power of meth.
Erich (07-31-2011)
 Old 07-31-2011, 11:17 AM   #67
jwilkins88's Avatar
Groans: 126
Considering that they're going to be using meth and e85 for their "race gas" tune, I think they're using it for power more than safety
The Following User Says Thank You to jwilkins88 For This Useful Post:
Erich (07-31-2011)
 Old 07-31-2011, 11:53 AM   #68
708
Erich's Avatar
Don't remember saying below ambient anywhere, though we are going to target below ambient on the race gas tune by putting ice in the reservoir. He wanted a CO2 setup to spray the heat exchanger, but below ambient wasn't important enough for me to spend the money on that.
Also, fwiw yesterday we let it sit and idle for close to 30 minutes to see what the intake air temps would do. This heat soaked the fluid for the W/A and I did not drive a sufficient distance to cool it. On previous tests at 80 degrees ambient we were seeing IAT of around 130 and boosted temps of about 25 less then that at around 105. Yesterdays pulls, my boosted air temps were about 125 when I pulled away from the shop, in the time I drove 3 miles to the freeway they had dropped to about 116 and then held there through my first pull... had dropped to about 108 by the time I got off the freeway 2 miles later and held that for my second pull getting back on the freeway. I think if we had not let the W/A heat soak the boosted air temps would have been about the same as the IAT
Will be running my daily driving tune way more then my track tune, so 90%+ of the time the meth will be for safety. In fact, right now I am just spraying water.
 Old 07-31-2011, 12:09 PM   #69
jwilkins88's Avatar
Groans: 126
Track tune vs daily driver tune is soooo overrated. You need to have race car status 24/7
I was actually just spraying wtaer towards the end of the era of the 3076. It was for a different reason though... Leak in the meth tank = watching money drip out of your life
Erich (07-31-2011)
 Old 07-31-2011, 12:18 PM   #70
708
Erich's Avatar
Not even close to what I will have for a daily driver tune yet and already traction issues in 2nd in 3rd. Boost tables and WG tables are zeroed with a 16 psi spring in the wastegate. So running 16 PSI. Not tires smoking not going anywhere traction issues yet, but leave 2 long black lines when I floor it in second. I will say that it is much more pleasant then K04 tire hopping traction issues.
Would probably more aggressive with a daily driver tune as well if I didn't drive my daughter around in the car, as it is I will be trying for something around 425.
 Old 07-31-2011, 12:20 PM   #71
jwilkins88's Avatar
Groans: 126
You just need better tires. That's a part of the fun man!
Erich (07-31-2011)
 Old 07-31-2011, 12:29 PM   #72
bmylez's Avatar
Call me crazy, but I'm 99.9% positive someone's post got deleted. Someone said "Hey, why aren't you dropping below ambient?" so I replied to that.
 Old 07-31-2011, 12:29 PM   #73
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groaned at 86 Times in 65 Posts
What I am confused about is the talk about the meth system being extra fueling. Lets say the stock fuel system can stretch to 500whp (just for shits and giggles i am just making up a limit). Having the meth setup with 4 m4 nozzles - is about 300ml/min x 4 = 1200ml/min. That is a decent size / amount of meth BUT irregardless - meth has such low energy it is a horrible idea to use it for additional fueling. Meth is used for cooling and octane boost. I've setup people with dual m10 nozzles, dual 1mm nozzles (pwm meth kits not standard on/off), etc. that flow a ton more meth. Meth is not a good additional fuel source. You'd be better off with a meth nozzle or two pre-throttle body giving better atomization to promote better cooling, running a 50/50 mix to keep cylinder temps down as well, and putting a few 150-220cc PI injectors in controlled with a standard fuel controller to work in the upper rpms when you run out of fuel (if you plan on pushing it this far). If you came in here and said I did this because of this and this is why it will be baller...I'd applaud. But I don't see the point of what was done here I guess. It looks like a conglomeration of shadetree made parts and lots of money spent without real purpose. I do applaud you on doing something different.
-JEWBERT
jhershorin is offline   Reply With Quote
The Following User Says Thank You to jhershorin For This Useful Post:
SilverDemon (07-31-2011)
 Old 07-31-2011, 12:31 PM   #74
bmylez's Avatar
Ah, here it is.
Erich (07-31-2011)
 Old 07-31-2011, 12:48 PM   #75
708
Erich's Avatar
If I wasn't able to view the post you deleted, I may actually have thought this was constructive criticism. You can pat yourself on the back now, another job well done.
 Old 07-31-2011, 12:54 PM   #76
bmylez's Avatar
"Conglomeration of shadetree made parts." That's a good one.
 Old 07-31-2011, 12:57 PM   #77
kmac's Avatar
Posts: 1,792   (View Stats)
I see what u r saying about the fuel , but I don't see any shade tree parts . I think it looks good and if u don't like it It's one thing , but don't give back handed compliments .
