![]() | | #161 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] |
![]() | | #162 | ![]() |
![]() Join Date: Dec 2010 Location: Alexandria, VA
Rep Power: 875 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 765
Groaned at 20 Times in 12 Posts
| Not Ranked : 0 score subbed for coming back to when I need to see winning in mazdaspeed6 form. incredible how to. Only read the 1st page
__________________ 2010 MS3 - 13.42 at 107 - street tires - 306whp/338tq Moore automotive (dynojet) Roadcoursing > all http://www.youtube.com/watch?v=GO-xoFpsgj4 |
| The Following User Says Thank You to Schmitty5 For This Useful Post: | dougefresh_ (12-08-2011) |
![]() | | #163 | ![]() |
| Banned ![]() Join Date: Jun 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score Here's the new top mount with 44mm V-band at angle to fix the clearance issue. Angles away from the alternator and also away from the block. |
| The Following 4 Users Say Thank You to steedspeed For This Useful Post: |
![]() | | #164 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
| Not Ranked : 0 score |
![]() | | #165 | ![]() |
![]() | | #166 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just a heads up... @crazyp brought up in his thread that his turbo nuts bad backed off (a ton) as a result of the washers we both used (listed in OP, but edited w/ this warning). My turbo was off recently at the dealer, but one had still recently backed out a bit (back left one here): @jmhinkle said to use lock washers instead, and that should do the trick.
| The Following User Says Thank You to dougefresh_ For This Useful Post: | djuosnteisn (01-20-2012) |
![]() | | #167 | ![]() |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score I've never had one back out, but I did have the lock nuts seize up and cause the studs to back out when I was trying to swap turbos. That, in turn, caused the studs to gall inside the manifold and break off two of them. Best bet is probably loc-tite on the bottom of the stud into the manifold, and use a lock washer and regular nut on top. Coat the top in anti-seize as well so the nuts don't corrode to the studs.
__________________ |
| The Following 2 Users Say Thank You to jmhinkle For This Useful Post: | djuosnteisn (01-20-2012), dougefresh_ (01-17-2012) |
![]() | | #168 | ![]() |
![]() Join Date: Mar 2008 Location: W. Suffield, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 674
| Not Ranked : 0 score Im throwing the idea around of going with a GTX3071R with a top mount like this, throwing some rods and the new mazda pistons in my spare long block (if block OK) with the big valve head and using the spearco 1-992 FMIC. Ive always wanted to do this as that was why I was stockpiling parts, but it is a lot to take on at the moment. Im trying to figure out costs on a spreadsheet. Can I get a twin scroll GTX3071? I think cause the isn't the difference on the compressor side only? Also Ive got to locate a machine shop around here, but should be too much of a problem being right next to Sikorsky. Last edited by aviator79; 02-26-2012 at 03:44 PM. |
| The Following User Says Thank You to aviator79 For This Useful Post: | dougefresh_ (02-26-2012) |
![]() | | #169 | ![]() |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score cost wise a gtx3071 is the same as a gtx3076. edgeautosports had the best price when I was turbo shopping
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
| The Following User Says Thank You to crazyp For This Useful Post: | dougefresh_ (02-26-2012) |
![]() | | #170 | ![]() |
![]() Join Date: Apr 2012
| Not Ranked : 0 score wow, even doing the install outside. clearly you don't mess around! |
| The Following User Says Thank You to hedgehog7 For This Useful Post: | dougefresh_ (04-11-2012) |
![]() | | #171 | ![]() |
![]() Join Date: Jul 2010 Location: Charlotte Nc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 352
| Not Ranked : 0 score every time i get angry or upset at the world I look at the pics in this thread and think of a day when i too will be top mount and all is well!
__________________ 2006 Mazdaspeed6 GT Liquid Platinum Metallic "because racecar!" " I love this $%&*ing car" ![]() -Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps -2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete -TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender -Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod -Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge |
| The Following User Says Thank You to ESB Jiu JItsu For This Useful Post: | dougefresh_ (09-02-2012) |
![]() | | #172 | ![]() |
![]() Join Date: May 2012 Location: Easton, PA
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score i feel stupid for asking but what is the issue with the ms3 and a top mount? |
![]() | | #173 | ![]() |
![]() @djuosnteisn; could elaborate on ms3 issue.
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | |
![]() | | #174 | ![]() |
Groans: 162
| Not Ranked : 0 score Not the hood. It is the cowl area. The 6 has more room to the windshield, but the 3 has more room down lower. Top mount can be done with the twisted Perm kit easier than anything else, but it is another beast altogether.
| The Following 2 Users Say Thank You to jmhinkle For This Useful Post: | dougefresh_ (01-21-2013), Funkster777 (02-10-2013) |
![]() | | #175 | ![]() |
| Not Ranked : 0 score Thanks @dougefresh_; on the mod to cpe fmic hot pipe as I bought a jbr intake that wont fit so going to order 2 18" Ls and a hump coupler. Just hope it will clear my synapse bov.
__________________ MS6 - BNRs3 - Cobb AP - JBR Tru-3.0 - Spearco FMIC - MAC EBCS - Synapse BOV - DNP - CPE DP->MF - SU RRM - TTFMM - TT + CPE Diff Mounts - Mrlilguy HPFP - Projector HID fogs - TSX projector retrofit - LI jammers - Advan RZs w/ 245 PSSs - Koni - WL RSB |
| The Following User Says Thank You to aviator79 For This Useful Post: | dougefresh_ (10-28-2013) |
![]() | | #176 | ![]() |
![]() Join Date: Jul 2009 Location: Key West, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,273
Groans: 143
| Not Ranked : 0 score Does anyone know of someone who can make an intake for the top mount setup? It is the last thing I have left to do for my top mount setup. @djuosnteisn; doesn't seem to be here anymore and was the only person to have made them.
