![]() | | #41 | ![]() |
| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score |
| The Following 4 Users Say Thank You to EdgeAutosport.com For This Useful Post: |
![]() | | #42 | ![]() |
| Not Ranked : 0 score Lol, you installed, uninstalled, reinstalled, reuninstalled, rereinstalled, rereuninstalled, and rerereinstalled that fucking thing so many times.
| The Following 4 Users Say Thank You to djuosnteisn For This Useful Post: | 86AmishMs3 (04-25-2012), bwspeed (04-27-2012), cld12pk2go (04-26-2012), EdgeAutosport.com (04-25-2012) |
![]() | | #43 | ![]() |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score Dildo....I flipped mine around but since the wga arm is not straight it would just torque itself back to that position. I had to consecutively cut 3/4" off the entire arm. I would say I've fucked with my wga about 10 times. Finally all is good. I just had to hack the shit out of mine.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
| The Following 4 Users Say Thank You to 86AmishMs3 For This Useful Post: | atvfreek (04-25-2012), bwspeed (04-27-2012), djuosnteisn (04-25-2012), EdgeAutosport.com (04-25-2012) |
![]() | | #44 | ![]() |
I initially could not get over ~20 PSI with my incorrect 10 PSI WGA (at 100% WGDC) so I tightened the rod 4 turns from stock (freed up about 20% from WGDC), which got me to ~23-24 PSI. Now I am at 5 turns which is good for probably 25 PSI if LCV2™ wasn't giving me the business...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
![]() | | #45 | ![]() |
![]() Join Date: Jul 2010 Location: Lunenburg Mass
Rep Power: 2310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,516
I did take off my Greddy Type RS BOV took it apart cleaned it out cranked it down all the way and sealed it down the best I could. Now the car seems to consistently hit a solid 22psi about 600RPM sooner then before. I think that the BOV is at it's max and is just leaking I hope to try out a new one next weekend. Here is a 3-4th gear log
__________________ 2006 Black MS6 531HP 486TQ FREEKBUILT -- FreekTune BW S300sx 62mm -- Twin TIAL 38mm EWG -- Perm Top Mount Twin Scroll Turbo Manifold -- Perm 4" Intake TR1035FMIC -- JBR TB and IM thermal spacers -- JBR OCC -- Bosch 3.5 Bar MAP -- Greddy BOV-- CP-E Injector seals Perm Downpipe -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS -- NGK Iridium Ported Head and Intake Manifold -- Snow Performance Meth Injection D10 and D12 -- balance shaft delete -- EGR delete ACT 6 Puck -- ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob 2006 CWP MS6 313HP 319TQ FreekTune ATP GTX3076r -- TIAL 38mm EWG -- HTP 3" Intake System -- CPE Single Exit Exhaust-- ATP Catless Down Pipe CPE Differential Mount -- CPE Top Mount Intercooler -- JBR 80D Trilogy Mount Package -- Grimmspeed EBCS Autotech Internals -- Bosch 3 Bar Map Sensor -- Bit Wise Plug n Play -- GFB Hybrid BOV Bilstein Struts -- H&R Sport Lowering Springs -- Cobb v3 -- e85 1990 Nissan Skyline GTR ![]() 1991 White BMW 325ic Scorpion catback -- Short shifter -- Bilstein HD -- HR Springs -- Intake -- NRG Wheel -- Chassis and strut tower brace -- Sway bars | |
| The Following 2 Users Say Thank You to Lakespeed6 For This Useful Post: | atvfreek (05-02-2012), dougefresh_ (05-01-2012) |
![]() | | #46 | ![]() |
(Thread Starter) | Not Ranked : 0 score Figured I would update this fail of a build. IWG arm was hitting some coolant lines that are on the firewall. I moved those out of the way. My BOV was not the issue it was that my IWG arm was not preloaded. What a bitch to adjust that on the 6 with the CP-E exhaust mani. I found that I had to remove the rear motor mount and jack up the rear of the engine. This gave me an extra inch so that I could just see the C clip. I gave the IWG arm 2 full turns. Before peak boost was only 20psi with my MBC all the way tight. Now peak boost was 24psi but it hit it around 4800RPM. Gave the IWG 2 more turns. Now hitting 24psi by ~4200RPM Gave the IWG another 2 turns to see if I could get full spool by 3600RPM Shit went bad, full boost is now at 5200RPM and I was spiking to 26PSI. I also started seeing some knock in the high RPM. Right around here I did a log and noticed my HPFP pressure was dropping into the 800psi range under WOT. FUCK KMD! Had bought them new from someone on the forum so no warranty. ordered some autotechs through edge last week. In prep for putting these in I backed off the IWG one turn and swapped my DO6 for a DO10 meth nozzle. Fail continued. Went to remove the KMDs. The plunger came out no problem but the piston was seized in the pump where the 18mm nut is. I will be picking up a stock HPFP from @darkcherry on Monday and will put my autotechs in it. More fail will commence soon! So install was on 3/25 and still have not finished up my tune... @atvfreek has been a big help!