The Following 3 Users Say Thank You to kmac For This Useful Post:
Erich (07-31-2011), rigor (07-31-2011), SLOWHATCH (01-08-2012)
 Old 07-31-2011, 12:58 PM   #78
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
1.) Wow.
2.) No E85?
Erich (07-31-2011)
 Old 07-31-2011, 01:07 PM   #79
708
Erich's Avatar
1.) Wow.
2.) No E85?
Hadn't really considered it... maybe I should.
 Old 07-31-2011, 02:01 PM   #80
Mizzle's Avatar
Groans: 324
More exhaust volume for teh huge turboz,cooler charge temps, no need for WMI... Even if you ran E50 you should be able to do crazy shits.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/bullseye-billet-s259-build-soon-double-batmowheel-86881/
COBB Tuning - The First AccessPORT Tuned 600+ WHP MAZDASPEED3 This thread Refback 06-18-2015 03:14 AM
Engine rebuild mk1 ? Mazda MPS Owners Club This thread Refback 12-28-2014 12:55 PM
Engine rebuild mk1 This thread Refback 06-07-2014 07:39 AM
Search Results mazda This thread Refback 03-29-2014 08:59 PM
Engine rebuild mk1 This thread Refback 02-17-2014 08:47 PM
Engine rebuild mk1 ? Mazda MPS Owners Club This thread Refback 09-12-2013 04:54 PM
Untitled document This thread Refback 12-23-2012 10:24 AM
| Page 6 This thread Refback 11-11-2012 02:08 PM
?????? This thread Refback 09-25-2012 01:22 PM
| Page 5 This thread Refback 09-16-2012 10:31 AM
------The Mazdaspeed Thread----- This thread Refback 07-04-2012 08:17 AM
My Mazdaspeed 3 - Page 3 - Club3G Forum : Mitsubishi Eclipse 3G Forums This thread Pingback 06-09-2012 01:48 PM
| Page 3 This thread Refback 05-19-2012 09:11 AM
COBB Tuning Blog » Search Results » mazdaspeed This thread Refback 04-24-2012 12:44 AM
COBB Tuning Blog » Mazdaspeed This thread Refback 04-19-2012 01:54 PM
COBB Tuning Blog » AccessPORT This thread Refback 04-18-2012 01:50 PM
COBB Tuning Blog This thread Refback 04-13-2012 09:05 PM
COBB Tuning Blog » AccessPORT Manager This thread Refback 04-08-2012 07:21 AM
COBB Tuning Blog » Video This thread Refback 04-02-2012 02:25 PM
COBB Tuning Blog » Motorsports This thread Refback 04-01-2012 04:26 PM
708 whp Mazdaspeed3 This thread Refback 03-04-2012 08:36 PM
COBB Tuning Blog » MAZDASPEED3 This thread Refback 02-23-2012 11:03 PM
COBB Tuning Blog » COBB Tuning This thread Refback 02-22-2012 08:37 PM
The First AccessPORT Tuned 600+ WHP MAZDASPEED3 | SpeedForums.org This thread Refback 02-16-2012 10:20 PM
The First AccessPORT Tuned 600+ WHP MAZDASPEED3 This thread Refback 02-16-2012 03:46 PM
The First AccessPORT Tuned 600+ WHP MAZDASPEED3 — blogs.cobbtuning.com — Readability This thread Refback 02-16-2012 02:37 PM
COBB Tuning Blog » The First AccessPORT Tuned 600+ WHP MAZDASPEED3 This thread Refback 02-16-2012 07:56 AM
Gros setup pour mazdaspeed 3 - 640WHP - Page 2 - Mazda 3 Quebec This thread Refback 02-13-2012 11:27 AM
640whp mazdaspeed3 This thread Refback 02-07-2012 09:33 AM
640whp ms3??? This thread Refback 02-07-2012 08:26 AM
Report: Audi would rather build its own plant in Mexico than double-up with VW Haltech Automotive News 0 07-22-2011 09:30 AM
Need a JB Billet RMM installation pdf (Help!) MoparGo Mazdaspeed3/6 General Discussion 17 06-08-2011 06:58 AM
jbr 80 duro billet rmm tddvrrn JAMES BARONE RACING 8 05-08-2011 10:12 PM
SEMA 2009: Toyota Tundra Hot Rod kinda cool, but misses the bullseye Haltech Automotive News 0 11-04-2009 04:00 PM
Bullseye / Borg Warner .55 A/R T3 S256 Turbo, Need input! JumpingJackson MazdaSpeed 3/6 - Turbo Induction 5 09-03-2009 07:45 AM
Page generated in 0.63115 seconds with 39 queries
