![]() Join Date: Dec 2009 Location: Painesville, Oh
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 308
(Thread Starter) | Not Ranked : 0 score Ok so before I go any farther trying to get this shit out lemme ask...I am trying to get the manifold and turbo out all as one piece, has anyone had any luck doing that? Has anyone installed it that way or removed it like that? I unbolted the rmm like I did to install the manifold but it seems as if my tmm is hindering it from moving up enough...Ive given up for the night just wanted to see if it was even possible before I spend more time trying to do it that way or it I should just separate and pull it that way.
__________________ Under Construction |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
Here is a pic of how it looked after I removed all that and lowered mani+turbo down into place: One more thing you can do to make it easier is to cut the hardpipe that points out from between the mani and windshield. I cut that down to about 1"
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi Last edited by SpeedRebirth; 04-12-2015 at 05:03 AM. | |
| The Following 2 Users Say Thank You to SpeedRebirth For This Useful Post: | Last_Loser (04-11-2015), Swinger13 (04-11-2015) |
(Thread Starter) | Not Ranked : 0 score Ok I'll give that a shot...my problem seems to be when I pull the manifold off the studs and try to rotate it forward to pull it out the compressor housing hits that metal piece on the firewall however doing what you did I should just be able to lift it right up. Thanks man
| CPe EWG Turbo Manifold vs. ATP EWG Turbo housing | cam1391 | MazdaSpeed 3/6 - Big Turbo Builds | 13 | 01-30-2015 07:12 AM |
| High strength studs for turbo (manifold to head and manifold to turbo) | bnoon | MazdaSpeed 3/6 - Turbo Induction | 4 | 03-11-2009 10:26 PM |
| Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold | nobmood | Mazdaspeed3/6 General Discussion | 18 | 03-01-2009 08:14 PM |