__________________ 2016 BMW M235i [Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals Electrical - GS EBC - Cobb AP Richtune in progress Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40. |
![]() | | #177 | ![]() |
![]() Join Date: Apr 2011 Location: Millsboro, De
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,597
__________________ 2006 Mazdaspeed 6 GT-unDISI swap in progress 1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5 Skreets be calling... [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to BobtailedSnail For This Useful Post: | thehead (04-12-2014) |
![]() | | #178 | ![]() |
(Thread Starter) | Not Ranked : 0 score I know a guy, who knew a guy who knows a guy...
| The Following User Says Thank You to dougefresh_ For This Useful Post: | jmhinkle (04-15-2014) |
![]() | | #179 | ![]() |
![]() Join Date: Jun 2010 Location: France, Fos sur mer
Rep Power: 130 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
__________________ Mazda 6 MPS 2006: H&R bilstein B8, steedspeed t3 top mount TS with HX35, custom 3" downpipe, cpe duplex 3",dbw 3", 5 injectors methanol with devilsown dvc, blow through maf 3", custom fmic, forge blowoff, ported intake manifold vtcs delete and meth bung, intake custom 3.5", Spec stage 3+ clutch and flywheel, Cometic headgasket / ARP stud, balace shaft delete, egr delete,Brembo calipers EVO X, RX8 rims /sessenta 235/40/18, Galaxy tab2 gps mod, & more..... |
| The Following User Says Thank You to Fracass For This Useful Post: | dougefresh_ (06-10-2014) |
![]() | | #180 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can't believe how much work this fucking thing was. The install wasn't that bad, thanks to DJ and Joel, but fuck, the prep work was intensive for a dim witted cpa. @jmhinkle; is Dustin still making these? EDIT: I couldn't spell Dustin's MSF name to save both my nuts, or 3" off my prick.
![]() | | #181 | ![]() |
Groans: 162
| Not Ranked : 0 score He's moved on to other things. There were only a limited number of SteedSpeed manifolds to begin with.
| The Following User Says Thank You to jmhinkle For This Useful Post: | dougefresh_ (06-10-2014) |
![]() | | #182 | ![]() |
Why is your sig so gad damn big, but there's nothing there? Tell Dusty I said hai
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] Last edited by dougefresh_; 06-10-2014 at 01:09 AM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #183 | ![]() |
Groans: 162
| Not Ranked : 0 score That's why I have the WTF? in there. Some mod jacked with it awhile ago and I gave up trying to fix it. I don't frequent these forums much anymore so it doesn't matter. I'm not building the GTR, maybe some light restoration if anything. I have a thread I started from when I maybe the initial purchase with the same pics from facebook. Nothing special.
![]() | | #184 | ![]() |
![]() | | #185 | ![]() |
![]() Join Date: Dec 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Mental build , i know its a old thread but surely you will need an effective way of dissipating that heat .For the sake of the bonnet paint
__________________ BNRS3 CORKSPORT STAGE 2 INTAKE AUTOTECH HPFP FORGE INTERCOOLER TOTAL MPS DOWNPIPE MIJ CATBACK COBB 3PORT EBS DICE DUST CAPS TB COOLANT DELETE FORGE V2 BPV |
![]() | | #186 | ![]() |
Groans: 162
| Not Ranked : 0 score The airflow through the engine bay is more than enough. Several of us have been on topmounts over 4 years without any problems at all.
| The Following 2 Users Say Thank You to jmhinkle For This Useful Post: | crazyp (06-17-2014), dougefresh_ (06-17-2014) |
![]() | | #187 | ![]() |
EDIT: PS Joel, I'm still running that 'upgraded' coolant return line you suggested ($50 for like 3'... my original coolant line fried over time, but corrected info in OP)... the shit that failed on you iirc. I checked mine the other day, and the shit looks brand new. Granted, I have 45K on the car, and only about 15K since BT.
| The Following 2 Users Say Thank You to dougefresh_ For This Useful Post: | Micha (06-25-2014), SternRitteR (06-18-2014) |
![]() | | #188 | ![]() |
(Thread Starter) | Not Ranked : 0 score Bruh, I had another problem with my coolant return line. I need to replace the line again. I was getting dyno tuned by @atvfreek; and it started leaking bad on the second E85 run. But at just 22psi, she's making 345/350, which will keep me content as my daily driver, and I'll turn up the boost a notch once I get the coolant line fixed. Here's a pull from today: https://www.youtube.com/watch?v=tpDRlThTCHo
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/how-top-mount-turbo-set-up-83344/ | ||||
| Garret GT3071R - Mazda 3 Quebec | This thread | Refback | 11-28-2012 05:25 PM | |
| l'Interet d'un Turbo en Top Mount? | This thread | Refback | 09-05-2012 07:33 AM | |
| Free PSP ISO Downloads EUR PSP ISO & CSO Downloads | This thread | Refback | 05-02-2012 07:56 AM | |
| 2006 MazdaSpeed6 GT with Navi Big Turbo | This thread | Refback | 04-29-2012 01:56 PM | |
| Top mount turbo setups | djuosnteisn | MazdaSpeed 3/6 - Big Turbo Builds | 1856 | 09-18-2011 08:46 AM |
| Top Mount Turbo Manifold | aminzer | Mazdaspeed3/6 General Discussion | 25 | 02-06-2010 08:19 PM |
| TRZ Transmission Mount/ Mazda3online turbo inlet installed and review! | Raider | Mazdaspeed Forums User Reviews | 0 | 06-29-2009 06:40 AM |
