 Old 03-06-2014, 05:19 PM   #1
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
These are the 3 port interrupt setup instructions.
You can run this solenoid in 2 port mode.
All you need to do is to cap off port 3 and then just connect the port 2 to your turbo inlet pipe and port 1 to the top port on your wastegate actuator.
Make sure the bottom port on the wastegate actuator is still attached to the compressor housing barb at the bottom.
Here's a diagram of setting up a 3 port in 2 port mode:
http://stratifiedauto.com/images/3P%...eed%20Mode.png
Oopps sorry! I just copied the link I had on my favorites bar from when I installed mine. I thought those had the instructions for 2 port and 3 port. Now that I think about it, Grimmspeed's instructions has the instructions for both.
My bad. Thanks for the save @Lex;
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
The Following User Says Thank You to rymanmazda For This Useful Post:
Lex (03-13-2014)
switching oil? blackms3_71 Mazdaspeed3/6 General Discussion 9 11-17-2013 12:17 AM
Switching from SB to AP... need help MS3 Ventura MazdaSpeed 3/6 - ECU Computer Tuning 23 12-20-2010 11:15 PM
switching to sythetic oil phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 61 04-19-2010 03:15 AM
Switching to MBC cpolly69 MazdaSpeed 3/6 - Turbo Induction 10 09-20-2009 06:43 PM
Page generated in 0.23188 seconds with 21 queries
