Like Tree13Likes
 Old 10-27-2015, 09:09 AM   #1
CorkSport's Avatar
Posts: 3,416   (View Stats)
Default Mazdaspeed 6 FMIC Kits
We have been working over the past few months to get a few more of the MS6 FMIC kits put together from components we had on the shelf from earlier batches. We are happy to say we have a very limited number of the kits completed and ready to go. This is really it on the end of the kits, we have used up all that we had left to build these.
Link to the MS6 FMIC Kit.
-Derrick
ItsNox likes this.
WWW.CORKSPORT.COM
dale_gribble (10-27-2015), davychronic (10-28-2015), littleloogy (10-27-2015)
 Old 10-27-2015, 09:19 AM   #2
ItsNox's Avatar
Posts: 3,076   (View Stats)
IM OFF TO THE STREET CORNER TO MAKE SOME DOLLARS.
Shit 900 of them.
CorkSport likes this.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
dagrimey1 (04-07-2016)
 Old 10-27-2015, 10:30 AM   #3
Shwaykid's Avatar
Posts: 646   (View Stats)
2010+ Mazdaspeed6s... must be a real niche market you guys are targeting
thanks, @CorkSport; now this post won't make sense
CorkSport and season_of_ages like this.
2008 Mazdaspeed3 GT
Jet Black Wax (06/24/2017)
Shwaykid is offline   Reply With Quote
The Following User Says Thank You to Shwaykid For This Useful Post:
CorkSport (10-27-2015)
 Old 10-27-2015, 10:38 AM   #4
@dale_gribble;
 Old 10-27-2015, 10:41 AM   #5
For shits-n-gigs, @Big Mike;
 Old 10-27-2015, 11:01 AM   #6
sfds
 Old 10-27-2015, 10:46 AM   #7
season_of_ages's Avatar
Posts: 290   (View Stats)
season_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond repute
Is that an air box bolted at the top?
season_of_ages is offline   Reply With Quote
 Old 10-27-2015, 10:48 AM   #8
looks like it, Ram Air Intake replaces the TMIC area with this kit.
 Old 10-27-2015, 11:07 AM   #9
How does the intercooler compare to say a TR6?
 Old 10-27-2015, 11:17 AM   #10
Brandon@corksport's Avatar
Posts: 170   (View Stats)
YEP
Cheers,
Brandon Johnson
CorkSport Mazda Performance
(360)260-2675 ext. 106
BrandonJ@corksport.com
 Old 10-27-2015, 11:29 AM   #11
CorkSport's Avatar
We have never done a apples to mangos comparison between them so I cannot say. We do use the same core type as our other FMIC kits.
Derrick
WWW.CORKSPORT.COM
WetzMS3 (10-27-2015)
 Old 10-27-2015, 12:40 PM   #12
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Didn't the ram air kits have issues with maf cal? Been a while but going front mount has been a consideration.
2007 MS6 GT:
HTP 3" Full Intake, CS TMIC, AutoTech Internals, APv3, Forge Version 2 BPV(Blue+1 Shim), CP-E Catted DP, Whiteline RSB, CP-E Rear Diff mount, CP-E RMM, CS transmission mount insert, JBR Stage 2 OCC, JBR Boost tubes and recirc hose, Bilsteins B6's all around, Techna-Fit SS clutch and brake lines with ATE fluid, FreekTuned!
Big Dog is offline   Reply With Quote
 Old 10-27-2015, 01:09 PM   #13
dale_gribble's Avatar
Posts: 4,720   (View Stats)
ROFL, after all my trials and tribulations to get where I am this comes out. In my defense, I did ping CS about any kits around a while back with no luck.
CS FMIC = 2.25" piping, 630 in^3 volume IC, minimal couplers, accepts Mazda flange BPV. 10/10 would run it if I didn't already dump what I did into this old CP-E kit. I'm not sure about the whole ram air thing, but I'm sure someone could get an SRI in if desired.
