![]() Join Date: Apr 2011
(Thread Starter) | Not Ranked : 0 score Pinkcheese AKA Logan I have a 2009 mazda 3 GT Sunlight silver Modification's listed below. Performance •AEM 96" Universal wiring harness •AEM Boost Control solenoid •AEM Coolant Temp sensor •AEM EMS-4 •AEM Intake Temp sensor •AEM Fuel pressure regulator •AEM TwinFire ignition system •AEM UEGO •ARP Head Studs •ARP Main Studs •ARP Cam bolts •ARP Crank bolt •ARP 2000series Rod Bolts •Autolite AR 93 6step colder Spark plugs •Borg Warner S256 turbo •Borla 3" Straight exhaust •CFM 67MM throttle body •Cosworth heavy Duty Main bearings •Cosworth Heavy Duty Rod bearings •Cosworth crankshaft keyed sprocket •Cosworth camshafts •Crower titanium springs •Crower titanium retainers •CP-E center dash gauge pod •Crower Stage 2 FI Cams 280/280 (Should be labled as stage 4 with as much overlap they have) Soon to be installed •Custom keyed ranger crank •Custom Fuel basket with return •Custom intake manifold spacer •Custom built intank fuel surge pot •Derale Oil Cooler •Derale Oil Thermostat •Eagle H Beam Rods •GodSpeed intake Manifold •Focus SVT re-Manufactored 255LPH fuel pump (BAP, Compatible) •Ford GT green top 300 LPH pump •Megan Racing Oil Catch can •Modified Reactive racing turbo kit •MSD Blaster II coils (150,000V) •PCS XFC •Silicone vacuum hoses •Siemens Deka 1000cc/min high impedance injectors •Supertech lash caps •Supertech shims •Suptech valves Stainless steel Intake Black Nitride coated. •Suptech valves Inconel Exhaust •Suptech valve seats •Supertech valve seals •Supertech pistons 9.5:1 compression With custom valve reliefs •Summit Racing braided stainless oil feed line -3an •Summit Racing braided stainless oil return line -10an •Summit Racing braided stainless fuel feed lines -6an •Summit Racing Route around check valve •TurboSmart 38mm wastegate •TurboSmart E-boost street 40PSI •Throttle body adapter •Valveoline Full race synthetic 20w50 (The illegal stuff) •2.0 oil conversion plate •2.5" stainless down pipe Drivetrain •ACT G6 sprung clutch kit •ACT flywheel •ACT Heavy Duty pressure plate •Mazdaspeed 3 6speed transmission •Protege Garage shifter weight •Street Unit 90 duro tranny •Street Unit 90duro passanger side engine mount •Street Unit full race main engine mount •Street Unit shifter bushings •Royal purple MTX fluid 75w-90 Machine work •Balance shaft feed line welded shut •Balanced Crankshaft, Pistons and Rod assembly to .05grams for 9000RPM •Custom keyed crankshaft •Custom keyed pulley •Decked block •Honed cylinder chambers •Oil pan welded for return line •Pinned main bearings •Pinned Rod bearings Brakes GoodRidge Stainless Steel lines Mazda 5 rear brake conversion Mazdaspeed 3 Front Calipers Stoptech Rotors Front Stoptech Rotors Rear Suspension •AWR endlinks (aftermarket style) Fronts •AWR endlinks (aftermarket style) Rear •Hotchkits sway bars Front and Rear •Megan racing coilovers 10kg front 12kg rear •2"drop Front •1.5" drop rear interior •COBB short throw shifter •Dome light LED blue •Glovebox light LED blue •Greddy turbo timer special edition black •Mazdaspeed 3 shift knob •Mazdaspeed pedals •Map light LED blue •Modified advanced warning features to include boost cut through Turbosmart E-boost street •Modified Zeitronix Datalogger Water temp Fuel pressure O2 sensor Oil temp Oil pressure EGT sensor Map sensor •Schroth 4point harness Exterior •Anodized valve stems •Engine hood spacers •Enkei RPF-1 17X9 +45 •kumho ecsta XS 245/45/17 •Street Unit sponsor vinyl •Zoom-ZOOm 3rd brake light Running off AEM EMS-4 Last edited by pinkcheese; 02-01-2012 at 09:55 AM. |
| The Following 6 Users Say Thank You to pinkcheese For This Useful Post: | Coaststarlight (07-01-2012), IshiKage (10-26-2011), jeopardy98 (11-28-2012), kmac (10-26-2011), Raider (11-12-2011), rfinkle2 (10-28-2011) |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score Damn looks like a badass build! And a lot of $$$ |
![]() Join Date: Apr 2011 Location: Brisbane, Australia
| Not Ranked : 0 score Can't wait to see the results from this build |
![]() Join Date: Jan 2011 Location: Midlothian, Va
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,042
