| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
(Thread Starter) | Not Ranked : 0 score Let me preface this with, I have not figured out how to post pics, mid thread yet. So what should read/look like instructions, will be a wall of text and pictures below. Sorry. The prototype box itself is good looking. The finish is rough on at points because it is a a early version, as you'll see in pictures. There are also scratches on the exterior that I assume are from Dan trying to fit the box to Elisa Joy. It came with 4 5mm Allen bolts to attach the top, 4 bolts to attach attach the OEM 10mm nuts to secure the ECU, a slick looking battery tie down, and two nasty looking long bolts for the tie down, 1 with a wing nut, 1 with a 10mm bolt. Obviously I started by disconnecting the battery and removing it and the stock battery box. I removed the ECU cover, and disconnected it, labeling each connection because I figured things may get messy. Then I removed the ECU heat shield, and ECU bracket from the OEM battery box. Total of 6 screws, 4 P3, 2 P2. I disconnected the ground line near the strut tower so it could be fed through the box. Then I disconnected both hot lines into the battery connector. This is where my initial fail begins. For some reason I assumed the ECU was being relocated to the front face of the battery box. So I attached the ECU to the box in that location. This caused a few issues. The box itself is large. Taller and probably close to as long as the stock box. In order to get the box in place I had to route the fuse box positive cable through a hole, while angling the box into place. The bracket holding the wire harness clip was in the way and had to be removed in order to get the box into place. I also removed the white harness clip. Because I wrongfully mounted the ECU on the outside of the box at first, I needed more slack on the harness. I also unclipped a few tie downs for slack. That turned out to be unnecessary. I realized my fail, the ECU needed to be inside the box, so I turned it around. Fed the ECU connectors, and positive and ground cables through the large slot in the box. I tied up the wires left exposed by the lack of harness clip with tape, and clipped the wire looms back into place. Along the way I removed the SRI to have access to all of this. Then I tied up the hot leads to the battery connector, and bolted the ground into place. Hooked in the janky long bolts, and dropped in the battery, then tied it down with the nice crossbar. Then bolted the top on and was done. It is a clean, good looking battery box. But I have to say, I am not sure what benefit it may have. It doesn't seem to be noticeably smaller or lighter. The ECU relocation doesn't add much usable space in reality. And at this point it is a bigger hassle to put in and out than the stock box is. I like the design and hope that with testing this can be improved to make it both a useful and good looking product. My initial suggestions would be some sort of rubber lining around the opening to help protect wires in the harness and maybe making it slightly smaller and more snug around the battery in favor of space in the bay. All in all, it looks cool, but was a pain to put in. And may be a pain to remove regularly for other work. But I still like the idea and look of it. I expect the next iteration will be better.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP Last edited by WetzMS3; 09-22-2013 at 07:54 PM. |
| The Following 14 Users Say Thank You to WetzMS3 For This Useful Post: | breakfstincluded (09-22-2013), bstover17 (01-30-2014), Easter Bunny (01-05-2014), El_Diablo (09-22-2013), He Hate Me (09-22-2013), hnda etr (09-23-2013), Koke382 (03-10-2015), Mauro_Penguin (09-23-2013), naoandlater (09-23-2013), Nliiitend1 (09-22-2013), rfinkle2 (09-22-2013), silvapain (09-23-2013), speedaholic (03-04-2015), Tomas (09-22-2013) |
(Thread Starter) | Not Ranked : 0 score I've got additional detail pictures as well, if anyone is interested in more. Just a lot to upload at once.
![]() Join Date: Mar 2013 Location: Morgantown WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30,420
Groans: 40
| Not Ranked : 0 score Doesn't just moving the ecu to the front of the battery gain you enough space for a larger intake? It looks like it does in your pics. Seems like that's the problem that it's trying to solve.
