![]() | | #81 | ![]() |
![]() Join Date: Jan 2010 Location: Ladera Ranch, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
(Thread Starter) | Not Ranked : 0 score Tapatalka
__________________ 2008 MAZDASPEED 3 GT | Cobb SRI | Cobb XLE BPV | SURE TIP | SURE RMM | Resonators Deleted | TurboXs Catless DP | | Cobb AP Stage 2+ | PG/Godspeed FMIC | BC Coilovers | Evo X Wheels | 245/40/18 Hankook RS3 | | Cquence Drilled/Slotted Rotors | Hawk HPS Pads | TWM STS | Glowshift Boost Gauge | Sti V Limited Front Lip | |
![]() | | #82 | ![]() |
(Thread Starter) | Not Ranked : 0 score Double post.
![]() | | #83 | ![]() |
(Thread Starter) | Not Ranked : 0 score Looks like turbo is going out. Went wot and stopped at a light and my car was gushing white smoke. Pulled into parking lot and let it idle and it kept smoking. Going to put it on the lift at my friends shop tonight and check it out. Anything I should be looking for? Tapatalka
![]() | | #84 | ![]() |
Groans: 433
| Not Ranked : 0 score too much presshuh. ask @bmylez
![]() | | #85 | ![]() |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score White smoke? I hope it's not your head gasket. It starts off as white smoke...but if you let it keep going, it should turn blue-ish if it's oil you're burning. Quick solution: stop driving the car if possible, or drive VERY lightly, order this: eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices Then get a drill and a 5/64" titanium bit. Enlarge the hole in that restrictor bolt, install in turbo, and smoking should go away...unless you are the unluckiest schmuck like I am and it won't help. It's cheap to do and worth a shot. Tip: If you go through with drilling out that bolt, go VERY slowly or the bit will poke through and drill the other side...then you will be stuck with a bolt with two .078" holes which is barely better than stock. One .078" hole is perfect oil feed for our turbo.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
![]() | | #86 | ![]() |
(Thread Starter) | Not Ranked : 0 score It was all white smoke, didn't let it idle long enough to see if it turned black. What I did notice when I popped the hood though was my heat sheild on my mani was cracked. I had my friend pick me up and I'm letting it sit for about an hour then going to his shop to investigate it. Would the bnoon bolt help at all in this situation? I just need it to last me till around january till I get the pte in. I think I will flash the stage 2 safe map as well to keep me from going wot. I am investing in a gas scooter to get around soon also for shit like this. Tapatalka
![]() | | #87 | ![]() |
| Not Ranked : 0 score Can you get a hold of a Bnoon bolt?
![]() | | #88 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I'm guessing he doesn't sell them anymore? Lol fuckk. Ill try drilling my own hole as you have suggested. Hopefully that works. Going to pick the car up right now and will get back to here after its up on the lift. Tapatalka
![]() | | #89 | ![]() |
| Not Ranked : 0 score Yeah dude, Brad doesn't make them anymore. He doesn't even have his tools anymore (long story). Order that bolt right now. It should only take 3 days MAX to get there because that seller is in CA. Really hoping your seals aren't as fucked as mine were. Even with a .0625" hole (a little on the small side), I was getting bad smoke at idle. Fuckin ghetto. A .078" hole makes sure you won't be oil starved, but it's less than half of the flow of the factory bolt, which I don't know what the fuckin Mazda engineers were thinking, but two .095" holes is mad retarded.
![]() | | #90 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah I have hich hopes that the seals are still somewhat good, at least until I can get the rest of my parts for my build. I will definitely order that bolt as soon as I get to a computer, itd be the same install as the bnoon bolt correct? Tapatalka
![]() | | #91 | ![]() |
(Thread Starter) | Not Ranked : 0 score It drove and sounded fine driving from the light to the gas station, just smoked whenever I stopped. I haven't done much research on the smoking turbo because mine hadn't been this bad before so idk if that's a symptom or not. My car looked like a fog machine lol. Tapatalka
![]() | | #92 | ![]() |
| Not Ranked : 0 score Yeah, dude direct bolt on. Don't mind the banjo fitting it comes with. I couldn't find just a straight bolt without it. Use the crush washers, of course. One thing I noticed is that it only threads in a turn or two by hand, so it's deceiving. After it turns smoothly one turn, get a wrench on it. If it continues to turn really easily with a wrench, it is threaded correctly. It's a piece of cake. Smoking at idle is the EXACT symptom. My car didn't smoke in part throttle...but since it was super fucked, it smoked badly at WOT. The smoke at idle was atrocious, though, and really embarrassing.