| The Following 2 Users Say Thank You to Lakespeed6 For This Useful Post: | atvfreek (08-03-2012), psychophyr (08-03-2012) |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Finishing off the update for now. Autotechs went in, lasted 2 weeks before more fueling issues. Found out that my relief(rail) valve decided to crap out. Relief valve replaced fueling is good, for now... Swapped in my D10 nozzle and went to GSD to finish off the Freektune. First pull 333HP 355TQ. 4 maps later 383HP 385TQ corrected. Freektune FTW Turbo is still slow to spool up. Peak boost is around 4800-5000RPM. Will probably do EWG in the spring
![]() | | #48 | ![]() |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 566
| Not Ranked : 0 score it's weird that it spools later in the second run then the first, i would see this being good for an ms3 but not an ms6, i think that can spool earlier
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
![]() | | #49 | ![]() |
Groans: 433
| Not Ranked : 0 score lakespeed, niggah. have you missed all the details on the gtx3076 specifically? you have to manually preload the FOCK out of the wastegate actuator. I mean, to the point where I actually cut threads off and screwed it down as far as it would go. After I did that, I was able to hit 24psi by 3800rpm. Dew it. you'll see a major improvement. Also, you should be able to fly past 400whp with that d10 on there! edit: what boost level is that? I find this turbo doesn't really seem to 'come alive' until 22-23psi
| The Following 4 Users Say Thank You to Chimmike For This Useful Post: |
![]() | | #50 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score glad your figuring this beast out after all that fail! is it sit back and enjoy time yet?
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() | | #51 | ![]() |
I did preload it a good amount. I think I did 8 or 10 full turns. I started seeing a 1psi boost spike so I backed it off a turn. Car is at 24~25psi. ~380whp is as far as I want to go on stock internals on a 6. I know the car is capable of much more.
| The Following 3 Users Say Thank You to Lakespeed6 For This Useful Post: |
![]() | | #52 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
Peak boost was about 25.5 to make that power. We both agreed to stop there. I've seen too many rods bend at 400hp on speed6's so we kept it dialed back a touch. I think if he can get his spool sorted out, this car will be an all around blast to drive, not just at high rpm ![]() Freekn tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following 3 Users Say Thank You to atvfreek For This Useful Post: |
![]() | | #53 | ![]() |
But I enjoyed the trip and the troubleshooting. A new clutch is needed soon, motor mounts, a few cosmetic thing. EWG or more preload. I like getting my hands dirty. But the car is a fucking blast to drive!
![]() | | #54 | ![]() |
Groans: 433
| Not Ranked : 0 score Yah. If you've already got the EWG mani, go for it. At that boost level you should be around 400-420whp If you didn't have the EWG mani I'd tell you to buy my old IWG off me from my gtx, haha. Also. Man. EBCS. dial in that WGDC early to help spool too. what's your MAF voltage at? On 3" intake I hit 4.95v on 26psi. I'd have to bet, unless something is wrong, you're ~4.7v?
| The Following User Says Thank You to Chimmike For This Useful Post: | Lakespeed6 (11-09-2012) |
![]() | | #55 | ![]() |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
| Not Ranked : 0 score Great numbers! That is right around where I want to be with my BT build in the spring. EWG ftw
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. |
![]() | | #56 | ![]() |
What kind of power are you at with hitting 26psi on the 3?
![]() | | #57 | ![]() |
Groans: 433
I'm thinking 26psi should have me in the 430-450whp range.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
| The Following 3 Users Say Thank You to Chimmike For This Useful Post: |
![]() | | #58 | ![]() |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score Not trying to scare anyone, but dougefresh bent a rod at only 385whp. I'm sure freek has way more experience with keeping it safe near the limit, but there are several examples of people NOT at 400 who broke something. Best of luck, though, I'm sure the car is tons of fun.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
| The Following User Says Thank You to bmylez For This Useful Post: | atvfreek (04-13-2013) |
![]() | | #59 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score Damn that blows
__________________ [01:31 PM] SoAgg159: my dick is called "quarter mile" it's about 1/4" long and i can give about 14secs of pleasure [07:06 PM] DarkHeartMS6: yeah. I actually hope i catch my wife with another dude. gives me an excuse to open the emergency door and bail. LOL [09:13 PM] Pu Manchu: i like to take my gf through the drive thru so i can prove that i can pleasure a woman |
![]() | | #60 | ![]() |
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 | |
| The Following User Says Thank You to snailD For This Useful Post: | Chimmike (11-10-2012) |
![]() | | #61 | ![]() |
![]() Join Date: Jul 2011 Location: New London, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 759
| Not Ranked : 0 score Great write up man. Your car has changed a ton since we met in Milford at bww. Stoked to see this thing run in future. Definitely has me wanting to take the dive into bt. |
| The Following 2 Users Say Thank You to ABloodBrother For This Useful Post: | atvfreek (04-13-2013), Lakespeed6 (04-12-2013) |
| CrazyP TOPMOUNT BT GTX3076 Build (Easy Breezy PT. 4) | crazyp | MazdaSpeed 3/6 - Big Turbo Builds | 469 | 06-22-2014 11:24 AM |
| Realgib3 - GTX3076 - 400whp | Realgib3 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 63 | 10-13-2011 02:57 PM |
| Finally let my balls drop! - GTX3076 | Realgib3 | MazdaSpeed 3/6 - Big Turbo Builds | 109 | 10-04-2011 01:51 PM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