__________________ 2010 CBM Mazdaspeed3 w/Tech Package 240 whp/282 ft-lb @ CP-e Mustang Dyno [8/3/13] 271 whp/314 ft-lb @ Moore Automotive DynoJet [10/19/13] Cobb AP // JBR Stage II PowerPath Intake // GFB Respons BOV // AutoTech Internals // Sure Race Pipe (Cullen Eats Penises) // CPe TMIC JBR 88a RMM // JBR 70a TMM // JBR EGR Block Off Plate // Damond OCC // NGK Iridium IX Spark Plugs // JBR Bypass Valve Hose // SU Boost Tubes JBR Spherical Heavy Shift Knob // CorkSport interior LEDs // JBR License Plate Frame Mod // G2 Black Caliper Paint // 35% tint On deck: VG Sharkfin Antenna ![]() |
It may be close, but I don't have a larger intake to test it with at this point. Based on the design, I don't think that was the intention, especially since they just came out with a small battery box for that application, but I could be wrong.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP | |
(Thread Starter) | Not Ranked : 0 score Honestly, I like the box a lot. It looks really clean,and the wiring seems logical. I am happy I have it so far. My only concern is removing it for work in other areas. I will test that more in the coming weeks. Hopefully I will be in contact with @CorkSport to update them on the use-ablitiy if the piece in the coming weeks.
| The Following User Says Thank You to WetzMS3 For This Useful Post: | jk_ms3 (09-22-2013) |
![]() Join Date: Jan 2013 Location: OC, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 633
| Not Ranked : 0 score Not trying to sound like a killjoy but the box doesn't seem to net space saved from the stock box. You can look at the pictures you took and look at the space between the brake fluid reservoir in the pictures of the stock box and the CS box and the distance is about identical, also between the strut tower as well. Only thing you are saving space from is the moving of the ECU into the box (which is cool) but what protects the ECU from lets say an acid spill? Perhaps a piece of metal between the two to help separate? Also, on a Gen 1 we have a hole in the stock battery box, not technically sure why, possibly for heat or "fumes? Any reason to do away with that? Very nice write-up by the way though. |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,451
| Not Ranked : 0 score It would be cool to see how it fits with the HTP 3" I hope it doesn't turn out to only allow room for their own upcoming 3" lol
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
![]() Join Date: Feb 2010 Location: Seattle, WA
Rep Power: 2233 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 142
| Not Ranked : 0 score ^^^ yeah, the only noticeable difference it the fact that the ECU has moved to the front of the box...
__________________ Zoom-Zoom-Coons on 05/10/16 ![]() 2011 Mazdaspeed3 Celestial Blue Mica BUILT BY CORKSPORT CP-e Catted Downpipe || CP-e HPFP || Corksport Turbo || Corksport 3-bar Map Sensor || Corksport EBCS|| Corksport SRI || Corksport TIP || Corksport CBE || Corksport Boost Cut Killer || Corksport FMIC || Corksport SSP || Corksport MM Inserts || Corksport Blue Shift Knob || Corksport Injector Seals || DM Full EGR Delete Kit || Corksport License Plate Relocation Kit || Snyapse Engineering Synchronic BOV || Cobb V3 Accessport (PD Tune in progress) |
| The Following User Says Thank You to Worbit For This Useful Post: | breakfstincluded (09-22-2013) |
| Not Ranked : 0 score breakfstincluded: You can fit a JBR 3" intake just fine with the stock setup (ECU included). Tight, but it fits. Not sure how the HTP 3" differs from a JBR though. |
| The Following User Says Thank You to He Hate Me For This Useful Post: | breakfstincluded (09-22-2013) |
| Not Ranked : 0 score Right, for 160... just taking off the ECU cover and drilling out the mount holes to move the stock box over sounds like a pretty good alternative for 3" intakes. And it doesn't fit genwon anyway. Do you still need an allen key to open the CS box?
Honestly, I am not sure what the purpose of the box is. It is not much if any smaller, and seems like it will be more involved to remove to gain access to other work, than the stock box is.
Groans: 136
| Not Ranked : 0 score The box was approximately 1/2" too long to work with my HTP 3.5" intake. Based on how close it was, I believe it would fit with a 3" intake. CorkSport told me that it fit in their Pu with a 3.5" intake. I have been told that the dimensions for the production version are slightly different, but I'll leave that for CorkSport to give you the details. Otherwise, the box will work perfectly well with a GenJuan as well as a Pu. The box shifts the battery further back towards the firewall as well as move the ECU to be inside with the battery. This is a nice alternative to the small 51R battery boxes for those who want/need the larger capacity and higher CCA's of a stock-size Group 35 battery. Yes, @WetzMS3; the scratches are from me. The CS box is not sealed on the top; if you look at the pics posted, you can see there is a gap all the way around between the box and the lid.
