![]() | | #41 | ![]() |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
Please re-take some datalogs and include the following logging parameters (some things were missing in your log, and other unnecessary parameters were present). Note that a proper WOT datalog should be taken on a flat, smooth, straight road and it should begin just under 3000rpm and run to at least 6000rpm in a single gear (preferably 3rd or 4th). Accelerator Pedal Position Actual AFR Boost (psi) Boost Air Temp Calculated Load Coolant Temp HPFP Actual Pressure Inj. Duty Cycle Intake Temp Intake Valve Adv. Knock Retard Long Term Fuel Trims (LTFT) MAF Voltage MAF Airflow RPM Short Term Fuel Trim (STFT) Spark Advance Throttle Position (not throttle duty cycle) Vehicle Speed Wastegate Duty
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | joefromkocomo (01-18-2020) |
![]() | | #42 | ![]() |
![]() Join Date: Mar 2019
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 15
tegxsi: I don't think what I was doing there would be considered true WOT. I wasn't on a stretch of road where I felt good really laying into it for a true WOT pull. More like I saw something I didn't like and wanted to take a quick log to see if it did it again and was something I needed to look further into. Of course this is all speculation, I'll just get a proper datalog and post again with real data instead of speculative bullshit.
__________________ '07 Mazdaspeed3 Mostly Stock... for now. | |
![]() | | #43 | ![]() |
![]() Join Date: Jun 2009
| Not Ranked : 0 score
One cell of 17 psi is not harmful and might be pure anomaly, since it never recurred. OP might want to consider VersaTune as an option. Their stock maps are held in high regard. He can still use his AP for datalogging.
| The Following User Says Thank You to MSMS3 For This Useful Post: | joefromkocomo (01-18-2020) |
![]() | | #44 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright, 2 logs. First one in 3rd, second one in 4th. Had to cut it off a little before 6k on the 4th log, didn't want to be hooning it up somebodies butt and I was little closer to them than I felt comfortable with.
![]() | | #45 | ![]() |
![]() Join Date: Oct 2011 Location: San Leandro, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 460
Groans: 87
4th gear has a bit of knock... probably what a stage0 map would do when it encounters more load. Stage 0 ignition timing is aggressive and may cause knock under more load.
__________________ 2018 Audi RS3 2013 CWP Mazdaspeed3 - CS Turbo 2007 Acura TSX 6MT | |
| The Following 2 Users Say Thank You to tegxsi For This Useful Post: | joefromkocomo (01-18-2020), MSMS3 (01-20-2020) |
![]() | | #46 | ![]() |
Conversely, if the KR starts low and continues to grow up into the 5+ range as I continue to stay at WOT, THIS is that knock that I really need to be afraid of and attempt to diagnose ASAP. And then is there is also something called Partial Throttle Knock that seems to be reserved strictly for GenJuans? (this one has me scratching my head... not gonna lie) Obviously no KR is best case. Before I start bolting more stuff on I'd like to have an understanding of what I should be looking for in terms of red flags. The relationships (inverse/linear ratios and such) between certain values, and what is normal so that I can on a very basic level troubleshoot and tell when I might need to have someone professional look at it.
![]() | | #47 | ![]() |
Groans: 87
I think you are safe to run Stage1 and post logs. I think you posted a log before but I don't think you were logging correctly.
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score @Vansquish @MSMS3 anything to add?
| The Following User Says Thank You to joefromkocomo For This Useful Post: | MSMS3 (01-21-2020) |
![]() | | #49 | ![]() |
| Not Ranked : 0 score The logs looks fine from a safety standpoint. Leaving a lot on the table. Only reaching a load of 1.5 - 1.6, but that may be all that the stock OEM tune calls for. I think you are ready to begin modding. Start with fuel pump internals. Do not try to run a big downpipe/racepipe without pump internals and an appropriate tune. Cobb OTS maps are just to “get you to a tuner” as they are not very good. Bring a reputable e-tuner into your modding early, not later.
![]() | | #50 | ![]() |
Just got the catch can on the car yesterday. I'll have the fuel pump internals the latter half of next month. I do actually already have a downpipe, but it's not on the car and it won't be until the fuel pump internals go on. Planning on reaching out to E-tuners this week or next week to get a feel for who I want to work with. Funny story about the downpipe... picked up a barely used ATP 3" Catless for $150 yesterday. Get to his place to pick it up and it's still attached to the CBE and the turbo; the rest of the car was completely gutted other than the interior. Very clearly didn't have the tools needed on hand to get everything separated (he was using a 6" ratchet trying to undo exhaust bolts). Spends 30 minutes under the car getting the last bolt holding the downpipe and the catback undone. Starts trying to break the bolts holding the turbo and DP loose... 10 minutes go by, not even close to budging. Ended up offering me a rebuilt K04 still attached to the DP for free. Got rebuilt turbo + DP for $150, and apparently both only have like 4-5k miles on them. So I guess I have a backup turbo if needed, just have to run by my buddy's house and borrow his impact driver for a few minutes to get them separated. Purchasing the DP first was definitely out of order, but the deal was too good to pass up and ended up getting a whole lot sweeter when he didn't even ask for anything extra for the turbo.
![]() | | #51 | ![]() |
| Not Ranked : 0 score funny story. Exhaust bolts usually need impact/ + heat to get loose...or large bar to break them apart....Take a look at adaptor size as you may need all the pieces to fit it on a smaller stock cat back... For the turbo, check for wheel play to be sure and at worst, it could serve as a book holder if it is bad and the price is still good...
![]() | | #52 | ![]() |
| Display Modes | |
| Need help with spike | Zak | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 02-09-2011 07:59 PM |
| WTF is this spike? | Jarods7920 | Cobb ATR Support | 1 | 12-14-2010 05:19 PM |
| Spike of KR only happens sometimes at WOT | Lex | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 07-08-2009 09:37 AM |
| Strage KR Spike | badams118 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 01-31-2009 05:38 PM |
