 Old 01-08-2016, 02:55 PM   #1
josey's Avatar
Posts: 15   (View Stats)
josey is a jewel in the roughjosey is a jewel in the roughjosey is a jewel in the roughjosey is a jewel in the rough
Default Valve spring kit
Hi guys
i dont know is this good sub forum to ask, and if is not please move topic to correct one.
I have question for you,
what valve springs do you use on your big turbo setup?
i have 91mm turbo
supertech valve guides
supertech valves
cosworth cams
and upgraded cosworth retainers KK3459 kit* (for which i found data, they are 44lb seated pressure)
now second time same thing happens to me,
as soon as fully warmed up engine sees 15psi boost or more, piston hits valve (on 7000rpm rev limiter )
so im getting to conclusion that this valve spring retainers are not good enough for this boost level.
can you share your experience with valve springs?
* i have duratec 2.0 not 2.3 DISI, bit it is very similar engine.
thanks guys
josey is offline   Reply With Quote
Valve Spring Choices maisonvi MazdaSpeed 3 - Engine, Transmission & Driveline 67 01-19-2017 06:27 AM
Spill valve spring mod Enki MazdaSpeed 3/6 - E85 Fueling 15 02-02-2014 11:01 AM
Valve spring specifications sporadic 2010 MS3 - Engine, Transmission & Driveline 3 05-27-2013 06:38 PM
Page generated in 0.24712 seconds with 20 queries
