Like Tree115Likes
 Old 12-06-2012, 01:57 PM   #41
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
I miss this turbo already.
Beanfab / Tuned by Nishan
The Following 7 Users Say Thank You to doubleflusher For This Useful Post:
amoosenamedhank (12-17-2012), GunGuru727 (12-22-2012), JacksonMS30 (12-06-2012), MS3inDC (04-02-2013), NJSPEED3 (12-06-2012), Realgib3 (12-06-2012), Voltron (12-22-2012)
 Old 12-17-2012, 01:40 PM   #42
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
In my quest to keeping oil and coolant temps as close to factory as possible, I decided in adding an additional radiator fan next to the stock one. My coolant temps are usually 20 degrees above normal lol (200 degrees+/-).
I took some measurements earlier
height 12"
width 10.5"
depth 2.5"- 3"
So after doing some searching I found this bad boy
Derale Performance High Output Curved Blade Fans 16110 - SummitRacing.com
Im going to gut the back of the radiator frame, right around the plastic flappers. I'd like to bring coolant back down to 180-190 as oppose to 200-225 lol. I may do an external oil cooler eventually as well if it even needs one after this.
I'll just use this thread to full you guys in on my progress.
The Following 8 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (12-17-2012), BlueStreak (12-17-2012), Don06speed6 (12-17-2012), doubleflusher (12-17-2012), faeker (12-17-2012), fishin53 (12-18-2012), ms3blackmica (12-17-2012), WhiteWidow (05-18-2013)
 Old 12-17-2012, 02:10 PM   #43
you need the fan controller like i have, my ECT never breaks 200 on the hottest day sitting in traffic
11cruzito11 (12-18-2012), atvfreek (12-17-2012), MS3inDC (04-02-2013), NJSPEED3 (12-17-2012)
 Old 12-17-2012, 02:12 PM   #44
Tripple OG
NJSPEED3's Avatar
Groans: 113
I'm gonna pick one up to control both fans.
Keep in mind ms6's already have 2 fans and If im not mistaken your guys have a bigger radiator.
 Old 12-17-2012, 03:30 PM   #45
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
link please.
dantes5823 is offline   Reply With Quote
 Old 12-17-2012, 03:36 PM   #46
dantes5823's Avatar
doesnt @doubleflusher; have a radiator you can use......
The Following 3 Users Say Thank You to dantes5823 For This Useful Post:
doubleflusher (12-17-2012), NJSPEED3 (12-17-2012), SilverDemon (12-17-2012)
 Old 12-17-2012, 07:40 PM   #47
Tripple OG
NJSPEED3's Avatar
Groans: 113
yup its an aluminum core, that fool has parts for days. Im going to give this stuff a shot before having to mess with the radiator.
this
Derale Thread-In Thermostat Fan Control with Relay and Dual Threads - 180 Degrees Derale Radiator Fans D16720
plus replace the 180 sensor for the 190 one.
http://www.etrailer.com/Radiator-Fan...le/D16731.html
Plus
Titek Water Temp Gauge Adapter 30mm Radiator Hose New | eBay
Im not exactly sure what our stock coolant hose diameter is I'll have to see. I know the ms3/ms6's use different sizes.
I may try just running the controller on the stock fan to see if that alone does the trick.
@superskaterxes; has been running this set up for a while so we'll see if it does just as well on the ms3.
The Following 5 Users Say Thank You to NJSPEED3 For This Useful Post:
atvfreek (12-17-2012), dantes5823 (12-17-2012), doubleflusher (12-17-2012), ms3blackmica (12-17-2012), rfinkle2 (12-18-2012)
 Old 12-17-2012, 09:44 PM   #48
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
cobb still hasn't released the table that controls the kick-on/off temps of the fan yet. lame.
this will be my first upgrade of 2013 Koyorad Racing - News and Updates
'08 CWP MS3 w/ T3 3071r
 Old 12-17-2012, 10:10 PM   #49
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
+1
I think we have all been dying for that control
~217*F is not the right time to kick on for us power freeks lol
www.tunedbynishan.com
The Following 5 Users Say Thank You to ms3blackmica For This Useful Post:
amggilly305 (12-22-2012), NJSPEED3 (12-18-2012), Realgib3 (12-18-2012), rfinkle2 (12-18-2012), SLOWHATCH (03-27-2013)
 Old 12-18-2012, 07:22 AM   #50
Groans: 1,443
Buy mine
NJSPEED3 likes this.
