 Old 11-10-2010, 04:41 PM   #1
Speedie6's Avatar
Posts: 1,838   (View Stats)
Default LED DRL kit
I see on the Corksport site a "LED DRL kit". It says that it is comperable to HID. I knew LED lighting is coming of age, but, I had no idea that there was any LED lighting comparable to HID. Really true?
I had seen kits for putting HIDs in the fogs, but, I thought the install was not that easy, and best done by removing the bumper. But Corksport says its an easy 30 minute install. Is it really this easy? I guess I should go take a look under the car myself, but, I just thought I'd ask.
At any rate, if it is that good and that easy, it sounds like a great product. I'll probably be buying, if it all checks out.
 Old 11-10-2010, 04:48 PM   #2
Color will be nice, but light output is not comparable.
 Old 11-10-2010, 05:00 PM   #3
Speedie6's Avatar
Well, what Corksport's site says is:
"The light output of the DRL light upgrade matches that of most HID light kits in the 6000k color range."
When they say "light output" they just meant color but not lumins? As I read it, it certainly sounded like they were saying it had comparable lumins.
 Old 11-11-2010, 11:38 AM   #4
CorkSport's Avatar
Posts: 3,416   (View Stats)
It is the color, not the light output which we are talking about in the product listing.
-Derrick
WWW.CORKSPORT.COM
 Old 11-11-2010, 12:36 PM   #5
Speedie6's Avatar
-Derrick
Thanks. I hope you will clarify this. It says "light output is comparable". If the lumins don't compare to HID, maybe you can compare the lumins to stock.
 Old 11-11-2010, 12:41 PM   #6
dizzydtrain's Avatar
Posts: 2,476   (View Stats)
Groans: 64
I have the kit it looks really nice if you are running an aftermarket HID kit of around 5-6k. It almost matches perfectly but that's what i bought them for...to match. I would not recommend these if you actually do want to light up the road with your fogs.
The install is really easy and does not require taking off the bumper. You can remove the 2 undertray sections of the car right below where the fog lights are. I believe it's only llike 3 screws on each side--took me around 15 minutes to do once the car is slightly jacked up (my car is lowered as well so I had to jack it up).
I don't think there is much different between the stock fogs and this led kit. So if you want looks, go for this.
dizzydtrain is offline   Reply With Quote
The Following 2 Users Say Thank You to dizzydtrain For This Useful Post:
CorkSport (11-11-2010), xcoldricex (02-18-2011)
 Old 11-11-2010, 02:57 PM   #7
CorkSport's Avatar
That is really what they are for. If you take the metal shroud out of the housing you can get more light output. It just sucks to do the work.
Maybe I will do a how to on it.
-Derrick
WWW.CORKSPORT.COM
 Old 11-11-2010, 07:17 PM   #8
Corvette Tuner's Avatar
Posts: 404   (View Stats)
Corvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the worldCorvette Tuner is the leader of the world
Kit looks really good with a 6000K HID kit. I could not be more happy with the look. On a side note how long before the front mount kit for the 2010 MS3 comes out?
Corvette Tuner is offline   Reply With Quote
 Old 11-12-2010, 09:00 AM   #9
CorkSport's Avatar
End of the month/beginning of next month.
The pipes are being bent and the installation instructions are being finished up.
-Derrick
WWW.CORKSPORT.COM
 Old 11-12-2010, 10:02 AM   #10
That is great news. Let me know when it is ready. I am ready to order.
 Old 11-11-2010, 07:47 PM   #11
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
nate has these for fogs and they look fucking great
his thread died with the great msf shutdown
 Old 11-11-2010, 08:23 PM   #12
overdrift's Avatar
Posts: 93   (View Stats)
overdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant futureoverdrift has a brilliant future
Groaned at 6 Times in 4 Posts
Unless they are running an SST90 LED (read: huge heatsink) you are not even going to get close to the output of incan. Tint can be closely matched, though. That is what they are mentioning.
overdrift is offline   Reply With Quote
 Old 02-18-2011, 01:40 PM   #13
neotide87's Avatar
Posts: 1,388   (View Stats)
neotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the worldneotide87 is the leader of the world
anyone have pics of this kit installed on a gen1 sport model? I see on their site they have a Mazda 2 with them but want a more exact pic if possible. Been looking around for pics of it and fortunately found this thread but need some pics please. Thanks!
Edit: would the black ms3 in this pic be that kit? Sorry for grabbin it from ms307nm's thread about his new FMIC.
2007 Mazdaspeed 3 Sport SSM
Corksport SRI / HPFP Internals / Front Arm Bar // Cp-e RMM 75d // JBR RSB / IM & TB Gaskets / Bypass Valve Hose // Cobb AP / Shifter Weight // SU Shifter Bushings // Sure TIP // Viper 5901
neotide87 is offline   Reply With Quote
 Old 02-22-2011, 04:24 PM   #14
CorkSport's Avatar
What kind of picture do you want? An interior shot?
-Derrick
WWW.CORKSPORT.COM
 Old 02-23-2011, 08:27 PM   #15
neotide87's Avatar
I thought these were the fogs right?
CORKSPORT LED DRL Kit
From the pic I posted is that what they would look like when turned on?
 Old 03-04-2011, 10:29 AM   #16
CorkSport's Avatar
I cant tell from that picture if they are the same.
I will see if I can get a picture from a local customer and post it up.
-Derrick
WWW.CORKSPORT.COM
 Old 03-04-2011, 08:25 PM   #17
Novej's Avatar
Posts: 354   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
Took this after I installed these on my gen 1 running with stock xenons till I get my HID's........I also have the LED interior light/license plate light upgrade...absolutely love all my LED's LOL...........and no these will not light up the road (that you can see driving at least), though you will notice a blue tint to your lights on the road....Think it will look much better with the HID kit....
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
The Following User Says Thank You to Novej For This Useful Post:
neotide87 (03-04-2011)
 Old 03-04-2011, 11:37 PM   #18
neotide87's Avatar
thanks for the pic. Yea it doesn't look like it lights up the road at all. Probably wont be getting HID's anytime soon so might have to pass up on this mod and put it at the end of my list.
 Old 03-17-2011, 10:21 PM   #19
JTMS3's Avatar
Posts: 2,306   (View Stats)
here is what they look like next to the 8k HIDs I have. They light up about 5ft of road and thats it, but no worries as the HIDs flood the road so Im good. Nice LEDs and color is a good match.
The Following User Says Thank You to JTMS3 For This Useful Post:
CorkSport (03-19-2011)
Page generated in 0.38595 seconds with 29 queries