__________________ Last edited by silvapain; 09-23-2013 at 10:11 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | breakfstincluded (09-23-2013), Easter Bunny (01-05-2014), El_Diablo (09-23-2013), magicka (09-23-2013), Nliiitend1 (09-23-2013), WetzMS3 (09-23-2013) |
(Thread Starter) | Not Ranked : 0 score I figured that was from you manhandling it! Thanks again for the box.
| The Following User Says Thank You to WetzMS3 For This Useful Post: | silvapain (09-23-2013) |
And it doesn't "appear" to be any further back by comparing the location of the Fuse Box on the stock and CS box. Just pointing out my thoughts on this. Last edited by He Hate Me; 09-23-2013 at 10:38 AM. | |
![]() Join Date: Jun 2012 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,245
__________________ 2012 Liquid Silver Metallic MazdaSpeed3 with Tech Package. South Bend Clutch Stage 3 Endurance | TWM Full Replacement Shifter | Synapse Engineering BPV | Autotech Internals | Grimmspeed EBCS - 3port | NGK 1 Step Colder Plugs | CNT Catless DP and CBE w/resonator deleted | COBB AP - E35 Tune | HTP 3.5" Intake w/ AMSOIL Dry Filter and Pre-Filter | HTP Battery Tray w/ Energizer 51R | CP-E TMIC | CorkSport DISI Silicone Boost Tubes | Damond Motorsports/Saikou Michi Co. Stage2 OCC | Damond Motorsports Short Shift Plate | Sure Countershift | BOSCH 3 Bar MAP w/MattJackson86 PnP Harness | JBR Rear Sway Bar | JBR EGR Block Off Kit | JBR Manifold - TIG | JBR Throttle Body TIG & Coolant Bypass | JBR 88a RMM | JBR 88a TMM | JBR 80a PMM |JBR DISI Bypass Valve Hose | Ported and Polished Intake Manifold DIY | RX8 Wheels w/ Nitto Motivo 235/40/18 Tires | CP-E Towplate | DIY Custom 600g Shift Knob | Redline Tuning Hood QuickLIFT | 30% / 15% Tint | Craven Speed Stubby Antenna | Broadway 400mm Rear View Mirror | Debadged Mazdaspeed 3 Waiting to be installed: Devil's Own Stage 2 DVC-30 Meth Injection | Damond Motorsports Meth Throttle Body Plate On Order: Coming Soon: DIY Projects: FYCN - TEAM LBN BEERS - FYCN-TEAM MUMFORD - FYCN | |
(Thread Starter) | Not Ranked : 0 score I am not absolutely sure, but I think the box is longer, and shifted back towards the firewall slightly. I did not pay much attention to the clearance at the back, other than making sure the top would fit. However, it is definitely longer towards the front of the car, becasue I had to remove the wire harness clip and bracket that normally sit right in front of the box. I will try to measure both tonight and post dimensions.
| Not Ranked : 0 score Any chance you could get the measurements indicated in the picture below? That will tell me if it will fit with my HTP 3.5" intake.
(Thread Starter) | Not Ranked : 0 score Sure, when I get a chance to measure it, I'll note those dimensions for you.
| The Following User Says Thank You to WetzMS3 For This Useful Post: | SparkySparks (09-23-2013) |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
That is the final size of the box. There is more than enough space for a 4" intake but it all depends on the routing of the pipes. Last edited by CorkSport; 09-23-2013 at 01:32 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 5 Users Say Thank You to CorkSport For This Useful Post: | breakfstincluded (09-23-2013), El_Diablo (09-23-2013), magicka (09-23-2013), silvapain (09-23-2013), SparkySparks (09-23-2013) |
(Thread Starter) | Not Ranked : 0 score Brydon, do you know how this compares with the unit I have? Is that a hole up front for wiring, or venting? It isn't there on the version I have. I curious what revisions have been made.
The major difference between yours and the final product was a little length and the added hole. The hole for the main power wire was also enlarged slightly so you could send all of the wires from the relay box through the battery box if you really wanted to tuck all the wires away. Other than that the boxes are very similar. We also added laser cut tie down bracket. | |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | Easter Bunny (01-05-2014), El_Diablo (09-23-2013) |
(Thread Starter) | Not Ranked : 0 score Ah, ok. I am not sure what bracket that might be. The bracket for the wire harness that gave me issues was close to the corner. Just a thought, that probably wouldn't be an efficient drain, even in emergency, since the mounting holes are recessed. Fluid would likely go there first. I like the idea of a larger whole for the wire harness. Is there some sort additional trim piece around the hole to protect the wires? One thing I am concerned about is the wires rubbing on that opening. I imagine the opening on the finished version is cleaner than mine, but the rough fiberglass edges and vibration in there scare me a little.