The Following User Says Thank You to doubleflusher For This Useful Post:
 Old 12-18-2012, 07:31 AM   #51
this
Derale Thread-In Thermostat Fan Control with Dual Threads - 190 Degrees Derale Radiator Fans D16731
Plus
1.25" i.d. fits snug on the ms3.
dantes5823 (12-18-2012), ms3blackmica (12-18-2012), NJSPEED3 (12-18-2012), SLOWHATCH (03-27-2013)
 Old 12-18-2012, 07:52 AM   #52
Groans: 1,443
HOW-TO: Auxiliary Fan controller
ms3blackmica (12-18-2012), NJSPEED3 (12-18-2012), rfinkle2 (12-18-2012)
 Old 12-18-2012, 09:15 AM   #53
Tripple OG
NJSPEED3's Avatar
Groans: 113
MSF test mule FTMFW!
The Following 3 Users Say Thank You to NJSPEED3 For This Useful Post:
ms3blackmica (12-18-2012), MS3inDC (04-02-2013), rfinkle2 (12-18-2012)
 Old 12-18-2012, 01:18 PM   #54
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Anyone consider running the AWR radiator? I think Tony will get one to you if you talk to him, as it was not sold online anymore, IIRC
mczimer is offline   Reply With Quote
 Old 12-18-2012, 01:29 PM   #55
Groans: 1,443
I called AWR and they said they we're not going to sell it, as there was almost no demand for it.
The Koyorad can be had for less than half of what the AWR unit cost.
 Old 12-18-2012, 02:02 PM   #56
mczimer's Avatar
What koyorad do you run a MS6? I have never seen that done before
 Old 12-19-2012, 07:14 PM   #57
Groans: 1,443
Koyorad does not make one for an MS6. Nor do I have an MS6.
helmetface (12-22-2012), MS3inDC (04-02-2013)
 Old 12-20-2012, 01:07 PM   #58
Tripple OG
NJSPEED3's Avatar
Groans: 113
The Following 9 Users Say Thank You to NJSPEED3 For This Useful Post:
doubleflusher (12-20-2012), fishin53 (12-21-2012), ink28 (12-22-2012), JacksonMS30 (12-20-2012), KusteLokal (12-22-2012), ms3blackmica (12-20-2012), spnkr21 (12-20-2012), Vader (01-04-2013), Voltron (12-22-2012)
 Old 12-20-2012, 01:08 PM   #59
Groans: 1,443
That blows
Monotonous ONE (12-22-2012)
 Old 12-20-2012, 01:09 PM   #60
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
height 12"
width 10.5"
depth 2.5"- 3"
I see 200 Max with the block filled and IC blocking most of the rad
I was seeing 220's for a little while, took 3 bleeding to get it back down to where it needed to be.
dturboman is offline   Reply With Quote
The Following User Says Thank You to dturboman For This Useful Post:
Easter Bunny (12-20-2012)
 Old 12-21-2012, 08:38 PM   #61
Tripple OG
NJSPEED3's Avatar
Groans: 113
One 6th port 3" NJSPEED cold pipe done.
I'm probably going to eliminate that one straight coupler eventually. I'm thinking of doing a vband connection at the tb once I pick up Pablo's 75mm joint.
Voltron and The Panda like this.
The Following 7 Users Say Thank You to NJSPEED3 For This Useful Post:
BlueStreak (12-21-2012), doubleflusher (12-21-2012), ms3blackmica (12-21-2012), MS3inDC (04-02-2013), rfinkle2 (12-22-2012), The Panda (12-22-2012), Vader (01-04-2013)
 Old 12-21-2012, 08:41 PM   #62
stock TB FTL..........
doubleflusher (12-21-2012), NJSPEED3 (12-21-2012)
 Old 12-21-2012, 08:53 PM   #63
Groans: 1,443
Running car FTL.........
The Following 10 Users Say Thank You to doubleflusher For This Useful Post:
atvfreek (12-22-2012), BlueStreak (12-21-2012), dantes5823 (12-22-2012), Easter Bunny (12-22-2012), helmetface (12-22-2012), NJSPEED3 (12-21-2012), SarcasticOne (12-22-2012), superskaterxes (12-21-2012), Tokay444 (12-22-2012), Voltron (12-22-2012)
 Old 12-22-2012, 04:54 AM   #64
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
Nice Gerry....I'm assuming the welding came out ok?
@NJSPEED3;
Voltron is offline   Reply With Quote
The Following 2 Users Say Thank You to Voltron For This Useful Post:
ms3blackmica (12-22-2012), NJSPEED3 (12-22-2012)
 Old 12-22-2012, 07:25 AM   #65
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Nice stock horn noob
 Old 12-22-2012, 07:30 AM   #66
atvfreek's Avatar
Posts: 7,787   (View Stats)
Big horns are for diesel trucks, not race cars.
Looking awesome Gerry!
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
GunGuru727 (12-22-2012), NJSPEED3 (12-22-2012)
 Old 12-22-2012, 07:43 AM   #67
helmetface's Avatar
Groans: 219
Negative!
horn decibel is equivalent to penis girth!