![]() | | #93 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah it was pretty embarrassing. Fuck me I need to get approved for this new credit card so I can finish the build. How much does this bolt help? I don't mind occasional smoke but if it smokes like that 24/7 I'm gonna be pissed lol. I'm definitely not going wot anymore though that's forsure. Tapatalka
![]() | | #94 | ![]() |
| Not Ranked : 0 score I can't make any promises, man. You might get lucky like most people. Like I said, I'm one of the unluckiest guys when it comes to turbos. If your seals aren't as damaged as mine, it should completely eliminate the problem. In bnoon's thread, he said he was smoking like James Bond smoke screen style at idle and after he installed his bolt, it went away entirely, so it is definitely possible for you as well!
![]() | | #95 | ![]() |
Groans: 433
| Not Ranked : 0 score the bnoon bolt is a preventative measure, that's all. It won't stop smoking once it's begun. When the smoking starts, your seals are going bad, ain't no reversing it. bnoon bolt doesn't bolt into anything but stock turbo IIRC, too.
![]() | | #96 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'm still on stock turbo. And I babied my car on the drive home, didn't shift till 3k the whole drive. Got home let it idle and after 5mins it smoked like a smoke machine. Fml. Time to try the bolt and finish getting parts. Tapatalka
![]() | | #97 | ![]() |
| Not Ranked : 0 score And we are talking about stock turbo. Also...Brad said he was smoking BADLY, installed bolt, and smoking stopped...so, not sure what to tell ya.
![]() | | #98 | ![]() |
(Thread Starter) | Not Ranked : 0 score Anyways, now onto a build related question, since I'm not going to be using the coolant lines, should I cap them or route the two together? I read something about that in another precision thread. Tapatalka
![]() | | #99 | ![]() |
| Not Ranked : 0 score You cannot cap them. One of the lines goes to the EGR/coolant manifold. If you capped it off, you would be stopping coolant to part of the motor. Just buy a 3/8 barbed joiner. Problem solved
![]() | | #100 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lol awesome! Thanks man that's one of the last remaing questions I had about this build. I need to get moar parts! Tapatalka
![]() | | #101 | ![]() |
(Thread Starter) | Not Ranked : 0 score God I'm so sick of this smoke shit. I found that if I give it a little gas while at a light, it doesn't smoke, like around 1200rpms. I'm going to get atr tonight and raise my idle and hopefully that helps a little. Also going to switch to 5w40 in a week. Tapatalka
![]() | | #102 | ![]() |
| Not Ranked : 0 score I thought the same thing...but one time I sat at a light revving at 1500rpm for a little while and the smoke started pouring...so I let off and it got better...
![]() | | #103 | ![]() |
(Thread Starter) | Not Ranked : 0 score So far its been working well for me...also fuck atr not being compatible with macs.... Tapatalka
![]() | | #104 | ![]() |
| Not Ranked : 0 score Oh, and actually, it turns out my turbo wasn't smoking. FUCK ME. My PCV valve died so it looks like I'm smoking from my valve seals. You can have my stock turbo, haha.
| The Following User Says Thank You to bmylez For This Useful Post: | EL F00LI0 (12-07-2011) |
![]() | | #105 | ![]() |
(Thread Starter) | Not Ranked : 0 score How did you figure that out? Might be my problem too. But if its not, I'm all for your turbo ![]() Tapatalka
![]() | | #106 | ![]() |
| Not Ranked : 0 score Naw, I think my stocker is a little beat up. I disconnected my valve cover breather and let it dump into a container on the way to and from work. I had a shit ton of oil just from 36 miles...also, I'm still burning oil. The PCV valve is completely dicked and of course fuckin Mazda doesn't stock them so I have to wait. The damage has already been done, so we'll see what a new PCV valve does. New valve seals will cost a shit load...might have to throw in the towel...
