![]() | | #41 | ![]() |
| Not Ranked : 0 score
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
![]() | | #42 | ![]() |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
Is it peak power that makes you love the 6466 over 3076 or is there another variable involved? Spool? Sound? =) Im waiting for cpe to finish their atmosphere kit and im going with GT3076. Wouldn't it be wonderful if they had 5858/6262/6266 as options as well.... In a perfect world i guess
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi | |
![]() | | #43 | ![]() |
![]() Oh, and the atmosphere kit for those turbos would ONLY require them to make a slightly different downpipe for the precision turbos because they already offer a Precision Vband manifold and everything else would line up the same. | |
| The Following User Says Thank You to Realgib3 For This Useful Post: | SpeedRebirth (12-06-2013) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score I'm confused. I've always been under the impression that dbb turbos could handle axial loads much better than journals. So why do you say they can't take as much abuse?
![]() | | #45 | ![]() |
![]() Join Date: Jul 2012 Location: West Palm Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
I would rather compromise top end over spool. I'm not trying to set any records but I would like some nice headroom as well. Also it will be daily driven which is why I would like decent spool for around town.
__________________ "under construction" Last edited by 2012FailWheelDrive; 12-05-2013 at 08:36 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #46 | ![]() |
| Not Ranked : 0 score I love my GTX3071, but I often get some crazy thoughts that I wish I had a GTX3576 or PTE5858 so as to not have my boost limited to ~25 PSI up top... For my daily driver I am probably already at the ideal with the GTX3071 as it has awesome response and could easily make 500whp if I went catless, but the gearhead in me always wants more...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following 4 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #47 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
Having made that swap I can say one thing... don't lol, just go catless on your setup. Im amazed you're making as much power as you are with a cat though, I gained 3 psi with no changes to my tune going catless on my 3071 lol. I had a "fuck it, lets see what happens moment" after I did the swap and just did a 3rd gear hit lol. Wasn't ready for a 28 psi spike but damn it was exciting! haha
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
| The Following User Says Thank You to Voltwings For This Useful Post: | cld12pk2go (12-05-2013) |
![]() | | #48 | ![]() |
Yeah, I am guessing that I am experiencing a crazy amount of backpressure with the catted DP, that is probably limiting the pressure ratio around the turbine limiting power input to the compressor... I almost have the wife off my ass on other projects so maybe I can go catless in the spring...
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | atvfreek (12-05-2013) |
![]() | | #49 | ![]() |
I don't mean to talk down the 3576, its a badass turbo, but its just one that's hard to say I was happy with on a daily basis.
| The Following 3 Users Say Thank You to Voltwings For This Useful Post: |
![]() | | #50 | ![]() |
I mean I know I want more than 500whp, but I really don't need it in a DD. The tradeoffs start to be pretty painful above this point...
![]() | | #51 | ![]() |
| The Following User Says Thank You to Voltwings For This Useful Post: | cld12pk2go (12-06-2013) |
![]() | | #52 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright so I am going to go with the journal bearing 5858 .82 ar vband in/out with the cpe exhaust manifold and 3" vband downpipe. I will make a build thread once everything starts coming together. Thanks guys!
__________________ "under construction" |
| The Following 7 Users Say Thank You to 2012FailWheelDrive For This Useful Post: | ABolewski (12-29-2013), atvfreek (12-07-2013), Boost_creep (12-07-2013), cld12pk2go (12-07-2013), ItsNox (12-28-2013), LumberJack (12-07-2013), Realgib3 (12-08-2013) |
![]() | | #53 | ![]() |
![]() ![]() ![]() Join Date: Nov 2012 Location: Temecula, CA
Rep Power: 2724 ![]() Thanks: 3,896
Groans: 57
![]() Sent from my LG-LS980 using Tapatalk
__________________ 2018.... Doing even more freeky things! 10.36@148 Fastest Gen 2 | |
| The Following 3 Users Say Thank You to LumberJack For This Useful Post: |
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score Did you get a custom downpip or no?
![]() | | #55 | ![]() |
Groans: 57
| Yeas I'll be having one made Sent from my LG-LS980 using Tapatalk
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Okay. I still have to look into that. I know ATP has a vband downpipe but I think $300 is a bit steep.
![]() | | #57 | ![]() |
Groans: 57
![]() | | #58 | ![]() |
This flange http://www.treadstoneperformance.com...+V+Band+Flange
__________________ "under construction" Last edited by 2012FailWheelDrive; 12-07-2013 at 05:29 PM. | |
| The Following User Says Thank You to 2012FailWheelDrive For This Useful Post: | LumberJack (12-08-2013) |
![]() | | #59 | ![]() |
| Not Ranked : 0 score I'll get more info when I get to a PC, but you can either go with a full custom down pipe or get a cheap eBay dp, then just have a new flange welded on. That way you don't have to mess with any of the bends and exhaust hangers like a full custom one. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | Voltwings (12-08-2013) |
![]() | | #60 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright so I just got my 5858 in the mail and awaiting my cpe exhaust manifold, wastegate, and dump tube to be delivered. One more question. How much difference would I see between a single injector 5th port vs a double injector 6th port (goal is +-550). Thats the last thing I need to order but there isn't a vast amount of info on it.
