Like Tree5Likes
  • 1 Post By CorkSport
  • 1 Post By blackms3_71
  • 1 Post By RazoE
 Old 10-23-2015, 01:02 PM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default 1st Gen MS3 ECU Relocation Kit/Battery Box
We have the 2007-2009 Mazdaspeed 3 Battery Box/ECU Relocation kits finished and ready to ship out
The box is made from thermoformed ABS plastic and include an easy to remove (no tools required) lid.
Click here to get more details on it.
-Derrick
WWW.CORKSPORT.COM
The Following 11 Users Say Thank You to CorkSport For This Useful Post:
Boost_creep (10-23-2015), Code Monkey (10-23-2015), Easter Bunny (12-03-2015), ItsNox (10-23-2015), littleloogy (10-23-2015), magicka (10-24-2015), MS3Shadow (10-23-2015), Nliiitend1 (10-23-2015), Raider (10-23-2015), RazoE (10-23-2015), taf0422 (10-23-2015)
 Old 10-23-2015, 01:05 PM   #2
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Where was this a week and 1/2 ago?!
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 10-23-2015, 01:13 PM   #3
Boost_creep's Avatar
Posts: 829   (View Stats)
I like this box a lot. The only problem is my meth controller is mounted inside my oem box in front of the battery. Is there any room between the ecu (in your location) and the battery?
 Old 10-23-2015, 01:16 PM   #4
CorkSport's Avatar
Depends on the length of the battery. Let me go measure a car and see how much distance there is.
-Derrick
Boost_creep likes this.
WWW.CORKSPORT.COM
 Old 10-23-2015, 01:52 PM   #5
blackms3_71's Avatar
Posts: 2,250   (View Stats)
I would just relocate the meth controller. I personally dont like the controller in the engine bay but thats me. I have mine mounted by the traction control button area on my gen 1 ImageUploadedByTapatalk1445629919.057440.jpg
 Old 10-23-2015, 01:41 PM   #6
alexwlwsn's Avatar
Posts: 47   (View Stats)
alexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant futurealexwlwsn has a brilliant future
That looks really great! Time to add another thing to my endless shopping list...
2008.5 CWP MazdaSpeed3
Purple Drank Tuned
ATP GT3076R @ 26 psi
369.5whp & 348wtq.. yawn
alexwlwsn is offline   Reply With Quote
 Old 10-23-2015, 01:44 PM   #7
Okay so i looked at this on your site but i have a question or two.
Is this just a new battery box or is this for say 51r battery and ecu inside the box which is just a clean look?
If its just a normal box with ecu still on the side of the intake then is this just smaller providing More clearance for the intake?
 Old 10-23-2015, 01:50 PM   #8
CorkSport's Avatar
The ECU is moved in this box to the front to allow more space. The ECU bolts to the front cover. Check out the picture above.
-Derrick
ms3gt08 likes this.
WWW.CORKSPORT.COM
 Old 10-23-2015, 01:47 PM   #9
Going to make a 2nd Gen version?
 Old 10-23-2015, 01:48 PM   #10
CorkSport's Avatar
There isn't much space at all in there with the battery power cable.
WWW.CORKSPORT.COM
Boost_creep (10-23-2015), Easter Bunny (12-03-2015)
 Old 10-23-2015, 01:49 PM   #11
Ok i didnt notice the video but after watching it i have answered my questions lol.
This is pretty kool tbh. I have a 3" intake and all i had to do was remove the lower ecu cover but this is great as i could have a 3.5 intake and still have the stock battery. This is important to me as my battery is only a year old and i can careless for a 51r battery
Barett@CorkSport likes this.
 Old 10-23-2015, 03:21 PM   #12
white09ms3's Avatar
Posts: 56   (View Stats)
white09ms3 is a name known to allwhite09ms3 is a name known to allwhite09ms3 is a name known to allwhite09ms3 is a name known to allwhite09ms3 is a name known to allwhite09ms3 is a name known to all
I have an htp 3.5"intake and I'm wondering if this would work with it with no rubbing whatsoever.
Sent from my SM-G920V using Tapatalk
white09ms3 is offline   Reply With Quote
 Old 10-23-2015, 03:23 PM   #13
CorkSport's Avatar
Send us your intake and we can check out the clearance.....