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
| Not Ranked : 0 score 1st Gen Battery Box available when?
__________________ ![]() [SIGPIC][/SIGPIC] |
![]() | | #24 | ![]() |
| Not Ranked : 0 score Now to go home and measure, would still like the measurements from the points I indicated in my picture as they use easy to measure from landmarks in the car as a starting point. That will give us the location of the corner that will be closest to the intake and the limiting factor when it comes to how big of an intake you can have. Other wise I will have to remove my stock battery box and make a template based off your schematic to bolt in and see how close it is.
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can measure from the fixed points on the fuse box and firewall for you tonight. But the dimensions may be slightly different, since the design has changed some.
![]() | | #26 | ![]() |
| Not Ranked : 0 score Thank you, it should get me close enough. I guess if you could also measure your box and see if matches the new designs 225mm by 320mm. as long as there is enough room to get a finger between the intake and the box I should be good.
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alrighty. I've got more pictures and more information. First off, the top. The top does overhang and leave a tiny gap, however there is trim tape on the underside of the cover, preventing this from being for ventilation. But the back of the cover is open, as you'll see in pictures. I imagine this is mostly for ease of removal, but could also provide venting. Next up, dimensions and clearance. I measured and converted all of the dimensions CS provided, and added it to their provided drawing. I also took some pictures of clearances with a tape in pace, as well as noted them on the drawing. Let me know if I didn't get everything needed. EDIT: The pictures of clearance for an intake are pretty dark. I can take better ones with more light tomorrow. There is about 5 1/4" from the engine side of my CS Intake, to the edge of the box. About 3 3/4"-4" to the wire harness, but that only matters depending on the location and piping of the intake. The higher the piping, and there is more clearance.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP Last edited by WetzMS3; 09-23-2013 at 08:42 PM. Reason: More info |
| The Following 5 Users Say Thank You to WetzMS3 For This Useful Post: | breakfstincluded (09-23-2013), chomorro (09-24-2013), El_Diablo (09-25-2013), hnda etr (09-24-2013), SparkySparks (09-23-2013) |
![]() | | #28 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Thanks for the review the pictures are quite dark might be my shit monitor but all i mainly see is a yellow tape measure and a lot of black that doesn't show the inlet pipe position Also confuses me how there wouldn't be any room for a larger intake. Looking at mine with a stock battery box with a JBR 3 widepath it barely touches the ECU cover and the previous C/s intake didn't touch it at all, with the ECU gone there should be easy another inch or more for a 4 inch intake to fit. Unless the C/S battery box is way wider than the stocker? |
![]() | | #29 | ![]() |
I said there is space for a larger intake after measuring. There are also measurements of the box itself to compare with your stocker. It's similar in width, but the ECU is now inside the box, opening up space.
| The Following User Says Thank You to WetzMS3 For This Useful Post: | silvapain (09-25-2013) |
![]() | | #30 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score Any confirmed reports of fitment with jbr 3.5? tapafuck
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score Not that I am aware of. It's on my list of parts to buy in the next few months, so I'll know then, but not for a month or two. I'm fairly confident it will fit. I plan to just order the whale penis. So if it doesn't fit, I'll have to put the CS back in and order JBR's box. But like I said, I'm pretty sure it'll fit. I'm not sure if anyone has bought or installed the production version yet. That'd be your best bet for now. Or ask Corksport for some pictures of a larger intake installed with it.
| The Following User Says Thank You to WetzMS3 For This Useful Post: | lilred (10-14-2013) |
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Last night I got installed a new 3.5" HTP intake with the early version CS ECU Box I have. So I imagine that the more flexible silicone of the JBR 3.5" would fit with this box as well. It is very tight. I should mention that I also recently installed the new cs bpv. It is noticeably shorter than the Turbosmart I was running. Didn't take measurements of that, but as you can see the filter just about touches the BPV, so keep that in mind if you're still TMIC.
![]() | | #33 | ![]() |
![]() Join Date: Jun 2012 Location: Hickory NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
Groans: 106
| Not Ranked : 0 score wow that is still some tight space there, I know with the jbr battery relocate kit you have a lot more room, but you also run a 51r batter which allows for more room to.
