| CorkSport To say that CorkSport is passionate about Mazda Performance is understatement. It is the essence of what we do. Our mission to offer unparalleled customer service and support, an uncompromising commitment to the community, and deliver top quality performance parts is demonstrated with each product we develop to help fulfill your vehicles performance potential. At CorkSport we believe it doesn’t have to come in a fancy package or be the most expensive product on the market to be the best. |
![]() Join Date: Mar 2019 Location: cincinnati, oh
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I adjust mine from the top. You can get it done with two 10mm combo wrenches. If you don't mind me asking, why are you adjusting it?
(Thread Starter) | Not Ranked : 0 score Sure, my tuner said it's not building enough PSIs and I need to increase the preload on the wastegate. |
| Not Ranked : 0 score My preload is factory set and I can get 28psi. What boost are you aiming for? Lol.
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Define, "not enough PSIs". What boost pressure are you targeting? Are you sure that everything is buttoned up properly and that you don't have a leak somewhere in the system?
(Thread Starter) | Not Ranked : 0 score I'm getting 19.5 psi, looking for more than that. |
| Not Ranked : 0 score Hell, my boost creeps to almost that with 0% WGDC.
![]() Join Date: Jun 2013 Location: Jacksonville FL
Rep Power: 0 ![]() Thanks: 5
| Not Ranked : 0 score Bump, did you get this resolved? I’m also having issues, I’m at 80%WGDC and only able to hit 24.5 psi. Checked 2 times for boost leaks, none found. I feel kinda odd adjusting the preload to be honest. I have a CS EBCS set up in bleed mode and CSt4 |
(Thread Starter) | Not Ranked : 0 score No not really, I adjusted preload. You can get to it feom the top of engine. I did find a small boost leak that helped some. |
| Not Ranked : 0 score Change your setup to 3-port interrupt instead of 2-port bleed.
| MS6 AWD trans bearings / preload question | Boltz | MazdaSpeed 6 - Engine, Transmission & Driveline | 15 | 01-25-2014 04:25 AM |
| Adjusting preload IWG | shawn. | MazdaSpeed 3/6 - Big Turbo Builds | 7 | 08-05-2013 09:02 AM |
| Adjusting WG spring preload on turbo? | p057 | MazdaSpeed 3/6 - Turbo Induction | 10 | 10-30-2012 05:55 PM |