Groans: 274
| Not Ranked : 0 score Bad ass man. If I may suggest, loose the mazdaspeed banner up front. Other than that, car looks great and that is one awesome build. What kind of power is it putting out? |
| The Following User Says Thank You to SLOWHATCH For This Useful Post: | DONOTBUGME (10-26-2011) |
(Thread Starter) | Not Ranked : 0 score It was putting out around 350-375WHP before switching over to the standalone. Once I finish up the standalone there will be nothing stopping it at this point. Before I was running a piggyback which limited me on how far I can take the car due to lack of timing control. Now the only limitation is the clutch. I am shooting for 450+ WHP in Dec. When I go to get it tuned. Then a few months after that aiming for 500+ WHP, Once I have done a direct port meth injection aswell as a more efficient intercooler. Still have lots more to upload to this thread quite a bit missing from what is actually done to the car. ^^ That banner is part of MazdaSpeed Motorsports program, has nothing to do with MazdaSpeed 3 Last edited by pinkcheese; 10-27-2011 at 12:08 PM. |
| The Following 2 Users Say Thank You to pinkcheese For This Useful Post: | Downmented (07-01-2012), SLOWHATCH (10-26-2011) |
Groans: 433
| Not Ranked : 0 score nothing stopping? that 255lph in-tank pump gonna stop ya! Holy $$$ build batman. Good luck
![]() Join Date: May 2010 Location: West Palm Beach, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,842
Groans: 819
| Not Ranked : 0 score Awesome I can actually say i have seen this car in person...which makes me cool
__________________ |
![]() Join Date: Nov 2010 Location: Lakeland, WA
Rep Power: 1231 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 875
Groans: 266
| Not Ranked : 0 score wouldnt it be cheaper to get a speed and put in a bt.
__________________ Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next. |
| The Following 2 Users Say Thank You to DONOTBUGME For This Useful Post: | manelscout4life (10-27-2011), Palms (10-27-2011) |
| Not Ranked : 0 score Guess you're only gonna do a few pulls here and there. Cuz with the stock radiator your shit's gonna get mucho caliente if you ever do more than 5 or 6 WOT pulls at a time. Nice red line. 9K rpm. Wheeew! Does your rpm gauge do more than one full turn? lol. Did not see an rpm gauge in your interior mods.
| The Following User Says Thank You to Tomas For This Useful Post: | Palms (10-27-2011) |
(Thread Starter) | Not Ranked : 0 score You guys would be surprised I have less in this build than most of the big turbo guys here do. Doing all the work myself. That fuel pump is rated for 255LPH at 12v I'm pushing 14.3v through it and BAP on the way just in-case the added pressure is there. It is a remanufactored SVT focus pump which was built for boost a pump applications. This is one area I am not worried about in this build. |
Groans: 266
| Not Ranked : 0 score what about all the other parts like brakes, axles, tranny, and other stuff the speed has upgraded compared to the mz3...or do they?
^^ I have a 6speed tranny this includes the axles. Brakes I am running MS3 fronts and Mazda 5 rears. Yellow stuff pads, and good ridge lines. This isn't just a power build everything that could possibly break has been changed out and all the weak links as far as suspension and braking goes. Last edited by pinkcheese; 10-27-2011 at 05:27 AM. | |
| The Following 2 Users Say Thank You to pinkcheese For This Useful Post: | 802MS3 (10-27-2011), DONOTBUGME (10-26-2011) |
__________________ | |
(Thread Starter) | Not Ranked : 0 score In Virginia, local autocross chapter rents out places time to time for track day events. I missed VIR this year but hopefully next season I'll get out for some NASA events. |
![]() Join Date: Jun 2010 Location: li, merrick, new york
Rep Power: 2273 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,757
| Not Ranked : 0 score Nice build . U got my attention |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score Funny bit is you will probably make more power than any MS3 here since you aren't crippled by DISI and won't run out of fuel like we do.