__________________ go fast- atp gt2871r,3bar map sensor,3port ebcs,freektune 4" wp intake,,jbr trilogy mount, turbosmart bov,cpe tmic,cpe cbe, UR catless DP, UR catless TP, autotech internals cobb ap v2, aem meth controller and pump, custom meth tank,snow solenoid and aquamist nozzle suspension-c/s springs,c/s midbrace,jbr rsb, 235/40/18 nitto nt55 |
| The Following User Says Thank You to motherfnmonsta For This Useful Post: | WetzMS3 (01-05-2014) |
![]() | | #34 | ![]() |
![]() Join Date: Sep 2012 Location: West Hartford, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
Groaned at 6 Times in 4 Posts
I recall hearing some on one of the beta testers videos, and heard that goes away after a while. Just want to see if you have the same situation or if that was just a single case.
__________________ 2008.5 Metro Grey MS3 Performance:HTP 3.5" Intake | Autotech HPFP Internals | SU TMIC | EBay Catless DP | Stratified Tuned | JBR 88a Dogbone - Short shift plate | Eibach Pro-Kit | 18x8 MB Interline wheels | Conti DW's 235/40R18 | JBR Rear Sway Bar Other fun: Dashhawk | Single res delete | Corksport Interior LED light kit - Bypass valve hose | Vent pod boost gage | Custom Heated driver and passenger seats | Leather shift boot | |
![]() | | #35 | ![]() |
I believe the issues the testers were having were resolved in the redesign of the piston and change in lube.
![]() | | #36 | ![]() |
| Not Ranked : 0 score Ah good to hear. Thanks for the input.
![]() | | #37 | ![]() |
| Not Ranked : 0 score Thanks for the update, That is about how I thought it would fit with the 3.5" HTP based off the provided measurements. A bit close for me so it looks like 51R is in my future which sucks cause I like how clean this the engine compartment looks with this box.
![]() | | #38 | ![]() |
![]() Join Date: Apr 2013 Location: Seattle, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,526
Thanks for the update!
__________________ SOLD: 2009 Metro Gray Mica Mazdaspeed 3 - CorkSport Stage II SRI - CorkSport High Flow Downpipe -CorkSport TMIC - CorkSport Short Shift Plate - CorkSport Shifter Bushings - CorkSport Rear Motor Mount - CorkSport Passenger Side Motor Mount -Cobb Accessport - CorkSport HPFP Max Flow Fuel Pump Internals - CorkSport LED Kit 1992 Red Mazda Miata - Flyin Miata Swaybars, Hard Dog Hard Bar, Koni Yellow Shocks, Flying Miata Springs, Spec Stage 1 Clutch, E-Code headlights Next?: 2016 Mazda Mx5? 2017 Mazdaspeed 3? [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to SpencerC For This Useful Post: | WetzMS3 (03-03-2015) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score I know it's a year later, but just wanted to bump and say I have a customer who has used our CorkSport Battery Box with the 3.5" JBR Intake and confirmed it fits. THE MORE YOU KNOW!
![]() | | #40 | ![]() |
![]() Join Date: May 2013 Location: Bryn Mawr, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,449
| Not Ranked : 0 score Please clarify, Spencer. Is it the TRU JBR 3.5 or the 3.5 before the revision. Also, is it the silicone or aliminum. I onyl say this because I have the battery box and the TRU 3.5 aliminum JBR intake did not fit.
__________________ 2013 LSM Mazdaspeed3 - stocked out and traded 6/5/2017 2017 LGM Golf R - South Bend stage 3 daily clutch / IE intake / Wagner IC / AWE downpipe / Indvidia catback / EQT Tuned 2004 Yamaha R6 - Micron Ricer Pipe / PC 2005 Honda CBR 600 F4i - R.I.P. 10/29/13 |
| Install/Review: New CorkSport RSB | evil MS3 | 2010 MS3 - Suspension & Brakes | 55 | 07-13-2013 10:09 AM |
| Battery dies after FMIC install | LOLredranger | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 11 | 04-23-2013 09:00 PM |
| Battery supplier to Boeing, Honda and Mitsubishi cleared in airliner review | Haltech | Automotive News | 0 | 01-29-2013 01:20 PM |
| Skyactiv Prototype Review 370 torque? | breakfstincluded | Mazdaspeed3/6 General Discussion | 6 | 08-02-2011 10:53 PM |
| Toyota already building EV prototype with Tesla battery pack? | Haltech | Automotive News | 0 | 07-09-2010 08:50 AM |