![]() | | #61 | ![]() |
![]() Join Date: Dec 2008 Location: Harrisburg, pa
Groaned at 7 Times in 5 Posts
![]() | | #62 | ![]() |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok sounds good. And just for general knowledge what is a 5th port good for?
![]() | | #64 | ![]() |
| Not Ranked : 0 score |
![]() | | #65 | ![]() |
Groans: 57
You can also get the perm kit through edge with bigger injectors than the 1000cc you just have to ask and there will be a small upcharge as well. Sent from my LG-LS980 using Tapatalk
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score And the 5th port is only 500hp? And are we talking with straight 93 or with an e85 mix?
![]() | | #67 | ![]() |
Groans: 57
![]() | | #68 | ![]() |
Which also brings up another question. There are 2 main kits available, Perm and sp63. What are the main differences between the two that make the price vary so much? And what is the main consensus on the "favorite one"
__________________ "under construction" | |
![]() | | #69 | ![]() |
Groans: 57
![]() | | #70 | ![]() |
![]() | | #71 | ![]() |
Groans: 57
| Not even that much man, just added both to the cart on each website and it was $30 bucks difference lol
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Holy shit $44.50 to ship from sp, must be shipped by unicorns. So now they are 4 dollars apart. Looks like I will go with perm for quickness lol. You haven't done the install yet have you?
![]() | | #73 | ![]() |
Groans: 57
| No I haven't, waiting until my built motor goes in. It looks extremely simple. The hardest part will be having to drop the Tank to install the fuel pump
![]() | | #74 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
That 650 number is with the larger injectors. But I would say a standard 6th port would be enough for 600.
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | LumberJack (12-29-2013) |
![]() | | #75 | ![]() |
Obviously every setup is different and we could bump the DI% up to 100% and run a little less E, but that 600 number eould be at the ragged ragged edge of the standard 6th port. You really start seeing diminishing returns from the 6th port over 510-20 whp. Thats where I start havimg to request a lot more IPW from the standard 6th port kit vs my car with the upgraded lines and regulator. | |
| The Following User Says Thank You to Realgib3 For This Useful Post: | 2012FailWheelDrive (12-29-2013) |
![]() | | #76 | ![]() |
(Thread Starter) | Not Ranked : 0 score why not cut around the access hole under the seat?
![]() | | #77 | ![]() |
![]() Join Date: Jul 2012 Location: Oceanside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,654
| Not Ranked : 0 score There is a lot of great info in this thread about the 450-600whp (big range) turbo options! Very interested to see what that 5858 does for you OP!
__________________ 2010 Alternative Lifestyle Blue Mazdaspeed3 (sold)2008 Chevy Colorado. The only truck that comes with a lifetime guarantee... |
| The Following 2 Users Say Thank You to ABolewski For This Useful Post: | Realgib3 (12-29-2013), sleeperstang1994 (12-31-2013) |
![]() | | #78 | ![]() |
You run straight e85 through the 6th port though correct? If so, that is quite a bit of fueling headroom left on the table. IIRC DJ was at about 550 at elevation and he was only in the high 80s for DI IDC No number is set in stone and Bryce will be a pioneer for trying larger injectors in the 6th port kit. So we will see what happens. Worse case scenario is we ditch e85 and run race gas for the track map which will also open up some headroom.
![]() | | #79 | ![]() |
![]() | | #80 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks man. I can't wait to get everything up and running and see what power can be made.
| The Following User Says Thank You to 2012FailWheelDrive For This Useful Post: | ABolewski (01-02-2014) |
| For the big BIG turbo guys who complain about spool time... | phate | MazdaSpeed 3/6 - Turbo Induction | 26 | 12-31-2014 08:35 AM |
| Time for a Beener. Smoking Turbo. | Stew | MazdaSpeed 3/6 - Big Turbo Builds | 4 | 09-26-2013 09:55 PM |
| Its time to upgrade the turbo, need help/info with flange and ar setup | sg1320 | MazdaSpeed 3/6 - Big Turbo Builds | 20 | 12-19-2011 01:30 PM |
| Trouble shooting big turbo slow spool time | Ckmazdaspeed3 | 2010 MS3 - Troubleshoot/Diagnostics | 87 | 06-18-2011 10:58 AM |