The Following 4 Users Say Thank You to helmetface For This Useful Post:
dantes5823 (12-22-2012), Easter Bunny (12-22-2012), MS3inDC (04-02-2013), NJSPEED3 (12-22-2012)
 Old 12-22-2012, 11:00 AM   #68
Nishan
money shall not be wasted on horns when trying to go fast
GunGuru727 likes this.
The Following 9 Users Say Thank You to ms3blackmica For This Useful Post:
09Speed3Z (12-22-2012), atvfreek (12-22-2012), cld12pk2go (12-26-2012), GunGuru727 (12-22-2012), helmetface (12-22-2012), MS3inDC (04-02-2013), NJSPEED3 (12-22-2012), SLOWHATCH (03-27-2013), Voltron (12-22-2012)
 Old 12-22-2012, 11:23 AM   #69
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Louder horns emit a more powerful frequency which at speeds send air waves into the path ahead and creates a drag like effect by lowering the air density directly in front of the vehicle.
The Following 5 Users Say Thank You to Monotonous ONE For This Useful Post:
GunGuru727 (12-22-2012), MS3inDC (04-02-2013), NJSPEED3 (12-22-2012), SLOWHATCH (03-27-2013), Voltron (12-22-2012)
 Old 12-22-2012, 11:30 AM   #70
helmetface's Avatar
Groans: 219
See, I knew I was on to something.
GunGuru727 (12-22-2012), MS3inDC (04-02-2013), NJSPEED3 (12-22-2012), Voltron (12-22-2012)
 Old 12-22-2012, 11:31 AM   #71
Realgib3's Avatar
Posts: 2,443   (View Stats)
Why did you decide to keep the BOV on the cold pipe instead of the hot pipe? Any specific reason? My Tial runs in almost that same spot, but on the hotside, with great success.
 Old 12-22-2012, 12:04 PM   #72
Tripple OG
NJSPEED3's Avatar
Groans: 113
My hotpipe is routed below the car, there isn't a clean spot for it. I been running my bov in that location for quite a while without any issues.
Sent from my XT894 using Tapatalk 2
The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post:
ms3blackmica (12-22-2012), Realgib3 (12-22-2012)
 Old 12-22-2012, 12:25 PM   #73
Realgib3's Avatar
Yeah mines routed under the car too, Ill try to get a pic of it, but its almost in the same spot as yours, just on the other side of the IC.
Only reason I went that way is for the added safety of not somehow releasing fuel from the 6 port into the engine bay.
 Old 12-22-2012, 12:39 PM   #74
Tripple OG
NJSPEED3's Avatar
Groans: 113
Yup agreed, my location 100% fuel proof though.
6th port is directly before the tb, and the bov flange is on the top part of the pipe (1 o'clock). There is no way for fuel to actually release past the bov this way. Its all about gravity and air flow. Hot pipe is the safest location no doubt.
 Old 12-22-2012, 01:21 PM   #75
Nishan
The only benefit that I can see from a loud horn is soundin that shit off in front of teh gf's house cause lord knows she takes 1hr to come out.
Maybe that would piss her off enough..
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
dantes5823 (12-22-2012), derek13p (03-27-2013), GunGuru727 (12-22-2012), mazdafreak (07-28-2013)
 Old 12-22-2012, 01:28 PM   #76
helmetface's Avatar
Groans: 219
My car idles loud enough to piss anyone off:
Gt30 w/ 3.5" intake
Catless
Cheap catback
Yup
My horn however is great for those dumbass moms thinking they own the roads with their $60k bitchmobiles..something is wrong with the wiring on mine so it fluctuates, wawawawawa
100x more annoying
 Old 12-22-2012, 02:20 PM   #77
dantes5823's Avatar
i want more njspeed3 hard parts! im getting rid of my only part!
 Old 12-22-2012, 03:59 PM   #78
Tripple OG
NJSPEED3's Avatar
Groans: 113
More Hard parts u say
http://static.photobucket.com/player...222_174300.mp4
Voltron likes this.
The Following 6 Users Say Thank You to NJSPEED3 For This Useful Post:
amggilly305 (12-22-2012), dantes5823 (12-22-2012), doubleflusher (12-22-2012), ms3blackmica (12-22-2012), RE-ACTIONENGSPEED3 (09-04-2013), Realgib3 (12-22-2012)
 Old 12-22-2012, 04:02 PM   #79
Nishan
me likeyyyyyy Gerry !
Did you have to cut out that section where the flapper doors are?
 Old 12-22-2012, 04:13 PM   #80
Tripple OG
NJSPEED3's Avatar
Groans: 113
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f498/my-hta3586-build-132009/
MPS and RPM - Page 3 This thread Refback 11-08-2013 12:46 AM
New build? forcedinduktion Computers & Technology News 2 12-08-2010 09:24 PM
Page generated in 0.62504 seconds with 34 queries
