Like Tree14Likes
 Old 02-15-2013, 08:57 AM   #81
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I've installed both. The CPE mount is a beast compared to the sure unit.
Edit: I should say both work fine
-06 MS6
-Corn fed 07 MS3 - Sold
superskaterxes (02-18-2013)
 Old 02-15-2013, 09:17 AM   #82
dadderllama's Avatar
Posts: 123   (View Stats)
dadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond reputedadderllama has a reputation beyond repute
have you ever held the CPE mount and the SURE mount in your hands at the same time?
you would laugh at the SURE mount.
@superskaterxes; I know SURE's reputation as of late, but have any diff mounts failed? I know different alloys have different strengths and density. Beefiness isn't always better, e.g. You could have a heavy duty beefy girl that you would never destroy, or a normal sexy girl that again you could never destroy.... Or an easier comparison.... Have you ever felt a carbon fiber hood? Relatively flimsy compared to a metal hood, however strength would not even be a comparison. I'm not saying this is the case, however I would like a better explanation based off of your experiences.
CS LED kit, Aux input, Sure TIP, Sure SRI v2, Sure RMM, Turbosmart BPV, IVT22's, Prosport Boost gauge, JBarone SSP v2 and counterweight, H&R Drop Springs, Bilstein Shocks, Cobb AP, Sure M6, Sure Juggernaught, Sure Dreadnaught, Whiteline RSB, DSS axle, AT internals, Sure Charge Tubes. Currently getting DIZZY tuned!
dadderllama is offline   Reply With Quote
The Following 2 Users Say Thank You to dadderllama For This Useful Post:
phate (02-15-2013), xI Leveler Ix (02-16-2013)
 Old 02-15-2013, 09:20 AM   #83
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
To be fair, I don't think this is the place for this discussion.
Jh8909 likes this.
The Following 8 Users Say Thank You to Dizzy Turbo For This Useful Post:
Jh8909 (02-15-2013), Juyoung (02-19-2013), KusteLokal (02-16-2013), phate (02-15-2013), PhillyCheese (02-16-2013), Speed_j23 (02-15-2013), superskaterxes (02-15-2013), Vansquish (02-20-2013)
 Old 02-15-2013, 09:43 AM   #84
i agree this isent the place for discussion, but theres a reason why theres a V2 from them. Someone BENT the v1 and they released an updated version aka V2.
jracer (02-15-2013), Juyoung (02-19-2013)
 Old 02-16-2013, 01:41 PM   #85
PhillyCheese's Avatar
Posts: 226   (View Stats)
How about a skid tray also? My plastic pieces were gone when I bought my ms6. I see no point in plastic garbage if you make one
 Old 02-16-2013, 01:46 PM   #86
I'm in the same position as ^^ guy
 Old 02-18-2013, 11:01 AM   #87
crazyspeed6's Avatar
Posts: 74   (View Stats)
crazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud ofcrazyspeed6 has much to be proud of
@CorkSport; Could you please post a picture of where you mounted your catch can. Thank you in advance.
2006 Speed 6 - GTX3071, Cobb AP, CPE HPFP, CPE DP, HTP 3" Turbo Inlet, HTP 3" MAF Housing, CX FMIC, Greddy BOV, 3 Port EBC, JBR IM TIG, 3 Bar MAP, Corksport OCC, Stratified Tuned by Lex
STOCKING OUT
crazyspeed6 is offline   Reply With Quote
 Old 02-18-2013, 02:28 PM   #88
robertof's Avatar
Posts: 405   (View Stats)
robertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the world
Corksport MS6 aluminum skidplate
This came up a while back
robertof is offline   Reply With Quote
 Old 02-19-2013, 04:53 PM   #89
Wow. That was a while back. Guess I'll send a request. I don't want to buy the oem platic junk. It's wierd they have one for the protege but not the ms6. I mean I still have my 01 MP3 but I'm surprised they had enough intrest to produce it. This New Enland weather is hell on the engine bay. Salt everywhere
 Old 02-19-2013, 11:19 PM   #90
CorkSport's Avatar
Posts: 3,416   (View Stats)
This is a project which isnt dead....