It would definitely be good to hack the crashbar and drill out holes to get some more air into that massive IC.
MINI H1 6.0 - CAR LED TAILS
Easter Bunny (10-27-2015), WetzMS3 (10-27-2015)
 Old 10-27-2015, 01:24 PM   #14
CorkSport's Avatar
2.5 inch hole saw FTW
Do something like this and weld in some 2.5 ID pipe.
Derrick
WWW.CORKSPORT.COM
Easter Bunny (10-27-2015), neganox (11-06-2015), WetzMS3 (10-27-2015)
 Old 10-27-2015, 01:40 PM   #15
Derrick
I see tape on the hood of that pu for what was likely the CF hood scoop measurements. I also see more tape on the hood on the drivers side.... Care to tease me a bit?
ItsNox (10-27-2015)
 Old 10-27-2015, 03:44 PM   #16
CorkSport's Avatar
Here you go
-Derrick
WetzMS3 likes this.
WWW.CORKSPORT.COM
BLKSTIG (10-29-2015), Code Monkey (10-27-2015), MS3Shadow (10-27-2015), WAMBUSHHHH! (10-28-2015), WetzMS3 (10-27-2015)
 Old 10-27-2015, 08:14 PM   #17
Big Dog's Avatar
Groans: 89
@dale_gribble; time to buy this and do a comparison to the ETS tmic and other fmic you have for us MS6 owners everywhere.
2007 MS6 GT:
 Old 10-28-2015, 09:40 AM   #18
Omega's Avatar
Posts: 441   (View Stats)
Are you guys willing to sell a batch like the older FMIC w/ SRI kits instead of FMIC with ram air?
2006 Super Clean BCM MS6
 Old 10-28-2015, 02:20 PM   #19
This will be a last run kind of deal, so they will be as they sit for now.
Cheers,
Brandon Johnson
 Old 10-29-2015, 11:59 AM   #20
CorkSport's Avatar
We have 4 kits total available, one is a scratch and dent kit which will have a discount on it.
-Derrick
WWW.CORKSPORT.COM
 Old 10-29-2015, 01:56 PM   #21
maddocx240's Avatar
Posts: 823   (View Stats)
Just an fyi you can run an sri with this for if you want. I had the ram air kit originally and went over to an htp 3" with no problem.
 Old 11-02-2015, 08:10 AM   #22
Omega's Avatar
@maddocx240; thanks for the info that gives me something to think about!
 Old 11-02-2015, 05:15 PM   #23
CorkSport's Avatar
3 kits available...
WWW.CORKSPORT.COM
 Old 11-15-2015, 12:12 PM   #24
jhise's Avatar
Posts: 25   (View Stats)
jhise is just really nicejhise is just really nicejhise is just really nicejhise is just really nicejhise is just really nice
I cant wait to get this on my car. Order placed last night. I am becoming a corksport junkie
jhise is offline   Reply With Quote
 Old 11-15-2015, 12:14 PM   #25
Soo about two reminding kits?
Sent from my Nexus 6P
 Old 11-17-2015, 12:44 PM   #26
CorkSport's Avatar
All gone.
Derrick
WWW.CORKSPORT.COM
 Old 11-17-2015, 03:24 PM   #27
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
All the kits are gone you say....maybe there is a market and you should make more MS6 FMIC (and other performance) kits...
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
The Following User Says Thank You to MazdaspeedKills For This Useful Post:
dale_gribble (11-17-2015)
 Old 11-23-2015, 02:57 PM   #28
djern's Avatar
Posts: 1,139   (View Stats)
Groans: 27
im over here like
http://youtu.be/1pTiWi6gsL0?t=2m26s
wish i could have gotten one tho
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
twitter.com/djern
instagram.com/djern
facebook.com/djern
 Old 11-23-2015, 03:42 PM   #29
Originally Posted by djern View Post
im over here like
HAHAHAHA That's how it works for me too..
