| Banned ![]() Join Date: May 2010 Location: Toronto/Springville NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Groaned at 8 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score Hey guys, I'm planning out my big turbo install parts list and I would like to know if there is anyone using the pg fmic with a big turbo set up? Any input will be appreciated. |
![]() Join Date: Apr 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 427
Groaned at 27 Times in 21 Posts
| Not Ranked : 0 score Definitely upgrade the core if you go that route. TurboXS has the biggest IIRC. |
Groans: 239
| Not Ranked : 0 score it depends, are you going to run meth?
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
(Thread Starter) | Not Ranked : 0 score Yeh, I'm planning to run meth since I already do on my current set up. How good are the Turbo xs intercoolers? |
Groans: 239
| Not Ranked : 0 score are you going to be meth dependent? imo, get a somewhat smaller IC, meth does enough cooling.
Do you have a link for the mentioned core? Last edited by the_rolex_guy; 11-24-2011 at 08:54 AM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Nov 2011 Location: edgewood md
Rep Power: 2429 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,644
Groans: 391
Groaned at 75 Times in 49 Posts
TR8 Intercooler- TREADSTONE PERFORMANCE
__________________ moore automitive 4/13/13 515whp 511 tq Mason Dixon Raceway 11.289 @125 1.845 60' Killah Built Powered By Purple Drank | |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| Not Ranked : 0 score L2A Intercooler. |
![]() Join Date: Feb 2009 Location: Salt Lake City, Utah
Rep Power: 427 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score The PG core is only rated for 350hp, I just switched out my pg core for the tredstone tr8l. Loving it so far.
__________________ 417whp 428tq 12.037@117.2mph |
| The Following User Says Thank You to Snyeed For This Useful Post: | rigor (11-24-2011) |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score tr10 3.5 ftw
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| The Following User Says Thank You to rigor For This Useful Post: | Captain KR (11-24-2011) |
Groans: 391
| The Following User Says Thank You to Captain KR For This Useful Post: | rigor (11-25-2011) |
Groans: 239
| Not Ranked : 0 score meth cooling > big ic chemical cooling > pressure drop
| The Following 2 Users Say Thank You to dooderek For This Useful Post: | rigor (11-25-2011), thatsmrgimp2u (11-25-2011) |
Groans: 391
| Not Ranked : 0 score next mod meth kit with a 2 gallon tank.
| Banned ![]() ![]() Join Date: Apr 2011 Location: Lanoka Harbor, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 238
Groans: 68
| Not Ranked : 0 score Godspeed has a few big cores available also |
| Not Ranked : 0 score Meth is really a patch up job for a bad intercooler. Go for an L2A. |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score Also another option is to use an upgraded tmic cooler especially if you run meth. I will be running my ets. The core is decent, bigger then some of the kits out there. Just make sure you get a decent sized core. As mentioned above tr8 would be great. tr10's are pretty damn big.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold Last edited by 86AmishMs3; 11-25-2011 at 01:51 AM. |
![]() Join Date: Dec 2010 Location: TX
| Not Ranked : 0 score Pretty sure you have to chop up your bumper a fair amount to fit the TR10.
__________________ 2007 CTS-V - Trying to sell 2009 CTS-V - Not getting a cam. Ever. |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score I decided to go with a TMIC after i planned on running meth and couldnt be happier. Helps with sleeper status (if you care) and I didnt want to get salt and all the nasty gunk that gets on the roads up here when it snows.
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
| Not Ranked : 0 score Yea dropping boost temps below ambient is a total patch up job. Liquid to air doesn't offer that big of a difference. Boost temps will be nearly identical with an upgraded air to air intercooler and it can and will heatsoak. It takes significantly longer for water to cool back down. Get the biggest heat exchanger you can fit if you go with this setup. On the plus side w2a is relatively inexpensive but you will have to do a moderate amount of fabrication and have more parts that could potentially fail. In the spring when I do my BT I will be doing a upgraded tmic with my current meth setup. I can eliminate heatsoak in a couple of seconds with meth. Getting rid of the stock tmic pressure drop is my main reason for upgrading, as well as better flow. Meth is some badass stuff, definitely worth it imo. Sent from my Rezound using Tapatalk
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
| Not Ranked : 0 score Quote Originally Posted by Corky Bell "The water injector is not a very interesting device. It has little place in a properly conceived turbo system. Two circumstances are viable for a water injection: a 1970 Vega turbo with a draw-through carb, or a Roots supercharger sitting between a huge engine and two huger (really big) carbureturs. To stake the margin of safety of a turbocharged engine on an inherently unreliable device is and idea whose time has long since passed. RIP ->Rule: A water injector on a turbo car is a poor-excuse band-aid for not correctly doing the job the first time." Page 70 Bell, Corky "Maximum Boost" 1997 Quote Originally Posted by Corky Bell "Don't be too hasty to create a margin of safety on detonation based on an unreliable device. Water Injection is best used when boost levels over 6 psi are desired but no intercooler is present. Do not allow a situation to exist where the water injector is used as an excuse for improper air/fuel ratios. All things considered, you would be far ahead never to have heard of a water injector." Page 74 Bell, Corky "Maximum Boost" 1997 |
Groans: 90
Nothings perfect but when it comes to cooling boost temps, meth does it very well. Sent from my Rezound using Tapatalk
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM | |
Groans: 239
| Not Ranked : 0 score you also have to understand automotive technology as changed alot since when the book was made. ive personally talked to corky bell, you can also reach him since he owns a company called begi. i briefly asked him about maximum boost, and he said that although he stands by what he said at the time, alot as changed since then and technology has made some of his points obsolete. in the last paragraph imo it sounds more like hes saying if you cant get enough fuel, dont band aid it by wmi injection. however on the relevant topic he pretty much says. "Water Injection is best used when boost levels over 6 psi are desired but no intercooler is present. " my advice isnt to delete a intercooler completely, but if wmi is used, i would advise to run a smaller intercooler as you will have less of a pressure drop, and with wmi there really is no need for the extra air to air cooling. oh and running a big intercooler requires modification of the crashbar. i had to cut mine at the flanges since those are what hold the core up. another food for thought
| Evo 8 intercooler | zumin | 2010 MS3 - Turbo Induction | 6 | 02-25-2011 03:25 PM |
| INTERCOOLER | akbrazil | 2010 MS3 - Engine, Transmission & Driveline | 100 | 05-06-2010 10:08 AM |
| HELP...OIL IN INTERCOOLER | bombdotcom | MazdaSpeed 3 - Engine, Transmission & Driveline | 5 | 10-16-2008 02:22 PM |