WWW.CORKSPORT.COM
The Following 7 Users Say Thank You to CorkSport For This Useful Post:
06Speed6 (02-19-2013), Colin1337 (06-07-2013), DiGi Faggot (03-02-2013), Dizzy Turbo (02-20-2013), Jh8909 (02-20-2013), PhillyCheese (02-20-2013), robertof (02-20-2013)
 Old 02-19-2013, 11:59 PM   #91
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Thank god
2006 Mazdaspeed 6
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
 Old 02-20-2013, 04:44 AM   #92
Product request sent
 Old 02-20-2013, 11:47 AM   #93
CorkSport's Avatar
We have one on our MS6 right now. The placement of the oil drain is easy but the filter drain is a bit tough. It is right where a structural bend needs to be. I might end up making a cover that is structural. Like a folded sump that doubles as an access panel.
06Speed6 (02-20-2013), fivefingerdeathpunch (06-10-2013), PhillyCheese (02-20-2013)
 Old 02-20-2013, 01:41 PM   #94
Speeeeeed
06Speed6's Avatar
Sounds like alot more thought is going into this as compared to the turbine tech one which is great because its just a water jetted sheet of alum that got stuffed into a bender to make it halfway fit. I honestly gave up on this ever happening, def put me down for one.
2006 Mazdaspeed 6
 Old 02-20-2013, 01:44 PM   #95
robertof's Avatar
Put me down for one as well, like @PhillyCheese; said winter is hell on these engine bay on the north east coast
The Following 2 Users Say Thank You to robertof For This Useful Post:
 Old 02-20-2013, 01:50 PM   #96
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
Sent in my product request for diff mounts
 Old 02-20-2013, 02:00 PM   #97
Would the drain hole match up for those of us with spin on conversions?
 Old 02-20-2013, 02:05 PM   #98
CorkSport's Avatar
Version1. Before the cutouts. The front adds structure and access to the filter. The final product will be slightly different.
Yes.
Code Monkey likes this.
Last edited by CorkSport; 02-20-2013 at 02:05 PM. Reason: MSF Database - Automerged Doublepost
The Following 9 Users Say Thank You to CorkSport For This Useful Post:
06Speed6 (02-20-2013), CorkSport (02-20-2013), Etipp98 (02-20-2013), Funkster777 (02-20-2013), gigs2000 (02-20-2013), LaraS (06-11-2013), PhillyCheese (02-20-2013), robertof (02-20-2013), xI Leveler Ix (02-24-2013)
 Old 02-24-2013, 03:25 PM   #99
Ru5tyNut5's Avatar
Posts: 24   (View Stats)
Ru5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond reputeRu5tyNut5 has a reputation beyond repute
I don't have a pic, but it's right in front of the drivers side front tire, just inside the inner fender. Next time I drain it I'll try to remember to get a pic.
'07 MazdaSpeed 6 GT
CorkSport SRI//CorkSport TIP//BNR Stage 3 turbo//Cobb EBCS//CorkSport FMIC//CorkSport Catted Downpipe//CorkSport OCC//CorkSport Short Shifter//CorkSport Front and Rear Sway Bars//CorkSport Lowering Springs//CorkSport skid tray//RX8 Wheels//CorkSport RMM//CorkSport Tranny Mount Insert//Cobb AP//CorkSport HPFP//CorkSport LED light kit
Ru5tyNut5 is offline   Reply With Quote
The Following User Says Thank You to Ru5tyNut5 For This Useful Post:
crazyspeed6 (02-24-2013)
 Old 02-25-2013, 07:58 PM   #100
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Update on diff mounts???
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 02-25-2013, 08:26 PM   #101
IamJamen's Avatar
Posts: 789   (View Stats)
I mounted mine on the drivers side frame rail:
The Following User Says Thank You to IamJamen For This Useful Post:
crazyspeed6 (02-26-2013)
 Old 02-26-2013, 02:31 PM   #102
CorkSport's Avatar
It is still being tested. It will work with everything we sell and most other company's swaybars. I would say all others but I haven't tested everything.
Mazdazilla6 (02-26-2013), Speed_j23 (02-26-2013)
 Old 02-26-2013, 07:39 PM   #103
Thanks for posting that @IamJamen; That definitely gives me a starting point for my install this weekend. Did you have to drill any extra holes? Not around my car right now....