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
Groans: 70
| Not Ranked : 0 score ^^this. but i wouldnt go as far saying "any" |
![]() Join Date: Apr 2009 Location: VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 677
Groans: 320
| Not Ranked : 0 score |
| The Following 2 Users Say Thank You to Manny For This Useful Post: | AtTheDriveIn (10-28-2011), Monotonous ONE (10-27-2011) |
Also The crower cams I am putting in peak power around 8,000rpm and drop off around 8,500rpm. so this gives me some shifting room and won't stress my components inside the engine to much with harmonic instability. YEs the needle will go past the gauge it stops just before hitting the inner edge of the gauge. I do not plan to mod it because I rarely will get that high in the rev range. Added a few pics of the keyed crankshaft surprised some of you haven't switched over to this yet atleast I would have expected some of the big power guys to. | |
![]() Join Date: Nov 2009 Location: las vegas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 711
| Not Ranked : 0 score seems like there are a few things us speed 3 guys can do that you 3 guys are doing, build looks sick man! how different is the speed 3s head compaired to the 3s head? iv never looked into it. 9000 rpm red line! bad ass!
__________________ T3 Steed Speed twinscroll manifold- GT35R- CPE HPFP- COBB AP- DO METH- PTP BSD/WIN- CPE FMIC 2.5 piping- Twin Gates- CorkSport Exhaust- Full Mounts Last edited by mason; 10-27-2011 at 05:02 PM. Reason: MSF Database - Automerged Doublepost |
Groans: 433
I mean, I know Erich's build probably cost a lot, but I'm guessing he didn't reach the parts expense you have by a long shot, and he's at over 500whp
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() Join Date: Mar 2009 Location: Broomfield CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 823
Groans: 60
| Not Ranked : 0 score That's what I was thinking. I am willing to bet my BT build cost less than half that parts list. Either that or OP is ultra Jew and got the parts for next to nothing.
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph |
| The Following 2 Users Say Thank You to dsmluck For This Useful Post: | Chimmike (10-28-2011), manelscout4life (10-27-2011) |
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Not Ranked : 0 score damn this shit is legit. nice job. bet youre gonna surprise some much fast cars out on the track.
![]() | | #24 | ![]() |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score Erich has a built block. Let's talk about kmac. 494whp, stock motor. There's no way he spent even 1/3 of what the OP's parts list is. Turbo manifold, turbo, intake manifold, water/air intercooler, custom meth setup, clutch...and then all the other miscellaneous things, but nothing super expensive.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
![]() | | #25 | ![]() |
Groans: 819
| Not Ranked : 0 score this build is cool and all but i think you should answer the obvious question on everyones mind what kind of gas mileage do you expect to get?
![]() | | #26 | ![]() |
Groans: 433
I'm betting the overall cost for this thing in parts alone exceeds what most guys here with built motors have spent, and with something simple like port FI, I'm betting 550whp isn't going to be hard to reach on the DISI.
![]() | | #27 | ![]() |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,419
Groans: 81
Groaned at 30 Times in 25 Posts
| Not Ranked : 0 score hey logan didnt know you had a build thred here. <3 you.
eh not really i got him those parts and it wasnt bad at all what he spend for the system. MAYBE a alittle more than a AP.
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler Last edited by J-Liss; 10-28-2011 at 07:56 AM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to J-Liss For This Useful Post: | Chimmike (10-28-2011) |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score Gas milage isn't bad even with speed density tunning and no maf it's around 20milea to the gal. Aslong as I keep my foot out of it there isn't real issues. No highway numbers yet because I don't drive to far with the far till it's all sorted out. Lasttime I drove it on a long trip it was around 35-38mpg The speed 3 head and the 2.3l and 2.0l head one I'n the same are about $1200 of machine work from fitting together mainly the oil and coolant passages only thing that lines up is the headstuds. I am going to start building a frakenstien block here around tax season with a speed bottom end and a mz3 head. As a backup block. I can tell you guys that only about 2-3 of the listed parts were bought at retail cost. And none of them big items. |
![]() | | #29 | ![]() |
Groans: 81
| Not Ranked : 0 score if anyone can do it logan you def can.
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler |
![]() | | #30 | ![]() |
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| Not Ranked : 0 score Logan. Which shop is doing the machining for you? Oh and fuck you and your port injection...
