  • 1 Post By Djohns
 Old 09-26-2018, 04:43 PM   #1
eliwwjd's Avatar
Posts: 518   (View Stats)
Default CS Cams install valve clearance
Ok I’m getting ready to do corksport cams and I know that from engine to engine valve clearance (tappets) can vary but wanted to know from anybody here that has done these cams , what were the tappets range they use to adjust clearance. I know that when I do my install clearance is going to be different but just wanted to have an idea of around what measurements people here experienced in their install
Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS
 Old 09-26-2018, 09:19 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
depends on your current tappet number and measured valve clearance when the new cams go in.
when I tore down my motor to build it, my head had a wide range of tappet numbers. no two heads are alike.
the best thing you can do is follow the instructions.
pull 1 tappet at a time and enter the number into CS's spreadsheet. put tappet back in. repeat 15 more times.
put the new cams in, torque cam caps.
measure clearance at each tappet and enter that data into CS's spreadsheet.
the spreadsheet will spit out a list of what tappets you need to achieve the proper clearance.
remove cams. remove all tappets. whatever tappets you have in the list, go ahead and drop those in where the spreadsheet says they go.
whatever is left on the list is what you need to buy or get from a local. I had 3 heads to pull tappets from and it wasn't enough. I had to get a few from a local and had to purchase two new ones from the stealership to end up with all clearances in spec.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
CorkSport (09-27-2018)
 Old 09-27-2018, 07:12 AM   #3
eliwwjd's Avatar
Do you remember what were the number of the tappets you had to buy and where exactly did you buy them?
 Old 09-27-2018, 07:19 AM   #4
Fstrnyou's Avatar
I bought from the local Mazda stealership. The tappet numbers I needed are irrelevant to your build.
Other rides:
History:
Djohns (09-27-2018)
 Old 09-27-2018, 09:36 AM   #5
Djohns's Avatar
Posts: 3,944   (View Stats)
Random question, but why cams before a bigger turbo or built motor?
tegxsi likes this.
2010 black mica speed3
Soon:built motor
tegxsi (09-28-2018)
 Old 09-28-2018, 03:26 AM   #6
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Remember to measure the tappet when you pull it to make sure it hasn't worn down compared to the stamped number. If it's worn enuf you will end up ordering a new tappet that will be to big. I doubt you will have a issue unless you have a lot of miles.
Are you going to do a vvt job while you are in there?
MECP
2012 BM
Rfinkle tune in progress
 Old 09-28-2018, 05:13 AM   #7
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
If you want to be 100% sure just buy new buckets.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 09-28-2018, 10:49 AM   #8
Groans: 74
Make sure to do some before and after logs so we can see the increase. Im still kicking myself for not doing them when i built the motor. The prospect of swapping cams is about as enticing as a catheter.
MECP
2012 BM
 Old 09-28-2018, 11:52 AM   #9
Fstrnyou's Avatar
There are many people making good power on stock head and cams.
But I want cams too for my weak goals.
Other rides:
History:
 Old 09-28-2018, 01:13 PM   #10
Posts: 2,235   (View Stats)
From an old n/a point of view cams are the first mod after the basic intake/exaust....
I just wonder if you can increase lag of a large BT with more duration
 Old 06-24-2019, 12:39 PM   #11
mopakarim7600's Avatar
Posts: 2   (View Stats)
mopakarim7600 has a little shameless behaviour in the past
I just wonder if you can increase lag of a large BT with more duratmy ip birthday wishes tnebion
mopakarim7600 is offline   Reply With Quote
The Following User Says NO Thank You to mopakarim7600 For This Un-useful Post:
Fstrnyou (06-24-2019)
CS Cams install valve clearance eliwwjd 2010 MS3 - Engine, Transmission & Driveline 0 09-26-2018 04:42 PM
Valve Tappet Clearance Excel Spreadsheet silvapain MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-11-2018 01:32 PM
VALVE CLEARANCE ADJUSTMENT jaguar_mike CX-7 > Engine, Transmission & Driveline 1 02-08-2016 06:02 PM
Head Rebuild and Valve clearance issues tkephart MazdaSpeed 6 - Engine, Transmission & Driveline 14 10-05-2012 12:46 PM
Page generated in 0.33011 seconds with 26 queries