WWW.CORKSPORT.COM
 Old 10-23-2015, 04:19 PM   #14
white09ms3's Avatar
I wish I could. Don't have a second intake and I need my car as it's my daily
 Old 10-23-2015, 05:11 PM   #15
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Can I send you my 4" HTP intake to see if it fits with your PU battery box?
 Old 10-23-2015, 05:31 PM   #16
white09ms3's Avatar
That might be a good idea @jdmage_mx5; I'm not able to send mine
 Old 10-24-2015, 07:59 AM   #17
CorkSport's Avatar
Sure! Shoot me a PM.
Derrick
WWW.CORKSPORT.COM
 Old 10-23-2015, 03:22 PM   #18
EvoFire's Avatar
Posts: 389   (View Stats)
Would a 51R be too small and bang around in the box?
 Old 10-23-2015, 10:13 PM   #19
RazoE's Avatar
Posts: 181   (View Stats)
RazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond reputeRazoE has a reputation beyond repute
So the air scoop to the battery would go unused? Moar air to the IC, I guess...
-2008 Mazdaspeed3
Corksport Stage II SRI - boost tubes - Dual VTA BPV / CP-E TMIC / HKS 3" CBE / JBR shifter bushings - Reverse gate - Modified Raider air dam for TMIC / COBB cold air box - AP V3 / Autotech HPFP / Damond short shift plate / Optima yellow top / Mazdaspeed lowering springs and camber arms / Black Gen Pu wheels
RazoE is offline   Reply With Quote
 Old 12-02-2015, 11:40 PM   #20
white09ms3's Avatar
It actually fits with my HTP 3.5"intake. There's a small area where the intake might touch on the side of the tray due to engine movement, but nothing too crazy. A small piece of insulating tape down the side edge can also remedy any rubbing
The Following 3 Users Say Thank You to white09ms3 For This Useful Post:
mooseaidz (06-18-2016), Nliiitend1 (12-03-2015), squats (12-03-2015)
 Old 12-03-2015, 07:01 PM   #21
Jester2552's Avatar
Posts: 126   (View Stats)
Jester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the worldJester2552 is the leader of the world
I had to find out the hard way but this box does NOT work with the Duralast OEM sized battery. The brackets for the plastic handle on the battery makes it too long so you can't close the top.
Had to go with the next size down of battery.
2007 Black MS3
CorkSport Turbocharger, HTP 3" Intake, CorkSport Catless Downpipe, CorkSport Catless Testpipe, CorkSport Catback, Tial 38mm EWG, GrimmSpeed EBCS, Bosch 3 Bar MAP Sensor, Forge V1 BPV, Cobb AcessPort, CP-e Stage 2 RMM, JBR Rear Sway, Moog Endlinks, ETS TMIC, AT Internals, JBR IM/TB TIG, Bilstein B8s, Cobb Springs, Rays Gram Lights 57C6 18X8.5 ET45, 235/40 Ventus RS-3,
Tuned by Nishan
USAF 2W1 "Warheads on Foreheads"
Jester2552 is offline   Reply With Quote
 Old 12-03-2015, 07:42 PM   #22
white09ms3's Avatar
I was going to go with the HTP small battery tray, but what I liked about this one is that it completely hides the ecu.
Weren't you able to cut the brackets for the plastic handle?
Last edited by white09ms3; 12-03-2015 at 07:42 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-03-2015, 07:56 PM   #23
Jester2552's Avatar
Don't have a picture of it right now but they were pretty big. I guess you could have...I needed a new battery anyways so oh well
2007 Black MS3
Tuned by Nishan
battery relocation diy dooderek MazdaSpeed 6 - How-To's 19 10-07-2013 05:15 PM
My battery relocation Nitr0EngiE MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-18-2011 05:55 PM
Battery Relocation? madvillain MazdaSpeed 3 - Engine, Transmission & Driveline 43 03-01-2010 11:00 AM
Battery Relocation on 2nd Gen Slipstream 2010 MS3 - Car Audio & Electronics 42 10-09-2009 06:07 PM
Battery Relocation KayWhy MazdaSpeed 3/6 - Car Audio & Electronics 18 08-24-2009 09:59 AM
Page generated in 0.43468 seconds with 31 queries