![]() | | #107 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well shit man dont give up! The bad luck will end eventually....if your turbo doesnt smoke and your willing to send it out ill take it idc if theres shaft play or it doesnt perform at its best. Im just using it to be able to get around with a safe map loaded.
![]() | | #108 | ![]() |
| Not Ranked : 0 score Well, like I said, I don't know if it was smoking or not since I have multiple symptoms. I guess I could let it go for a few bucks + shipping, just to cover costs. I'm assuming you can't afford to have the car down?
![]() | | #109 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hmm and there's no way to check the seals once its off the car? Let me get back to you on the k04, I'm going to try the thicker oil/banjo bolt and see if that subdues it a little. Tapatalka
![]() | | #110 | ![]() |
| Not Ranked : 0 score Only way to check the seals would be to run pressurized oil through it, haha.
![]() | | #111 | ![]() |
(Thread Starter) | Not Ranked : 0 score Lol yup thatd be a little hard Tapatalka
![]() | | #112 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got the bolt today, going to attemp to drill it out tonight. A 5/64 drill bit should make a .078" hole correct? And do I drill into the tiny hole already on the side? Tapatalka
![]() | | #113 | ![]() |
| Not Ranked : 0 score Yes, you just want to enlarge the hole that is already there. Be very careful not to punch through the other side. And of course, triple check for metal shavings.
![]() | | #114 | ![]() |
(Thread Starter) | Not Ranked : 0 score I will report back with the results tonight! Tapatalka
![]() | | #115 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well installed bolt. So far, no smoke upon startup, just smoke coming out cuz its cold. No smell of burning oil, will see if it smokes after driving to eat. Tapatalka
![]() | | #116 | ![]() |
(Thread Starter) | Not Ranked : 0 score Bolt didn't help at all lol. Can check that off the list. Now going to try 5w40 on my oil change coming up in a couple days. I really think bumping the idle would fix it. When I'm at a light and I keep the rpms at 1500, no smoke. Without it, there's smoke. Wish atr was compatible with macs... Tapatalka
![]() | | #117 | ![]() |
| Not Ranked : 0 score If you are still smoking with that much smaller of a bolt, it sounds like your seals are just as shot as mine are. 5w40 might help, but who knows. Sad times.
![]() | | #118 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, definitely sad times....just need to get the rest of my parts after xmas so I can get rid of this tiny k04! Tapatalka
![]() | | #119 | ![]() |
![]() Join Date: Jul 2011 Location: hesperia, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 295
| Not Ranked : 0 score damn bro get the Turboh up and running. Ill be going gtx71r after taxes =)
__________________ 2008.05 True Red Mazdaspeed3 Lex Tuned GTX3071r | 38mm Tial WG | Hallman MBC Cobb AP E85 30% |CPE Big MAF | CPE Big TIP | CPE FMIC | SS Ex Mani | CPE Catted DP | CNT CBE | CPE Triple Gauge Pod | Autotech HPFP Internals | Denso ITV22 | TS BPV | TWM ShortShifter | JBR Shifter Bushings | JBR 88 RMM | Razo Heavy Shift Knob | 20% Tint | DDM 55W HID | Hankook Ventus V12 | H&R Springs |
| The Following User Says Thank You to TRSpeed For This Useful Post: | EL F00LI0 (12-13-2011) |
![]() | | #120 | ![]() |
(Thread Starter) | Not Ranked : 0 score It will be up and running by mid January-early February....xmas is killing my wallet right now!
| R.I.P. PTE 5557 | cageyvet | MazdaSpeed 3/6 - Big Turbo Builds | 30 | 12-19-2010 07:56 PM |
| pte 5557 .63 ar, cpe sb, 420 whp | cageyvet | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 129 | 07-25-2010 05:33 PM |
| PTE 5557 @ 17-18psi | cageyvet | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 40 | 04-16-2010 08:11 PM |