Cheers,
Brandon Johnson
 Old 11-25-2015, 04:08 PM   #30
maddocx240's Avatar
That sold quick. Funny how fast they sold within two weeks and it was out for like two years and didn't move, lol.
Here is the cs kit with a 3inch intake. Just for those of you that were wondering.
http://
dale_gribble likes this.
The Following User Says Thank You to maddocx240 For This Useful Post:
Easter Bunny (12-01-2015)
 Old 11-25-2015, 04:10 PM   #31
Classic supply and demand. Supply dried up, demand went up.
maddocx240 (11-25-2015)
 Old 12-01-2015, 09:05 AM   #32
Omega's Avatar
I figured they'd move quickly, glad I snatched mine up when I did!
 Old 12-01-2015, 10:36 PM   #33
jhise's Avatar
Just received mine in the mail yesterday. Now I just have to get the time to install it. It is sexy though.
 Old 12-07-2015, 12:21 AM   #34
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
@CorkSport; Could you please link the install guide for this FMIC, I can't find it since it's off your site now. I'm interested in how the core is mounted.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 12-07-2015, 02:41 AM   #35
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
You can see how the core is mounted here:
http://support.corksport.com/instruc...130-10-WEB.pdf
CorkSport and Mazdazilla6 like this.
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
Mazdazilla6 (12-07-2015)
 Old 12-09-2015, 02:26 PM   #36
CorkSport's Avatar
The core is supported by a big weld on tab on the top with a h shaped bracket to the top of the crash bar.
Thanks @SpeedRebirth; for posting up the link.
-Derrick
WWW.CORKSPORT.COM
Mazdazilla6 (12-09-2015), SpeedRebirth (12-09-2015)
 Old 02-24-2016, 04:29 PM   #37
pwdunmore's Avatar
Posts: 368   (View Stats)
@CorkSport; I just bought a MS6 and finding a FMIC is an issue... looks like I need to go custom.
My car thread:
 Old 02-24-2016, 07:10 PM   #38
Most folks don't necessarily need an fmic. Why do you need one?
MS3Shadow (02-24-2016), robbspeed (02-24-2016), sporkbomb (02-25-2016)
 Old 02-26-2016, 11:58 AM   #39
pwdunmore's Avatar
My tuner wasn't sure if the CP-e TMIC could would push north of 400 WHP on my MS6, he recommended I look into FMIC options.
Think the BNR S4 pushed to it's max will see the upgraded TMIC as a restriction?
The engine is forged and fueling will be enough to max the S4 out.
Any suggestions would be appreciated because I know the TMIC is efficient so I don't need to be told about that, that's why I have an upgraded TMIC on my MS3.
If I even knew where to source a the CS core I can get piping made...
My car thread:
 Old 02-27-2016, 04:15 PM   #40
Groans: 33
@pwdunmore;
You should look into the HDI Mazda 6 MPS FMIC kit, i gained 20hp and much better cooling going from cpe tmic to this fmic. Its from australia and is available on ebay and since the AUD is much lower than USD it will be very affordable. 700aud ~500usd
Mazdaspeed6 -06
290 AWHP / K04
pwdunmore (02-28-2016)
GI: JBR FMIC Piping Kits JBR JAMES BARONE RACING 853 11-13-2015 03:05 PM
New JBR FMIC K04 Under Mounted Clocking Kits in Stock!! JBR JAMES BARONE RACING 0 04-16-2015 02:01 PM
ebay universal fmic kits contreras MazdaSpeed 3/6 - Turbo Induction 5 06-19-2012 08:26 PM
FMIC piping kits and cores... Meder MazdaSpeed 3/6 - Turbo Induction 15 02-17-2012 08:02 AM
Interest: PowerLab Kits/ProEFI (Turbo/FMIC/FMS) ResilientMike MazdaSpeed 3/6 - Turbo Induction 9 04-22-2008 05:05 AM
Page generated in 0.58807 seconds with 37 queries