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Originally I used L&W and Melvins for a few oddball jobs. But I will more tha likely use this place in Ashland VA for the Frankenstein block sense they have quite a bit of expierence with this and other work I want done. There has been quite a bit of headway recently with the new skiactive engines mazda came out with. I expect to see some more 500+ speeds now that you have a new fuel rail, Injectors and 2900PSI to work with. Port injection is ok but I will miss the little bit of high pressure (175-220PSI) I was running there. Nothing like having a smooth idle, and being able to ramp the injectors with fuel pressure to change the flow characteristics for high power. Only thing port injection really has is simplisitic proven design with a lot more aftermarket stock for stock I'd Take DISI anyday. Thanks for the vote of convidence Josh. |
| The Following User Says Thank You to pinkcheese For This Useful Post: | kabobulate (10-28-2011) |
![]() | | #32 | ![]() |
Groans: 60
__________________ 2003 Lancer Evolution VIII - FIC 1120cc/Walbro 255/E85/Pure Drive Performance Tune 1990 Talon TSI AWD: Evo III 16g/E85/Exhaust/PTE 1000cc's/2g Maf/ECMLink *Wrecked* 2012 WRX: TD05 20g/E85/FIC 900cc's/Walbro 255 *SOLD* 12.8@110mph 2009 MS3: GT3076r/(75/25) E85/Bolt-ons *SOLD* 13.6@112mph | |
![]() | | #33 | ![]() |
Groans: 433
| Not Ranked : 0 score he's referring to the skyactiv injectors, but as speedsixkillah mentioned, they do not directly fit the MZR, however he's sending them off to see if the internals will work in our injector housing
![]() | | #34 | ![]() |
![]() Join Date: Apr 2010 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 492
| Not Ranked : 0 score damn logan didnt realize you had so much in the car. I gotta go for a ride in that thing sometime haha looks sick
__________________ 2010 super smiley Red MS3 - Corksport SRI/TIP - ETS TMIC - CNT hiflow catted long DP - Sure boost tubes - SURE motorsports anchors - SU RMM - Greddy Type S BPV - KMD HPFP Internals - harryclay tune - Semi-flat black wheels (painted stockers) - Eibach pro springs ftw - Michelin Pilot Super Sports 235/40/18 - Yellow 55v fogs 13.69 @ 106 (4g eth mix, intake/tune) 13.67 @106 (intake,dp,tmic, 50/50 eth) |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score You'll have to wait till the beginning of the year. I'm driving around on 7psi right now. Not pushing it till I get some more time been so busy with work and school 7days a week. But once it's fully tuned and running good I'll give you a ride. Most of the work is I'n the engine which can't be seen and the engine bay looks somewhat stock with everything hidden. nice sleeper effect. |
| The Following User Says Thank You to pinkcheese For This Useful Post: | harryclay (10-31-2011) |
![]() | | #36 | ![]() |
Groans: 60
| Not Ranked : 0 score How did I miss this? What are the chances the internals would fit?
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score Unfortunately my tune date is getting pushed back, I have to send my EMS back to AEM for awhile voltage regulator is for the coms is going out do I cannot connect to it half the time with my laptop. Apparently this is a known issue bad batch of regulators, that AEM recieved. Pushed back 2 weeks. This gives me a chance to properly seal up the wiring with slmething more permanent now that I'm happy with the mock up I choose. |
![]() | | #38 | ![]() |
![]() Join Date: Jan 2011 Location: vancouver,WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
| Not Ranked : 0 score You know Logan I was seriously considering resleeving my block with some Darton mids, hell of a lot better then the 2mm liner we have to work with, $660, probably another 300 for the machine work involve, can't say for sure I haven't really looked into it yet, also I think I found a reinforced main girdle assembly though you wouldn't think a one piece girdle could walk especially when using arp studs. Mid december I' am headed back to PRE and do another dyno session since I will have the new ewg installed with the 18" screamer dump, and the new 386lph intank walbro...maybe just maybe might hit close to 400whp...we will see. and I 'll get the final word on that halltech platinum 1000 mzr setup, pretty sure the oe ecm will still need to be ran parallel for ancillaries just like you are going to have to do with the AEM unit. look good man, keep up the progress |
![]() | | #39 | ![]() |
Sense you can pull timing and alter injection pulse width, you will make 400 only thing is that the stock computer does have limitations. I would suggest you really look into that haltech, You will have to upgrade your ignition system at a point to make those types of numbers aswell as need some full control in areas it isn't offered that and the peace of mind. The stock computer has to control the ancillaries, the power steering isn't belt driven and the alternator is a pain. | |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score Fuel system is finished and ready for install. Pressure tested it for 80PSI and it works. Includes factory form and function. Removed the restrictive check valve, as well as ported out the fuel passageways from 1/4" to 3/8" Also modified the factory feed so it acts as a return line now and feeds the fuel into the surge pot. This will help for high speed cornering. Finally replaced the factory fuel pump with The Ford GT 300lph pump at 14.5V Last edited by pinkcheese; 02-01-2012 at 03:48 PM. |
| BorgWarner aquires Haldex | Haltech | Automotive News | 0 | 12-20-2010 07:20 AM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 10:10 PM |
| Bullseye / Borg Warner .55 A/R T3 S256 Turbo, Need input! | JumpingJackson | MazdaSpeed 3/6 - Turbo Induction | 5 | 09-03-2009 07:45 AM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