STOCKING OUT
 Old 02-26-2013, 08:12 PM   #104
IamJamen's Avatar
I put a 90 in the t-bar mount supplied with the kit and shortened the end closer to the headlight. I drilled two new holes in the frame rail and mounted the t-bar with two self-taping screws. I had to move the small radiator part to the top of the rail and bend the A/C line bracket a little to make room for the can but it fits just fine. I've taken it out twice to drain it in the frigid winter temps.
 Old 02-26-2013, 08:18 PM   #105
Thanks for the heads up, I would like to try and mount mine similar to the way yours is. Thanks again
STOCKING OUT
 Old 06-07-2013, 12:18 AM   #106
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
Anything new on the ms6? Where are the updates! @CorkSport; @Brydon@CorkSport;
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
 Old 06-09-2013, 10:12 AM   #107
Twinturbo6's Avatar
Posts: 125   (View Stats)
Twinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond reputeTwinturbo6 has a reputation beyond repute
Groaned at 29 Times in 10 Posts
Evey product should come with a full page glossy Picture of KIM, signed even... just saying.
Twinturbo6 is offline   Reply With Quote
The Following User Says Thank You to Twinturbo6 For This Useful Post:
IanMacKenzie (06-10-2013)
 Old 06-09-2013, 07:05 PM   #108
ESA
ESA's Avatar
Posts: 120   (View Stats)
ESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond reputeESA has a reputation beyond repute
Do you guys plan to make It Big turbo??
[B]06 Speed6
Prosport Boost,Oil Tem.,Oil Press Gauge/Corksport DP/Corksport Catless RP/ITV22/Autotech Internals/Cobb AP/Corksport SRI (Stage 2)/JBR RMM/TWM stage2/CPE Safe Seal.
GT3071 EWG Kit on stand by.... Waiting for more funds for suporting mod...
ESA is offline   Reply With Quote
The Following User Says Thank You to ESA For This Useful Post:
AustinK (06-10-2013)
 Old 06-10-2013, 02:49 PM   #109
CorkSport's Avatar
Nothing to report at the moment.
-Derrick
WWW.CORKSPORT.COM
 Old 06-10-2013, 02:58 PM   #110
dubunderpar's Avatar
Posts: 841   (View Stats)
dubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the worlddubunderpar is the leader of the world
Where are the camber arms....
dubunderpar is offline   Reply With Quote
 Old 06-10-2013, 03:53 PM   #111
CorkSport's Avatar
Send me a PM if you are interested in arms for the Mazdaspeed6.
 Old 06-10-2013, 07:34 PM   #112
racingrayson's Avatar
Posts: 190   (View Stats)
racingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the world
I really hope you already offer camber arms for the ms6 since you sold me a set months ago.
racingrayson is offline   Reply With Quote
 Old 06-11-2013, 06:44 AM   #113
I've been blowing up cs for the past month waiting on their release, so not sure where you got them.
sent from the tapagods
 Old 06-13-2013, 01:02 PM   #114
Derrick sold me a set over emails in October. Haven't installed them yet because I'm waiting to see what brakes I'm going with before I track the car again.
 Old 06-13-2013, 01:46 PM   #115
 Old 06-13-2013, 05:23 PM   #116
I will hopefully have a set soon... @CorkSport;
 Old 06-13-2013, 07:24 PM   #117
gigs2000's Avatar
Posts: 198   (View Stats)
gigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the worldgigs2000 is the leader of the world
Groans: 357
Groaned at 73 Times in 45 Posts
Pm sent sir!
gigs2000 is offline   Reply With Quote
 Old 06-14-2013, 03:12 PM   #118
So what are these camber arms I have? Are they actually for the 6?
 Old 06-14-2013, 04:41 PM   #119
CorkSport's Avatar
Likely they are Mazda3. The big difference is the width at the ends. You can make the mazda3 work on the 6 but we made larger machined ends to take the gap up with. Function is identical though. I know a few people have run the camber arms on Mazda6 successfully. If the camber arm fit great then there is no issue. If not, send me a PM and I will get it squared away.
 Old 06-14-2013, 06:02 PM   #120
Looking back at the messages, Derrick did tell me they were the same arms. My mistake.
mazdaspeed6 MBC boosted_speed6 MazdaSpeed 3/6 - Turbo Induction 6 03-24-2011 06:07 PM
BBK for Mazdaspeed6 Magier MazdaSpeed 3/6 - Suspension & Brakes 7 03-01-2011 12:54 AM
Page generated in 0.58791 seconds with 39 queries
