| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() Join Date: May 2013 Location: Ponce, Puerto Rico
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS |
| Not Ranked : 0 score depends on your current tappet number and measured valve clearance when the new cams go in. when I tore down my motor to build it, my head had a wide range of tappet numbers. no two heads are alike. the best thing you can do is follow the instructions. pull 1 tappet at a time and enter the number into CS's spreadsheet. put tappet back in. repeat 15 more times. put the new cams in, torque cam caps. measure clearance at each tappet and enter that data into CS's spreadsheet. the spreadsheet will spit out a list of what tappets you need to achieve the proper clearance. remove cams. remove all tappets. whatever tappets you have in the list, go ahead and drop those in where the spreadsheet says they go. whatever is left on the list is what you need to buy or get from a local. I had 3 heads to pull tappets from and it wasn't enough. I had to get a few from a local and had to purchase two new ones from the stealership to end up with all clearances in spec.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | CorkSport (09-27-2018) |
__________________ Forge BPV V2//COBB AP V3// COBB DP //ETS TMIC//AUTOTECH HPFP//JBR SRI//JBR TIP//JBR COOLANT BYPASS KIT//JBR DISI HOSES//JBR BYPASS HOSE//JBR THROTTLE BODY THERMAL GASKETS//JBR SHIFTER BUSHINGS// //RACING BEAT CBE//DAMOND MOTORSPORTS OCC//COBB RMM//CS LED KIT//CS LED FOGS//CBI OSRAM HID BULBS//CONTI EXTREME CONTACT 235/40 R18//RACESENG SHIFT KNOB//FREEKTUNED ON 93 PUMP GAS | |
| Not Ranked : 0 score I bought from the local Mazda stealership. The tappet numbers I needed are irrelevant to your build.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | Djohns (09-27-2018) |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score Random question, but why cams before a bigger turbo or built motor?
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
| The Following User Says Thank You to Djohns For This Useful Post: | tegxsi (09-28-2018) |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Remember to measure the tappet when you pull it to make sure it hasn't worn down compared to the stamped number. If it's worn enuf you will end up ordering a new tappet that will be to big. I doubt you will have a issue unless you have a lot of miles. Are you going to do a vvt job while you are in there?
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
Groans: 111
| Not Ranked : 0 score If you want to be 100% sure just buy new buckets.
Groans: 74
| Not Ranked : 0 score Make sure to do some before and after logs so we can see the increase. Im still kicking myself for not doing them when i built the motor. The prospect of swapping cams is about as enticing as a catheter.
| Not Ranked : 0 score There are many people making good power on stock head and cams. But I want cams too for my weak goals.
| Not Ranked : 0 score From an old n/a point of view cams are the first mod after the basic intake/exaust.... I just wonder if you can increase lag of a large BT with more duration
![]() Join Date: Jun 2019
Rep Power: 0 ![]() Thanks: 0
| The Following User Says NO Thank You to mopakarim7600 For This Un-useful Post: | Fstrnyou (06-24-2019) |
| Display Modes | |
| CS Cams install valve clearance | eliwwjd | 2010 MS3 - Engine, Transmission & Driveline | 0 | 09-26-2018 04:42 PM |
| Valve Tappet Clearance Excel Spreadsheet | silvapain | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 05-11-2018 01:32 PM |
| VALVE CLEARANCE ADJUSTMENT | jaguar_mike | CX-7 > Engine, Transmission & Driveline | 1 | 02-08-2016 06:02 PM |
| Head Rebuild and Valve clearance issues | tkephart | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 10-05-2012 12:46 PM |
